晶聯(lián)訊JLX12864G液晶屏(COG封裝) STM32F103T6驅(qū)動(dòng)(ST7567/ST7565R),從官方規(guī)格書(shū)C51單片機(jī)代碼移植,!
下載附件
2019-6-30 17:03 上傳
單片機(jī)源程序如下:
- #include "stm32f10x.h"
- #include "key.h"
- #include "lcd.h"
- unsigned char cheng1[];
- unsigned char gong1[];
- unsigned char zhuang1[];
- unsigned char tai1[];
- unsigned char shi1[];
- unsigned char yong1[];
- unsigned char bmp_12864_1[];
- unsigned char bmp_12864_2[];
- unsigned char bmp_12864_3[];
- unsigned char bmp_12864_4[];
- unsigned char bmp_12864_5[];
- unsigned char bmp_12864_6[];
- unsigned char Bmp_Tou[];
- int main(void)
- LCD_GPIO_Config();
- KEY_GPIO_Config();
- while(1)
- initial_lcd();
- clear_screen(); //clear all dots
- test_display(0x55,0xff); //全顯示
- waitkey();
- //delay(3000);
- test_display(0x55,0xaa); //雪花1
- waitkey();
- //delay(3000);
- test_display(0xaa,0x55); //雪花2
- waitkey();
- //delay(3000);
- display_graphic_128x64(1,1,bmp_12864_1); //顯示12864點(diǎn)陣圖片 回字型圖案
- waitkey();
- //delay(3000);
- display_graphic_128x64(1,1,bmp_12864_2);
- waitkey();
- //delay(3000);
- display_graphic_128x64(1,1,bmp_12864_3);
- waitkey();
- //delay(3000);
- display_graphic_128x64(1,1,bmp_12864_4);
- waitkey();
- //delay(3000);
- display_graphic_128x64(1,1,bmp_12864_5);
- waitkey();
- //delay(3000);
- display_graphic_128x64(1,1,bmp_12864_6);
- waitkey();
- //delay(3000);
- display_graphic_32x32(1,(1+32*1),cheng1); /*在第1頁(yè),第49列顯示單個(gè)漢字"成"*/
- display_graphic_32x32(1,(1+32*2),gong1); /*在第1頁(yè),第49列顯示單個(gè)漢字"功"*/
- display_graphic_16x16_2(0,6,1,zhuang1); /*在第5頁(yè),第1列顯示單個(gè)漢字"狀"*/
- display_graphic_16x16_2(0,6,(1+16),tai1); /*在第5頁(yè),第17列顯示單個(gè)漢字"態(tài)"*/
- display_string_8x16(6,(1+16+16),":"); /*在第5頁(yè),第25列顯示單個(gè)字符":"*/
- display_graphic_16x16(6,(1+16*2+8),shi1); /*在第5頁(yè),第41列顯示單個(gè)漢字"使"*/
- display_graphic_16x16(6,(1+16*3+8),yong1); /*在第5頁(yè),第49列顯示單個(gè)漢字"用"*/
- display_string_8x16(6,89,"12:45"); /*在第5頁(yè),第89列顯示單個(gè)數(shù)字"0"*/
- waitkey();
- //delay(3000);
- display_string_8x16(1,1,"0123456789abcdef");/*在第1頁(yè),第1列顯示字符串*/
- display_string_8x16(3,1,"~`!@#$%^&*()_-+=");/*在第*頁(yè),第*列顯示字符串*/
- display_string_5x8(5,1," ! #$%&'()*+,-./01234");
- display_string_5x8(6,1,"56789:;<=>?@ABCDEFGHI");
- display_string_5x8(7,1,"JKLMNOPQRSTUVWXYZ[\\]^");
- display_string_5x8(8,1,"_`abcdefghijklmnopqrs");
- waitkey();
- //delay(3000);
- unsigned char Bmp_Tou[]={0x00,0x10,0x10,0x10,0xFE,0x90,0x10,0xC0,0xBC,0x84,0x84,0xBE,0xC4,0x40,0x40,0x00,
- 0x00,0x02,0x22,0x41,0x3F,0x00,0x40,0x40,0x23,0x14,0x08,0x16,0x21,0x60,0x20,0x00};//投,16*16
- unsigned char cheng1[]={
- /*-- 文字: 成 --*/
- /*-- 宋體23; 此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=31x31 --*/
- /*-- 高度不是8的倍數(shù),現(xiàn)調(diào)整為:寬度x高度=32x32 --*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0C,
- 0xFC,0xFC,0x88,0x00,0x00,0x1C,0x78,0xF0,0xE0,0x00,0x80,0x80,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0xFF,0xFF,0x83,0x83,0x83,0x83,0x83,0x83,0xC3,0xC3,0x03,0x1F,
- 0xFF,0xFF,0x83,0x03,0x03,0x03,0xC3,0xF3,0xF3,0x63,0x03,0x03,0x00,0x00,0x00,0x00,
- 0x00,0x00,0xFC,0xFF,0x3F,0x00,0x80,0x00,0x00,0x80,0xFF,0xFF,0x03,0x00,0x00,0x03,
- 0x9F,0xFF,0xF8,0xF8,0xBE,0x1F,0x07,0x01,0x00,0x00,0xE0,0x20,0x00,0x00,0x20,0x38,
- 0x1F,0x07,0x01,0x00,0x00,0x01,0x01,0x07,0x07,0x23,0x31,0x18,0x0C,0x0E,0x07,0x03,
- 0x01,0x01,0x01,0x03,0x07,0x0F,0x0E,0x1C,0x1F,0x3F,0x30,0x00,0x00,0x00,0x00,0x00};
- unsigned char gong1[]={
- /*-- 文字: 功 --*/
- 0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0xC0,0xC0,0xC0,0x00,
- 0x00,0x00,0x00,0xFE,0xFC,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00,0x00,0x0C,0x04,0x04,
- 0x04,0x84,0xFF,0xFF,0x04,0x04,0x04,0x04,0x04,0xFE,0xFE,0x04,0x00,0x00,0x00,0x00,
- 0xC0,0xC0,0xC0,0xC0,0xE0,0x60,0x7F,0x3F,0x30,0x30,0x10,0x18,0x18,0x88,0xC0,0xF8,
- 0x7F,0x1F,0x01,0x00,0x00,0x00,0x00,0xF8,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x01,
- 0x01,0x00,0x00,0x00,0x00,0x20,0x20,0x30,0x18,0x0C,0x0C,0x07,0x03,0x01,0x00,0x04,
- 0x04,0x0C,0x0C,0x1C,0x38,0x3C,0x1F,0x0F,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
- unsigned char zhuang1[]={
- /*-- 文字: 狀 --*/
- /*-- 宋體12; 此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=16x16 --*/
- 0x08,0x30,0x00,0xFF,0x20,0x20,0x20,0x20,0xFF,0x20,0xE1,0x26,0x2C,0x20,0x20,0x00,
- 0x04,0x02,0x01,0xFF,0x40,0x20,0x18,0x07,0x00,0x00,0x03,0x0C,0x30,0x60,0x20,0x00};
- unsigned char tai1[]={
- /*-- 文字: 態(tài) --*/
- 0x00,0x04,0x04,0x04,0x84,0x44,0x34,0x4F,0x94,0x24,0x44,0x84,0x84,0x04,0x00,0x00,
- 0x00,0x60,0x39,0x01,0x00,0x3C,0x40,0x42,0x4C,0x40,0x40,0x70,0x04,0x09,0x31,0x00};
- unsigned char shi1[]={
- /*-- 文字: 使 --*/
- …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
JHDLCDSTM32.7z
(667.43 KB, 下載次數(shù): 460)
2019-6-30 18:42 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
