查看: 3437|回復: 4
stm32控制兩相電機源程序
ID:530349 發(fā)表于 2019-5-8 10:54 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
這是我設(shè)計的stm32F103控制兩相電機程序
測試好用
附件有keil工程文件
  1. #include "Bsp.h"
  2. #include "stm32f10x.h"
  3. #include <stdio.h>
  4. #include <stdlib.h>
  5. #include <string.h>
  6. #ifdef __GNUC__
  7.   /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
  8.      set to 'Yes') calls __io_putchar() */
  9.   #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
  10. #else
  11.   #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
  12. #endif /* __GNUC__ */
  13. #define DEBUG        1
  14. char                        TestWord[USARTBUFLEN];
  15. char                        Cmd_buf[USARTBUFLEN];
  16. uint8_t                Cmd_LockFlag        =        0;
  17. uint8_t                ResetCmd_Flag        =        0;
  18. uint8_t                Cmd_FinishFlag=        0;
  19. #define         ACKSTR                "OK_\r\n"
  20. #define   NACKSTR                "BADCMD_\r\n"
  21. #define         BUSYSTR                "WAIT_\r\n"
  22. char                          startchar[USARTBUFLEN];
  23. const char CMD_LIST[8][PARASTRLEN]={"RESET","MOVE","STOP","POWER","SET","READ","ZERO"};        //允許的命令
  24. const        char HelpMsg[8][USARTBUFLEN]={{"Command List: MOVE STOP SET READ POWER ZERO;\r\n"},
  25.        {"MOVE:         e.g. :FF MOVE VERTICAL/HORIZONT CW/ANCW xxx.xx(0-360,sOLUTION: 0.01);\r\n"},
  26.        {"STOP:                e.g. :FF STOP VERTICAL/HORIZONT;\r\n"},
  27.        {"POWER:        e.g. :FF POWER VERTICAL/HORIZONT ON/OFF;\r\n"},
  28.        {"SET:                e.g. :FF SET VERTICAL/HORIZONT ;\r\n"},
  29.        {"READ:                e.g. :FF READ VERTICAL/HORIZONT;\r\n"},
  30.        {"ZERO:                e.g. :FF ZERO VERTICAL/HORIZONT;\r\n"},
  31.        {"RESET:        e.g. :FF RESET;\r\n"}};
  32. char                         CmdRespondStr[50];
  33. char                          para_list[CMDPARANUM][PARASTRLEN];        //保存命令中的參數(shù)
  34. SYSTEM_STA        Sys_Sta;
  35.
  36. void CMD_Analyse(const char *cmd,uint8_t        cmdlen);
  37. uint8_t str2float(const char *str,float *result);
  38. u8 Flag=0;                                      //指示輸出角度是否到達360度或-360,如果到了,講360置為0度
  39. /****************************************************************************
  40. * 名    稱:                                 main
  41. * 功    能:                 串口占用GPIO初始化
  42. * 入口參數(shù):
  43. * 出口參數(shù):
  44. * 說    明:
  45. * 調(diào)用方法:
  46. * 修改日志:
  47. ****************************************************************************/
  48. int  main(void)
  49. {
  50.         uint16_t                temp[4],temp1=0,HVTemp1;
  51.         uint16_t                data_tmp;
  52.         int32_t                        step_num        = 0;
  53.         uint32_t                devison_tmp,step_speed;
  54.         uint32_t                sendbytes=0;
  55.         const        char        *usart_sendaddr;
  56.         float                                angle_tmp,speed_tmp,limit_tmp;
  57.         uint8_t                        error;
  58.         uint8_t                 tmp                                          = 0;
  59.         uint8_t                        fault_try                        =        0;
  60.         STEPMOTOR_INDEX                ver_hor;
  61.         MOTIONDIR                                        cw_ncw;
  62.         uint8_t                                                cycle_cnt,char_num;;
  63.         Cmd_LockFlag                                                        =        0;
  64.         Bsp_Init();
  65.
  66. //         AT24CXX_Write(0,HelpMsg[0],strlen(HelpMsg[0]));
  67.         usart_sendaddr                                                =        CmdRespondStr;
  68.         cycle_cnt        =        0;
  69.         temp[0]        =        0;
  70.         ResetCmd_Flag                                                        =        0;
  71.         #ifdef DEBUG
  72.                 //打印識別信息
  73.                 char_num        = sprintf(startchar,"\r\n 134mm-Diameter Step-Motor Driver.\r\nCorp.AGGC,By LK,140\r\n");
  74.                 UsartDMASend(startchar,char_num);
  75.         #endif
  76.
  77.
  78.         //上電首先檢查振鏡位置是否超出允許
  79. /*
  80.         Delay_ms(5000);
  81.         if((RESET == GPIO_ReadInputDataBit(ANCW_LIMIT))|(RESET == GPIO_ReadInputDataBit(CW_LIMIT)))
  82.         {
  83.                 Hor_Info.motion_sta                        =        OutOfRange;
  84.
  85.                 if(RESET == GPIO_ReadInputDataBit(ANCW_LIMIT))
  86.                 {
  87.                         Hor_Info.motion_dir                =        Motion_CW;
  88.                         Hor_Info.dir_now                        = Hor_Info.dir_range_ancw;
  89.                 }
  90.                 else
  91.                 {
  92.                         Hor_Info.motion_dir                =        Motion_ANCW;
  93.                         Hor_Info.dir_now                        = Hor_Info.dir_range_cw;
  94.                 }
  95.         }
  96.
  97. */
  98.         while(1)
  99.         {
  100.         //程序運行指示燈
  101.                 cycle_cnt++;
  102.                 if(cycle_cnt > 1)
  103.                 {
  104.                         LEDToggle();
  105.                         cycle_cnt        =0;
  106.                 }
  107.
  108.                 //垂直電機位置超出允許范圍,嘗試反向轉(zhuǎn)動3次,失敗后,定義為振鏡異常
  109. /*
  110.                 if(OutOfRange == Hor_Info.motion_sta)
  111.                 {
  112.                         Delay_ms(1000);
  113.                         if((RESET == GPIO_ReadInputDataBit(ANCW_LIMIT))|(RESET == GPIO_ReadInputDataBit(CW_LIMIT)))
  114.                         {
  115.                                 //
  116.                                 if(fault_try<3)
  117.                                 {
  118.                                         if(Stop== Hor_Info.motor_sta)
  119.                                         {
  120.                                                 MOTOR_DISEN_HOR;
  121.                                                 Hor_Info.motor_sta                =        Move;
  122.                                                 Hor_Info.motor_fb                        =        FB_Enable;
  123.                                                 Move_Angles(Horizontal,Hor_Info.motion_dir,5);        //嘗試反向轉(zhuǎn)5度,離開限位開關(guān)位置
  124.                                                 MOTOR_START_HOR;
  125.                                                 fault_try++;
  126.                                         }
  127.                                 }
  128.                                 else
  129.                                 {
  130.                                         Hor_Info.motion_sta                        =        Fault;
  131.                                         MOTOR_EN_HOR;
  132.                                 }
  133.                         }
  134.                 }
  135.                 else
  136.                                 fault_try        =        0;
  137.
  138. */
  139.
  140.
  141.                 //收到一條命令
  142.                 if(1 == Cmd_FinishFlag)
  143.                 {
  144.                         Cmd_LockFlag                =0;                        //串口命令解鎖
  145.                         Cmd_FinishFlag        =0;
  146.                         CMD_Analyse(Cmd_buf+1,30);
  147.                         memset(Cmd_buf,0,USARTBUFLEN);  //USARTBUFLEN=100 串口命令最大長度
  148.                   //void *memset(void *s,int c,size_t n)  將已開辟內(nèi)存空間S的首個n字節(jié)的值設(shè)置為C
  149.                         sendbytes        =        sprintf(CmdRespondStr,NACKSTR);  //sprintf字符串格式化命令,主要將格式化的數(shù)據(jù)寫入字符串中
  150.                         if(0 == strncmp(para_list[0],"MOVE",sizeof("MOVE")))                        //電機運動命令,sizeof返回字節(jié)大小
  151.                         {                        //strncmp ( const char * str1, const char * str2, size_t n );str1,str2為需要比較的字符串,n為比較數(shù)量
  152.                                                        //str1第一個字符減去str2第一個字符,若差值為0,則繼續(xù)比較下一個字符
  153.                                 if(0 == strncmp(para_list[1],"VERTICAL",sizeof("VERTICAL")))
  154.                                         ver_hor                        =        Vertical; //垂直
  155.                                 else if(0 == strncmp(para_list[1],"HORIZONT",sizeof("HORIZONT")))
  156.                                         ver_hor                        =        Horizontal;  //水平
  157.                                 else
  158.                                         ver_hor                        = Unknow;
  159.
  160.                                 if(Unknow != ver_hor)
  161.                                 {
  162.                                         if(0 == str2float(para_list[2],&angle_tmp))
  163.                                         {
  164.                                                 float end_angle=0;
  165.                                                 end_angle= Motor_Info[ver_hor].angle_now+angle_tmp;
  166.                                                 //當前位置不能超過設(shè)定范圍
  167.                                                 if((end_angle >= -1*Motor_Info[ver_hor].limit_angle)&&(end_angle <= Motor_Info[ver_hor].limit_angle))
  168.                                                 {
  169.                                                         if(angle_tmp >0)
  170.                                                         {
  171.        cw_ncw                        = Motion_CW;  //步進電機方向
  172.                                                         }
  173.                                                         else if(angle_tmp <0)
  174.                                                         {
  175.        cw_ncw                        =        Motion_ANCW;
  176.        angle_tmp                *= -1;
  177.                                                         }
  178.                                                         else
  179.        cw_ncw                        =        Hold;
  180.                                                 }
  181.                                                 else if(end_angle < -1*Motor_Info[ver_hor].limit_angle)        //超過逆時針轉(zhuǎn)動范圍
  182.                                                 {
  183.        cw_ncw                        = Motion_ANCW;
  184.        angle_tmp                = Motor_Info[ver_hor].angle_now + Motor_Info[ver_hor].limit_angle;
  185.
  186.                                                 }
  187.                                                 else         if(end_angle > Motor_Info[ver_hor].limit_angle)        //超過順時針轉(zhuǎn)動范圍
  188.                                                 {
  189.        cw_ncw                        = Motion_CW;
  190.        angle_tmp                = Motor_Info[ver_hor].limit_angle - Motor_Info[ver_hor].angle_now;
  191.                                                 }
  192.                                                 else
  193.                                                         cw_ncw                        =        Hold;
  194.
  195.                                                         //電機停止狀態(tài)下,才能允許轉(zhuǎn)動
  196.                                                         if((Hold != cw_ncw)&&(Stop == Motor_Info[ver_hor].motor_sta))
  197.                                                         {
  198. //        Motor_Info[ver_hor].move_pulsenum        =(uint32_t)(angle_tmp*CODER_NUM);
  199.        Move_Angles(ver_hor,cw_ncw,angle_tmp);
  200.        sendbytes        =        sprintf(CmdRespondStr,ACKSTR);
  201.                                                         }
  202.                                                         else
  203.        sendbytes        =        sprintf(CmdRespondStr,BUSYSTR);
  204. //                                                 }
  205. //                                                 else
  206. //                                                         sendbytes        =        sprintf(CmdRespondStr,"AngleWrong_\r\n");
  207.
  208.                                         }
  209.                                 else sendbytes        =        sprintf(CmdRespondStr,NACKSTR);
  210.                                 }
  211.                         }
  212.                         else if(0 == strncmp(para_list[0],"CHECK",sizeof("CHECK")))        //查詢當前電機狀態(tài)(是否在轉(zhuǎn))
  213.                         {
  214.                                 if(0 == strncmp(para_list[1],"VERTICAL",sizeof("VERTICAL")))
  215.                                 {
  216.                                         ver_hor                        =        Vertical;
  217.                                 }
  218.                                 else if(0 == strncmp(para_list[1],"HORIZONT",sizeof("HORIZONT")))
  219.                                 {
  220.                                         ver_hor                        =        Horizontal;
  221.                                 }
  222.                                 else
  223.                                         ver_hor                        = Unknow;
  224.
  225.                                 if(Unknow != ver_hor)
  226.                                 {
  227.                                         if(Move == Motor_Info[ver_hor].motor_sta)
  228.                                                 sendbytes        =        sprintf(CmdRespondStr,"MOVE_\r\n");
  229.                                         else
  230.                                                 sendbytes        =        sprintf(CmdRespondStr,"HOLD_\r\n");
  231.                                 }
  232.                         }
  233.                         else if(0 == strncmp(para_list[0],"STATUS",sizeof("STATUS")))        //查詢當前電機狀態(tài)(是否在轉(zhuǎn))
  234.                         {
  235.                                 if(0 == strncmp(para_list[1],"VERTICAL",sizeof("VERTICAL")))
  236.                                 {
  237.                                         ver_hor                        =        Vertical;
  238.                                 }
  239.                                 else if(0 == strncmp(para_list[1],"HORIZONT",sizeof("HORIZONT")))
  240.                                 {
  241.                                         ver_hor                        =        Horizontal;
  242.                                 }
  243.                                 else
  244.                                         ver_hor                        = Unknow;
  245.
  246.                                 if(Unknow != ver_hor)
  247.                                 {
  248.                                         if(Stepslost == Motor_Info[ver_hor].motion_sta)
  249.                                                 sendbytes        =        sprintf(CmdRespondStr,"STEPSLOST_\r\n");
  250.                                         else if(OutOfRange == Motor_Info[ver_hor].motion_sta)
  251.                                                 sendbytes        =        sprintf(CmdRespondStr,"OVERRANGE_\r\n");
  252.                                         else if(Zero == Motor_Info[ver_hor].motion_sta)
  253.                                                 sendbytes        =        sprintf(CmdRespondStr,"ZERO_\r\n");
  254.                                         else if(Fault == Motor_Info[ver_hor].motion_sta)
  255.                                                 sendbytes        =        sprintf(CmdRespondStr,"FAULT_\r\n");
  256.                                         else
  257.                                                 sendbytes        =        sprintf(CmdRespondStr,"NORMAL_\r\n");
  258.                                 }
  259.                         }
  260.                         else if(0 == strncmp(para_list[0],"STOP",sizeof("STOP")))                //運動停止命令
  261.                         {
  262.                                 if(0 == strncmp(para_list[1],"VERTICAL",sizeof("VERTICAL")))
  263.                                         ver_hor                        =        Vertical;
  264.                                 else if(0 == strncmp(para_list[1],"HORIZONT",sizeof("HORIZONT")))
  265.                                         ver_hor                        =        Horizontal;
  266.                                 else
  267.                                         ver_hor                        = Unknow;
  268.
  269.                                 if(Unknow != ver_hor)
  270.                                 {
  271.                                         if(Vertical == ver_hor)
  272.                                         {
  273.                                                 Ver_Info.motor_sta                =        Stop;
  274.                                                 Ver_Info.motor_fb                        =        FB_Disable;
  275.                                                 MOTOR_STOP_VER;
  276.                                         }
  277.                                         else
  278.                                         {
  279.                                                 Hor_Info.motor_sta                =        Stop;
  280.                                                 Hor_Info.motor_fb                        =        FB_Disable;
  281.                                                 MOTOR_STOP_HOR;
  282.                                         }
  283.                                         sendbytes        =        sprintf(CmdRespondStr,ACKSTR);
  284.                                 }
  285.                         }
  286.                         else if(0 == strncmp(para_list[0],"SET",sizeof("SET")))                                                //參數(shù)設(shè)置命令
  287.                         {
  288.                                 if(0 == strncmp(para_list[1],"VERTICAL",sizeof("VERTICAL")))
  289.                                         ver_hor                        =        Vertical;
  290.                                 else if(0 == strncmp(para_list[1],"HORIZONT",sizeof("HORIZONT")))
  291.                                         ver_hor                        =        Horizontal;
  292.                                 else
  293.                                         ver_hor                        = Unknow;
  294.
  295.                                 //電機停止時,允許進行參數(shù)設(shè)定
  296.                                 if(Stop == Motor_Info[ver_hor].motor_sta)
  297.                                 {
  298.                                         if(Unknow != ver_hor)
  299.                                         {
  300.                                                 if(0 == strncmp(para_list[2],"DEVISION",sizeof("DEVISION")))        //設(shè)置細分比例
  301.                                                 {
  302.                                                         devison_tmp        =        atoi(para_list[3]);
  303.                                                         if((devide_1 == devison_tmp)|(devide_2 == devison_tmp)|(devide_8 == devison_tmp)|(devide_16 == devison_tmp))
  304.                                                         {
  305.        if(Vertical == ver_hor)
  306.        {
  307.        Ver_Info.subdevision                =        (DEVISIONVALUE)devison_tmp;
  308.        Ver_Info.step_resolution=        MOTOR_RESOLUTION/(RATIO_GEAR*devison_tmp);
  309.        Ver_Info.step_speed        =        360.0f*Ver_Info.speed/(60.0f*Ver_Info.step_resolution);
  310.        SPEEDSET_VER(1000000/Ver_Info.step_speed);
  311.        Ver_Info.dir_range_cw                        =        (int32_t)RATIO_GEAR*Ver_Info.subdevision*180/MOTOR_RESOLUTION;        //順時針電機方位角范圍
  312.        Ver_Info.dir_range_ancw                =        -1*(int32_t)RATIO_GEAR*Ver_Info.subdevision*180/MOTOR_RESOLUTION;        //逆時針電機方位角范圍
  313.        //更新EEPROM中保存的參數(shù)
  314.        UPDATE_DEVISIONH_VER;
  315.        UPDATE_STEPRE_VER;
  316.        UPDATE_SPEED_VER;
  317.        UPDATE_DIRRANGE_VER;
  318.        }
  319.        else if(Horizontal == ver_hor)
  320.        {
  321.        Hor_Info.subdevision                =(DEVISIONVALUE)devison_tmp;
  322.        Hor_Info.step_resolution=        MOTOR_RESOLUTION/(RATIO_GEAR*devison_tmp);
  323.        Hor_Info.step_speed        =        360.0f*Hor_Info.speed/(60.0f*Hor_Info.step_resolution);
  324.        SPEEDSET_HOR(1000000/Hor_Info.step_speed);
  325.        Hor_Info.dir_range_cw                        =        (int32_t)RATIO_GEAR*Hor_Info.subdevision*360/MOTOR_RESOLUTION;        //順時針電機方位角范圍
  326.                         Hor_Info.dir_range_ancw                =        -1*(int32_t)RATIO_GEAR*Hor_Info.subdevision*360/MOTOR_RESOLUTION;        //逆時針電機方位角范圍
  327.        AT24CXX_Write(HORINFO_ADDR,(const uint8_t *)&Hor_Info,sizeof(MOTORINFO));
  328.        //更新EEPROM中保存的參數(shù)
  329.        UPDATE_DEVISIONH_HOR;
  330.        UPDATE_STEPRE_HOR;
  331.        UPDATE_SPEED_HOR;
  332.        UPDATE_DIRRANGE_HOR;
  333.        }
  334.        sendbytes        =        sprintf(CmdRespondStr,ACKSTR);
  335.                                                         }
  336.                                                 }
  337.                                                 else if(0 == strncmp(para_list[2],"LOCATION",sizeof("LOCATION")))        //設(shè)置當前位置對應(yīng)角度,手動歸零時使用該命令
  338.                                                 {
  339.                                                         if(0 == str2float(para_list[3],&angle_tmp))
  340.                                                         {
  341.        if((angle_tmp >= -185)&&(angle_tmp <= 185))
  342.        {
  343.        if(Vertical == ver_hor)
  344.        {
  345.        Ver_Info.angle_now                =        angle_tmp;
  346.        Ver_Info.dir_now                        =        angle_tmp/360.0f*Ver_Info.dir_range_cw*2;
  347.        //更新EEPROM中保存的參數(shù)
  348.        UPDATE_ANGEL_VER;
  349.        UPDATE_DIRNOW_VER;
  350.        }
  351.        else if(Horizontal == ver_hor)
  352.        {
  353.        Hor_Info.angle_now                =        angle_tmp;
  354.        Hor_Info.dir_now                        =        angle_tmp/360.0f*Hor_Info.dir_range_cw*2;
  355.        //更新EEPROM中保存的參數(shù)
  356.        UPDATE_ANGEL_HOR;
  357.        UPDATE_DIRNOW_HOR;
  358.        }
  359.        sendbytes        =        sprintf(CmdRespondStr,ACKSTR);
  360.        }
  361.                                                         }
  362.                                                 }
  363.                                                 else if(0 == strncmp(para_list[2],"SPEED",sizeof("SPEED")))        //設(shè)置轉(zhuǎn)動速度
  364.                                                 {
  365.                                                         speed_tmp        = atof(para_list[3]);
  366.                                                         if((speed_tmp > 0)&&(speed_tmp <= 2000))                //分鐘轉(zhuǎn)速小于2000r/min
  367.                                                         {
  368.        if(Vertical == ver_hor)
  369.        {
  370.        Ver_Info.speed                        =        speed_tmp;
  371.        Ver_Info.step_speed        =        360.0f*Ver_Info.speed/(60.0f*Ver_Info.step_resolution);
  372.        SPEEDSET_VER(1000000/Ver_Info.step_speed);
  373.        //更新EEPROM中保存的參數(shù)
  374.        UPDATE_SPEED_VER;
  375.        UPDATE_SPEEDSTEPS_VER;
  376. //        AT24CXX_Write(VERINFO_ADDR,(const uint8_t *)&Ver_Info,sizeof(MOTORINFO));
  377.        }
  378.        else if(Horizontal == ver_hor)
  379.        {
  380.        Hor_Info.speed                        =        speed_tmp;
  381.        Hor_Info.step_speed        =        360.0f*Hor_Info.speed/(60.0f*Hor_Info.step_resolution);
  382.        SPEEDSET_HOR(1000000/Hor_Info.step_speed);
  383.         //        AT24CXX_Write(HORINFO_ADDR,(const uint8_t *)&Hor_Info,sizeof(MOTORINFO));
  384.        //更新EEPROM中保存的參數(shù)
  385.        UPDATE_SPEED_HOR;
  386.        UPDATE_SPEEDSTEPS_HOR;
  387.        }
  388.        sendbytes        =        sprintf(CmdRespondStr,ACKSTR);
  389.                                                         }
  390.                                                 }
  391.                                                 else if(0 == strncmp(para_list[2],"LIMIT",sizeof("LIMIT")))        //設(shè)置轉(zhuǎn)動范圍
  392.                                                 {
  393.                                                         if(0 == str2float(para_list[3],&limit_tmp))
  394.                                                         {
  395.        if((limit_tmp > 0)&&(limit_tmp <= 361))
  396.        {
  397.        Motor_Info[ver_hor].limit_angle                                =        limit_tmp;
  398.        if(Vertical == ver_hor)
  399.        UPDATE_LIMITANGEL_VER;
  400.        else
  401.        UPDATE_LIMITANGEL_HOR;
  402.
  403.        sendbytes        =        sprintf(CmdRespondStr,ACKSTR);
  404.        }
  405.                                                         }
  406.                                                 }
  407.                                         }
  408.                                 }
  409.                                 else
  410.                                                 sendbytes        =        sprintf(CmdRespondStr,BUSYSTR);
  411.                         }
  412.                         else if(0 == strncmp(para_list[0],"READ",sizeof("READ")))                                //讀取細分參數(shù)命令
  413.                         {
  414.                                 if(0 == strncmp(para_list[1],"VERTICAL",sizeof("VERTICAL")))
  415.                                         ver_hor                        =        Vertical;
  416.                                 else if(0 == strncmp(para_list[1],"HORIZONT",sizeof("HORIZONT")))
  417.                                         ver_hor                        =        Horizontal;
  418.                                 else
  419.                                         ver_hor                        = Unknow;
  420.
  421.                                 if(Unknow != ver_hor)
  422.                                 {
  423.                                         if(0 == strncmp(para_list[2],"DEVISION",sizeof("DEVISION")))        //讀取細分比例
  424.                                         {
  425.                                                 if(Vertical == ver_hor)
  426.                                                         sendbytes        =        sprintf(CmdRespondStr,"Vertical_Devision_%d_\r\n",Ver_Info.subdevision);
  427.                                                 else if(Horizontal == ver_hor)
  428.                                                         sendbytes        =        sprintf(CmdRespondStr,"Horizontal_Devision_%d_\r\n",Hor_Info.subdevision);
  429.                                         }
  430.                                         else if(0 == strncmp(para_list[2],"LOCATION",sizeof("LOCATION")))        //讀取當前位置對應(yīng)角度
  431.                                         {
  432.                                                 if(Vertical == ver_hor)
  433.                                                         sendbytes        =        sprintf(CmdRespondStr,"%.2f_\r\n",Ver_Info.angle_now);
  434.                                                 else if(Horizontal == ver_hor)
  435.                                                         sendbytes        =        sprintf(CmdRespondStr,"%.2f_\r\n",Hor_Info.angle_now);
  436.                                         }
  437.                                         else if(0 == strncmp(para_list[2],"SPEED",sizeof("SPEED")))        //讀取當前位置對應(yīng)步進速度
  438.                                         {
  439.                                                 if(Vertical == ver_hor)
  440.                                                         sendbytes        =        sprintf(CmdRespondStr,"%.2d_\r\n",Ver_Info.step_speed);
  441.                                                 else if(Horizontal == ver_hor)
  442.                                                         sendbytes        =        sprintf(CmdRespondStr,"%.2d_\r\n",Hor_Info.step_speed);
  443.                                         }
  444.                                         else if(0 == strncmp(para_list[2],"LIMIT",sizeof("LIMIT")))        //設(shè)置轉(zhuǎn)動范圍
  445.                                         {
  446.                                                 if(Vertical == ver_hor)
  447.                                                         sendbytes        =        sprintf(CmdRespondStr,"%.1f_\r\n",Ver_Info.limit_angle);
  448.                                                 else if(Horizontal == ver_hor)
  449.                                                         sendbytes        =        sprintf(CmdRespondStr,"%.1f_\r\n",Hor_Info.limit_angle);
  450.                                         }
  451.                                 }
  452.                         }
  453.                         else if(0 == strncmp(para_list[0],"ZERO",sizeof("ZERO")))                //角度歸零,待完善
  454.                         {
  455.                                 if(0 == strncmp(para_list[1],"VERTICAL",sizeof("VERTICAL")))
  456.                                         ver_hor                        =        Vertical;
  457.                                 else if(0 == strncmp(para_list[1],"HORIZONT",sizeof("HORIZONT")))
  458.                                         ver_hor                        =        Horizontal;
  459.                                 else
  460.                                         ver_hor                        = Unknow;
  461.
  462.                                 if(Unknow != ver_hor)
  463.                                 {
  464.                                         ZeroMotor(ver_hor);
  465.                                         sendbytes        =        sprintf(CmdRespondStr,ACKSTR);
  466.                                 }
  467.                         }
  468.                         else if(0 == strncmp(para_list[0],"HELP",sizeof("HELP")))                //命令使用信息查詢
  469.                         {
  470.                                 usart_sendaddr                =HelpMsg[0];
  471.                                 sendbytes                                        =strlen(HelpMsg[0]);
  472.                         }
  473.                         else if(0 == strncmp(para_list[0],"RESET",sizeof("RESET")))                        //系統(tǒng)復位命令
  474.                         {
  475.                                 //復位前,停止電機轉(zhuǎn)動
  476.                                 MOTOR_STOP_HOR;
  477.                                 MOTOR_STOP_VER;
  478.                                 Sys_Soft_Reset();
  479.                         }
  480.                         else
  481.                                 sendbytes        =        sprintf(CmdRespondStr,NACKSTR);
  482.
  483.                         for(tmp=0;tmp<CMDPARANUM;tmp++)
  484.                                 memset(para_list[tmp],0,PARASTRLEN);
  485.                 }
  486.
  487.                 //DMA空閑時,將數(shù)據(jù)發(fā)送出去
  488.                 if((0 == DMA_GetCurrDataCounter(PC_DMA_CHANNEL))&&(sendbytes > 0))
  489.                 {
  490.                         UsartDMASend(usart_sendaddr,sendbytes);
  491.                         usart_sendaddr                                                =        CmdRespondStr;
  492.                         sendbytes                =0;
  493.                 }
  494.                 //將方位更新到角度,并判斷是否超過設(shè)定范圍
  495.                 Ver_Info.angle_now        =        (float)Ver_Info.dir_now*Hor_Info.step_resolution;
  496.                 Hor_Info.angle_now        =        (float)Hor_Info.dir_now*Hor_Info.step_resolution;      //當前的角度為實際脈沖數(shù)計算得到,angle_now=360*dir_now/(2*200*140)      (細分比率*200*次輪比)
  497.                 UPDATE_ANGEL_HOR;
  498.                 UPDATE_DIRNOW_HOR;
  499.
  500.                 UPDATE_ANGEL_VER;
  501.                 UPDATE_DIRNOW_VER;
  502.                 WG_Feed();
  503.
  504.         }
  505. }
  506. /****************************************************************************
  507. * 名    稱: str2float()
  508. * 功    能:收到的角度是否合法
  509. * 入口參數(shù):
  510. * 出口參數(shù):
  511. * 說    明:
  512. * 調(diào)用方法:
  513. * 修改日志:
  514. ****************************************************************************/
  515. uint8_t str2float(const char *str,float *result)
  516. {
  517.         uint8_t        charcnt;
  518.         volatile uint8_t        isok=1;
  519.         uint8_t        paracnt                        =0;
  520.         uint8_t        paracharcnt        =0;
  521.         uint8_t        point_flag        =0;
  522.         uint8_t        num_flag                =0;
  523.         uint8_t        sym_flag                =0;
  524.         uint8_t        sym_loc                        =0;
  525.         for(charcnt=0;charcnt<PARASTRLEN;charcnt++)
  526.         {
  527.                 if(('-' == *(str+charcnt))|('-' == *(str+charcnt)))
  528.                 {
  529.                         sym_flag        = charcnt+1;
  530.                         if(sym_flag>1)
  531.                                 break;        //符號位超過一個
  532.                 }
  533. ……………………
  534. …………限于本文篇幅 余下代碼請從51黑下載附件…………
StepMotor_LV4(134口徑振鏡源代碼).7z (180.66 KB, 下載次數(shù): 32)
收藏收藏2 分享淘帖 頂 踩
ID:530349 發(fā)表于 2019-5-8 13:35 | 只看該作者
不錯不錯喲
ID:1 發(fā)表于 2019-5-8 20:51 | 只看該作者
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
ID:777142 發(fā)表于 2020-12-31 10:06 | 只看該作者
目前在了解這個,感謝樓主的分享
ID:597820 發(fā)表于 2021-1-1 20:17 | 只看該作者
不錯不錯,感謝樓主的分享!
主站蜘蛛池模板: 久久精品视频免费 | 99热免费 | av观看网站 | 日韩欧美一区二区在线观看 | 色婷婷国产 | 四虎黄色片 | 国产日韩欧美在线 | 毛片毛片毛片 | 成人黄色在线视频 | 成人黄色一级片 | 国产强伦人妻毛片 | 亚洲超碰在线 | 成年人黄色 | 日韩免费在线观看视频 | 亚洲综合另类 | 夜夜欢视频 | 日本国产视频 | 国产午夜精品一区二区三区视频 | 久久久久久久久国产精品 | 三级黄色片网站 | 国产精品福利视频 | 日韩香蕉视频 | 日韩视频二区 | 久久视频免费观看 | 中文字幕影院 | 成人在线视频观看 | 日本久久精品视频 | 久久国产美女 | 四虎永久在线 | 婷婷激情综合网 | 亚洲精品一二三四 | 国产网站免费 | 性生活毛片 | 99久久国产视频 | 日本一级黄色 | 自拍视频一区 | 亚洲综合五月天婷婷丁香 | 五月av | 欧美手机在线 | 亚洲最大黄色 | 96看片|
