查看: 5281|回復: 2
51單片機溫濕度時間顯示鬧鐘設置 仿真和代碼
ID:289258 發表于 2019-5-16 09:17 | 顯示全部樓層 |閱讀模式
1602液晶顯示器顯示當前時間,溫濕度和時間,通過按鍵可以設置時間和鬧鐘,當鬧鐘響起時按下增加或者減少按鍵取消鬧鐘
  1. #include<reg52.h>
  2. #include"ds1302.h"
  3. #include"lcd.h"
  4. #include "DHT111.h"
  5. #define uint unsigned int
  6. #define uchar unsigned char
  7. sbit Key_1 = P3^3;
  8. sbit Key_2 = P3^4;
  9. sbit Key_3 = P3^5;
  10. sbit Buzzer = P3^6;
  11. uchar KeyValue = 0;        //按鍵值
  12. uchar Sec_temp;
  13. uchar Clock_Hour=8,Clock_Min=59;
  14. uchar Loc = 1;
  15. uchar Clock_Flag;
  16. void Key_Scan();
  17. void Delay10ms(uchar delaytime);
  18. void Main_DisPlay();
  19. void Display();
  20. void Time_Set();
  21. void Cursor_Set();
  22. void Set_Screen();
  23. void Set_Clock();
  24. void Clock_Check();
  25. void main()
  26. {
  27.     Delay10ms(100);
  28.     LcdInit();
  29.     Ds1302Init();
  30.     Ds1302ReadTime();
  31.     Main_DisPlay();
  32.     while(1)
  33.     {
  34.         Key_Scan();
  35.         Display();                //檢查時間是否發生變化
  36.         Set_Screen();
  37.         Time_Set();
  38.                 Clock_Check();                //鬧鐘檢測
  39.     }
  40. }
  41. void Key_Scan()
  42. {
  43.     KeyValue = 0;
  44.     if(Key_1 == 0)                //增加按鍵按下
  45.     {
  46.         Delay10ms(1);
  47.         if(Key_1 == 0)
  48.         {
  49.             KeyValue = 1;
  50.             while(Key_1 == 0);                //等待按鍵釋放
  51.         }
  52.     }
  53.     if(Key_2 == 0)                //減少按鍵按下
  54.     {
  55.         Delay10ms(1);
  56.         if(Key_2 == 0)
  57.         {
  58.             KeyValue = 2;
  59.             while(Key_2 == 0);                //等待按鍵釋放
  60.         }
  61.     }
  62.     if(Key_3 == 0)                //設置按鍵按下
  63.     {
  64.         Delay10ms(1);
  65.         if(Key_3 == 0)
  66.         {
  67.             KeyValue = 3;
  68.             while(Key_3 == 0);                //等待按鍵釋放
  69.         }
  70.     }
  71. }
  72. void Display()
  73. {
  74.     RH();
  75.     LcdWriteNum(2,6,U8T_data_H_temp);
  76.     LcdWriteNum(2,12,U8RH_data_H_temp);
  77.     Ds1302ReadTime();
  78.     if(Sec_temp != TIME[0])
  79.     {
  80.         Sec_temp = TIME[0];
  81.         LcdWriteNum(1,7,TIME[2]);                        //寫入時
  82.         LcdWriteNum(1,10,TIME[1]);                        //寫入分
  83.         LcdWriteNum(1,13,TIME[0]);                        //寫入秒
  84.         LcdWriteNum(1,1,TIME[4]);                        //寫入月
  85.         LcdWriteNum(1,4,TIME[3]);                        //寫入日
  86.     }
  87. }
  88. void Main_DisPlay()
  89. {
  90.     LcdClear();
  91.     LcdWriteStr(1,1,"00-00 00:00:00");
  92.     LcdWriteStr(2,1,"TEMP:00 RH:00");
  93.     LcdWriteNum(1,7,TIME[2]);                        //寫入時
  94.     LcdWriteNum(1,10,TIME[1]);                        //寫入分
  95.     LcdWriteNum(1,13,TIME[0]);                        //寫入秒
  96.     LcdWriteNum(1,1,TIME[4]);                        //寫入月
  97.     LcdWriteNum(1,4,TIME[3]);                        //寫入日
  98.     Sec_temp = TIME[0];                                        //讀取當前秒
  99. }
  100. void Time_Set()
  101. {
  102.     if(KeyValue == 3)
  103.     {
  104.         LcdClear();
  105.         Ds1302ReadTime();
  106.         LcdWriteStr(1,1,"SET:00-00-00 ");
  107.         LcdWriteStr(2,1,"    00:00:00");
  108.         LcdWriteNum(2,5,TIME[2]);                        //寫入時
  109.         LcdWriteNum(2,8,TIME[1]);                        //寫入分
  110.         LcdWriteNum(2,11,TIME[0]);                        //寫入秒
  111.         LcdWriteNum(1,5,TIME[6]);                        //寫入年
  112.         LcdWriteNum(1,8,TIME[4]);                        //寫入月
  113.         LcdWriteNum(1,11,TIME[3]);                        //寫入日
  114.         LcdWriteCom(0x0f);                                                //開光標
  115.         LcdWriteCom(0x80+4);
  116.         while(1)
  117.         {
  118.             Key_Scan();
  119.             if(KeyValue == 1)
  120.             {
  121.                 switch(Loc)
  122.                 {
  123.                 case 1:        //設置年
  124.                     TIME[6]++;
  125.                     LcdWriteNum(1,5,TIME[6]);                        //寫入年
  126.                     break;
  127.                 case 2:        //設置月
  128.                     if( TIME[4] <12)
  129.                         TIME[4]++;
  130.                     else
  131.                         TIME[4] = 1;
  132.                     LcdWriteNum(1,8,TIME[4]);                        //寫入月
  133.                     break;
  134.                 case 3:        //設置日
  135.                     if(TIME[3] < 31)
  136.                         TIME[3]++;
  137.                     else
  138.                         TIME[3] = 1;
  139.                     LcdWriteNum(1,11,TIME[3]);                        //寫入日
  140.                     break;
  141.                 case 4:        //設置時
  142.                     if(TIME[2] < 24)
  143.                         TIME[2]++;
  144.                     else
  145.                         TIME[2] = 0;
  146.                     LcdWriteNum(2,5,TIME[2]);                        //寫入時
  147.                     break;
  148.                 case 5:        //設置分
  149.                     if(TIME[1] < 59)
  150.                         TIME[1]++;
  151.                     else
  152.                         TIME[1] = 0;
  153.                     LcdWriteNum(2,8,TIME[1]);                        //寫入分
  154.                     break;
  155.                 case 6:        //設置秒
  156.                     if(TIME[0] < 59)
  157.                         TIME[0]++;
  158.                     else
  159.                         TIME[0] = 0;
  160.                     LcdWriteNum(2,11,TIME[0]);                        //寫入秒
  161.                     break;
  162.                 }
  163.                 Cursor_Set();
  164.             }
  165.             if(KeyValue == 2)
  166.             {
  167.                 switch(Loc)
  168.                 {
  169.                 case 1:        //設置年
  170.                     TIME[6]--;
  171.                     LcdWriteNum(1,5,TIME[6]);                        //寫入年
  172.                     break;
  173.                 case 2:        //設置月
  174.                     if( TIME[4] > 1)
  175.                         TIME[4]--;
  176.                     else
  177.                         TIME[4] = 12;
  178.                     LcdWriteNum(1,8,TIME[4]);                        //寫入月
  179.                     break;
  180.                 case 3:        //設置日
  181.                     if(TIME[3] > 1)
  182.                         TIME[3]--;
  183.                     else
  184.                         TIME[3] = 31;
  185.                     LcdWriteNum(1,11,TIME[3]);                        //寫入日
  186.                     break;
  187.                 case 4:        //設置時
  188.                     if(TIME[2] > 0)
  189.                         TIME[2]--;
  190.                     else
  191.                         TIME[2] = 24;
  192.                     LcdWriteNum(2,5,TIME[2]);                        //寫入時
  193.                     break;
  194.                 case 5:        //設置分
  195.                     if(TIME[1] > 0)
  196.                         TIME[1]--;
  197.                     else
  198.                         TIME[1] = 59;
  199.                     LcdWriteNum(2,8,TIME[1]);                        //寫入分
  200.                     break;
  201.                 case 6:        //設置秒
  202.                     if(TIME[0] > 0)
  203.                         TIME[0]--;
  204.                     else
  205.                         TIME[0] = 59;
  206.                     LcdWriteNum(2,11,TIME[0]);                        //寫入秒
  207.                     break;
  208.                 }
  209.                 Cursor_Set();
  210.             }
  211.             if(KeyValue == 3)
  212.             {
  213.                 if(Loc < 6)
  214.                     Loc++;
  215.                 else
  216.                 {
  217.                     Ds1302WriteTime();                        //寫入時間
  218.                     LcdWriteCom(0x0c);  //開顯示不顯示光標
  219.                     return;
  220.                 }
  221.                 Cursor_Set();
  222.             }
  223.         }
  224.     }
  225. }
  226. void Clock_Check()
  227. {
  228.         static uchar i;
  229.         if(KeyValue == 1 || KeyValue == 2)
  230.         {
  231.                 Buzzer = 1;
  232.                 Clock_Flag = 2;
  233.         }
  234.         if(TIME[1] == Clock_Min)                //分相等
  235.         {
  236.                 if(Clock_Flag == 0)
  237.                 {
  238.                         if(TIME[2] == Clock_Hour)                                        //時相等
  239.                         {
  240.                                 i++;
  241.                                 if(i > 5)
  242.                                 {
  243.                                         i = 0;
  244.                                         Buzzer = ~Buzzer;
  245.                                 }
  246.                         }
  247.                 }
  248.         }
  249.         else
  250.         {
  251.                 i = 0;
  252.                 Clock_Flag = 0;
  253.                 Buzzer = 1;
  254.         }
  255. }
  256. void Cursor_Set()
  257. {
  258.     if(Loc <= 3)
  259.     {
  260.         LcdWriteCom(0x80+4+(Loc-1)*3);
  261.     }
  262.     else
  263.     {
  264.         LcdWriteCom(0xc0+4+(Loc-4)*3);
  265.     }
  266. }
  267. void Set_Screen()
  268. {
  269.     uchar Cursor;
  270.     if(KeyValue == 3)
  271.     {
  272.         Cursor = 1;                //設置光標
  273.         LcdClear();
  274.         LcdWriteStr(1,1,">");
  275.         LcdWriteStr(1,3,"Set Time");
  276.         LcdWriteStr(2,3,"Set Clock");
  277.         while(1)
  278.         {
  279.             Key_Scan();
  280.             if(KeyValue == 1 || KeyValue == 2)
  281.             {
  282.                 if(KeyValue == 1)
  283.                     Cursor++;
  284.                 if(KeyValue == 2)
  285.                     Cursor--;
  286.                 if(Cursor == 0)
  287.                     Cursor=2;
  288.                 if(Cursor == 3)
  289.                     Cursor=1;
  290.                 if(Cursor == 1)
  291.                 {
  292.                     LcdWriteStr(1,1,">");
  293.                     LcdWriteStr(2,1," ");
  294.                 }
  295.                 if(Cursor == 2)
  296.                 {
  297.                     LcdWriteStr(1,1," ");
  298.                     LcdWriteStr(2,1,">");
  299.                 }
  300.             }
  301.             if(KeyValue == 3)
  302.             {
  303.                 switch(Cursor)
  304.                 {
  305.                 case 1:
  306.                     Time_Set();
  307.                     break;
  308.                 case 2:
  309.                     Set_Clock();
  310.                     break;
  311.                 }
  312.                 Main_DisPlay();
  313.                 KeyValue = 0;
  314.                 return;
  315.             }
  316.         }
  317.     }
  318. }
  319. void Set_Clock()
  320. {
  321.     uchar Cursor=0;
  322.     LcdClear();
  323.     LcdWriteStr(1,3,"  Set Clock  ");
  324.     LcdWriteStr(2,5,"  :  ");
  325.     LcdWriteNum(2,5,Clock_Hour);
  326.     LcdWriteNum(2,8,Clock_Min);
  327.     LcdWriteCom(0xc0+5);
  328.     LcdWriteCom(0x0f);                //光標閃爍
  329.     while(1)
  330.     {
  331.         Key_Scan();
  332.         if(KeyValue == 1)
  333.         {
  334.             if(Cursor == 0)
  335.             {
  336.                 if(Clock_Hour < 59)
  337.                     Clock_Hour++;
  338.                 LcdWriteNum(2,5,Clock_Hour);
  339.                 LcdWriteCom(0xc0+5);
  340.             }
  341.             if(Cursor == 1)
  342.             {
  343.                 Clock_Min++;
  344.                 if(Clock_Hour < 59)
  345.                     Clock_Min++;
  346.                 LcdWriteNum(2,8,Clock_Min);
  347.                 LcdWriteCom(0xc0+8);
  348.             }
  349.         }
  350.         if(KeyValue == 2)
  351.         {
  352.             if(Cursor == 0)
  353. ……………………
  354. …………限于本文篇幅 余下代碼請從51黑下載附件…………
資料.zip (157.43 KB, 下載次數: 146)
ID:629552 發表于 2020-2-26 21:27 來自觸屏版 | 顯示全部樓層
為啥沒有仿真文件
ID:906585 發表于 2021-4-23 20:44 | 顯示全部樓層
樓主有原理圖嗎,可以分享一下嗎,跪求
主站蜘蛛池模板: 色秀网站 | 亚洲精品成人 | 国产免费一区二区三区免费视频 | 日一区二区三区 | 91精品在线播放 | 亚洲成人自拍 | 欧美精品v | 国产精品一区二区在线 | 天天综合久久网 | 人人鲁人人莫人人爱精品 | 国产九九九九 | 欧美一区二区三区 | 日本特黄特色aaa大片免费 | 久久九九影视 | 亚洲精品一区在线观看 | 免费高清av | 99精品久久 | 欧美视频成人 | 欧美高清一区 | 毛片在线视频 | 一区二区三区亚洲 | 日韩精品免费在线观看 | 欧美色综合 | 欧美www在线| 亚洲国产欧美一区 | 欧美亚洲另类丝袜综合网动图 | 久久久精| 欧美日韩亚洲国产 | 欧美一区二区三区四区视频 | 亚洲综合在线一区二区 | 免费黄色片视频 | 国产精品1区 | 日韩精品在线观看一区二区 | 久久这里只有 | 亚洲精品久久久久中文字幕欢迎你 | 精品国产乱码一区二区三区a | 国产一区在线免费观看视频 | 小h片免费观看久久久久 | 久久久久久91 | 在线免费观看黄网 | 日本免费一区二区三区四区 |
