#include<STC12C5A60S2.H> #define uint unsigned int #define uchar unsigned char sbit CS=P2^0; //LCD12864串行通信片選 sbit SID=P2^1; //LCD12864串行通信數(shù)據(jù)口 sbit SCLK=P2^2; //LCD12864串行通信同步時(shí)鐘信號(hào) sbit PSB=P2^5; //LCD12864并/串選擇:H并行 L串行 unsigned int temp1,sh1,ge1,n1,m1; unsigned char ad_result_data[10]; //AD轉(zhuǎn)換高八位 unsigned char ad_result_low2[10]; //AD轉(zhuǎn)換低八位 unsigned char ad_result_total[10]; //AD轉(zhuǎn)換總十位 unsigned char ad_average_result; //AD轉(zhuǎn)換十次的平均值 unsigned char Ain,Vin; unsigned char b,t,R; char tp=0; unsigned char code ma1[6]={0xb5,0xe7,0xd1,0xb9,0xa1,0xc3}; //電壓: unsigned char code ma2[]={"."}; uchar code disp1[]={"提示: 按1 鍵進(jìn)入"}; uchar code disp2[]={"功能選擇界面. "}; unsigned char code num0[]={0xa3,0xb0}; unsigned char code num1[]={0xa3,0xb1}; unsigned char code num2[]={0xa3,0xb2}; unsigned char code num3[]={0xa3,0xb3}; unsigned char code num4[]={0xa3,0xb4}; unsigned char code num5[]={0xa3,0xb5}; unsigned char code num6[]={0xa3,0xb6}; unsigned char code num7[]={0xa3,0xb7}; unsigned char code num8[]={0xa3,0xb8}; unsigned char code num9[]={0xa3,0xb9}; //-------模塊延時(shí)程序---------------------------- 1ms void delay1ms(uint delay1ms) //STC11F60XE,22.1184M,延時(shí)1ms { uint i,j; for(;delay1ms>0;delay1ms--) for(i=0;i<7;i++) for(j=0;j<210;j++); } void delay(uint delay) //STC11F60XE,22.1184M,延時(shí)170us { uint i,j; for(;delay>0;delay--) for(i=0;i<124;i++); for(j=0;j<124;j++); } /******************************************************* AD轉(zhuǎn)換程序 *******************************************************/ void AD_initiate() //初始化函數(shù) { ES=0; TMOD=0x21; //定時(shí)計(jì)數(shù)器方式控制寄存器,"自動(dòng)重裝,16位計(jì)數(shù)器". SCON=0x50; //串行控制寄存器,方便在串口助手那觀察 TH1=0xfa; TL1=0xfa; TR1=1; } void ADC_Power_On() //AD轉(zhuǎn)換電 { ADC_CONTR|=0x80; delay(5); //必要的延時(shí) } void get_ad_result() //取AD結(jié)果函數(shù),它是十位AD轉(zhuǎn)換,每十次平均,最后取低八位作為AD采樣數(shù)據(jù) { uint i,q=0; for(i=0;i<10;i++) { tp=0; ADC_RES=0; //高八位數(shù)據(jù)清零,STC12C5A60S2 AD數(shù)據(jù)寄存名與STC12C54××系列不同 ADC_RESL=0; //低兩位清零 ADC_CONTR|=0x08; //啟動(dòng)AD轉(zhuǎn)換 while(!tp) //判斷AD轉(zhuǎn)換是否完成 { tp=0x10; tp&=ADC_CONTR; } ADC_CONTR&=0xe7; ad_average_result=ADC_RES; q=q+ad_average_result; } ad_average_result=q/10; //ad_average_result=ad_average_result*4*5000/1024; } /************************AD轉(zhuǎn)換結(jié)束***********************/ void send_ad_result() //取AD結(jié)果函數(shù)發(fā)送到串口,方便調(diào)試 { SBUF=n1; while(TI==0) ; TI=0; delay1ms(100); //SBUF=R>>4; } //---------------------電壓采樣程序------------------------- void caiyangP10() //測(cè)電壓 { P1M0|=0x01; //設(shè)P1_0為開漏模式 如: P1_0= #00000000B P1M1|=0x01; ADC_CONTR=0xe0; //設(shè)置P1.0為輸入AD轉(zhuǎn)換口 delay(2); get_ad_result(); //取轉(zhuǎn)換數(shù)據(jù) Vin=ad_average_result; R=Vin; } /*-----------寫控制字到LCD12864------------*/ void write_cmd(uchar cmd) { uchar i; uchar i_data; i_data=0xf8; //命令控制字:11111000寫指令 11111010寫數(shù)據(jù) 11111100讀狀態(tài) 11111110讀數(shù)據(jù) CS=1; //片選置高,才能進(jìn)行讀寫操作 SCLK=0; /*----------寫命令控制字-----------------*/ for(i=0;i<8;i++) //循環(huán)八次,每次讀取一位數(shù)據(jù) { SID=(bit)(i_data&0x80); //bit表示取其最高位 SCLK=0; SCLK=1; //正跳變寫入指令 i_data=i_data<<1; //左移一位 } /*---------------------------------------*/ /*----------寫指令高四位-----------------*/ i_data=cmd; i_data=i_data&0xf0; //把低四位置0 for(i=0;i<8;i++) //循環(huán)八次,每次讀取一位數(shù)據(jù) { SID=(bit)(i_data&0x80); //bit表示取其最高位 SCLK=0; SCLK=1; //正跳變寫入指令 i_data=i_data<<1; //左移一位 } /*---------------------------------------*/ /*----------寫指令低四位-----------------*/ i_data=cmd; i_data=i_data<<4; //左移四位,把低四位的數(shù)據(jù)移到高四位,再把低四位置0 for(i=0;i<8;i++) //循環(huán)八次,每次讀取一位數(shù)據(jù) { SID=(bit)(i_data&0x80); //bit表示取其最高位 SCLK=0; SCLK=1; //正跳變寫入指令 i_data=i_data<<1; //左移一位 } /*-----------------------------------------*/ CS=0; //把片選置低 delay1ms(5); //延時(shí)是因?yàn)闆]有進(jìn)行忙檢測(cè),適當(dāng)?shù)难訒r(shí)可以不進(jìn)行忙檢測(cè) } /*-----------------------------------------*/ /*------------寫數(shù)據(jù)到LCD12864-------------*/ void write_dat(uchar dat) { uchar i; uchar i_data; i_data=0xfa; CS=1; for(i=0;i<8;i++) { SID=(bit)(i_data&0x80); SCLK=0; SCLK=1; i_data=i_data<<1; } i_data=dat; i_data=i_data&0xf0; for(i=0;i<8;i++) { SID=(bit)(i_data&0x80); SCLK=0; SCLK=1; i_data=i_data<<1; } i_data=dat; i_data=i_data<<4; for(i=0;i<8;i++) { SID=(bit)(i_data&0x80); SCLK=0; SCLK=1; i_data=i_data<<1; } CS=0; delay1ms(5); } /*-----------------------------------------*/ /*--------------顯示坐標(biāo)-------------------*/ void lcd_pos(uchar x,uchar y) //漢字顯示坐標(biāo),x為哪一行,y為哪一列 { uchar pos; if(x==0) x=0x80; //第一行 else if(x==1) x=0x90; //第二行 else if(x==2) x=0x88; //第三行 else if(x==3) x=0x98; //第四行 pos=x+y; //顯示哪一行(總共有4行)哪一豎(總共有8豎,每16列為1豎) write_cmd(pos); } /*-----------------------------------------*/ /*--------------顯示8個(gè)漢字-------------------*/ void disp_hanzi(uchar code *chn) { uchar i; write_cmd(0x30); //基本指令操作方式 for(i=0;i<16;i++) //16列*8個(gè)漢字=128(剛好) write_dat(chn); } /*-----------------------------------------*/ /*--------------顯示數(shù)字-------------------*/ void disp_num(uchar code *chn) { uchar i; write_cmd(0x30); //基本指令操作方式 for(i=0;i<2;i++) //1個(gè)數(shù)字 write_dat(chn); } void disp_number(uchar num) { switch(num) { case 0: disp_num(num0);break; case 1: disp_num(num1);break; case 2: disp_num(num2);break; case 3: disp_num(num3);break; case 4: disp_num(num4);break; case 5: disp_num(num5);break; case 6: disp_num(num6);break; case 7: disp_num(num7);break; case 8: disp_num(num8);break; case 9: disp_num(num9);break; default: break; } } /*----------- --LCD初始化------------------*/ void lcd_init() { PSB=0; write_cmd(0x30); //基本指令 write_cmd(0x02); //地址歸位 write_cmd(0x06); //游標(biāo)右移 write_cmd(0x0c); //整體顯示 write_cmd(0x01); //清屏 } /*-----------------------------------------*/ void displayP10() { float ad1; //unsigned int temp1,sh1,ge1,n1,m1; //uchar code dis2[]={0x01,0x02,0x00}; //ad1=x*7.8125; //電壓修正 uchar i; ad1=Vin*3.9608; //具體線性參數(shù)由輸入電壓值調(diào)整,該值的測(cè)量范圍為0-10.00V,5V左右的測(cè)量比較準(zhǔn)確, //兩端的最大誤差為70mv,其他一般在40mv以內(nèi) temp1=(int)ad1; sh1=temp1/1000; //十位 ge1=(temp1%1000)/100; //個(gè)位 n1=((temp1%1000)%100)/10; //小數(shù)點(diǎn)后一位 m1=((temp1%1000)%100)%10; //小數(shù)點(diǎn)后二位 //write_cmd(0x01); write_cmd(0x30); //基本指令操作方式 lcd_pos(0,0); for(i=0;i<6;i++) write_dat(ma1); lcd_pos(0,3); disp_number(sh1); lcd_pos(0,4); disp_number(ge1); lcd_pos(0,5); for(i=0;i<2;i++) write_dat(ma2); lcd_pos(0,6); disp_number(n1); lcd_pos(0,7); disp_number(m1); /*lcd_pos(2,0); disp_hanzi(disp1); lcd_pos(3,0); disp_hanzi(disp2);*/ } void main() { EA=1; AD_initiate(); //初始化 ADC_Power_On(); //開AD電源 //init(); lcd_init(); delay(10); while(1) { caiyangP10(); //測(cè)電壓 send_ad_result(); //Vin=Vin*4007; displayP10(); delay(10); } } 參考鏈接:http://www.picavr.com/news/2010-11/2388.htm |
