查看: 3714|回復: 0
[求助][原創(chuàng)]程序實現(xiàn)PWM的占空比并且實現(xiàn)一小時內的可控定時工功能
ID:44588 發(fā)表于 2012-9-11 20:34 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
 程序大致可以實現(xiàn)定時刻PWM輸出功能,但有一個缺點:輸出的波形不穩(wěn)定,在數(shù)碼管上顯示是不是出現(xiàn)跳碼。跪求大神指點。
#include<reg51.h>
#define uchar unsigned char
#define uint unsigned int
sbit PWM=P2^1;
sbit alarm=P1^7; //高電平時鬧鐘響
sbit selecta=P2^4;
sbit selectb=P2^5;
sbit selectc=P2^6;
sbit select=P2^7; //只需要第一段,第二段和第六段亮,即
uchar Keystate;
uchar buffer[]={0,0,0,0,0};
uint a,b;
uchar table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};//共陰數(shù)碼管代碼
uchar Overflow=0;//定時溢出次數(shù)
uchar minute,second;//定義倒計時變量
//ms延時函數(shù)
void delayms(uint x)
 uint i;
 while(x--) for(i=0;i<1000;i++);
void delay(uint x)
uchar j;
 while(x--)for(j=0;j<5;j++);
//數(shù)碼管顯示函數(shù)
   void display()
  uchar s,k;
  buffer[0]=minute/10;
  buffer[1]=minute%10;
  buffer[2]=second/10;
  buffer[3]=second%10;
  buffer[4]=b%10;
  for(k=0;k<5;k++)
   s=k;
    switch(k)
   case 0:selecta=0;selectb=1;selectc=0;
           break;
   case 1: selecta=1;selectb=1;selectc=0;
         break;
   case 2: selecta=0;selectb=0;selectc=1;
         break;
   case 3: selecta=1;selectb=0;selectc=1;
         break;
   case 4:selecta=1;selectb=1;selectc=1;
         break;
  P0=table[buffer];
  delay(3);
 }//要實現(xiàn)動態(tài)顯示
//本程序需要用到兩個定時器,兩個中斷
void KeyScan();
 P2=0x00;
 a=0;
 b=5;
 minute=30;
 second=0;
 RD=0;
 select=1;
 TMOD=0x11;
 TH0=(65536-10)/256;
 TL0=(65536-10)%256;
 EA=1;
 IT1=1; IT0=1;
 EX1=1; EX0=1;
 PX1=1;
 KeyScan();
 TR1=1;
 ET1=1;
  display();
  delay(10);
 void X1_INT()interrupt 2
if(b>0) b--;
else b=9;
void X0_INT()interrupt 0
b++;
if(b>9) b=0;
 void time1() interrupt 3
   TL1=(65536-10)%256;
   TH1=(65536-10)/256;
   a++;
   if(a==10) a=0;
   if(a<b) PWM=1;
   else PWM=0;
void timer0start()//定時器初始化函數(shù)
 TH0=(65536-50000)/256;  //定時器定時為50ms,晶振的周期為12MHz
 TL0=(65536-50000)%256;
 ET0=1;  //定時器1中斷開
 TR0=1; //定時器1開
 //鬧鈴函數(shù) 需要輸出聲音悅耳
  void beef()
  uchar x=100;
   while(x--)
   alarm=!alarm;
   delayms(10);
   alarm=0;
  //定時器0中斷函數(shù)程序
void time0()interrupt 1
 if(Overflow==20)
  Overflow=0;
  if(second==0)
   if(minute==0)
   beef();
   minute=0;
   second=0;
   while(1);
   else minute--;
   second=59;
  else second--;
 else Overflow++;
  //按鍵掃描函數(shù)
 void KeyScan()
 uint x=1000;
  while(x--)
  P1=0xff;
 Keystate=P1&0x03;
 display();
 delay(50);
 if(Keystate!=0x03)
    delayms(2);  //去抖
   if(Keystate!=0x03)//去抖后再確認一下
    delayms(1);
     switch(Keystate)
     case 0x01:minute++;
               if(minute==60)minute=0;
               break;
     case 0x02:minute--;
              if(minute==0)minute=59;
              break;
     default:break;
  while(P1!=0xff)display();    //松手檢測并保證可以從循環(huán)中出來
 timer0start();
主站蜘蛛池模板: 亚洲福利专区 | 国产女人高潮毛片 | 国产精品毛片va一区二区三区 | 欧美国产精品一区二区 | 综合色av | 一区二区三区在线免费 | 精品国产91 | 免费在线观看av | 91午夜精品亚洲一区二区三区 | 一级黄色在线观看 | 老司机免费福利视频 | 日本毛片在线观看 | 欧美激情啪啪 | 在线看日韩 | 国产精品一区二区av | 国产精品视频免费看 | 亚洲最大黄色网址 | 午夜黄色大片 | 91成人精品一区在线播放 | 免费视频久久久 | 最新日韩av | 最新国产精品视频 | 一区二区三区四区精品 | 黄色一节片 | 黄色免费观看视频 | 久久青 | 99久久精品国产一区二区三区 | 高潮毛片又色又爽免费 | 国产伊人网 | 成人免费视频国产免费麻豆 | 亚洲www啪成人一区二区麻豆 | 国产午夜影院 | 国产精品一区二 | 黄色片免费网站 | 精品蜜桃一区二区三区 | 久操视频在线观看 | 精品久久久久久久久久久久久 | 黄色精品网站 | 日韩一区二区三区视频 | 免费一区二区视频 | 可以在线观看的av |
