查看: 3639|回復: 2
STM32 USART通過DMA發送程序
ID:302293 發表于 2019-5-29 10:48 | 顯示全部樓層 |閱讀模式
#include "stm32f10x.h"
#define se 3//傳輸的字節數
u32 SendBuff[3];
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
//毫秒級的延時
void delay_ms(u16 time)
   u16 i=0;
   while(time--)
      i=12000;  //自己定義
      while(i--) ;
void DMA_Config(void)
    DMA_InitTypeDef DMA_InitStructure;
   RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);    //開啟DMA時鐘
                    //配置DMA中斷
     /*設置DMA源:內存地址&串口數據寄存器地址*/
  DMA_InitStructure.DMA_PeripheralBaseAddr = 0x40013804;
    /*內存地址(要傳輸的變量的指針)*/
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)SendBuff;
    /*方向:從內存到外設*/
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
    /*傳輸大小DMA_BufferSize=SENDBUFF_SIZE*/
  DMA_InitStructure.DMA_BufferSize = se;
    /*外設地址不增*/
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
    /*內存地址自增*/
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
    /*外設數據單位*/
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
    /*內存數據單位 8bit*/
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
    /*DMA模式:一次傳輸,循環*/
DMA_InitStructure.DMA_Mode = DMA_Mode_Normal ;
    /*優先級:中*/
DMA_InitStructure.DMA_Priority = DMA_Priority_Medium;
    /*禁止內存到內存的傳輸    */
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
    /*配置DMA1的4通道*/
    DMA_Init(DMA1_Channel4, &DMA_InitStructure);
      DMA_Cmd (DMA1_Channel4,ENABLE);                    //使能DMA
      DMA_ITConfig(DMA1_Channel4,DMA_IT_TC,ENABLE);  //配置DMA發送完成后產生中斷
//系統時鐘配置
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);//使能串口1的GPIO時鐘
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOC,  ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,  ENABLE);
//串口GPIO口配置
USART_InitTypeDef USART_InitStructure;
/* LED0*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2|GPIO_Pin_13;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOC, &GPIO_InitStructure);
// GPIO_PinRemapConfig(GPIO_Remap_USART1, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;     //復用推挽輸出
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;   //懸浮輸入
USART_InitStructure.USART_BaudRate = 9600;      //設定波特率
USART_InitStructure.USART_WordLength = USART_WordLength_8b;  //傳輸數據位數
USART_InitStructure.USART_StopBits = USART_StopBits_1;   //停止位1
USART_InitStructure.USART_Parity = USART_Parity_No;    //不用校驗位
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//不用流量控制
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //使用接收和發送功能
USART_Init(USART1, &USART_InitStructure);       //初始化串口1
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);     //使能串口1 讀中斷
USART_Cmd(USART1,ENABLE);  //串口1使能
USART_ClearFlag(USART1,USART_IT_TC );//發送完成中斷
//中斷配置
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);     //先占優先權2,從優先級2位
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;    //開串口中斷1
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0;   //指定搶占優先級別1
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;    //指定相應優先級別0
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
void USART1_IRQHandler( u32 temp_trx)       //串口接收中斷,并將接收到得數據發送出
if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)//判斷 是否 接收中斷
    temp_trx = USART_ReceiveData(USART1);
  USART_SendData(USART1,USART_ReceiveData(USART1));
int main(void)
RCC_Configuration();//系統時鐘配置
   DMA_Config();
NVIC_Configuration();//中斷配置
GPIO_Configuration();//GPIO口配置
while(1)          //LED燈循環亮滅,串口循環發送ASCII“9”
  delay_ms(500);
USART_SendData(USART1,9);
  delay_ms(50);
         USART_SendData(USART1,0xdf);
   delay_ms(50);
         USART_SendData(USART1,0xec);
  delay_ms(50);
         GPIO_WriteBit(GPIOC,GPIO_Pin_13,(BitAction)(1-GPIO_ReadOutputDataBit(GPIOC,GPIO_Pin_13)));
ID:721221 發表于 2020-4-2 19:47 | 顯示全部樓層
今天剛看到這里在學習DMA,看了你的程序   發現了一個不知道是不是問題的問題(我沒有找到使能USART的DMA請求函數)
USART_DMACmd(USART1, USART_DMAReq_Tx, ENABLE);
我剛學  也不太懂
ID:302293 發表于 2020-9-17 17:26 | 顯示全部樓層
PAIDAXINGG 發表于 2020-4-2 19:47
今天剛看到這里在學習DMA,看了你的程序   發現了一個不知道是不是問題的問題(我沒有找到使能USART的DMA請 ...
   串口的數據用DMA發送出去的,不占用中斷資源
主站蜘蛛池模板: 麻豆一区二区三区 | 欧美成人精品一区二区三区在线看 | 黄色天天影视 | 国产成人三级一区二区在线观看一 | 久久亚洲精品视频 | 国产三级做爰高清在线 | avtt久久| 久久国产成人 | 91精品网| 欧美在线免费观看 | 青青青在线视频 | 成人激情视频网 | 黄色av一区 | 久久香蕉网 | 久久久亚洲天堂 | 三级视频网 | 极品尤物一区二区三区 | 亚洲精品911 | 欧美日本在线 | 二区在线观看 | 日韩综合精品 | 国产一区精品在线 | av最新在线 | 欧美视频一区二区三区 | 日韩中文字幕视频 | 国产三区四区 | 日韩av免费在线播放 | 韩日在线视频 | 狠狠干狠狠插 | 成人免费毛片aaaaaa片 | 国产又猛又黄又爽 | 日韩免费观看视频 | av福利网| 国产女优在线 | 操综合| 99精品国产一区二区 | 天天久久 | 四虎www| 在线观看中文字幕 | 亚洲日本视频 | 韩国三级中文字幕hd久久精品 |
