查看: 2924|回復: 0
基于51單片機和Proteus仿真的自動換擋電壓表
ID:517871 發(fā)表于 2019-5-9 17:29 | 顯示全部樓層 |閱讀模式
#include <AT89X52.H>
#define LEDDATA P0
#define v20_on {s3=0;s2=0;s1=1;} //宏定義不同量程,不同的開關狀態(tài)
#define v2_on {s3=0;s2=1;s1=0;}
#define v02_on {s3=1;s2=0;s1=0;}
unsigned char code dispcode[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00};
unsigned char dispbuf[8]={0,0,0,0,0,0,0,0};
unsigned char getdata;
unsigned long temp;
unsigned char i,k,l,m;
unsigned char code  mytable0[]=" Welcome to use  ";
unsigned char code  mytable1[]="Auto Voltmeter!";
unsigned char code line0[]="  Voltmeter   ";    //初始化顯示
unsigned char code line1[]=" Value:     V ";
//引腳定義
sbit lcdrs=P2^0;
sbit lcden=P2^1;
sbit s3=P3^7;
sbit s2=P3^6;
sbit s1=P3^5;
sbit OE=P3^0;
sbit EOC=P3^1;
sbit ST=P3^2;
void delay(unsigned int z)      //延時子函數(shù)  z*1ms
        unsigned int x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void write_com(unsigned char c)   //寫命令子函數(shù)
        lcdrs=0;                //低電平選擇為 寫指令
        lcden=0;
        LEDDATA=c;                   //把指令寫入P0口
        delay(5);               //參考時序圖
        lcden=1;                //開使能
        delay(5);               //讀取指令
        lcden=0;                //關閉使能
void write_data(unsigned char d)  //寫數(shù)據(jù)子函數(shù)
        lcdrs=1;             //高電平選擇為 寫數(shù)據(jù)
        LEDDATA=d;                //把數(shù)據(jù)寫入P0口
        delay(5);            //參考時序圖
        lcden=1;             //開使能
        delay(5);            //讀取數(shù)據(jù)
        lcden=0;                 //關閉使能
void initialize()      //LCD初始化函數(shù)
    unsigned char num;
        lcden=0;
        write_com(0x38);   //設置16x2顯示,5x7點陣顯示,8位數(shù)據(jù)接口
        write_com(0x0c);   //00001DCB,D(開關顯示),C(是否顯示光標),B(光標閃爍,光標不顯示)
        write_com(0x06);   //000001N0,N(地址指針+-1)
        write_com(0x01);      //清屏指令  每次顯示下一屏內(nèi)容時,必須清屏
        write_com(0x80+0x10);           //第一行,頂格顯示
        for(num=0;num<17;num++)
                write_data(mytable0[num]);
                delay(10);
        write_com(0x80+0x50);           //第二行,從第一格開始顯示
        for(num=0;num<15;num++)
                write_data(mytable1[num]);
                delay(10);
                for(num=0;num<16;num++)
                write_com(0x1c);   //0001(S/C)(R/L)**;  S/C:高電平移動字符,低電平移動光標;  R/L:高電平左移,低電平右移
                delay(300);
           delay(1000);
        write_com(0x80);
        for(num=0;num<14;num++)
                write_data(line0[num]);
                delay(10);
        write_com(0x80+0x40);
                write_data(line1[num]);
                delay(10);
void value(unsigned char add,unsigned char dat)
         write_com(0x80+0x47+add);
         if(l==3&&add==2||l!=3&&add==1)
              write_data(0x2e);
              write_data(0x30+dat);
main()
   initialize();
_20v:
       v20_on;
       ST=0;
       ST=1;
       ST=0;
          while(EOC==0);
          OE=1;
                  getdata=P1;
          OE=0;
                   if(getdata<21)
             goto _2v;
                  l=3;
              temp=getdata;
          temp=(temp*1000/51)/2;
                  goto disp;
_2v:
         v2_on;
          ST=0;
          ST=1;
          ST=0;
          while(EOC==0);
           OE=1;
           getdata=P1;
           OE=0;
           if(getdata<21)
             goto _02v;
           else if(getdata>204)
             goto _20v;
           l=2;
           temp=getdata;
           goto disp;
_02v:
          v02_on;
          ST=0;
          ST=1;
          ST=0;
          while(EOC==0);
           OE=1;
           getdata=P1;
           OE=0;
          if(getdata>204)
             goto _2v;
           l=1;
           temp=getdata;
                   m=temp%10;
                   if(m>5){temp=temp/10+1;}
                   else{temp=temp/10;}
                   goto disp;
disp:          for(i=0;i<=3;i++)
               dispbuf[i]=temp%10;
               temp=temp/10;
                  if(l==3)
                           for(i=4;i>=3;i--)
                           dispbuf[i]=dispbuf[i-1];
                          dispbuf[4]=dispbuf[3];
              for(k=0;k<5;k++)
                      value(k,dispbuf[4-k]);
                 if(l==2){goto _2v;}
                 else if(l==1){goto _02v;}
基于51單片機和Proteus仿真的自動換擋電壓表.zip
69.9 KB, 下載次數(shù): 23, 下載積分: 黑幣 -5
主站蜘蛛池模板: 欧美黑人狂野猛交老妇 | av永久 | 男女免费观看在线爽爽爽视频 | av网站免费看 | 日韩视频国产 | 中文字幕一区二区三区在线视频 | 国产在线不卡视频 | 亚洲精品久久久蜜桃 | 日韩在线免费观看视频 | 国产精品不卡 | 日韩精品一区二区三区中文字幕 | 高清视频一区二区三区 | 亚洲一区二区三区免费视频 | 欧美在线视频一区二区 | 国产成人福利 | 黄色大片网| 中文一区 | 国产精品片aa在线观看 | 九九热精品在线视频 | 亚洲欧美国产精品久久 | 亚洲国产aⅴ成人精品无吗 国产精品永久在线观看 | 黄色免费观看 | 日批日韩在线观看 | 亚洲三区在线观看 | 涩爱av一区二区三区 | 国产一区二区三区免费观看在线 | 国产精品一区视频 | 毛片在线看片 | 日韩在线视频一区二区三区 | 中国91av| 午夜99| 一级aaaaaa毛片免费同男同女 | 龙珠z在线观看 | 可以在线看的黄色网址 | 国内精品免费久久久久软件老师 | 91高清免费观看 | 国产精品久久福利 | 91视频进入 | 中文字幕不卡在线观看 | 视频一区 国产精品 | 国产精品国产精品国产专区不卡 |
