查看: 10208|回復: 12
51hei單片機,MQ-5天然氣傳感器,1602顯示
ID:42637 發表于 2012-7-24 22:09 | 顯示全部樓層 |閱讀模式
用51hei板,買了個MQ-5天然氣傳感器,做了個燃氣漏泄報警器兼讀數。
用打火機檢驗,靈敏,滿足要求
#include <reg52.h>
#include <intrins.h>
#define uint unsigned int
#define uchar unsigned char
#define lcd P0
sbit adc_cs=P2^0;
sbit adc_rd=P3^7;
sbit adc_wr=P3^6;
sbit en=P3^4;
sbit rw=P2^7;
sbit rs=P3^5;
sbit busybit=P0^7;
sbit beep=P2^2;
sbit P26=P2^6;
sbit P27=P2^7;
sbit P24=P2^4;
bit beep_flag;
bit adc_flag;
bit adc_start;
uchar tab[]="0123456789";
void lcd_init(void);
void delay(uint temp)
 while(temp--);
void init(void)
 P24=0;
 P27=1;
 P0=0xff;
 P27=0;
 P26=1;
 P0=0x00;
 P26=0;
 lcd_init();
 TMOD=0x01;
 TH0=0x3c;
 TL0=0xb0;
 ET0=1;
 TR0=1;
 IT1=0;
 EX1=1;
 IT0=1;
 EX0=1;
 EA=1;
void  int0_srv() interrupt 0
 adc_flag=1;
void int1_srv() interrupt 2
 beep_flag=1;
void timer0_srv() interrupt 1
 uchar temp;
 TH0=0x3c;
 TL0=0xb0;
 temp++;
 if(temp==20)
  temp=0;
  adc_start=1;
void testbusy(void)//read com
 busybit=1;
 en=0;
 rs=0;
 rw=1;
 delay(5);
 en=1;
 delay(5);
 while (busybit);
 en=0;
void wr_dat(uchar dat,busyflag)
 if(busyflag)
 testbusy();
 en=0;
 rs=1;
 rw=0;
 lcd=dat;
 delay(5);
 en=1;
 delay(5);
 en=0;
void wr_com(uchar com,busyflag)
 if(busyflag)
 testbusy();
 en=0;
 rs=0;
 rw=0;
 lcd=com;
 delay(5);
 en=1;
 delay(5);
 en=0;
void lcd_init(void)
 delay(1650);//time
 wr_com(0x38,0);
 delay(550);//time
 wr_com(0x38,0);
 delay(550);
 wr_com(0x38,0);
 wr_com(0x38,1);
 wr_com(0x08,1);
 wr_com(0x01,1);
 wr_com(0x06,1);
 wr_com(0x0c,1);
uchar adc_change(void)
 uchar value;
 adc_cs=1;
 adc_wr=1;
 delay(2);
 adc_cs=0;
 delay(2);
 adc_wr=0;
 delay(10);
 adc_wr=1;
 delay(2);
 adc_cs=1;
 while(!adc_flag);
 adc_flag=0;
 adc_rd=1;
 _nop_();
 adc_cs=0;
 delay(2);
 adc_rd=0;
 _nop_();
 value=P1;
 _nop_();
 adc_rd=1;
 delay(2);
 adc_cs=1;
 return value;
 uchar adc_value;
 uchar ge,shi,bei;
 init();
  if(beep_flag)
   beep_flag=0;
   beep=0;
   delay(10000);
   beep=1;
   delay(10000);
  if(adc_start)
   adc_start=0;
   adc_value=adc_change();
   bei=adc_value/100;
   adc_value=adc_value%100;
   shi=adc_value/10;
   ge=adc_value%10;
  wr_com(0x80,1);
  wr_dat('M',1);
  delay(3);
  wr_dat('Q',1);
  delay(3);
  wr_dat('-',1);
  delay(3);
     wr_dat('5',1);
  delay(3);
  wr_dat(':',1);
  delay(3);
     wr_com(0xc0,1);
  wr_dat(tab[bei],1);
  delay(3);
  wr_dat(tab[shi],1);
  delay(3);
  wr_dat(tab[ge],1);
  delay(3);
參與人數 1黑幣 +5 收起 理由
ssfc + 5 贊一個!
ID:42637 發表于 2012-7-24 23:01 | 顯示全部樓層
上電3小時,MQ-5有點燙,靈敏度沒有降低
ID:42637 發表于 2012-7-24 23:09 | 顯示全部樓層
去掉USB接口線顯示暗淡,加上USB線顯示正常,供電要考慮
ID:1 發表于 2012-7-25 04:38 | 顯示全部樓層
牛人啊  期待更多 精彩分享
ID:29947 發表于 2012-7-26 15:21 | 顯示全部樓層
提示: 作者被禁止或刪除 內容自動屏蔽
ID:42637 發表于 2012-7-26 20:51 | 顯示全部樓層
用hei51板上的ADC0804是為了量化漏泄濃度
MQ-5模塊有4個引腳,DOUT#就是你說的直接IO測,我也用到了。
而AOUT腳,就是量化濃度。
另外這個程序有漏洞,我已經作了完善處理。
[此貼子已經被作者于2012-7-26 20:55:59編輯過]
ID:61997 發表于 2014-7-6 15:11 | 顯示全部樓層
學習學習
ID:102765 發表于 2016-1-17 09:18 | 顯示全部樓層
MQ-4可不可以用這個
ID:106437 發表于 2016-2-26 15:13 | 顯示全部樓層
請問有沒有MQ5和單片機的連接電路圖啊
ID:106804 發表于 2016-3-1 11:25 | 顯示全部樓層
牛人啊,程序先收藏私,待我的單片機到貨了來驗證.
ID:119416 發表于 2016-5-9 01:57 | 顯示全部樓層
請問有沒有基于DM430-A ,MQ-5可燃氣體傳感器,lcd1602 顯示器的編程,求答,畢業論文用
ID:162555 發表于 2017-1-20 16:14 | 顯示全部樓層
傳感器接到單片機I/O口?怎么掃描?
ID:183779 發表于 2017-8-10 15:01 | 顯示全部樓層
程序都沒有注釋,看著費力不懂
主站蜘蛛池模板: 青青操国产 | 99精品欧美一区二区蜜桃免费 | 日本伊人久久 | 日韩精品中文字幕在线观看 | 日韩视频一区二区三区 | 日韩网站免费观看 | 免费一级全黄少妇性色生活片 | 国产日韩欧美亚洲 | 亚洲激情网 | 久久精品一区二区三区四区五区 | 亚洲深夜福利 | 欧美资源在线 | 欧美性猛交乱大交 | 天天看片天天爽 | 性生活视频网站 | 国产日本在线观看 | 久久久中文字幕 | 麻豆一区二区三区 | 黄色小视频免费 | 超碰成人在线观看 | 国产h片在线观看 | 亚洲伊人影院 | 成年免费视频黄网站在线观看 | 精品一区二区三区视频 | 不卡免费视频 | 成人午夜激情 | 日韩中文字幕第一页 | 一区二区三区网站 | 亚州av在线 | 国产精品国产精品国产专区不卡 | 一二三区视频 | 成人综合网站 | 国产中文在线观看 | 午夜影院免费观看 | 伦一理一级一a一片 | 国产一区福利 | 国产一区二区在线播放 | 午夜视频一区二区三区 | 国产高清在线视频 | 日韩精品视频免费播放 | 天天干夜夜拍 |
