查看: 17800|回復: 18
手機app連接wifi模塊esp8266
ID:564334 發表于 2019-6-26 16:03 | 顯示全部樓層 |閱讀模式
本帖最后由 ldxxin 于 2019-6-26 16:09 編輯
這個是主程序
package
com.example.a123.myapplication;
import android.support.v7.app.AppCompatActivity;
import android.os.Bundle;
import android.view.View;
import android.widget.Button;
import android.widget.EditText;
import android.widget.Toast;
import java.io.IOException;
import java.io.PrintStream;
import java.net.Socket;
public class MainActivity extends AppCompatActivity implements View.OnClickListener {
    private EditText mIp;   //  IP
private EditText mPort;     //  端口號
private String mStrIp;      //  字符串類型ip
private int miPort;    //  字符類型端口
private Button mBtnConnect; //  連接
private Socket mSocket;     //  套接字
private PrintStream out;    //  打印輸出流
private ConnectThread mConnectThread;   //  TCP連接線程
private Button mMotorZ;      //  按鈕LED燈開
private Button mMoyorF;     //  按鈕LED燈關
@Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        mBtnConnect=(Button)findViewById(R.id.mBt1);
        mMotorZ=(Button)findViewById(R.id.mBt2);
        mMoyorF=(Button)findViewById(R.id.mBt3);
        mIp=(EditText)findViewById(R.id.mEtIP);
        mPort=(EditText)findViewById(R.id.mEtPort);
        mBtnConnect.setOnClickListener(this);
        mMotorZ.setOnClickListener(this);
        mMoyorF.setOnClickListener(this);
    @Override
    public void onClick(View v) {
        switch(v.getId()){
            case R.id.mBt1:
                if( mSocket == null || ! mSocket.isConnected()) {
                    mStrIp = mIp.getText().toString();
                    miPort = Integer.valueOf(mPort.getText().toString());
                    mConnectThread = new ConnectThread(mStrIp, miPort);
                    mConnectThread.start();
                    if(mSocket != null && mSocket.isConnected()){
                        try {
                            mSocket.close();
                            mSocket=null;   //  清空mSocket
mBtnConnect.setText("連接");
                            Toast.makeText(MainActivity.this,"連接已關閉", Toast.LENGTH_LONG).show();
                        } catch (IOException e) {
                            e.printStackTrace();
                          break;
                    case R.id.mBt2:
                        if(out!=null){
                            out.print("0");
                            out.flush();
                        break;
                        case R.id.mBt3:
                          if (out!=null){
                         out.print("1");
                         out.flush();
                             break;
    private class ConnectThread extends Thread{
        private String ip;
        private int port;
        public ConnectThread(String ip,int port){
            this.ip=ip;
            this.port=port;
        @Override
        public void run() {
            try {
                mSocket=new Socket(ip,port);
                out = new PrintStream(mSocket.getOutputStream());
                runOnUiThread(new Runnable(){
                    @Override
                    public void run() {
                        mBtnConnect.setText("斷開");
                        Toast.makeText(MainActivity.this,"連接成功",Toast.LENGTH_LONG).show();
                @Override
                public void run() {
                        Toast.makeText(MainActivity.this,"連接失敗",Toast.LENGTH_LONG).show();
以下是AndroidManifest.xml文件的配置
<?xml version="1.0" encoding="utf-8"?>
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
    xmlns:tools="http://schemas.android.com/tools"
    package="com.example.a123.myapplication">
添加以下的才能與esp8266通信
<uses-permission android:name="android.permission.INTERNET"></uses-permission>
    <uses-permission android:name="android.permission.WRITE_EXTERNAL_STORAGE"></uses-permission>
    <uses-permission android:name="android.permission.READ_EXTERNAL_STORAGE"></uses-permission>
以下是界面的一些程序
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:app="http://schemas.android.com/apk/res-auto"
android:layout_width="match_parent"
android:layout_height="match_parent"
android:orientation="vertical"
tools:context=".MainActivity"
tools:ignore="Deprecated">
    <TextView
android:layout_width="wrap_content"
android:layout_height="wrap_content"
android:layout_x="9dp"
android:layout_y="24dp"
android:text="服務器IP:"
android:textSize="20dp"
tools:ignore="HardcodedText,MissingConstraints,ObsoleteLayoutParam,SpUsage" />
    <EditText
android:id="@+id/mEtIP"
android:layout_x="112dp"
android:layout_y="20dp"
android:ems="10"
android:inputType="textPersonName"
android:text="192.168.4.1"
tools:ignore="HardcodedText,LabelFor,ObsoleteLayoutParam" />
    <TextView
android:layout_x="36dp"
android:layout_y="86dp"
android:text="端口:"
    <EditText
android:id="@+id/mEtPort"
android:layout_x="113dp"
android:layout_y="66dp"
android:ems="10"
android:text="8089"
    <Button
android:id="@+id/mBt1"
android:layout_height="59dp"
android:layout_x="155dp"
android:layout_y="173dp"
android:text=""
tools:ignore="HardcodedText,ObsoleteLayoutParam"
tools:layout_editor_absoluteX="144dp"
tools:layout_editor_absoluteY="163dp" />
    <Button
android:id="@+id/mBt2"
android:layout_height="69dp"
android:text="開"
tools:ignore="HardcodedText" />
    <Button
android:id="@+id/mBt3"
android:layout_height="72dp"
android:text="關"
</LinearLayout>
ID:263427 發表于 2019-11-19 09:24 | 顯示全部樓層
我以前寫這個APP的時候經常忘記了加權限,導致調試不成功,所以大家一定要注意。
還有大家復制代碼的時候一定要理解其中的核心邏輯,才能自己編寫...
ID:72988 發表于 2019-12-19 09:24 | 顯示全部樓層
非常好!!!
ID:527251 發表于 2020-3-5 22:40 | 顯示全部樓層
非常好,必須的謝謝了,困擾了好久
ID:361216 發表于 2020-5-2 23:16 | 顯示全部樓層
唉,就想整個現成的APP,有學習困難癥啊!
ID:69408 發表于 2020-5-3 22:23 | 顯示全部樓層
不知道朋友這個APP是用什么軟件寫的哦,怎么用eclipse在第一句這里 AppCompatActivity就報錯誤
ID:592184 發表于 2020-5-7 18:16 | 顯示全部樓層
denminshen 發表于 2020-5-3 22:23
androidstudio
ID:69408 發表于 2020-5-12 11:55 | 顯示全部樓層
樓主朋友你好,我根據朋友發的這個APP程序,用eclipse里也編譯成功了,在電腦上用AVD5554里運行,將WiFi模塊連接到電腦上在串口助手里也可以顯示到接收到的開關信號0和1如下圖串口助手最后接收的就是: qwe.JPG 可是將APP安裝在手機上一點擊開或者關按鍵APP就閃退了串口助手里還是有顯示的就是不正確的內容了如下圖: JPG.JPG 請問是怎么回事啊!謝謝啦!!!
ID:69408 發表于 2020-5-14 11:51 | 顯示全部樓層
不好意思!樓主的這個APK非常好的,只是我在eclipse里編譯創建時選最高運行的版本時選的安卓4.4,因為我只下載了4.4的編譯平臺,可是我生成的apk又用在了安卓7.1的手機上所以發生閃退,我又下載了安卓5.1.1,因為我還有一個5.1.1的舊手機,最后用5.1.1重新編譯后可以使用這個APK了,非常感謝樓主
ID:152184 發表于 2021-1-15 23:31 來自觸屏版 | 顯示全部樓層
高手,膜拜大神。
ID:880184 發表于 2021-1-24 16:54 來自觸屏版 | 顯示全部樓層
拜膜,大神>o<!?
ID:880590 發表于 2021-1-27 11:33 | 顯示全部樓層
能設計成無線調試?
ID:190577 發表于 2022-8-8 21:27 | 顯示全部樓層
你好,你這個代碼基于什么軟件寫的
ID:368534 發表于 2022-11-30 11:45 | 顯示全部樓層
bbxyliyang 發表于 2022-8-8 21:27
你好,你這個代碼基于什么軟件寫的
他這個是Android studio開發的,主要介紹TCP的Socket通信類的使用,了解Socket后看他代碼就一目了然了。還有這里是把ESP8266當成服務器使用的。
ID:1075303 發表于 2023-5-6 06:49 | 顯示全部樓層
精彩的帖子,收藏了
ID:359281 發表于 2023-8-10 13:41 | 顯示全部樓層
精彩的帖子,收藏了
ID:359281 發表于 2023-8-21 17:54 | 顯示全部樓層
謝謝!用E4A寫的控制ESP8266的二路LED燈的源程序有嗎?
ID:359281 發表于 2023-8-25 14:24 | 顯示全部樓層
非常好,必須的謝謝了
ID:359281 發表于 2023-9-8 14:32 | 顯示全部樓層
謝謝!控制ESP8266的二路LED燈的源程序有嗎?
主站蜘蛛池模板: 草草网| 精品影院| 一级片在线播放 | 欧美一级做性受免费大片免费 | a视频在线免费观看 | 亚洲午夜在线观看 | 国产超碰人人模人人爽人人添 | 亚洲免费精品 | 日本乱子伦 | 国产理论片在线观看 | 国产精品国产精品国产专区不片 | 午夜久久久久久久 | 国产伦精品一区二区三区四区免费 | аⅴ资源新版在线天堂 | 在线观看免费黄色 | 久热中文字幕 | 久草免费福利视频 | 一级片毛片 | a级片在线观看 | 伊人成人在线 | www.青青草| 中文字幕在线不卡 | 欧美日韩视频一区二区 | 久久在线视频 | 午夜精品久久久久久久 | 992tv在线| 亚洲综合自拍 | 久久国产一区二区三区 | 精品在线免费视频 | 日本久久网站 | 一色桃子av| 国产一级片免费观看 | 国产精品久久久一区二区三区 | 国产欧美精品一区二区三区 | 成人免费精品 | 天天精品视频 | 国产精品嫩草影院桃色 | 久久久精品国产sm调教网站 | 日韩有码在线视频 | 欧美另类激情 | 欧美日韩91 |
