查看: 4999|回復: 2
基于51單片機和Proteus仿真的自動打鈴器
#include <AT89X52.h>
#include <stdio.h>
bit bclassFlg = 0;
sbit FMQ = P3 ^ 7;
unsigned char stringtemp[10]="";
struct time
        unsigned char        second;
        unsigned char        minute;
        unsigned char        hour;
        unsigned char        day;
        unsigned char        weekday;
        unsigned char        month;
        unsigned int        year;
} time;
sbit tim_sda=P2^6;
sbit tim_scl=P2^7;
sbit        lcd16rs        =        P2^0;
sbit        lcd16rw        =        P2^1;
sbit        lcd16en        =        P2^2;
unsigned char        lcd16_1[16];
unsigned char        lcd16_2[16] = {"welcome"};
bit         tim_ack;                // i2c slave ack.
bit         tim_err;
unsigned char tim_rd_buffer[16];
unsigned char tim_wr_buffer[16];
/*****************11us延時函數*************************/
void delay11us(unsigned char t)
  for (;t>0;t--);
void delay(unsigned int x)
        unsigned int a,b;
        for(a=x;a>5;a--);
                for(b=10;b>0;b--);
//寫指令
void write_com(unsigned char com)
        P1=com;// 將指令值寫到數據線上
        lcd16rs=0;//寫指令
        lcd16en=0;//給一個LCD 使能脈沖
        delay(10);
        lcd16en=1;
        delay(10);
        lcd16en=0;
//寫數據
void write_date(unsigned char date)
        P1=date;    //將數據寫到數據線上
        lcd16rs=1;    //寫數據
        lcd16en=0;    //給一個LCD 使能脈沖
        delay(10);
        lcd16en=1;
        delay(10);
        lcd16en=0;
//初始化LCD
void lcd_init()
        lcd16rw = 0;
        write_com(0x38);//顯示模式設置
        delay(20);
        write_com(0x0f);//開顯示,顯示光標、光標閃爍
        delay(20);
        write_com(0x06);//光標和顯示指針加一,屏幕不移動
        delay(20);
        write_com(0x01);//清顯示屏
        delay(20);
//在第N行顯示第M個字
void lcd16_n_line_n_byte(unsigned char n_line,unsigned char n_byte)
        unsigned char j;
        unsigned char com;
        unsigned char *dat1;
        unsigned char *dat2;
        dat1 = lcd16_1;
        dat2 = lcd16_2;
        if(n_line==0)                                   //顯示第一行。
                for(j=0;j<n_byte;j++)
                        com = 0x80+j;
                        write_com(com);
                        write_date(*dat1);
                        dat1++;
        if(n_line==1)                           //顯示第二行。
                        com = 0xc0+j;
                        write_com(com);
                        write_date(*dat2);
                        dat2++;
// i2c start.
void PCF8563_start()        //start flag is when tim_scl 1, tim_sdafrom 1 to 0.
        tim_sda = 1;
        delay11us(1);
        tim_scl = 1;
        delay11us(1);
        tim_sda = 0;
        delay11us(1);
// i2c stop.
void PCF8563_stop()                         //start flag is when tim_scl 1, tim_sdafrom 0 to 1.
        tim_sda = 0;
        delay11us(1);
        tim_scl = 1;
        delay11us(1);
        tim_sda = 0;
//i2c slave respons.
void PCF8563_respons()
        unsigned char i;
        tim_scl = 1;
        delay11us(1);
        while((tim_sda)&&(i<250))  i++;
        if(!tim_sda)
                tim_ack = 1;
                tim_ack = 0;
        tim_scl = 0;
        delay11us(1);
// i2c master respons.
void PCF8563_master_respons(bit master_ack)
        tim_scl = 0;
        delay11us(1);
        tim_sda = ~master_ack;
        delay11us(1);
        tim_scl = 1;
        delay11us(1);
        tim_scl = 0;
        delay11us(1);
//i2c init.
void PCF8563_init()
        tim_sda = 1;
        delay11us(1);
        tim_scl = 1;
        delay11us(1);
// i2c write n byte.
void PCF8563_wr_byte(unsigned char dat)
        unsigned char i , temp;
        temp = dat;
        for(i=0;i<8;i++)
                tim_scl = 0;
                delay11us(1);
                if(temp&0x80)
                        tim_sda = 1;
                        tim_sda = 0;
                temp = temp<<1;
                delay11us(1);
                tim_scl = 1;
                delay11us(1);
        tim_scl = 0;
        delay11us(1);
        tim_sda = 1;
        delay11us(1);
unsigned char PCF8563_rd_byte()
        unsigned char i,k;
        tim_scl = 0;
        delay11us(1);
        tim_sda = 1;
        delay11us(1);
        for(i=0;i<8;i++)
                tim_scl = 1;
                delay11us(1);
                k = (k<<1)|tim_sda;
                tim_scl = 0;
                delay11us(1);
        return k;
void PCF8563_write_n_byte(unsigned char add,unsigned char com,unsigned char *dat,unsigned char n_byte)   //
        unsigned char i = 0;
        unsigned char temp;
        temp = *dat;                                  // send to begin address to 'temp'.
        add = add<<1;
        add = 0xa0+add+0x00;
        PCF8563_start();
        PCF8563_wr_byte(add);                 //send EEPROM address, bit 0 = 0 is write.
        PCF8563_respons();
        if(!tim_ack)                                //if i2c respons.
                tim_err = 1;
                return;
        PCF8563_wr_byte(com);                        //send EEPROM beginning address.
        PCF8563_respons();
                tim_err = 1;
                return;
        while(n_byte)                           //write n byte.
                PCF8563_wr_byte(temp);
                PCF8563_respons();
                if(!tim_ack)
                        tim_err = 1;
                        PCF8563_stop();
                        return;
                temp++;
                n_byte--;
        PCF8563_stop();
void PCF8563_read_n_byte(unsigned char add,unsigned char com,unsigned char n_byte)
        unsigned char *temp;
        temp = tim_rd_buffer;
        add = add<<1;
        PCF8563_start();
        PCF8563_wr_byte(add);                                 //send address + wr.
        PCF8563_respons();
        PCF8563_wr_byte(com);                                // first byte address.
        PCF8563_respons();
        add = add+0x01;
        PCF8563_start();
        PCF8563_wr_byte(add);                           //send address + rd.
        PCF8563_respons();
        while(n_byte)                                   // rd n byte .
                *temp = PCF8563_rd_byte();
                if(n_byte != 1)                                //if i2c respons.
                        PCF8563_master_respons(1);        //if the number is not the last one, master send a ack bit.
                temp++;
                n_byte--;
        PCF8563_stop();
void PCF8563_wr_time()
        tim_wr_buffer[0] = 0x00;        //second
        tim_wr_buffer[1] = 0x11;        //minute
        tim_wr_buffer[2] = 0x22;        //hour
        tim_wr_buffer[3] = 0x15;        //day
        tim_wr_buffer[4] = 0x03;        //weekday
        tim_wr_buffer[5] = 0x06;        //month
        tim_wr_buffer[6] = 0x10;        //year
        PCF8563_write_n_byte(1,2,tim_wr_buffer,8);
//延時眼熟
void DelayFM(unsigned int x)
        unsigned char t;
        while(x--)
                 for(t=0;t<120;t++);
//蜂鳴器驅動函數,參數為發聲聲調
void FM(unsigned char x)
        unsigned char i;
        for(i=0;i<100;i++)
                 FMQ = ~FMQ;
                DelayFM(x);
        FMQ = 0;
void PCF8563_rd_time()
        unsigned char        temp;
        PCF8563_read_n_byte(1,2,9);
        time.second = ((tim_rd_buffer[1]&0x70)>>4)*10 + (tim_rd_buffer[1]&0x0f);        //second
        time.minute = ((tim_rd_buffer[2]&0x70)>>4)*10 + (tim_rd_buffer[2]&0x0f);        //minute
        time.hour = ((tim_rd_buffer[3]&0x30)>>4)*10 + (tim_rd_buffer[3]&0x0f);                //hour
        time.day = ((tim_rd_buffer[4]&0x30)>>4)*10 + (tim_rd_buffer[4]&0x0f);                //day
        time.weekday = tim_rd_buffer[5]&0x07;        //weekday
        time.month = ((tim_rd_buffer[6]&0x10)>>4)*10 + (tim_rd_buffer[6]&0x0f);                //month
  if(time.second == 0)
    if(bclassFlg == 0 )
      sprintf(stringtemp,"%x%x",time.hour,time.minute);
//      printf("%s\n",stringtemp);
      printf("it's time to have class\n"); //上課
      bclassFlg = 1;
      FM(3);
  else if(time.second == 45) //如果到了45分鐘,開始下課鈴
    if(bclassFlg == 1)
      printf("it's time to finish class\n");
      bclassFlg = 0;
      FM(7);
        temp = (tim_rd_buffer[4]&0x80)>>7;
        time.year = (temp+20)*100+((tim_rd_buffer[7]&0x70)>>4)*10 + (tim_rd_buffer[7]&0x0f);           //year
                lcd16_1[0] = time.hour/10+0x30;          //hour
                lcd16_1[1] = time.hour%10+0x30;
                lcd16_1[2] = '-';
                lcd16_1[3] = time.minute/10+0x30;          //minute
                lcd16_1[4] = time.minute%10+0x30;
                lcd16_1[5] = '-';
                lcd16_1[6] = time.second/10+0x30;          //second
                lcd16_1[7] = time.second%10+0x30;
                lcd16_2[0] = time.year/1000+0x30;          //year
                lcd16_2[1] = (time.year%1000)/100+0x30;
                lcd16_2[2] = (time.year%100)/10+0x30;
                lcd16_2[3] = time.year%10+0x30;
                lcd16_2[4] = '-';
                lcd16_2[5] = time.month/10+0x30;  //mon
                lcd16_2[6] = time.month%10+0x30;
                lcd16_2[7] = '-';
                lcd16_2[8] = time.day/10+0x30;          //day
                lcd16_2[9] = time.day%10+0x30;
                lcd16_2[10] = 'w';
                lcd16_2[11] = 'e';
                lcd16_2[12] = 'e';
                lcd16_2[13] = 'k';
                lcd16_2[14] = ':';
                lcd16_2[15] = time.weekday+0x30;
                lcd16_n_line_n_byte(0,16);
                lcd16_n_line_n_byte(1,16);
void DelayMS(unsigned int ms)
        unsigned char i;
        while(ms--)
                 for(i=0;i<120;i++);
void InitUart(void)
        SCON = 0x50;                                  //工作方式1
        TMOD = 0x21;
        PCON = 0x00;
        TH1 = 0xfd;                                   //使用T1作為波特率發生器
        TL1 = 0xfd;
        TI = 1;
        TR1 = 1;                                      //啟動T1        //啟動T1
  PCF8563_init();
//        PCF8563_wr_time();
        lcd_init();
  InitUart();
                PCF8563_rd_time();
    DelayMS(250);
基于51單片機和Proteus仿真的自動打鈴器.zip
75.87 KB, 下載次數: 82, 下載積分: 黑幣 -5
收藏收藏2 分享淘帖 頂1 踩
ID:91165 發表于 2020-3-20 08:19 | 只看該作者
謝謝樓主分享
ID:856413 發表于 2020-12-13 16:22 來自觸屏版 | 只看該作者
樓主,有方案說明和原理圖嗎?
主站蜘蛛池模板: 国产亚洲欧美在线 | 国产逼逼 | 亚洲观看黄色网 | 久草视频网站 | 99精品免费视频 | www中文字幕 | 麻豆一区二区三区 | 欧美精品久久久久久久 | 超碰国产在线 | 亚洲成人av在线 | 欧美日韩一区在线观看 | 精品少妇 | 在线观看免费黄色 | 日韩国产在线播放 | 欧美午夜视频 | 精品一区二区三区四区 | 一级片黄色 | 欧美日韩国产在线 | 中文在线字幕免费观看 | 免费一区二区三区 | 中文字幕偷拍 | 婷婷激情综合网 | 免费视频一区 | 日韩成人免费 | 久久久久一区二区三区 | 日韩福利一区 | 国产精品视屏 | 色综合五月 | 成年人黄色 | 日韩三级一区二区 | 午夜国产一区 | 欧美日韩在线一区二区 | 国产精品国产成人国产三级 | 国产三级黄色片 | 国产三级久久 | 欧美在线a | 欧美亚洲在线观看 | 日韩av免费看 | 99久久视频| 日韩综合在线观看 | 国产黄色片视频 |
