查看: 3932|回復(fù): 4
stm32f103zet6對(duì)sg90的控制源程序
ID:309976 發(fā)表于 2019-7-5 17:42 | 顯示全部樓層 |閱讀模式
此程序使了tim3定時(shí)器的pwm功能,驅(qū)動(dòng)信號(hào)頻率為250hz,已注明配置好的頻率大致對(duì)應(yīng)的角度,可同時(shí)產(chǎn)生4路pwm信號(hào)驅(qū)動(dòng)4個(gè)舵機(jī),pwm初始化程序參考了網(wǎng)上的大佬,轉(zhuǎn)角用TIM_SetComparex函數(shù)可以實(shí)時(shí)控制,已測(cè)試可用。
單片機(jī)源程序如下:
  1. #include "public.h"
  2. //中值為650,250為90度多一點(diǎn)
  3. //4個(gè)舵機(jī)TIM3 4個(gè)通道
  4. int main()
  5. {
  6.         PWM_Init();
  7.         TIM_Config(288,1000);     //頻率為250
  8.         while(1)
  9.         {
  10.                 Timer3_PWM_SetDutyCycle(1,675);
  11.                 delay_ms(2000);
  12.                 Timer3_PWM_SetDutyCycle(1,800);
  13.                 delay_ms(2000);
  14.         }
  15. }
  1. #include "pwm.h"
  2. void PWM_Init(void)
  3. {
  4.     GPIO_InitTypeDef GPIO_InitStructure;
  5.                 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  6.                 RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
  7.     RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
  8.                 GPIO_PinRemapConfig(GPIO_FullRemap_TIM3,ENABLE);
  9.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  10.     GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AF_PP;
  11.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9;
  12.     GPIO_Init(GPIOC, &GPIO_InitStructure);
  13. }
  14. void TIM_Config(u8 arr,u8 psc)
  15. {
  16.     TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
  17.     TIM_OCInitTypeDef  TIM_OCInitStructure;
  18.     //定時(shí)器配置
  19.     TIM_TimeBaseStructure.TIM_Prescaler = arr-1;//設(shè)置分頻
  20.     TIM_TimeBaseStructure.TIM_Period = psc-1;//設(shè)置計(jì)數(shù)溢出大小,每計(jì)psc個(gè)數(shù)就產(chǎn)生一個(gè)更新事件
  21.     TIM_TimeBaseStructure.TIM_ClockDivision = 0;//設(shè)置時(shí)鐘分割
  22.     TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;//設(shè)置計(jì)數(shù)器模式為向上計(jì)數(shù)模式
  23.     TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);//將配置應(yīng)用到TIM3中
  24.     //PWM配置ch1
  25.     TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; //配置為PWM模式2
  26.     TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比較輸出使能
  27.     TIM_OCInitStructure.TIM_Pulse = 0; //設(shè)置待裝入捕獲比較寄存器的脈沖值
  28.     TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High ; //有效電平為高電平
  29.     TIM_OC1Init(TIM3, &TIM_OCInitStructure);//使能通道1
  30.     TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);
  31.     //PWM配置ch2
  32.     TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比較輸出使能
  33.     TIM_OCInitStructure.TIM_Pulse = 0; //設(shè)置待裝入捕獲比較寄存器的脈沖值
  34.
  35.     TIM_OC2Init(TIM3, &TIM_OCInitStructure);//使能通道2
  36.     TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable);
  37.     //PWM配置ch3
  38.     TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比較輸出使能
  39.     TIM_OCInitStructure.TIM_Pulse = 0; //設(shè)置待裝入捕獲比較寄存器的脈沖值
  40.
  41.     TIM_OC3Init(TIM3, &TIM_OCInitStructure);//使能通道3
  42.     TIM_OC3PreloadConfig(TIM3, TIM_OCPreload_Enable);
  43.     //PWM配置ch4
  44.     TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比較輸出使能
  45.     TIM_OCInitStructure.TIM_Pulse = 0; //設(shè)置待裝入捕獲比較寄存器的脈沖值
  46.
  47.     TIM_OC4Init(TIM3, &TIM_OCInitStructure);//使能通道4
  48.     TIM_OC4PreloadConfig(TIM3, TIM_OCPreload_Enable);
  49.     //使能
  50.     TIM_ARRPreloadConfig(TIM3, ENABLE);//使能TIM3重載寄存器ARR
  51.     TIM_Cmd(TIM3, ENABLE);//使能定時(shí)器3
  52. }
  53. void Timer3_PWM_SetDutyCycle(u8 ch, u16 Timer3_PWM_DutyCycle)     //配置4個(gè)通道占空比
  54. {
  55.     switch (ch)
  56.     {
  57.     case 1:
  58.         TIM_SetCompare1(TIM3, Timer3_PWM_DutyCycle );//通道1占空比
  59.         break;
  60.     case 2:
  61.         TIM_SetCompare2(TIM3, Timer3_PWM_DutyCycle );//通道2占空比
  62.         break;
  63.     case 3:
  64.         TIM_SetCompare3(TIM3, Timer3_PWM_DutyCycle );//通道3占空比
  65.         break;
  66.     case 4:
  67.         TIM_SetCompare4(TIM3, Timer3_PWM_DutyCycle );//通道4占空比
  68.         break;
  69.     }
  70. }
sg90.7z (197.05 KB, 下載次數(shù): 116)
ID:282095 發(fā)表于 2019-7-6 00:15 | 顯示全部樓層
PWM調(diào)速就是高電平的占空比
ID:717434 發(fā)表于 2020-5-25 10:41 | 顯示全部樓層
感謝分享,學(xué)習(xí)一下
ID:543928 發(fā)表于 2020-12-18 15:57 | 顯示全部樓層
沒(méi)有程序啊
ID:446934 發(fā)表于 2022-4-12 11:12 | 顯示全部樓層
PWM調(diào)速就是提高高電平的占空比
主站蜘蛛池模板: 精品日韩在线观看 | 国产农村妇女精品一二区 | 久久久午夜精品 | 91精品一区 | 美女综合网 | 在线观看日韩精品 | 国产一级免费观看 | 日本色婷婷 | 国产精品视频专区 | 欧美成人一区二区三区 | 中文字幕一区二区在线播放 | 国产激情久久 | 成人免费毛片果冻 | 高潮毛片无遮挡免费看 | 久久手机视频 | 日日夜夜精品 | 国产成人网 | 亚洲成人国产 | 一区二区视频在线 | a级片免费在线观看 | 日韩av在线免费播放 | 日本中文字幕视频 | 日韩 欧美| 日韩不卡在线 | 91成人精品一区在线播放 | 99热在线免费观看 | 国产强伦人妻毛片 | 亚洲一区二区三区免费视频 | 国产91在线播放 | 欧美精品久久99 | 中文在线字幕 | 天堂视频在线免费观看 | 国产成人一区二区 | 一区二区在线免费观看 | 成人免费福利 | 久久免费看视频 | av福利在线 | 国内精品一区二区三区 | hdxxxxhd100%| 午夜不卡视频 | av免费看片 |
