查看: 4554|回復: 5
[求助]給位牛人,幫我看看我的IIC總線通信協議程序問題出在哪兒了,看了半天也沒找到問題在哪?
ID:37087 發表于 2012-10-13 10:46 | 顯示全部樓層 |閱讀模式
/*將數據寫入AT24C02的0地址處,再讀出,并用數碼管顯示*/
#include"reg51.h"
sbit SDA=P2^0;
sbit SCL=P2^1;
sbit duan=P2^6;
sbit wei=P2^7;
void delay()
void init()
{SCL=1;
 SDA=1;
 delay();
void start()
{SDA=1;
 delay();
 SCL=1;
 delay();
 SDA=0;
 delay();
void stop()
{SDA=0;
 delay();
 SCL=1;
 delay();
 SDA=1;
 delay();
void ack()
{unsigned char i;
 SCL=1;
 while((SDA==1)&&(i<255))i++;
 SCL=0;
 delay();
void write(unsigned char date)
{unsigned char i,temp;
 temp=date;
 for(i=0;i<8;i++)
 {SCL=0;
  delay();
  temp<<=1;
  SDA=CY;
  delay();
  SCL=1;
  delay();
 SCL=0;
 delay();
 SDA=1;
 delay();
unsigned char read()
{unsigned char i,j;
 SCL=0;
 delay();
 SDA=1;
 delay();
 for(i=0;i<8;i++)
 {SCL=1;
  delay();
  j=(j<<1)|SDA;
  SCL=0;
  delay();
 return j;
write_addr(unsigned char date,unsigned char addr)
{start();
 write(0xa0);
 ack();
 write(addr);
 ack();
 write(date);
 ack();
 stop();
unsigned char read_addr(unsigned char addr)
{unsigned char i;
 start();
 write(0xa0);
 ack();
 write(addr);
 ack();
 start();
 write(0xa1);
 ack();
 i=read();
 stop();
 return i;
void shumaguan(unsigned char dat,unsigned char addr)
{unsigned char ziku[18]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x40,0x00};
 unsigned char wzk[8]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
 duan=0;
 P0=wzk[addr];
 wei=1;
 wei=0;
 P0=ziku[dat];
 duan=1;
 delay();
 P0=0;
 duan=0;
main()
{unsigned char i;
 init();
 write_addr(0x11,0);
 i=read_addr(0);
 {shumaguan(i%10,0);
  shumaguan(i/10%10,1);
  shumaguan(i/100,2);
ID:45396 發表于 2012-10-13 11:30 | 顯示全部樓層
我調試成功的,只是寫的:
void IIC_START()
 //DAT_PIN_OUT();
 SDIO=1;
 NOP();
 SCLK=1;
 NOP();
 SDIO=0;
 NOP();
 SCLK=0;
void IIC_STOP()
 //DAT_PIN_OUT();
 SCLK=0;
 NOP();
 SDIO=0;
 NOP();
 SCLK=1;
 NOP();
 SDIO=1;
void IIC_ACK()
 SCLK=0;
 NOP();
 NOP();
 NOP();
 _pbc = 0b10111111;   //DAT_PIN_IN();
 SDIO=1;
 NOP();
 NOP();
 SCLK=1;
 NOP();
 NOP();
 if(SDIO){
  NOP();
 SCLK=0;
 _pbc = 0b00111111;   //DAT_PIN_OUT();
    SDIO=0;
    SCLK=0;
//-----------------寫一字節數據---------------------
void IICWrByte(uchar DAT)
 uchar i;
 //DAT_PIN_OUT();
 NOP();
 for(i=0;i<8;i++) {
  NOP();
  SCLK=0;
  NOP();
  if(DAT & 0X01){
   SDIO=1;
else {
   SDIO=0;
  NOP();
  SCLK=1;
  NOP();
  SCLK=0;
  DAT >>= 1;
ID:45396 發表于 2012-10-13 11:34 | 顯示全部樓層
void SendData()
 IIC_START();
    IICWrByte(CMD_AutoAdr);   //; 數據設置
    IIC_ACK();
    IIC_STOP();
 IIC_START();
    IICWrByte(CMD_First_Addr);  //; 地址設置
    IIC_ACK();
 IICWrByte(DATA[0]);  //送數據
 IIC_ACK();
    IICWrByte(DATA[1]);
    IIC_ACK();
    IIC_STOP();
 IIC_START();
 IICWrByte(CMD_Disp_ON);   //;; 開顯示并調整灰度/最大可減少7
 IIC_ACK();
    IIC_STOP();
ID:45396 發表于 2012-10-13 11:38 | 顯示全部樓層
不好意思,后面那段發錯了,不是24C02的!一般用示波器看就可以找出問題來的!
ID:37087 發表于 2012-10-13 12:01 | 顯示全部樓層
問題是沒有示波器啊。
ID:7485 發表于 2012-10-13 14:43 | 顯示全部樓層
IIC的器件的通信協議是一樣的。都可以通用的。有些新的器件速度高一些,和速度低得比較,可以加少一些空操作(NOP)。但低速器件的程序可以用在高速器件上。
樓主的程序不是一點兩點的問題。
在IIC協議中,不管是主控器件還是從器件,1、向總線發送一個字節數據后,就要檢查應答信號,看看接收器件是否“字節接受完成”。
                                                      2、接收器件正確接收到一個字節的數據后,也要發送一個應答信號(1bit),告訴發送器件“字節接收完成”
如果接收器件接收不正確,則不會發送應答信號。發送器件就檢測不到“應答信號”,這時就要從“開始”步驟重來。
這里就有了這么幾個環節:“應答信號(1bit,低位)”、“非應答信號(1bit,高位)、“檢測應答信號”。
讀的流程:1發送開始信號-->2發送器件地址(含“寫”指令位)-->3檢測應答-->4發送字節地址-->5檢測應答-->6發送開始信號(含“讀”指令位)
              -->7檢測應答-->8讀一個字節-->9發送應答信號-->......(重復第8步)讀第2~N字節)-->發送非應答信號-->發送停止信號
寫的流程:1發送開始信號-->2發送器件地址(含“寫”指令位)-->3檢測應答-->4發送字節地址-->5檢測應答-->6寫一個字節-->7檢測應答信號
              -->(......(重復第6步)寫第2~N字節-->(重復第7步)檢測應答信號-->)發送停止信號
如果是單字節讀寫括號內不用。
[此貼子已經被作者于2012-10-13 14:55:24編輯過]
主站蜘蛛池模板: 久久免费视频观看 | 超碰在线成人 | 天天爽天天干 | 精品国产99久久久久久宅男i | 黄色a毛片 | 国产福利视频在线观看 | 国产成人免费在线视频 | 91视频观看 | 91精品亚洲 | 色婷婷综合网 | 欧美精品第一页 | 麻豆视频国产 | 欧美日韩在线播放 | 国产欧美精品一区二区三区 | 一级黄视频| 性网址 | 日本亚洲欧美 | 国产一级黄色录像 | 草草视频在线 | 日韩一级在线 | 国产一区二区三区免费 | 中文字幕一区二区三区四区 | 国产一区高清 | 欧美成人小视频 | 日韩理论在线 | 美女国产精品 | 久久视频免费 | 午夜无遮挡 | 一级黄色片网站 | 91一区二区三区 | 亚洲黄色小视频 | 国产激情久久 | 欧美一级全黄 | 亚洲综合二区 | 色片在线 | 欧美黄视频 | 成人免费看片39 | 精品一区二区三区免费 | www黄色片 | 日韩在线视频观看 | 一区二区三区在线看 |
