查看: 8531|回復: 4
基于51單片機和Proteus仿真的簡易電子琴程序
ID:517871 發表于 2019-5-9 17:14 | 顯示全部樓層 |閱讀模式
  1. #include<AT89X52.h>
  2. #define KeyPort P1
  3. unsigned char High,Low; //定時器預裝值的高8位和低8位
  4. sbit SPK=P3^7;          //定義蜂鳴器接口
  5. sbit playSongKey=P0^0;          //功能鍵
  6. sbit RS=P2^0;//液晶數據命令選擇
  7. sbit RW=P2^1;//液晶讀寫選擇
  8. sbit EN=P2^2;//液晶使能端
  9. unsigned char code freq[][2]={
  10.   0xD8,0xF7,//00440HZ 1
  11.   0xBD,0xF8,//00494HZ 2
  12.   0x87,0xF9,//00554HZ 3
  13.   0xE4,0xF9,//00587HZ 4
  14.   0x90,0xFA,//00659HZ 5
  15.   0x29,0xFB,//00740HZ 6
  16.   0xB1,0xFB,//00831HZ 7
  17.   0xEF,0xFB,//00880HZ `1
  18. };
  19. unsigned char Time;
  20. unsigned char code YINFU[9][1]={{' '},{'1'},{'2'},{'3'},{'4'},{'5'},{'6'},{'7'},{'8'}};
  21.                           //世上只有媽媽好數據表
  22. unsigned char code MUSIC[]={ 6,2,3,      5,2,1,      3,2,2,    5,2,2,    1,3,2,    6,2,1,    5,2,1,
  23.                      6,2,4,      3,2,2,      5,2,1,    6,2,1,           5,2,2,         3,2,2,           1,2,1,
  24.                      6,1,1,      5,2,1,      3,2,1,         2,2,4,           2,2,3,         3,2,1,    5,2,2,
  25.                      5,2,1,      6,2,1,      3,2,2,         2,2,2,    1,2,4,         5,2,3,           3,2,1,
  26.                      2,2,1,      1,2,1,      6,1,1,         1,2,1,           5,1,6,         0,0,0
  27.                                       };
  28.                          // 音階頻率表 高八位
  29. unsigned char code FREQH[]={
  30.                          0xF2,0xF3,0xF5,0xF5,0xF6,0xF7,0xF8,
  31.                          0xF9,0xF9,0xFA,0xFA,0xFB,0xFB,0xFC,0xFC, //1,2,3,4,5,6,7,8,i
  32.                          0xFC,0xFD,0xFD,0xFD,0xFD,0xFE,
  33.                          0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFF,
  34.                                } ;
  35.                          // 音階頻率表 低八位
  36. unsigned char code FREQL[]={
  37.                          0x42,0xC1,0x17,0xB6,0xD0,0xD1,0xB6,
  38.                          0x21,0xE1,0x8C,0xD8,0x68,0xE9,0x5B,0x8F, //1,2,3,4,5,6,7,8,i
  39.                          0xEE,0x44, 0x6B,0xB4,0xF4,0x2D,
  40.                          0x47,0x77,0xA2,0xB6,0xDA,0xFA,0x16,
  41.                                 };
  42. void Init_Timer0(void);//定時器初始化
  43. //延時函數大約約2*z+5us
  44. void delay2xus(unsigned char z)
  45. {
  46.    while(z--);
  47. }
  48. // 延時函數大約約1ms
  49. void delayms(unsigned char x)
  50. {
  51.    while(x--)
  52.    {
  53.      delay2xus(245);
  54.      delay2xus(245);
  55.    }
  56. }
  57. /*------------------------------------------------
  58.                 節拍延時函數
  59. 各調1/4節拍時間:
  60. 調4/4  125ms
  61. 調2/4  250ms
  62. 調3/4  187ms
  63. ------------------------------------------------*/
  64. void delayTips(unsigned char t)
  65. {
  66.     unsigned char i;
  67.           for(i=0;i<t;i++)
  68.     {
  69.             delayms(250);
  70.     }
  71.     TR0=0;
  72. }
  73. //播放音樂的函數
  74. void PlaySong()
  75. {
  76.    TH0=High;//賦值定時器時間,決定頻率
  77.    TL0=Low;
  78.    TR0=1;      //打開定時器
  79.    delayTips(Time); //延時所需要的節拍
  80. }
  81. //定時器T0初始化子程序
  82. void Init_Timer0(void)
  83. {
  84. TMOD |= 0x01;          //使用模式1,16位定時器,使用"|"符號可以在使用多個定時器時不受影響
  85. EA=1;            //總中斷打開
  86. ET0=1;           //定時器中斷打開
  87. }
  88. //定時器T0中斷子程序
  89. void Timer0_isr(void) interrupt 1
  90. {
  91. TH0=High;
  92. TL0=Low;
  93. SPK=!SPK;
  94. }
  95. //主函數
  96. void main (void)
  97. {
  98.   unsigned char num,k,i;
  99.   Init_Timer0();    //初始化定時器0,主要用于數碼管動態掃描
  100.   SPK=0;                        //在未按鍵時,喇叭低電平,防止長期高電平損壞喇叭
  101.   while (1)
  102.   {
  103.    switch(KeyPort)          //對按鍵進行處理
  104.                 {
  105.                  case 0xfe:num= 1;break;
  106.                  case 0xfd:num= 2;break;
  107.                  case 0xfb:num= 3;break;
  108.                  case 0xf7:num= 4;break;
  109.                  case 0xef:num= 5;break;
  110.                  case 0xdf:num= 6;break;
  111.                  case 0xbf:num= 7;break;
  112.                  case 0x7f:num= 8;break;      //分別對應不用的音調
  113.                  default:num= 0;break;
  114.                 }
  115.     P2 = KeyPort;
  116.     if(num==0)
  117.     {
  118.        TR0=0;
  119.        SPK=0;   //在未按鍵時,喇叭低電平,防止長期高電平損壞喇叭
  120.           }
  121.     else
  122.     {
  123.             High=freq[num-1][1];
  124.                    Low =freq[num-1][0];
  125.                   TR0=1;
  126.           }
  127.    if(playSongKey==0)        //如果播放音樂按鍵被按下
  128.    {
  129.      delayms(10);
  130.      if(playSongKey==0)
  131.      {
  132.        i=0;
  133.        while(i<100)
  134.             {
  135.             k=MUSIC[i]+7*MUSIC[i+1]-1;//去音符振蕩頻率所需數據
  136.             High=FREQH[k];
  137.             Low=FREQL[k];
  138.             Time=MUSIC[i+2];          //節拍時長
  139.             i=i+3;
  140.                         if(P1!=0xff)//長按任意8音鍵退出播放
  141.                         {
  142.                delayms(10);
  143.                if(P1!=0xff)
  144.                                  i=101;
  145.                         }
  146.             PlaySong();
  147.             }
  148.                    TR0=0;
  149.      }
  150.    }
  151.   }
  152. }
全部資料51hei下載地址:
基于51單片機和Proteus仿真的簡易電子琴.zip (57.99 KB, 下載次數: 133)
ID:773414 發表于 2020-6-9 11:07 | 顯示全部樓層
問一下我按你這個弄完后  右邊的二極管不亮是啥原因啊
ID:766245 發表于 2020-6-10 09:53 | 顯示全部樓層
小白白123 發表于 2020-6-9 11:07
你現在解決好了嘛
ID:851129 發表于 2020-12-19 14:04 來自觸屏版 | 顯示全部樓層
可以試著重新進一下hex文件
ID:942059 發表于 2021-6-22 09:43 來自觸屏版 | 顯示全部樓層
仁仁仙 發表于 2020-6-10 09:53
你現在解決好了嘛
我也想問,我這也不亮
主站蜘蛛池模板: www.毛片.com | 日韩在线精品视频 | 国产欧美视频在线观看 | 99一区二区| 夜夜嗨av一区二区三区网页 | 日韩欧美不卡 | 丁香婷婷色| 国产区在线视频 | 亚洲欧美日韩色图 | 欧美日韩成人在线 | 日本一区二区不卡视频 | 日日摸天天添天天添破 | 久久久青青 | 三级黄色在线观看 | 羞羞在线| 色午夜| 国内精品在线播放 | 日本中文字幕网站 | 免费黄色网址在线观看 | 欧美视频在线观看 | 国产日本在线观看 | 欧美成人极品 | 18成人免费观看网站 | 日韩国产一区二区三区 | 久草视频免费在线观看 | www久久久久 | 96久久| 国产激情一区二区三区 | 全部免费毛片在线播放高潮 | 一区二区在线视频 | 中文字幕欧美激情 | 欧美日韩| 国产福利在线视频 | 色一情一乱一伦一区二区三区 | 国产欧美日韩在线视频 | 欧美一级淫片bbb一84 | 精品亚洲国产成人av制服丝袜 | 少妇综合 | 黄色小视频免费看 | 欧美性视频在线 | 欧美日韩视频在线 |
