程序通過輸出直接Printf_lcd 打印就可以顯示,附件包含有字模取模和圖片取模方式!
可顯示數(shù)值和字符
可顯示圖片
- 取模軟件 液晶漢字字模提取
- // 漢字字模表 //
- // 漢字庫: 宋體16.dot 縱向取模下高位,數(shù)據(jù)排列:從左到右從上到下 輸出大小設(shè)置128*64 然后輸入字符串
- #include<reg51.h> //包含頭文件,一般情況不需要改動,頭文件包含特殊功能寄存器的定義
- #include<stdio.h>
- #include "delay.h"
- #include "math.h"
- #include "string.h"
- #include "ascii_hz.h"
- #include "12864.h"
- #define uchar unsigned char
- #define uint unsigned int
- sbit JIESHOU=P3^7;
- sbit led=P1^4;
- unsigned char uart_rx_finish=0;
- unsigned char uart_rx_cnt=0;
- unsigned char uart_rx_cnt_before=0;
- //char dis0[32]; //串口數(shù)據(jù)顯示
- unsigned char dis2[17]; //串口數(shù)據(jù)顯示
- unsigned char dis3[17]; //去掉后綴0x0d 0x0a
- unsigned long time_20ms=0; //定時器計數(shù)
- void Init_Timer0(void); //函數(shù)聲明
- void SendStr(unsigned char *s,unsigned char length);
- void UART_Init(void);
- void SendByte(unsigned char dat);
- void puts_to_SerialPort(uchar *s);
- void main (void)
- uchar i=0;
- Init_Timer0(); //定時器0初始化
- UART_Init();
- InitLcd(); //初始化液晶
- puts_to_SerialPort("Receiving From 8051...\r\n");
- lcd12864_write_one(0,0,"二維碼測試系統(tǒng)");
- lcd12864_write_one(2,0,"接收我二維碼: ");
- // InitLcd(); //初始化液晶
- // tupiandisplay();
- // DelayS(5);
- while (1) //主循環(huán)
- if(JIESHOU==0){
- tupiandisplay();
- if(uart_rx_finish==1){
- uart_rx_finish=0;
- // lcd12864_write_one(2,0," ");//顯示
- // lcd12864_write(4,0,dis2,"","");//顯示
- uart_rx_cnt_before=uart_rx_cnt;
- uart_rx_cnt=0;
- // memset(dis2,' ',sizeof(dis2));
- // if(tx_send==0){
- // DelayMs(20);
- // if(tx_send==0) {
- // puts_to_SerialPort("PC Receiving From 8051...\r\n");
- // while(!tx_send);
- TMOD |= 0x01; //使用模式1,16位定時器,使用"|"符號可以在使用多個定時器時不受影響
- TH0=(65536-20000)/256; //重新賦值 20ms
- TL0=(65536-20000)%256;
- EA=1; //總中斷打開
- ET0=1; //定時器中斷打開
- TR0=1; //定時器開關(guān)打開
- void Timer0_isr(void) interrupt 1
- time_20ms++;
- if(time_20ms%50==0) //1s時間發(fā)藍牙
- led=~led;
- SCON = 0x50; // SCON: 模式 1, 8-bit UART, 使能接收
- TMOD |= 0x20; // TMOD: timer 1, mode 2, 8-bit 重裝
- PCON = 0x00;
- TH1 = 0xFD; // TH1: 重裝值 9600 波特率 晶振 11.0592MHz
- TL1 = TH1;
- TR1 = 1; // TR1: timer 1 打開
- EA = 1; //打開總中斷
- ES = 1; //打開串口中斷
- void SendByte(unsigned char dat)//串口發(fā)送單字節(jié)數(shù)據(jù)
- unsigned char time_out;
- time_out=0x00;
- SBUF = dat; //將數(shù)據(jù)放入SBUF中
- while((!TI)&&(time_out<100)) //檢測是否發(fā)送出去
- {time_out++;DelayUs2x(10);} //未發(fā)送出去 進行短暫延時
- TI = 0; //清除ti標(biāo)志
- void SendStr(unsigned char *s,unsigned char length) //發(fā)送定長度字符串
- unsigned char NUM;
- NUM=0x00;
- while(NUM<length) //發(fā)送長度對比
- SendByte(*s); //放松單字節(jié)數(shù)據(jù)
- s++; //指針++
- NUM++; //下一個++
- while(*s != '\0')
- SendByte(*s);
- s++;
- DelayMs(5);
- void UART_SER (void) interrupt 4 //串行中斷服務(wù)程序
- uchar c;
- if(RI) //判斷是接收中斷產(chǎn)生
- c = SBUF;
- if(c=='\n') {
- uart_rx_finish=1;
- dis2[uart_rx_cnt]='\0';
二維碼顯示C51_V2圖片.rar
(8.66 MB, 下載次數(shù): 235)
2019-6-27 21:28 上傳
點擊文件名下載附件
