查看: 3947|回復: 1
超聲波模塊與主板接線示意圖及Arduino測試代碼
#include <Servo.h>
int pinLB=14;     // Define a 14 Pin
int pinLF=15;     // Define a 15 Pin
int pinRB=16;    // Define a 16 Pin
int pinRF=17;    // Define a 17 Pin
int MotorLPWM=5;  //Define a 5 Pin
int MotorRPWM=6;  //Define a 6 Pin
int inputPin = 9;  // Define the ultrasound signal receiving a Pin
int outputPin =8;  //Define the ultrasound signal emission Pin
int Fspeedd = 0;      // go
int Rspeedd = 0;      // The right to
int Lspeedd = 0;      // Turn left to
int directionn = 0;   // After the former = 8 = 2 left = 4 right = 6
Servo myservo;        // Set up the myservo
int delay_time = 250; // After the servo motor to the stability of the time
int Fgo = 8;         // go
int Rgo = 6;         // The right to
int Lgo = 4;         // Turn left to
int Bgo = 2;         // astern
void setup()
  Serial.begin(9600);     // Initialize
  pinMode(pinLB,OUTPUT); // Define 14 pin for the output (PWM)
  pinMode(pinLF,OUTPUT); // Define 15 pin for the output (PWM)
  pinMode(pinRB,OUTPUT); // Define 16 pin for the output (PWM)
  pinMode(pinRF,OUTPUT); // Define 17 pin for the output (PWM)
  pinMode(MotorLPWM,  OUTPUT);  // Define 5 pin for PWM output
  pinMode(MotorRPWM,  OUTPUT);  // Define 6 pin for PWM output
  pinMode(inputPin, INPUT);    // Define the ultrasound enter pin
  pinMode(outputPin, OUTPUT);  // Define the ultrasound output pin
  myservo.attach(11);    // Define the servo motor output 10 pin(PWM)
void advance(int a)     // go
     digitalWrite(pinRB,LOW);  // 16 feet for high level
     digitalWrite(pinRF,HIGH);   //17 feet for low level
     analogWrite(MotorRPWM,180);//Set the output speed(PWM)
     digitalWrite(pinLB,LOW);  // 14 feet for high level
     digitalWrite(pinLF,HIGH);   //15 feet for high level
     analogWrite(MotorLPWM,180);//Set the output speed(PWM)
     delay(a * 1);
void right(int b)        //right
     digitalWrite(pinRB,HIGH);
     digitalWrite(pinRF,LOW);
     analogWrite(MotorRPWM,250);
     digitalWrite(pinLF,LOW);
     delay(b * 100);
void left(int c)         //left
     analogWrite(MotorLPWM,250);
     delay(c * 100);
void turnR(int d)        //right
     digitalWrite(pinLB,HIGH);
     delay(d * 50);
void turnL(int e)        //left
     analogWrite(MotorRPWM,220);
     analogWrite(MotorLPWM,220);
     delay(e * 50);
void stopp(int f)         //stop
     delay(f * 100);
void back(int g)          //back
     analogWrite(MotorRPWM,0);
     analogWrite(MotorLPWM,230);
     delay(g * 500);
void detection()        //Measuring three angles(0.90.179)
      int delay_time = 200;   // After the servo motor to the stability of the time
      ask_pin_F();            // Read in front of the distance
     if(Fspeedd < 10)         // If the front distance less than 10 cm
      stopp(1);               // Remove the output data
      back(2);                // The back two milliseconds
      if(Fspeedd < 25)         // If the front distance less than 25 cm
        ask_pin_L();            // Read the left distance
        delay(delay_time);      // Waiting for the servo motor is stable
        ask_pin_R();            // Read the right distance
        if(Lspeedd > Rspeedd)   //If the distance is greater than the right distance on the left
         directionn = Lgo;      //Left
        if(Lspeedd <= Rspeedd)   //If the distance is less than or equal to the distance on the right
         directionn = Rgo;      //right
        if (Lspeedd < 15 && Rspeedd < 15)   /*If the left front distance and distance and the right distance is less than 15 cm */
         directionn = Bgo;      //Walk backwards
      else                      //If the front is not less than 25 cm (greater than)
        directionn = Fgo;        //Walk forward
void ask_pin_F()   // Measure the distance ahead
      myservo.write(90);
      digitalWrite(outputPin, LOW);   // For low voltage 2 us ultrasonic launch
      delayMicroseconds(2);
      digitalWrite(outputPin, HIGH);  // Let ultrasonic launch 10 us high voltage, there is at least 10 us
      delayMicroseconds(10);
      digitalWrite(outputPin, LOW);    // Maintaining low voltage ultrasonic launch
      float Fdistance = pulseIn(inputPin, HIGH);  // Read the time difference
      Fdistance= Fdistance/5.8/10;       // A time to distance distance (unit: cm)
      Serial.print("F distance:");      //The output distance (unit: cm)
      Serial.println(Fdistance);         //According to the distance
      Fspeedd = Fdistance;
void ask_pin_L()   // Measure the distance on the left
      myservo.write(5);
      delay(delay_time);
      float Ldistance = pulseIn(inputPin, HIGH);  // Read the time difference
      Ldistance= Ldistance/5.8/10;       // Will be time to distance distance (unit: cm)
      Serial.print("L distance:");       //The output distance (unit: cm)
      Serial.println(Ldistance);         //According to the distance
      Lspeedd = Ldistance;              // Will reading Lspeedd distance
void ask_pin_R()   // Measure the distance on the right
      myservo.write(177);
      delay(delay_time);
      float Rdistance = pulseIn(inputPin, HIGH);  // Read the time difference
      Rdistance= Rdistance/5.8/10;       //Will be time to distance distance (unit: cm)
      Serial.print("R distance:");       //The output distance (unit: cm)
      Serial.println(Rdistance);         //According to the distance
      Rspeedd = Rdistance;
void loop()
    myservo.write(90);  /*Make the servo motor ready position Prepare the next measurement */
    detection();        //Measuring Angle And determine which direction to go to
   if(directionn == 2)  //If directionn (direction) = 2 (back)
     back(8);                    //  back
     turnL(2);                   //Move slightly to the left (to prevent stuck in dead end lane)
     Serial.print(" Reverse ");   //According to the direction (reverse)
   if(directionn == 6)           //If directionn (direction) = 6 (right)
     back(1);
     turnR(6);                   // right
     Serial.print(" Right ");    //According to the direction (Right)
   if(directionn == 4)          //If directionn (direction) = 4 (left)
     back(1);
     turnL(6);                  // left
     Serial.print(" Left ");     //According to the direction (Left)
   if(directionn == 8)          //If directionn (direction) = 8 (forward)
    advance(1);                 // go
    Serial.print(" Advance ");   //According to the direction (Advance)
    Serial.print("   ");
超聲波測試代碼.rar
1.97 KB, 下載次數: 4, 下載積分: 黑幣 -5
ID:558099 發表于 2019-7-2 18:09 | 只看該作者
需要的可以拿去做測試
主站蜘蛛池模板: 精品亚洲一区二区 | 欧美日韩国产二区 | 国产一区二区中文字幕 | 五月婷婷色| 日韩香蕉视频 | 在线视频a| 国产精品乱码一区二区视频 | 97免费在线| 一级片免费 | 99久久婷婷国产综合精品草原 | 成人免费在线视频 | 涩色av | 色播av | www.色偷偷| 一区二区免费在线观看 | 欧美 日韩 国产 成人 在线 | 黄视频网站在线观看 | 一区二区三区久久久 | 精品日韩在线观看 | 欧美激情视频一区二区三区 | 国产aaaaaa | av狠狠干 | 日韩一级在线 | av手机版 | 国产一级网站 | 三级在线看 | 婷婷色av | 久久精品福利 | 蜜臀久久99精品久久久久宅男 | 国产欧美精品 | 亚洲欧美另类在线 | 久久精品视频免费 | 久久久天堂 | 亚洲国产精品久久久久久久 | 国产欧美欧洲 | 中文字幕永久免费 | 91看片网 | 亚洲欧美日韩一区二区三区四区 | 91污视频在线观看 | 国产精品手机在线观看 | 黄色av日韩|
