查看: 2628|回復: 0
LDC1000與STM32連接源程序
ID:537065 發表于 2019-6-3 14:58 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
分享一個LDC1000與STM32連接的代碼供大家學習
  1. #include "ldc1000.h"
  2. /*----------------------------------------
  3.                                 全局變量
  4. ----------------------------------------*/
  5. uint8_t RegArray[REG_LEN];
  6. /*----------------------------------------
  7.                                 宏定義
  8. ----------------------------------------*/
  9. #define CSB_0         GPIOB->BRR  = GPIO_Pin_7
  10. #define CSB_1         GPIOB->BSRR = GPIO_Pin_7
  11. /*----------------------------------------
  12. 函數功能: LDC1000初始化
  13. 函數參數: 無
  14. ----------------------------------------*/
  15. void LDC1000_Init(void)
  16. {
  17.         LDC1000_GPIO_Init();
  18.         LDC1000_SPI_Init();
  19.     LDC1000_WriteReg(LDC1000_CMD_RPMAX,       0x13);
  20.     LDC1000_WriteReg(LDC1000_CMD_RPMIN,       0x3A);
  21.         LDC1000_WriteReg(LDC1000_CMD_SENSORFREQ,  0x94);
  22.         LDC1000_WriteReg(LDC1000_CMD_LDCCONFIG,   0x17);
  23.         LDC1000_WriteReg(LDC1000_CMD_CLKCONFIG,   0x02);
  24.         LDC1000_WriteReg(LDC1000_CMD_INTCONFIG,   0x02);
  25.         LDC1000_WriteReg(LDC1000_CMD_THRESHILSB,  0x50);
  26.         LDC1000_WriteReg(LDC1000_CMD_THRESHIMSB,  0x14);
  27.         LDC1000_WriteReg(LDC1000_CMD_THRESLOLSB,  0xC0);
  28.         LDC1000_WriteReg(LDC1000_CMD_THRESLOMSB,  0x12);
  29.         LDC1000_WriteReg(LDC1000_CMD_PWRCONFIG,   0x01);
  30. }
  31. /*----------------------------------------
  32. 函數功能: LDC1000 GPIO初始化
  33. 函數參數: IO口連接圖
  34.         +5V         <->         +5V
  35.         DCLK        <->         PB6 <-> TIM4_CH1
  36.         SCLK    <->         PA5 <-> SPI1_SCK
  37.         SDI     <->         PA7 <-> SPI1_MOSI
  38.         SDO     <->         PA6 <-> SPI1_MISO
  39.         VIO                <->         3V3
  40.         GND                <->         GND
  41.         INT     <->         PC2 <-> GPIO
  42.         CSB                <->         PB7        <-> GPIO
  43.         GND                <->                GND
  44. ----------------------------------------*/
  45. void LDC1000_GPIO_Init(void)
  46. {
  47.         GPIO_InitTypeDef GPIO_InitStructure;
  48.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);        //記住使能AFIO時鐘
  49.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB| RCC_APB2Periph_GPIOC , ENABLE);
  50.
  51.         //PB6->PWM_OUTPUT
  52.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
  53.           GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                //PB6復用推挽輸出
  54.           GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  55.           GPIO_Init(GPIOB, &GPIO_InitStructure);
  56.         //A5->SCK  A6->MISO A7->MOSI
  57.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
  58.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;           //SPI用復用推挽輸出
  59.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  60.         GPIO_Init(GPIOA,&GPIO_InitStructure);
  61.         //PC2->INT
  62.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  63.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  64.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  65.         GPIO_Init(GPIOC,&GPIO_InitStructure);
  66.         //PB7->CSB
  67.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
  68.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  69.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  70.         GPIO_Init(GPIOB,&GPIO_InitStructure);
  71. }
  72. /*----------------------------------------
  73. 函數功能: SPI參數初始化
  74. 函數參數: LDC1000的時鐘頻率必須在4.2MHz
  75.                    且不能超過5MHz,不能低于4MHz,否則
  76.                    模塊不能夠正常通信,所以SPI波特率
  77.                    分頻系數選擇16分頻.
  78. ----------------------------------------*/
  79. void LDC1000_SPI_Init(void)
  80. {
  81.         SPI_InitTypeDef SPI_InitStructure;
  82.
  83.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1,ENABLE);                //使能APB2外設時鐘
  84.         SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  85.         SPI_InitStructure.SPI_Mode = SPI_Mode_Master;                        //SPI主
  86.         SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;                //數據格式8位
  87.         SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;                                //時鐘極性低,高都可以
  88.         SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;                    //時鐘相位第1,2邊沿觸發都可以
  89.         SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
  90.         SPI_InitStructure.SPI_BaudRatePrescaler        = SPI_BaudRatePrescaler_16; //必須是16分頻
  91.         SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;                //MSB在前,必須
  92.         SPI_InitStructure.SPI_CRCPolynomial = 7;                                //CRC多項式校驗,可有可無
  93.         SPI_Init(SPI1,&SPI_InitStructure);
  94.         SPI_Cmd(SPI1,ENABLE);
  95. }
  96. /*----------------------------------------
  97. 函數功能: LDC1000寫寄存器
  98. 函數參數: - addr 寄存器地址
  99.                    - dat  數據
  100. ----------------------------------------*/
  101. void LDC1000_WriteReg(int8_t addr, uint8_t dat)
  102. {
  103.         addr = addr & 0x7F;                     //MSB為0寫寄存器,為1讀寄存器
  104.         CSB_0;
  105. //        LDC1000_SendByte(addr);
  106. //        LDC1000_SendByte(dat);
  107.         SPI_I2S_SendData(SPI1, addr);
  108.         while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
  109.         SPI_I2S_SendData(SPI1, dat);
  110.         while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
  111.         CSB_1;
  112. }
  113. /*----------------------------------------
  114. 函數功能: LDC1000讀寄存器
  115. 函數參數: - addr 寄存器地址
  116. ----------------------------------------*/
  117. uint8_t LDC1000_ReadReg(int8_t addr)
  118. {
  119.         uint8_t temp;
  120.         addr = addr | 0x80;                     //MSB為1讀寄存器,為0寫寄存器
  121.         CSB_0;
  122.         SPI_I2S_SendData(SPI1, addr);
  123.         while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
  124.         SPI_I2S_SendData(SPI1, 0x00);
  125.         while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
  126.         temp = (uint8_t)SPI_I2S_ReceiveData(SPI1);
  127. //        LDC1000_SendByte(addr);
  128. //        temp = LDC1000_SendByte(0x00);
  129.         CSB_1;
  130.         return temp;
  131. }
  132. /*----------------------------------------
  133. 函數功能: 向LDC1000發送一字節數據
  134. 函數參數: 要發送的數據dat
  135. 返 回 值: 器件發回來的數據
  136. ----------------------------------------*/
  137. uint8_t LDC1000_SendByte(uint8_t dat)
  138. {
  139.         while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
  140.         SPI_I2S_SendData(SPI1, dat);
  141.         while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET);
  142.         return (uint8_t)SPI1->DR;
  143. }
  144. /*----------------------------------------
  145. 函數功能: 讀取LDC1000一個字節
  146. 函數參數: 空
  147. 返 回 值: 從器件發來的一字節數據
  148. ----------------------------------------*/
  149. uint8_t LDC1000_ReadByte(void)
  150. {
  151.         return 0x00;
  152. }
  153. /*----------------------------------------
  154. 函數功能: 讀取LDC1000 len個字節
  155. 函數參數: - addr
  156.                    - pBuffer
  157.                    - len
  158. 調用示例: LDC1000_ReadBytes(LDC1000_CMD_REVID,&RegArray[0],12);
  159. ----------------------------------------*/
  160. void LDC1000_ReadBytes(int8_t addr, uint8_t* pBuffer, uint8_t len)
  161. {
  162.         addr = addr | 0x80;                 //Read Data
  163.         CSB_0;
  164.         LDC1000_SendByte(addr);
  165.         while(len > 0)
  166.         {
  167.                  *pBuffer = LDC1000_ReadByte();
  168.                 pBuffer++;
  169.                 len--;
  170.         }
  171.         CSB_1;
  172. }
LDC1000 - STM32.7z (199.71 KB, 下載次數: 15)
主站蜘蛛池模板: 久久精品国产亚洲 | 欧美精品在线一区 | 日韩不卡在线 | 成年视频在线观看 | 久久99精品久久久久久琪琪 | 一级特黄毛片 | 亚洲国产精品久久 | 亚洲色欲色欲www在线观看 | 国语对白永久免费 | 国产精品麻豆免费版 | 久久精品欧美一区二区三区不卡 | 五月播播| 国产三级在线播放 | 五月天堂网 | a级成人毛片 | 亚洲欧美日韩成人 | 色综合激情 | 久久久久久国产精品 | 怡红院久久 | 色av导航 | 99久久精品国产一区二区三区 | 中文日韩在线 | 日韩av在线免费播放 | 精品综合网 | 特级黄色大片 | 中文字幕不卡在线 | av日韩在线播放 | 成人国产精品久久久网站 | 欧美日韩一区二区三区四区 | 欧美人xxxx | 免费观看一区二区三区毛片 | 天天爽夜夜爽夜夜爽 | 国产日本在线 | 91精品成人 | 国产又粗又大又硬 | 亚洲精品18在线观看 | 欧美日韩精品久久久免费观看 | 免费高清av| 亚洲欧美日本在线 | 人与拘一级a毛片 | 亚洲免费观看视频 |
