查看: 7171|回復: 9
鬧著玩-數控電源
一直想弄個數控電源,今天把手里的東西搜羅一下感覺可以整在一起就動手了,事后算了一下成本, 35元左右,而且都是淘寶可以買到的東西
電壓用手機軟件調節
lm2596 DCDC降壓模塊¥4.00
Mini360 DCDC¥2.00
LM393 電壓比較模塊¥4.00
ESP32 NodeMCU¥24.00
電阻三只(20k左右)¥1.00
合計¥35.00
ACDC電源適配器(12-19)自備
手機自備
收藏收藏6 分享淘帖 頂1 踩
ID:1 發表于 2019-3-13 22:08 | 只看該作者
樓主能分享制作資料嗎?
ID:489769 發表于 2019-3-13 23:28 | 只看該作者
admin 發表于 2019-3-13 22:08
樓主能分享制作資料嗎?
明天補上
ID:489769 發表于 2019-3-14 10:36 | 只看該作者
ID:489769 發表于 2019-3-14 10:45 | 只看該作者
ESP32 上的程序 基于 Arduino 和 Blynk
  Download latest Blynk library here:
    https://github.com/blynkkk/blynk-library/releases/latest
  Blynk is a platform with iOS and Android apps to control
  Arduino, Raspberry Pi and the likes over the Internet.
  You can easily build graphic interfaces for all your
  projects by simply dragging and dropping widgets.
  Blynk library is licensed under MIT license
  This example code is in public domain.
  This example runs directly on ESP32 chip.
  Note: This requires ESP32 support package:
    https://github.com/espressif/arduino-esp32
  Please be sure to select the right ESP32 module
  in the Tools -> Board menu!
  Change WiFi ssid, pass, and Blynk auth token to run :)
  Feel free to apply it to any other example. It's simple!
/* Comment this out to disable prints and save space */
#define BLYNK_PRINT Serial
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "your_auth";          //改成你自己的 auth
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "wifi_name";      //改成你自己的 wifi 名稱
char pass[] = "wifi_password";  //改成你自己的 wifi 密碼
int powerPin = 25;  //dac輸出腳
BLYNK_WRITE(V1)
    float tmpVal;
    tmpVal = param.asInt();
    tmpVal = tmpVal / 100; // assigning incoming value from pin V1 to a variable
    tmpVal = tmpVal / 6;   //根據分壓電阻調整系數
    tmpIntVal = tmpVal * 256 /3.3;
    dacWrite(powerPin, tmpIntVal);
void setup()
  // Debug console
  Serial.begin(115200);
  Blynk.begin(auth, ssid, pass);
void loop()
  Blynk.run();
ID:489769 發表于 2019-3-14 10:55 | 只看該作者
手機端在應用市場搜索Blynk安裝就好,ios,android 都可以,設置比較簡單控制V1端口輸出值就行,用blynk掃描 我提供的二維碼也可以
ID:472506 發表于 2019-3-19 08:46 | 只看該作者
好文章,收藏一個先。
ID:128989 發表于 2020-2-4 12:24 | 只看該作者
不錯的文章,學習了
ID:712493 發表于 2021-6-14 21:11 | 只看該作者
不錯的玩法 贊一個
ID:712493 發表于 2021-10-25 09:24 | 只看該作者
EP32的開發環境搭建可以講講  ESP32 上的程序 基于 Arduino
主站蜘蛛池模板: av日韩精品 | 成人动漫一区二区 | 精品理论片| 精品福利在线观看 | 亚洲精品一区二区三区在线 | h视频免费在线观看 | 国产丝袜视频 | 天天操狠狠干 | 国产999视频| 国产一级黄色录像 | 亚洲精品色 | 一级免费片 | 国产欧美激情 | 天天射天天干天天操 | 可以免费看的毛片 | 毛片av在线| 久久久久国产精品夜夜夜夜夜 | 欧美aaaaa | 欧美亚洲激情 | 97国产在线观看 | 欧美成人一级 | 日韩五十路 | 天天色天天爱 | 黄色小说视频网站 | 国产美女啪啪 | 久草视频免费在线观看 | 午夜快播 | 一区二区三区在线播放 | 欧美性爽 | 婷婷六月天 | 国产精品嫩草影院桃色 | 黄色av大片 | 国产高清av| 日本一区二区不卡视频 | 色女人影院 | 日本黄色三级视频 | 国产精品国产精品国产专区不片 | 日韩一区二区三区在线 | 精品一区av| 丁香花在线观看 | 日韩在线成人 |
