Altium Designer畫的16*16全彩點陣屏電路原理圖和PCB圖如下:(51hei附件中可下載工程文件)
- #define uchar unsigned char
- #define uint unsigned int
- uchar dd,ee,m1=0,m2=1,m3=2,m4=3,m5=4,m6=5,m7,m8,m9,m10,m11,m12,m13,m14,m15,m16;
- uchar yd,xh,xh1; //yd控制移動間隔時間i:每個字的顯示循環;j每個字的顯示碼除以2
- uint yd1=0; //顯示偏移控制,char類型最多只能顯示14個漢字+一個空白位字符
- sbit hwx=P3^2; //紅外接收數據引腳,
- unsigned char l_posit=0; //顯示位置
- unsigned char ly_lhj[4]; //保存NEC的四個字節數據
- bit ly_flag=1; //成功接收標志
- sbit STTP = P4^2;
- sbit key1=P4^3;
- sbit aa=P4^0;
- sbit a1=P2^0;
- sbit a2=P2^1;
- sbit a3=P2^2;
- sbit a4=P2^3;
- sbit bb=P0^4;
- sbit b1=P0^0;
- sbit b2=P0^1;
- sbit b3=P0^2;
- sbit b4=P0^3;
- sbit cc=P0^5;
- sbit c1=P2^4;
- sbit c2=P2^5;
- sbit c3=P2^6;
- sbit c4=P2^7;
- void delay(uint c)
- int i,j;
- for(i=0;i<c;i++)
- for(j=0;j<1;j++);
- void out_rxd(uchar *d)
- SBUF=*d;
- while(TI==0);
- TI=0;
- void mm1()
- if(m1==1){aa=0;bb=1;cc=1;}
- if(m1==2){aa=0;bb=0;cc=1;}
- if(m1==3){aa=1;bb=0;cc=1;}
- if(m1==4){aa=1;bb=0;cc=0;}
- if(m1==5){aa=1;bb=1;cc=0;}
- if(m1==6){aa=0;bb=1;cc=0;}
- void mm2()
- if(m2==1){aa=0;bb=1;cc=1;}
- if(m2==2){aa=0;bb=0;cc=1;}
- if(m2==3){aa=1;bb=0;cc=1;}
- if(m2==4){aa=1;bb=0;cc=0;}
- if(m2==5){aa=1;bb=1;cc=0;}
- if(m2==6){aa=0;bb=1;cc=0;}
- void mm3()
- if(m3==1){aa=0;bb=1;cc=1;}
- if(m3==2){aa=0;bb=0;cc=1;}
- if(m3==3){aa=1;bb=0;cc=1;}
- if(m3==4){aa=1;bb=0;cc=0;}
- if(m3==5){aa=1;bb=1;cc=0;}
- if(m3==6){aa=0;bb=1;cc=0;}
- void mm4()
- if(m4==1){aa=0;bb=1;cc=1;}
- if(m4==2){aa=0;bb=0;cc=1;}
- if(m4==3){aa=1;bb=0;cc=1;}
- if(m4==4){aa=1;bb=0;cc=0;}
- if(m4==5){aa=1;bb=1;cc=0;}
- if(m4==6){aa=0;bb=1;cc=0;}
- void mm5()
- if(m5==1){aa=0;bb=1;cc=1;}
- if(m5==2){aa=0;bb=0;cc=1;}
- if(m5==3){aa=1;bb=0;cc=1;}
- if(m5==4){aa=1;bb=0;cc=0;}
- if(m5==5){aa=1;bb=1;cc=0;}
- if(m5==6){aa=0;bb=1;cc=0;}
- void mm6()
- if(m6==1){aa=0;bb=1;cc=1;}
- if(m6==2){aa=0;bb=0;cc=1;}
- if(m6==3){aa=1;bb=0;cc=1;}
- if(m6==4){aa=1;bb=0;cc=0;}
- if(m6==5){aa=1;bb=1;cc=0;}
- if(m6==6){aa=0;bb=1;cc=0;}
- void xianshi()
- for(xh=0;xh<16;xh++)
- if(xh==0){a1=b1=c1=0;a2=b2=c2=0;a3=b3=c3=0;a4=b4=c4=0;mm1();}
- if(xh==1){a1=b1=c1=1;a2=b2=c2=0;a3=b3=c3=0;a4=b4=c4=0;mm2();}
- if(xh==2){a1=b1=c1=0;a2=b2=c2=1;a3=b3=c3=0;a4=b4=c4=0;mm3();}
- if(xh==3){a1=b1=c1=1;a2=b2=c2=1;a3=b3=c3=0;a4=b4=c4=0;mm4();}
- if(xh==4){a1=b1=c1=0;a2=b2=c2=0;a3=b3=c3=1;a4=b4=c4=0;mm5();}
- if(xh==5){a1=b1=c1=1;a2=b2=c2=0;a3=b3=c3=1;a4=b4=c4=0;mm6();}
- if(xh==6){a1=b1=c1=0;a2=b2=c2=1;a3=b3=c3=1;a4=b4=c4=0;mm1();}
- if(xh==7){a1=b1=c1=1;a2=b2=c2=1;a3=b3=c3=1;a4=b4=c4=0;mm2();}
- if(xh==8){a1=b1=c1=0;a2=b2=c2=0;a3=b3=c3=0;a4=b4=c4=1;mm3();}
- if(xh==9){a1=b1=c1=1;a2=b2=c2=0;a3=b3=c3=0;a4=b4=c4=1;mm4();}
- if(xh==10){a1=b1=c1=0;a2=b2=c2=1;a3=b3=c3=0;a4=b4=c4=1;mm5();}
- if(xh==11){a1=b1=c1=1;a2=b2=c2=1;a3=b3=c3=0;a4=b4=c4=1;mm6();}
- if(xh==12){a1=b1=c1=0;a2=b2=c2=0;a3=b3=c3=1;a4=b4=c4=1;mm1();}
- if(xh==13){a1=b1=c1=1;a2=b2=c2=0;a3=b3=c3=1;a4=b4=c4=1;mm2();}
- if(xh==14){a1=b1=c1=0;a2=b2=c2=1;a3=b3=c3=1;a4=b4=c4=1;mm3();}
- if(xh==15){a1=b1=c1=1;a2=b2=c2=1;a3=b3=c3=1;a4=b4=c4=1;mm4();}
- STTP=0;
- out_rxd(&hanzi[3][xh1+yd1+1]);
- out_rxd(&hanzi[3][xh1+yd1]);
- out_rxd(&hanzi[2][xh1+yd1+1]);
- out_rxd(&hanzi[2][xh1+yd1]);
- out_rxd(&hanzi[1][xh1+yd1+1]);
- out_rxd(&hanzi[1][xh1+yd1]);
- out_rxd(&hanzi[0][xh1+yd1+1]);
- out_rxd(&hanzi[0][xh1+yd1]);
- STTP=1;
- delay(10);
- STTP=0;
- out_rxd(&hanzi[3][0]);
- out_rxd(&hanzi[2][0]);
- out_rxd(&hanzi[1][0]);
- out_rxd(&hanzi[0][0]);
- STTP=1;
- xh1=xh1+2;
- yd++;
- xh1=0;
- if(yd>ee) //移動間隔時間;取值0--255
- yd=0;yd1=yd1+32;
- if(yd1>896){yd1=32;}
- m1++;m2++;m3++;m4++;m5++;m6++;
- if(m1>5)m1=0;if(m2>5)m2=0;if(m3>5)m3=0;
- if(m4>5)m4=0;if(m5>5)m5=0;if(m6>5)m6=0;
- void zd()
- EA=1; //首先開啟總中斷
- EX0=1; //開啟外部中斷1,紅外接收數據引腳
- IT0=1; //設置成下降沿觸發方式
- TMOD=0X01; //定時器1的方式1,16位計數器,用來計數時間
- aa=0;
- /***********外中斷1入口函數,P33引腳,紅外線接收IC數據腳**************************/
- void hongwai(void) interrupt 0
- unsigned char i,ia;
- /**************開始判斷是否為NEC波形引導碼的前9MS和后4.5MS******************************/
- TL0=0;
- TH0=0; //定時/計數器1初始值
- TR0=1; //定時器以12M晶振12分頻計數,即1us計數
- while(!hwx);
- TR0=0; //信號翻轉停止計數
- if(TH0<60||TH0>80) //NEC引導碼前9MS,計數約9000,TH1約等于35,給個誤差值,用30-40之間來判斷
- return;
- TR0=1;
- while(hwx){
- delay(20);
- if(TH0>44) //NEC引導碼引導碼的后4。5MS,計數約4500,TH1約等于17
- return;
- TR0=0;
- if(TH0<24) //NEC引導碼引導碼的后4。5MS,計數約4500,TH1約等于17
- return;
- /***********開始接收四個字節內容**************************************/
- for(i=0;i<4;i++){
- for(ia=0;ia<8;ia++){
- while(!hwx); //低電平開始,不處理只等待高電平
- TH0=0;
- TR0=1; //高電平開始,啟動計數
- while(hwx){
- delay(20);
- if(TH0>30)
- return;
- TR0=0;
- //高電平結束,判斷數據1或0向變量移入
- ly_lhj[i]>>=1; //數據由高位移入低位
- if(TH0>8) //時間量TH1高于4,即高于1MS判斷為1
- ly_lhj[i]|=0x80;
- ly_flag=1; //接收成功
1616全彩.zip
(2.86 MB, 下載次數: 114)
2019-4-10 21:57 上傳
點擊文件名下載附件
16*16點陣封裝原理圖
