2019-5-15版本一:https://www.bilibili.com/video/av52557415/
2019-6-2版本二:https://www.bilibili.com/video/av54323283/
廢話不多說,源碼如下
- 2019 © Arduino_Maker
- #include <TimerOne.h>
- byte m = 0;
- byte Pvalue = 0;
- boolean BreatheFlag = true;
- byte ModeNumber = 0;
- //byte oldModeNumber = 0;
- boolean Touchflag = false;
- unsigned int Time1 = 0;
- unsigned int timex = 0;
- const byte Ring[5][6]={
- {2,19,13},
- {9,14,17},
- {4,8,15,6,10,7},
- {18,16,12},
- {11,5,3}
- void setup() {
- Serial.begin(9600);
- for(int i=0;i<5;i++){
- for(int j=0;Ring[i][j]!='\0';j++){
- pinMode(Ring[i][j],OUTPUT);
- Timer1.initialize( 100000 );
- Timer1.attachInterrupt( Timer2Interrupt );
- void Timer2Interrupt(void){
- if((analogRead(A6) < 100) && (Touchflag==false)){
- Touchflag = true;
- Time1 = millis();
- ModeNumber = ModeNumber + 1;
- if(ModeNumber == 2) m = 0;
- if(ModeNumber == 7) ModeNumber = 0;
- //Serial.println(ModeNumber);
- else if((analogRead(A6) > 100) && (Touchflag==true)){
- Touchflag = false;
- timex = millis() - Time1;
- if(timex > 3000) ModeNumber = 0;
- void loop() {
- switch(ModeNumber){
- case 0: Mode0(); break;
- case 1: Mode1(10); break;
- case 2: Mode2(100); break;
- case 3: Mode3(100); break;
- case 4: Mode4(100); break;
- case 5: Mode5(10); break;
- case 6: Mode6(60); break;
- default: break;
- void Mode0(void)
- Ring_Run(0,false);
- Ring_Run(1,false);
- Ring_Run(2,false);
- Ring_Run(3,false);
- Ring_Run(4,false);
- void Mode1(int Mytime)
- analogWrite(Ring[4][0],Pvalue);
- analogWrite(Ring[4][1],Pvalue);
- analogWrite(Ring[4][2],Pvalue);
- if(BreatheFlag==true){
- Pvalue = Pvalue + 1;
- if(Pvalue == 255) BreatheFlag = false;
- if(BreatheFlag==false){
- Pvalue = Pvalue - 1;
- if(Pvalue == 0) BreatheFlag = true;
- delay(Mytime);
- void Mode2(int Mytime)
- switch(m){
- case 0: Ring_Run(0,true); break;
- case 1: delay(4*Mytime); break;
- case 2: Ring_Run(1,true); break;
- case 3: delay(3*Mytime); break;
- case 4: Ring_Run(2,true); break;
- case 5: delay(2*Mytime); break;
- case 6: Ring_Run(3,true); break;
- case 7: delay(Mytime); break;
- case 8: Ring_Run(4,true); break;
- case 9: delay(4*Mytime); break;
- case 10: delay(4*Mytime); break;
- case 11: Ring_Run(4,false);break;
- case 12: delay(Mytime); break;
- case 13: Ring_Run(3,false);break;
- case 14: delay(2*Mytime); break;
- case 15: Ring_Run(2,false);break;
- case 16: delay(3*Mytime); break;
- case 17: Ring_Run(1,false);break;
- case 18: delay(4*Mytime); break;
- case 19: Ring_Run(0,false);break;
- case 20: delay(4*Mytime); break;
- case 21: delay(4*Mytime); break;
- default: break;
- m = m + 1;
- if(m == 22) m = 0;
- void Mode3(int Mytime)
- Ring_Run(0,true);
- Ring_Run(1,true);
- Ring_Run(2,true);
- Ring_Run(3,true);
- Ring_Run(4,true);
- delay(Mytime);
- delay(Mytime);
- void Mode4(int Mytime)
- Leaf_Run(2,false);Leaf_Run(0,true);delay(Mytime);
- Leaf_Run(0,false);Leaf_Run(1,true);delay(Mytime);
- Leaf_Run(1,false);Leaf_Run(2,true);delay(Mytime);
- void Mode5(int Mytime)
- digitalWrite(Ring[0][2],LOW);digitalWrite(Ring[0][0],HIGH);delay(Mytime);
- digitalWrite(Ring[0][0],LOW);digitalWrite(Ring[0][1],HIGH);delay(Mytime);
- digitalWrite(Ring[0][1],LOW);digitalWrite(Ring[0][2],HIGH);delay(Mytime);
- digitalWrite(Ring[1][1],LOW);digitalWrite(Ring[1][0],HIGH);delay(Mytime);
- digitalWrite(Ring[1][0],LOW);digitalWrite(Ring[1][2],HIGH);delay(Mytime);
- digitalWrite(Ring[1][2],LOW);digitalWrite(Ring[1][1],HIGH);delay(Mytime);
- digitalWrite(Ring[2][4],LOW);digitalWrite(Ring[2][5],LOW);digitalWrite(Ring[2][2],HIGH);digitalWrite(Ring[2][3],HIGH);delay(Mytime);
- digitalWrite(Ring[2][2],LOW);digitalWrite(Ring[2][3],LOW);digitalWrite(Ring[2][0],HIGH);digitalWrite(Ring[2][1],HIGH);delay(Mytime);
- digitalWrite(Ring[2][0],LOW);digitalWrite(Ring[2][1],LOW);digitalWrite(Ring[2][4],HIGH);digitalWrite(Ring[2][5],HIGH);delay(Mytime);
- digitalWrite(Ring[3][2],LOW);digitalWrite(Ring[3][0],HIGH);delay(Mytime);
- digitalWrite(Ring[3][0],LOW);digitalWrite(Ring[3][1],HIGH);delay(Mytime);
- digitalWrite(Ring[3][1],LOW);digitalWrite(Ring[3][2],HIGH);delay(Mytime);
- digitalWrite(Ring[4][2],LOW);digitalWrite(Ring[4][0],HIGH);delay(Mytime);
- digitalWrite(Ring[4][0],LOW);digitalWrite(Ring[4][1],HIGH);delay(Mytime);
- digitalWrite(Ring[4][1],LOW);digitalWrite(Ring[4][2],HIGH);delay(Mytime);
- void Mode6(int Mytime)
- Ring_Run(0,true);
- Ring_Run(4,true);
- digitalWrite(Ring[2][4],LOW);digitalWrite(Ring[2][3],HIGH);delay(Mytime);
- digitalWrite(Ring[2][3],LOW);digitalWrite(Ring[3][1],HIGH);delay(Mytime);
- digitalWrite(Ring[3][1],LOW);digitalWrite(Ring[2][2],HIGH);delay(Mytime);
- digitalWrite(Ring[2][2],LOW);digitalWrite(Ring[2][1],HIGH);delay(Mytime);
- digitalWrite(Ring[2][1],LOW);digitalWrite(Ring[3][0],HIGH);delay(Mytime);
- digitalWrite(Ring[3][0],LOW);digitalWrite(Ring[2][0],HIGH);delay(Mytime);
- digitalWrite(Ring[2][0],LOW);digitalWrite(Ring[2][5],HIGH);delay(Mytime);
- digitalWrite(Ring[2][5],LOW);digitalWrite(Ring[3][2],HIGH);delay(Mytime);
- digitalWrite(Ring[3][2],LOW);digitalWrite(Ring[2][4],HIGH);delay(Mytime);
- void Ring_Run(byte n,boolean k)
- if(k==true)
- switch(n){
- case 0:
- for(int i = 0;i < 3;i++) digitalWrite(Ring[0][i],HIGH); break;
- case 1:
- for(int i = 0;i < 3;i++) digitalWrite(Ring[1][i],HIGH); break;
- case 2:
- for(int i = 0;i < 6;i++) digitalWrite(Ring[2][i],HIGH); break;
- case 3:
- for(int i = 0;i < 3;i++) digitalWrite(Ring[3][i],HIGH); break;
- case 4:
- for(int i = 0;i < 3;i++) digitalWrite(Ring[4][i],HIGH); break;
- default : break;
- else switch(n){
- case 0:
- for(int i = 0;i < 3;i++) digitalWrite(Ring[0][i],LOW); break;
- case 1:
- for(int i = 0;i < 3;i++) digitalWrite(Ring[1][i],LOW); break;
- case 2:
- for(int i = 0;i < 6;i++) digitalWrite(Ring[2][i],LOW); break;
- case 3:
- for(int i = 0;i < 3;i++) digitalWrite(Ring[3][i],LOW); break;
- case 4:
- for(int i = 0;i < 3;i++) digitalWrite(Ring[4][i],LOW); break;
- default : break;
- void Leaf_Run(byte n,boolean k)
- if(k==true)
- switch(n){
- case 0:
- digitalWrite(Ring[1][0],HIGH);
- digitalWrite(Ring[2][0],HIGH);
- digitalWrite(Ring[2][1],HIGH);
- digitalWrite(Ring[3][0],HIGH);
- digitalWrite(Ring[4][0],HIGH);
- break;
- case 1:
- digitalWrite(Ring[1][2],HIGH);
- digitalWrite(Ring[2][5],HIGH);
- digitalWrite(Ring[2][4],HIGH);
- digitalWrite(Ring[3][2],HIGH);
- digitalWrite(Ring[4][2],HIGH);
- break;
- case 2:
- digitalWrite(Ring[1][1],HIGH);
- digitalWrite(Ring[2][2],HIGH);
- digitalWrite(Ring[2][3],HIGH);
- digitalWrite(Ring[3][1],HIGH);
- digitalWrite(Ring[4][1],HIGH);
- break;
- default: break;
- else switch(n){
- case 0:
- break;
- case 1:
- break;
- case 2:
- break;
- default: break;
