查看: 32446|回復: 21
stm32HAL庫IIC 的0.96OLED屏幕驅動,可直接用不需要改
下午參考著網上的一些程序,寫了一個,拿去只需在Cubemx把PB6,PB7設置為IIC就行了,其余的不需要改直接用
  1. #include "oled.h"
  2. #include "ascii.h"
  3. #include "main.h"
  4. #include "stm32f1xx_hal.h"
  5. void WriteCmd(unsigned char I2C_Command)//寫命令
  6. {
  7.                 HAL_I2C_Mem_Write(&hi2c1,OLED0561_ADD,COM,I2C_MEMADD_SIZE_8BIT,&I2C_Command,1,100);
  8.
  9. }
  10.
  11. void WriteDat(unsigned char I2C_Data)//寫數據
  12. {
  13.                 HAL_I2C_Mem_Write(&hi2c1,OLED0561_ADD,DAT,I2C_MEMADD_SIZE_8BIT,&I2C_Data,1,100);
  14.
  15.   }
  16.         void OLED_Init(void)
  17. {
  18.         HAL_Delay(100); //這里的延時很重要
  19.
  20.         WriteCmd(0xAE); //display off
  21.         WriteCmd(0x20);        //Set Memory Addressing Mode
  22.         WriteCmd(0x10);        //00,Horizontal Addressing Mode;01,Vertical Addressing Mode;10,Page Addressing Mode (RESET);11,Invalid
  23.         WriteCmd(0xb0);        //Set Page Start Address for Page Addressing Mode,0-7
  24.         WriteCmd(0xc8);        //Set COM Output Scan Direction
  25.         WriteCmd(0x00); //---set low column address
  26.         WriteCmd(0x10); //---set high column address
  27.         WriteCmd(0x40); //--set start line address
  28.         WriteCmd(0x81); //--set contrast control register
  29.         WriteCmd(0xff); //亮度調節 0x00~0xff
  30.         WriteCmd(0xa1); //--set segment re-map 0 to 127
  31.         WriteCmd(0xa6); //--set normal display
  32.         WriteCmd(0xa8); //--set multiplex ratio(1 to 64)
  33.         WriteCmd(0x3F); //
  34.         WriteCmd(0xa4); //0xa4,Output follows RAM content;0xa5,Output ignores RAM content
  35.         WriteCmd(0xd3); //-set display offset
  36.         WriteCmd(0x00); //-not offset
  37.         WriteCmd(0xd5); //--set display clock divide ratio/oscillator frequency
  38.         WriteCmd(0xf0); //--set divide ratio
  39.         WriteCmd(0xd9); //--set pre-charge period
  40.         WriteCmd(0x22); //
  41.         WriteCmd(0xda); //--set com pins hardware configuration
  42.         WriteCmd(0x12);
  43.         WriteCmd(0xdb); //--set vcomh
  44.         WriteCmd(0x20); //0x20,0.77xVcc
  45.         WriteCmd(0x8d); //--set DC-DC enable
  46.         WriteCmd(0x14); //
  47.         WriteCmd(0xaf); //--turn on oled panel
  48. }
  49. void OLED_SetPos(unsigned char x, unsigned char y) //設置起始點坐標
  50. {
  51.         WriteCmd(0xb0+y);
  52.         WriteCmd(((x&0xf0)>>4)|0x10);
  53.         WriteCmd((x&0x0f)|0x01);
  54. }
  55. void OLED_Fill(unsigned char fill_Data)//全屏填充
  56. {
  57.         unsigned char m,n;
  58.         for(m=0;m<8;m++)
  59.         {
  60.                 WriteCmd(0xb0+m);                //page0-page1
  61.                 WriteCmd(0x00);                //low column start address
  62.                 WriteCmd(0x10);                //high column start address
  63.                 for(n=0;n<128;n++)
  64.                         {
  65.                                 WriteDat(fill_Data);
  66.                         }
  67.         }
  68. }
  69. void OLED_CLS(void)//清屏
  70. {
  71.         OLED_Fill(0x00);
  72. }
  73. void OLED_ON(void)
  74. {
  75.         WriteCmd(0X8D);  //設置電荷泵
  76.         WriteCmd(0X14);  //開啟電荷泵
  77.         WriteCmd(0XAF);  //OLED喚醒
  78. }
  79. void OLED_OFF(void)
  80. {
  81.         WriteCmd(0X8D);  //設置電荷泵
  82.         WriteCmd(0X10);  //關閉電荷泵
  83.         WriteCmd(0XAE);  //OLED休眠
  84. }
  85. // Parameters     : x,y -- 起始點坐標(x:0~127, y:0~7); ch[] -- 要顯示的字符串; TextSize -- 字符大小(1:6*8 ; 2:8*16)
  86. // Description    : 顯示codetab.h中的ASCII字符,有6*8和8*16可選擇
  87. void OLED_ShowStr(unsigned char x, unsigned char y, unsigned char ch[], unsigned char TextSize)
  88. {
  89.         unsigned char c = 0,i = 0,j = 0;
  90.         switch(TextSize)
  91.         {
  92.                 case 1:
  93.                 {
  94.                         while(ch[j] != '\0')
  95.                         {
  96.                                 c = ch[j] - 32;
  97.                                 if(x > 126)
  98.                                 {
  99.                                         x = 0;
  100.                                         y++;
  101.                                 }
  102.                                 OLED_SetPos(x,y);
  103.                                 for(i=0;i<6;i++)
  104.                                         WriteDat(F6x8[c][i]);
  105.                                 x += 6;
  106.                                 j++;
  107.                         }
  108.                 }break;
  109.                 case 2:
  110.                 {
  111.                         while(ch[j] != '\0')
  112.                         {
  113.                                 c = ch[j] - 32;
  114.                                 if(x > 120)
  115.                                 {
  116.                                         x = 0;
  117.                                         y++;
  118.                                 }
  119.                                 OLED_SetPos(x,y);
  120.                                 for(i=0;i<8;i++)
  121.                                         WriteDat(F8X16[c*16+i]);
  122.                                 OLED_SetPos(x,y+1);
  123.                                 for(i=0;i<8;i++)
  124.                                         WriteDat(F8X16[c*16+i+8]);
  125.                                 x += 8;
  126.                                 j++;
  127.                         }
  128.                 }break;
  129.         }
  130. }
  131. // Parameters     : x,y -- 起始點坐標(x:0~127, y:0~7); N:漢字在.h中的索引
  132. // Description    : 顯示ASCII_8x16.h中的漢字,16*16點陣
  133. void OLED_ShowCN(unsigned char x, unsigned char y, unsigned char N)
  134. {
  135.         unsigned char wm=0;
  136.         unsigned int  adder=32*N;
  137.         OLED_SetPos(x , y);
  138.         for(wm = 0;wm < 16;wm++)
  139.         {
  140.                 WriteDat(F16x16[adder]);
  141.                 adder += 1;
  142.         }
  143.         OLED_SetPos(x,y + 1);
  144.         for(wm = 0;wm < 16;wm++)
  145.         {
  146.                 WriteDat(F16x16[adder]);
  147.                 adder += 1;
  148.         }
  149. }
  150. // Parameters     : x0,y0 -- 起始點坐標(x0:0~127, y0:0~7); x1,y1 -- 起點對角線(結束點)的坐標(x1:1~128,y1:1~8)
  151. // Description    : 顯示BMP位圖
  152. void OLED_DrawBMP(unsigned char x0,unsigned char y0,unsigned char x1,unsigned char y1,unsigned char BMP[])
  153. {
  154.         unsigned int j=0;
  155.         unsigned char x,y;
  156.   if(y1%8==0)
  157.                 y = y1/8;
  158.   else
  159.                 y = y1/8 + 1;
  160.         for(y=y0;y<y1;y++)
  161.         {
  162.                 OLED_SetPos(x0,y);
  163.     for(x=x0;x<x1;x++)
  164.                 {
  165.                         WriteDat(BMP[j++]);
  166.                 }
  167.         }
  168. }
  169. void OLED_ShowChar(u8 x,u8 y,u8 chr,u8 Char_Size)
  170. {
  171.         unsigned char c=0,i=0;
  172.                 c=chr-' ';//得到偏移后的值
  173.                 if(x>128-1){x=0;y=y+2;}
  174.                 if(Char_Size ==16)
  175.                         {
  176.                         OLED_SetPos(x,y);
  177.                         for(i=0;i<8;i++)
  178.                         WriteDat(F8X16[c*16+i]);
  179.                         OLED_SetPos(x,y+1);
  180.                         for(i=0;i<8;i++)
  181.                         WriteDat(F8X16[c*16+i+8]);
  182.                         }
  183.                         else {
  184.                                 OLED_SetPos(x,y);
  185.                                 for(i=0;i<6;i++)
  186.                                 WriteDat(F6x8[c][i]);
  187.
  188.                         }
  189. }
  190. u32 oled_pow(u8 m,u8 n)
  191. {
  192.         u32 result=1;
  193.         while(n--)result*=m;
  194.         return result;
  195. ……………………
  196. …………限于本文篇幅 余下代碼請從51黑下載附件…………
經過檢測發現代碼不全,無法編譯,求幫助: HAL庫IIC OLED 驅動.rar (7.11 KB, 下載次數: 585)
大家還是去參考下51hei其他作者的吧:
http://m.zg4o1577.cn/bbs/dpj-150345-1.html
http://m.zg4o1577.cn/bbs/dpj-203015-1.html
收藏收藏5 分享淘帖 頂 踩
ID:510870 發表于 2019-4-19 16:58 | 只看該作者
謝謝!正好要學習這個。我來補全一下看看
ID:376232 發表于 2019-5-4 11:50 | 只看該作者
樓主用的i2c.h是哪個?
ID:223788 發表于 2019-5-6 15:25 | 只看該作者
用不了啊  東西不全怎么弄?
ID:384158 發表于 2019-5-19 18:57 | 只看該作者
那有這么簡單的
ID:473216 發表于 2019-5-25 23:54 來自觸屏版 | 只看該作者
FromUnknown 發表于 2019-5-4 11:50
樓主用的i2c.h是哪個?
都在里啊,
ID:473216 發表于 2019-5-25 23:55 來自觸屏版 | 只看該作者
JACKLI 發表于 2019-5-6 15:25
用不了啊  東西不全怎么弄?
在cubemx里把pb6,pb7配置為iic,然后程序直接添加到工程中就可以了
ID:473216 發表于 2019-5-25 23:56 來自觸屏版 | 只看該作者
bjdj0000 發表于 2019-5-19 18:57
那有這么簡單的
就是這么簡單,只要pb6,pb7配置為iic就能直接用
ID:313214 發表于 2019-5-27 15:04 | 只看該作者
為什么不行啊 應該和硬件沒關系的,可以將完整的東西發我郵箱嘛? 非常感謝樓主
ID:473216 發表于 2019-8-11 23:06 來自觸屏版 | 只看該作者
1655510098 發表于 2019-5-27 15:04
你oled的驅動芯片是ssd1306嗎,這是ssd1306的
ID:407940 發表于 2019-8-12 08:42 | 只看該作者
附件呢?我怎么看不到有附件?
ID:602755 發表于 2019-8-22 15:55 | 只看該作者
謝謝!正好要學習這個
ID:553282 發表于 2019-9-4 15:02 來自觸屏版 | 只看該作者
完全點不亮
ID:116773 發表于 2019-9-11 22:04 | 只看該作者
收藏備用,謝謝樓主分享!
ID:616492 發表于 2019-9-26 11:41 | 只看該作者
你好
能把  stm32HAL庫IIC 的0.96OLED屏幕驅動,可直接用不需要改   的完整工程發給我嗎?非常感謝,急需中
ID:349102 發表于 2019-10-7 16:47 來自觸屏版 | 只看該作者
先收藏,留著以后
ID:323384 發表于 2019-10-31 09:59 | 只看該作者
非常棒,謝謝你的分享!
ID:32137 發表于 2019-11-20 15:15 | 只看該作者
用的STM32F103VET6,編譯過了,但是點不亮,不知道是哪里的問題。
編譯過了, 但是還是沒點亮哦
ID:539798 發表于 2020-5-25 19:34 | 只看該作者
感謝感謝,這網站太好用了
ID:143203 發表于 2020-5-29 13:05 | 只看該作者
這個不全啊,main中調用沒有體現出來
ID:893310 發表于 2021-3-29 21:52 | 只看該作者
完全點不亮
主站蜘蛛池模板: 国产一级黄色 | 久久久久毛片 | a在线播放 | 亚洲日本一区二区 | 中文字幕在线观看第一页 | 久久精品美女 | 久久er99热精品一区二区 | 男男巨肉啪啪动漫3d | 日韩免费高清视频 | 午夜视频 | 欧美爱爱网站 | 欧美日韩啪啪 | 超碰成人福利 | 日本一级大毛片a一 | 日韩欧美二区 | 香蕉视频导航 | 青青在线 | 在线天堂视频 | 久久久久久亚洲 | 在线中文字幕网站 | 中文字幕在线观看日本 | 中文字幕在线免费播放 | 中文av网站| 在线免费观看黄色片 | 欧美日韩精品在线 | 天天躁日日躁狠狠躁av麻豆男男 | 成人福利网站 | 我要看一级片 | 在线观看国产免费视频 | 手机看黄色片 | 一级片免费在线观看 | 亚洲欧美日韩成人 | 日韩精品视频免费播放 | 老女人性生活视频 | 日本免费在线 | 蜜臀久久99精品久久久久久宅男 | 日皮视频免费看 | 午夜国产一区 | 黄av在线 | 久久av资源 | 成人午夜在线 |
