1、注意protues版本應當在8.7版本以上,8.6版本聯想后可能會出現IO讀入不能讓那個實現問題。
2、注意設置好電網,把初始的VSS和VDD添加進組。
3、注意設置好芯片界面下的默認晶振值,外接電路晶振沒有作用。
- #include "pbdata.h"
- u16 fre;
- void RCC_Configuration(void);
- void GPIO_Configuration(void);
- void TIM3_Configuration();
- void Delay (uint32_t nCount)
- for(; nCount != 0; nCount--);
- int main(void)
- u16 arr=42000;
- u16 led_dt = arr/2;
- RCC_Configuration(); //系統時鐘初始化
- GPIO_Configuration();//端口初始化
- TIM3_Configuration(arr);//定時器和pwm配置
- while(1)
- TIM_SetCompare2(TIM3,led_dt); //用的是TIM3的通道2,輸出PWM 送到相應的寄存器中 //滿占空比為900
- GPIO_SetBits(GPIOB,GPIO_Pin_5); //LED 發光
- Delay(0x2ffff);
- GPIO_ResetBits(GPIOB,GPIO_Pin_5);//LED 熄滅
- Delay(0x2ffff);
- // if(GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_7)== Bit_RESET)
- // //LED 發光
- // GPIO_SetBits(GPIOB,GPIO_Pin_5);
- // else
- // //LED 熄滅
- // GPIO_ResetBits(GPIOB,GPIO_Pin_5);
- SystemInit();
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1,ENABLE);//這個是必須的,仿真軟件必須的
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);//端口復用,一定在APB2的時鐘線
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,ENABLE);
- GPIO_InitTypeDef GPIO_InitStructure;
- //PWM
- GPIO_InitStructure.GPIO_Pin= GPIO_Pin_7;
- GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP; //通過PWM控制,端口為復用方式輸出
- GPIO_Init(GPIOA,&GPIO_InitStructure);
- //LED
- GPIO_InitStructure.GPIO_Pin= GPIO_Pin_5;
- GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
- GPIO_Init(GPIOB,&GPIO_InitStructure);
- //BUTTON
- GPIO_InitStructure.GPIO_Pin=GPIO_Pin_7;
- GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IPD;
- GPIO_Init(GPIOC,&GPIO_InitStructure);
- void TIM3_Configuration(arr)
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStruct;
- TIM_OCInitTypeDef TIM_OCInitStructure; //PWM的結構體
- GPIO_PinRemapConfig(GPIO_PartialRemap_TIM3,ENABLE);//TIM3 復用功能部分映射,可以此找到對應的管腳
- //關于部分映射可以參考“STM32參考手冊”119面
- //定時器初始化
- TIM_TimeBaseStruct.TIM_Period=arr;//初值
- TIM_TimeBaseStruct.TIM_Prescaler=2;//預分頻
- //不分頻,在晶振為72MHz的情況下,定時器執行到899后即會溢出,表示計數滿
- TIM_TimeBaseStruct.TIM_ClockDivision=0;
- TIM_TimeBaseStruct.TIM_CounterMode=TIM_CounterMode_Up;//向上
- TIM_TimeBaseInit(TIM3,&TIM_TimeBaseStruct);
- //pwm初始化
- TIM_OCInitStructure.TIM_OCMode=TIM_OCMode_PWM1; //使用模式1
- TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable; //使能位
- TIM_OCInitStructure.TIM_OCPolarity=TIM_OCPolarity_High; //設置輸出極性,一定注意
- TIM_OC2Init(TIM3,&TIM_OCInitStructure);
- TIM_OC2PreloadConfig(TIM3,TIM_OCPreload_Enable); //與裝載使能,不會說執行一次后就不執行了
- TIM_Cmd(TIM3,ENABLE);
- /*PWM不是中斷,所以不需要設置中斷優先級 */
protues仿真stm32f103輸出PWM.7z
(241.09 KB, 下載次數: 453)
2019-6-29 16:37 上傳
點擊文件名下載附件
