查看: 6962|回復: 1
用HAL庫寫的STM32F103C8T6的定時器控制LED燈1秒閃爍程序
這里用到了STM32CubeMx,用定時器控制LED燈1秒閃爍。
  1. /* Includes ------------------------------------------------------------------*/
  2. #include "main.h"
  3. #include "stm32f1xx_hal.h"
  4. /* USER CODE BEGIN Includes */
  5. /* USER CODE END Includes */
  6. /* Private variables ---------------------------------------------------------*/
  7. TIM_HandleTypeDef htim1;
  8. /* USER CODE BEGIN PV */
  9. /* Private variables ---------------------------------------------------------*/
  10. /* USER CODE END PV */
  11. /* Private function prototypes -----------------------------------------------*/
  12. void SystemClock_Config(void);
  13. static void MX_GPIO_Init(void);
  14. static void MX_TIM1_Init(void);
  15. /* USER CODE BEGIN PFP */
  16. /* Private function prototypes -----------------------------------------------*/
  17. /* USER CODE END PFP */
  18. /* USER CODE BEGIN 0 */
  19. /* USER CODE END 0 */
  20. /**
  21.   * @brief  The application entry point.
  22.   *
  23.   * @retval None
  24.   */
  25.
  26.         //定時器中斷
  27. void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
  28. {
  29.         if (htim->Instance == TIM1)
  30.         {
  31.                         /* Toggle LED */
  32.                         HAL_GPIO_TogglePin(LED1_GPIO_Port,LED1_Pin);//定時時間到后,LED1翻轉
  33.         }
  34. }
  35.
  36. int main(void)
  37. {
  38.   /* USER CODE BEGIN 1 */
  39.   /* USER CODE END 1 */
  40.   /* MCU Configuration----------------------------------------------------------*/
  41.   /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  42.   HAL_Init();
  43.   /* USER CODE BEGIN Init */
  44.   /* USER CODE END Init */
  45.   /* Configure the system clock */
  46.   SystemClock_Config();
  47.   /* USER CODE BEGIN SysInit */
  48.   /* USER CODE END SysInit */
  49.   /* Initialize all configured peripherals */
  50.   MX_GPIO_Init();
  51.   MX_TIM1_Init();
  52.
  53.         HAL_TIM_Base_Start_IT(&htim1);
  54.   /* USER CODE BEGIN 2 */
  55.
  56.   /* USER CODE END 2 */
  57.   /* Infinite loop */
  58.   /* USER CODE BEGIN WHILE */
  59.   while (1)
  60.   {
  61. //                HAL_GPIO_TogglePin(GPIOC,GPIO_PIN_13);
  62. //                HAL_Delay(500);
  63. //                HAL_GPIO_TogglePin(GPIOC,GPIO_PIN_13);
  64. //                HAL_Delay(1000);
  65.   /* USER CODE END WHILE */
  66.   /* USER CODE BEGIN 3 */
  67.   }
  68.   /* USER CODE END 3 */
  69. }
  70. /**
  71.   * @brief System Clock Configuration
  72.   * @retval None
  73.   */
  74. void SystemClock_Config(void)
  75. {
  76.   RCC_OscInitTypeDef RCC_OscInitStruct;
  77.   RCC_ClkInitTypeDef RCC_ClkInitStruct;
  78.     /**Initializes the CPU, AHB and APB busses clocks
  79.     */
  80.   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  81.   RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  82.   RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
  83.   RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  84.   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  85.   RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  86.   RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
  87.   if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
  88.   {
  89.     _Error_Handler(__FILE__, __LINE__);
  90.   }
  91.     /**Initializes the CPU, AHB and APB busses clocks
  92.     */
  93.   RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
  94.                               |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  95.   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  96.   RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  97.   RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  98.   RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  99.   if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
  100.   {
  101.     _Error_Handler(__FILE__, __LINE__);
  102.   }
  103.     /**Configure the Systick interrupt time
  104.     */
  105.   HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  106.     /**Configure the Systick
  107.     */
  108.   HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  109.   /* SysTick_IRQn interrupt configuration */
  110.   HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
  111. }
  112. /* TIM1 init function */
  113. static void MX_TIM1_Init(void)
  114. {
  115.   TIM_ClockConfigTypeDef sClockSourceConfig;
  116.   TIM_MasterConfigTypeDef sMasterConfig;
  117.   htim1.Instance = TIM1;
  118.   htim1.Init.Prescaler = 36000-1;                        //預分頻系數  APB2當前頻率為72MHz,我們希望每秒鐘發生1次中斷
  119.   htim1.Init.CounterMode = TIM_COUNTERMODE_UP;
  120.   htim1.Init.Period = 2000-1;                                                //自動重載值為1000-1    72,000,000/36000/2000=1Hz
  121.   htim1.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  122.   htim1.Init.RepetitionCounter = 0;
  123.   htim1.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
  124.   if (HAL_TIM_Base_Init(&htim1) != HAL_OK)
  125.   {
  126.     _Error_Handler(__FILE__, __LINE__);
  127.   }
  128.   sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
  129.   if (HAL_TIM_ConfigClockSource(&htim1, &sClockSourceConfig) != HAL_OK)
  130.   {
  131.     _Error_Handler(__FILE__, __LINE__);
  132.   }
  133.   sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
  134.   sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
  135.   if (HAL_TIMEx_MasterConfigSynchronization(&htim1, &sMasterConfig) != HAL_OK)
  136.   {
  137.     _Error_Handler(__FILE__, __LINE__);
  138.   }
  139. }
  140. /** Configure pins as
  141.         * Analog
  142.         * Input
  143.         * Output
  144.         * EVENT_OUT
  145.         * EXTI
  146. */
  147. static void MX_GPIO_Init(void)
  148. {
  149.   GPIO_InitTypeDef GPIO_InitStruct;
  150.   /* GPIO Ports Clock Enable */
  151.   __HAL_RCC_GPIOC_CLK_ENABLE();
  152.   __HAL_RCC_GPIOD_CLK_ENABLE();
  153.   /*Configure GPIO pin Output Level */
  154.   HAL_GPIO_WritePin(LED1_GPIO_Port, LED1_Pin, GPIO_PIN_SET);
  155.   /*Configure GPIO pin : LED1_Pin */
  156.   GPIO_InitStruct.Pin = LED1_Pin;        //選擇對應的LED管腳
  157.   GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;                        //輸出模式
  158.   GPIO_InitStruct.Pull = GPIO_NOPULL;
  159.   GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  160.   HAL_GPIO_Init(LED1_GPIO_Port, &GPIO_InitStruct);
  161. }
  162. /* USER CODE BEGIN 4 */
  163. /* USER CODE END 4 */
  164. /**
  165.   * @brief  This function is executed in case of error occurrence.
  166.   * @param  file: The file name as string.
  167.   * @param  line: The line in file as a number.
  168.   * @retval None
  169.   */
  170. void _Error_Handler(char *file, int line)
  171. {
  172.   /* USER CODE BEGIN Error_Handler_Debug */
  173.   /* User can add his own implementation to report the HAL error return state */
  174.   while(1)
  175.   {
  176.   }
  177.   /* USER CODE END Error_Handler_Debug */
  178. }
  179. #ifdef  USE_FULL_ASSERT
  180. /**
  181.   * @brief  Reports the name of the source file and the source line number
  182.   *         where the assert_param error has occurred.
  183.   * @param  file: pointer to the source file name
  184.   * @param  line: assert_param error line source number
  185.   * @retval None
  186.   */
  187. void assert_failed(uint8_t* file, uint32_t line)
  188. {
  189.   /* USER CODE BEGIN 6 */
  190.   /* User can add his own implementation to report the file name and line number,
  191.      tex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  192.   /* USER CODE END 6 */
  193. }
  194. #endif /* USE_FULL_ASSERT */
  195. /**
  196.   * @}
  197.   */
  198. /**
  199.   * @}
  200.   */
  201. /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
HAL庫的LED.7z (2.89 MB, 下載次數: 88)
ID:421823 發表于 2019-3-19 17:18 | 只看該作者
STM32CubeMX是個好東西
主站蜘蛛池模板: 欧美福利视频 | 欧美精品久久久久久久多人混战 | 色婷婷一区 | 亚洲午夜天堂 | 一区二区视频在线 | 日韩精品视频在线免费观看 | 欧美一区二区在线播放 | 91精品国产乱码久久久久 | 特黄网站 | 三级网站在线 | 亚洲精品a| 成人激情视频在线观看 | 久久精品二区 | 成人理论影院 | 国产欧美一区二区三区视频在线观看 | 欧美日韩视频在线 | av资源站 | 欧美综合一区二区 | 国产精品网站在线观看 | 99视频网站 | 亚洲国产精品va在线看黑人 | 久久九九免费视频 | 深夜福利网址 | 肉丝美脚视频一区二区 | 天天操天天干天天操 | 欧美日本在线 | 欧美一二 | av观看免费 | 国产一区二区三区免费 | 成人高潮片免费 | 成人少妇影院yyyy | 精品少妇一区二区三区免费观 | 野外(巨肉高h) | 激情网站在线观看 | 日韩一区二区三区四区 | 日韩一区二区在线视频 | 国产在线www | 97超碰免费 | 蜜臀久久99精品久久久久久宅男 | 日本一区二区三区四区五区 | 日韩黄色一级视频 |
