查看: 4083|回復: 0
看下這程序如何實現以下功能
ID:40821 發表于 2012-6-14 14:24 | 顯示全部樓層 |閱讀模式
IO定義:
輸出口P0.0
輸入口P2.7\P2.6P2.5\P2.4
要求:1、P2.6為低時,P0.0為高;P2.7和P2.6為低時,P0.0為低。P2.7單獨為低時,不作任何反映。
        2、當P2.4為低時,無論P2.7和P2.6在什么狀態,P0.0為低。
        3、當P2.5為低時,P0.0為低。
以下是程序,但有問題,請高手指出:
#include<STC12C5A60S2.h>
#define uchar unsigned char
#define uint unsigned int
#define Delaytime  100 //消抖
#define Delaybeemp 10
typedef signed   long           INT64S;
typedef unsigned long           INT64U;
typedef signed   int            INT32S;
typedef unsigned int            INT32U;
typedef signed   short          INT16S;
typedef unsigned short          INT16U;
typedef signed   char           INT8S;
typedef unsigned char           INT8U;
/*IO口定義*/
sbit out_upper=P0^0;   //接電磁閥
sbit out_lower = P0^2; //不用
sbit Buzzer = P0^1; //不用
sbit Upper_limit=P2^4; //(接光膜傳感器)
sbit Lower_limit = P2^5; //檢測電磁到位開關
sbit button = P2^6; //按鈕S2
sbit button1 = P2^7; //按鈕S1
typedef struct tagTYPE_UART_BUFFER
 INT8U  ucFlag;
    INT8U  ucIndex;
    INT8U  ucLength;
    INT8U  ucBuffer[20];
}TYPE_UART_BUFFER, *pTYPE_UART_BUFFER;
typedef struct tagTYPE_UART_INFO
    TYPE_UART_BUFFER    sRX;
    TYPE_UART_BUFFER    sTX;
}TYPE_UART_INFO, *pTYPE_UART_INFO;
unsigned char button_flag,jishu_flag,Upper_limit_flag,Lower_limit_flag;
unsigned char delay = Delaytime;
TYPE_UART_INFO xdata sUART0_Info = {0};
void sendonebyte(void);
函數功能:串口初始化,
波特率:38400 工作在1T模式,使用定時器1計數
void InitUART(void)
    TMOD = 0x21;
    SCON = 0x50;
 AUXR |= 0x40;//使其工作在1T模式下
    TH1 = 0xF7;
    TL1 = TH1;
    PCON = 0x00;
    EA = 1;
    ES = 1;
    TR1 = 1;
 //定時器0 定時時間:10ms
 TH0 = 0x0FF;
    TL0 = 0x0F6;
    EA = 1;
    ET0 = 1;
    TR0 = 1;
 //初始化輸入輸出的io
 P0M0 = 0xff;
 P0M1 = 0x00;
 P2M0 = 0x00;
 P2M1 = 0xff;
函數功能:延時時間為10ms
void delay_10ms(void)   //誤差 0us
    unsigned char a,b,c;
    for(c=1;c>0;c--)
        for(b=38;b>0;b--)
            for(a=130;a>0;a--);
void main(void)
 uchar i,flag=0;
// jishu_flag = 0;
 InitUART();
 out_upper = 1;//此時汽缸向上動作
 out_lower = 1;
 Upper_limit_flag = 0;   //  光幕傳感器
 Lower_limit_flag = 0;     //到位開關
 button_flag = 0; //按鈕S1
 button1_flag = 0; //按鈕S2
//  if(sUART0_Info.sRX.ucFlag == 1)
//   sUART0_Info.sRX.ucFlag = 0;
//    out_upper = 1;//此時汽缸向上動作
//    out_lower = 1;
//   for(i = 0;i<sUART0_Info.sRX.ucLength;i++)
//    sUART0_Info.sRX.ucBuffer = 0;
  if(Upper_limit_flag == 1)  //光幕傳感器
      out_lower = 1;
      flag = 0;
  if((Lower_limit_flag == 1)&&(flag == 0)) //限位開關和光幕傳感器做邏輯與運算
   Lower_limit_flag = 0;     //限位開關為低電位
    flag = 1;
   out_upper = 1;//此時汽缸向下動作
   out_lower = 0;
   sendonebyte();
  if(button_flag == 1)&&(button1_flag == 1)    //按鈕按下
     button_flag = 0;
     out_upper = 0;//此時汽缸向下動作
     out_lower = 1;
//  if((input==0)&&(jishu_flag == 0))
//   delay_10ms();
//    output = 0;//把汽缸合上
//    jishu_flag = 1;
//    overtime = 0;
//    while((input_test_qg==1)&&(overtime++ < Delaybeemp-1))
//     for(i = 0;i< 100;i++)
//      delay_10ms();
//     if(overtime>=Delaybeemp-1)
//      Buzzer = 0;
//     else if(input==0)
//      sendonebyte();
//  if(button_flag == 1)
//   button_flag = 0;
//   Buzzer = 1;
//   output = 1;
//  // jishu_flag = 0;
//  if(input==1)
//   delay_10ms();
//   if(input==1)
//    jishu_flag = 0;
//    Buzzer = 1;
void ISR_UART0(void)interrupt 4
     INT8U ucTemp;// 暫存變量
    // 接收
    if (RI){
        // 啟動接收
        RI = 0;
        ucTemp = SBUF;
        // 判斷數據
        switch (sUART0_Info.sRX.ucIndex)
            case 0:// "Z"
                if (ucTemp == 'Z')
                    // "Z"
                    sUART0_Info.sRX.ucBuffer[sUART0_Info.sRX.ucIndex ++] = ucTemp;
                    // 無效數據
                    sUART0_Info.sRX.ucIndex = 0;
                break;
            case 1:// "U"
                if (ucTemp == 'U')
                    // 無效數據
                break;
            case 2:// "Z"
                if (ucTemp == 'Z')
                    // "Z"
                    // 無效數據
                break;
            default:// 通信數據
                // 接收通信數據,
                // 接收通信數據,判斷回車鍵
                if(((ucTemp == '\r')||((ucTemp == '\n')))&&(sUART0_Info.sRX.ucIndex >= 3))
                 sUART0_Info.sRX.ucLength = sUART0_Info.sRX.ucIndex;
     sUART0_Info.sRX.ucIndex = 0; //接收完,清零索引
     sUART0_Info.sRX.ucFlag = 1;
                break;
    if (TI){
        TI = 0;
        if (sUART0_Info.sTX.ucIndex < sUART0_Info.sTX.ucLength)
            SBUF = sUART0_Info.sTX.ucBuffer[sUART0_Info.sTX.ucIndex ++];
            sUART0_Info.sTX.ucIndex = 0;
            sUART0_Info.sTX.ucLength = 0;
//10 ms掃描按鍵
void Timer0Interrupt(void) interrupt 1
  // 清除標志
    TF0 = 0;
    TR0 = 0;
    TH0 = 0x0FF;
    TL0 = 0x0F6;
 TR0 = 1;
 if((button == 0)||(Upper_limit == 0)||(Lower_limit == 0)) //按鈕、光幕傳感器、到位開關存在邏輯或的關系
  delay -- ; //延時消抖
  if(!delay)
   delay =  Delaytime;
   if(button == 0)
    button_flag =1;
   else if(Upper_limit == 0)
    Upper_limit_flag = 1;
   else if(Lower_limit == 0)
     Lower_limit_flag = 1;
    //add your code here!
  sUART0_Info.sTX.ucBuffer[0] = 'Z';
  sUART0_Info.sTX.ucBuffer[1] = 'f';
  sUART0_Info.sTX.ucBuffer[2] = 'Z';
  sUART0_Info.sTX.ucBuffer[3] = '\r';
     sUART0_Info.sTX.ucLength = 4;
主站蜘蛛池模板: 国产人人干| 天天干b | 91久久奴性调教 | 日韩免费一级片 | 人人射人人| 就要干就要操 | 婷婷在线视频 | 亚洲天堂一区 | 色综合天天综合网天天狠天天 | 极品淫少妇 | 久久久www成人免费精品 | 国产精品自拍第一页 | 五月天丁香 | 精品少妇v888av | 日韩免费看| 99精品在线观看 | 国产91在线播放 | 精品一区二区在线视频 | 亚洲激情欧美激情 | 日韩精品在线一区二区 | 久久青青| 欧美天堂在线 | 国产精品成人一区 | 国产日韩免费 | 一区二区三区高清 | 久久av红桃一区二区小说 | 中文字幕在线观看一区二区三区 | 一区二区三区日韩 | 男女久久久| 欧美日韩精品在线 | 国产特级淫片免费看 | 国模一区二区三区 | 黄色小视频免费 | 婷婷久久久 | a毛片大片 | 国产三区四区 | 日韩色网站 | 99在线视频免费观看 | 成人网址在线观看 | 91玖玖 | 一级片黄色|
