查看: 3697|回復: 0
IL0371 SSD1608 1.54inch墨水屏程序資料下載
ID:442993 發表于 2019-7-28 17:02 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
E-Ink_1.54.7z (148.96 KB, 下載次數: 27)
1.54寸墨水屏模塊 黑白屏模塊.7z (2.71 MB, 下載次數: 28)
IL0373.pdf (854.43 KB, 下載次數: 17)
IL0371數據手冊.pdf (889.91 KB, 下載次數: 22)
  1. /*******************************************************************************/
  2. /* Includes ------------------------------------------------------------------*/
  3. #include "stm32f10x.h"
  4. #include "Display_EPD_W21_spi.h"
  5. #include "Display_EPD_W21.h"
  6. /* Private typedef -----------------------------------------------------------*/
  7. /* Private define ------------------------------------------------------------*/
  8. /* Private macro -------------------------------------------------------------*/
  9. /* Private variables ---------------------------------------------------------*/
  10. ErrorStatus HSEStartUpStatus;
  11. /* Private function prototypes -----------------------------------------------*/
  12. void RCC_Configuration(void);
  13. void NVIC_Configuration(void);
  14. void GPIO_Configuration(void);
  15. const unsigned char logo[] = {
  16. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  17. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  18. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  19. ^^^^^^^^^^^^^^^^^^
  20. ^^^^^^^^^中間省略
  21. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  22. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  23. };
  24. const unsigned char LUTDefault_part[31] = {
  25.         0x32,        // command
  26. /*        0x00,0x00,0x00,0x18,
  27.         0x18,0x18,0x18,0x00,
  28.         0x00,0x00,0x00,0x00,
  29.         0x00,0x00,0x00,0x00,
  30.         0x00,0x00,0x00,0x00,
  31.         0x40,0x14,0x34,0x01,
  32.         0x00,0x00,0x00,0x00,
  33.         0x00,0x00,
  34. */
  35. 0x10 //C221 25C partial update waveform
  36. ,0x18
  37. ,0x18
  38. ,0x08
  39. ,0x18
  40. ,0x18
  41. ,0x08
  42. ,0x00
  43. ,0x00
  44. ,0x00
  45. ,0x00
  46. ,0x00
  47. ,0x00
  48. ,0x00
  49. ,0x00
  50. ,0x00
  51. ,0x00
  52. ,0x00
  53. ,0x00
  54. ,0x00
  55. ,0x13
  56. ,0x14
  57. ,0x44
  58. ,0x12
  59. ,0x00
  60. ,0x00
  61. ,0x00
  62. ,0x00
  63. ,0x00
  64. ,0x00
  65.         };
  66. const unsigned char LUTDefault_full[31] = {
  67.         0x32,        // command
  68. /*        0x11,0x11,0x10,0x02,        // full
  69.         0x02,0x22,0x22,0x22,
  70.         0x22,0x22,0x51,0x51,
  71.         0x55,0x88,0x08,0x08,
  72.     0x88,0x88,0x00,0x00,
  73.         0x34,0x23,0x12,0x21,
  74.         0x24,0x28,0x22,0x21,
  75.         0xA1,0x01
  76. */
  77. 0x02 //C221 25C Full update waveform
  78. ,0x02
  79. ,0x01
  80. ,0x11
  81. ,0x12
  82. ,0x12
  83. ,0x22
  84. ,0x22
  85. ,0x66
  86. ,0x69
  87. ,0x69
  88. ,0x59
  89. ,0x58
  90. ,0x99
  91. ,0x99
  92. ,0x88
  93. ,0x00
  94. ,0x00
  95. ,0x00
  96. ,0x00
  97. ,0xF8
  98. ,0xB4
  99. ,0x13
  100. ,0x51
  101. ,0x35
  102. ,0x51
  103. ,0x51
  104. ,0x19
  105. ,0x01
  106. ,0x00
  107.         };
  108. //unsigned int IC_SWITCH;
  109. //unsigned char vcom;
  110. void lcd_chkstatus(void);
  111. void lut_red(void);
  112. void lut_bw(void);
  113. void Ultrachip_red(void);
  114. void Ultrachip(void);
  115. void master_uc8154_init(void);
  116. void Ultrachip_red1(void);
  117. void Ultrachip1(void);
  118. void pic_display(void);
  119. unsigned char  EPD_W21_ReadDATA(void);
  120. void driver_delay_us(unsigned int xus)
  121. {
  122.         for(;xus>1;xus--);
  123. }
  124. void driver_delay_xms(unsigned long xms)
  125. {
  126.     unsigned long i = 0 , j=0;
  127.     for(j=0;j<xms;j++)
  128.         {
  129.         for(i=0; i<256; i++);
  130.     }
  131. }
  132. void parttest()
  133. {
  134.    unsigned int i,j,k;
  135.    EPD_W21_WirteLUT((unsigned char *)LUTDefault_part);
  136.    EPD_W21_POWERON();
  137.                 part_display(0x00,0x18,0xc7,0x00,0x00,0x00);        // set ram
  138.                 EPD_W21_UpdataDisplay((unsigned char *)logo,200,200);
  139.                 EPD_W21_Update1();
  140.                 driver_delay_xms(100000);
  141.                 part_display(0x00,0x18,0xc7,0x00,0x00,0x00);        // set ram
  142.                 EPD_W21_UpdataDisplay((unsigned char *)logo,200,200);
  143.                 driver_delay_xms(10000);
  144.                 for(i=0;i<6;i++)
  145.                 {
  146.                     k=200-i*32-4;
  147.                         j=k-32;
  148.                         part_display(0x12,0x12,k%256,k/256,j%256,j/256);        // set ram
  149.                         EPD_W21_WriteDispRamMono(8, 32, 0x00);        // white
  150.                          EPD_W21_Update1();
  151.                         driver_delay_xms(20000);
  152.                         part_display(0x12,0x12,k%256,k/256,j%256,j/256);        // set ram
  153.                         EPD_W21_WriteDispRamMono(8, 32, 0x00);        // white
  154.                         driver_delay_xms(10000);
  155.                 }
  156. }
  157. void EPD_init(void)
  158. {
  159.                 EPD_W21_Init();                        // display
  160.                 EPD_W21_WirteLUT((unsigned char *)LUTDefault_full);
  161.             EPD_W21_POWERON();
  162.         driver_delay_xms(30000);
  163.                 EPD_W21_SetRamPointer(0x00,0xC7,0x00);        // set ram
  164.                 EPD_W21_WriteDispRam(200, 200, (unsigned char *)second);        // white
  165.                 EPD_W21_Update();
  166.                 driver_delay_xms(300000);
  167.                 EPD_W21_SetRamPointer(0x00,0xC7,0x00);        // set ram
  168.                 EPD_W21_WriteDispRam(200, 200, (unsigned char *)third);        // white
  169.                 EPD_W21_Update();
  170.                 driver_delay_xms(200000);
  171.                 EPD_W21_SetRamPointer(0x00,0xC7,0x00);        // set ram
  172.                 EPD_W21_WriteDispRam(200, 200, (unsigned char *)forth);        // white
  173.                 EPD_W21_Update();
  174.                 driver_delay_xms(200000);
  175.
  176.                         EPD_W21_SetRamPointer(0x00,0xC7,0x00);        // set ram
  177.                 EPD_W21_WriteDispRam(200, 200, (unsigned char *)five);        // white
  178.                 EPD_W21_Update();
  179.                 driver_delay_xms(200000);
  180.
  181.                 EPD_W21_SetRamPointer(0x00,0xC7,0x00);        // set ram
  182.                 EPD_W21_WriteDispRam(200, 200, (unsigned char *)logo);        // white
  183.                 EPD_W21_Update();
  184.                 driver_delay_xms(100000);
  185.                 EPD_W21_SetRamPointer(0x00,0xC7,0x00);        // set ram
  186.                 EPD_W21_WriteDispRam(200, 200, (unsigned char *)logo);        // white
  187.                 EPD_W21_Update();
  188.                 driver_delay_xms(100000);
  189.                 parttest();
  190. }
  191. /*******************************************************************************
  192. * Function Name  : main
  193. * Description    : Main program
  194. * Input          : None
  195. * Output         : None
  196. * Return         : None
  197. #define NVIC_VectTab_FLASH  misc.h
  198. *******************************************************************************/
  199. int main(void)
  200. {
  201.
  202. #ifdef DEBUG
  203.   debug();
  204. #endif
  205.   // 系統時鐘設置
  206.    RCC_Configuration();
  207.   //GPIO參數設置
  208.    GPIO_Configuration();
  209.
  210.    EPD_init();
  211. }
  212. /***********************************************************
  213.                                                 end file
  214. ***********************************************************/
  215. /*******************************************************************************
  216. * Function Name  : RCC_Configuration
  217. * Description    : Configures the different system clocks.
  218. * Input          : None
  219. * Output         : None
  220. * Return         : None
  221. *******************************************************************************/
  222. void RCC_Configuration(void)
  223. {
  224.   // 復位RCC時鐘配置(用于調試模式)
  225.   RCC_DeInit();
  226.   // 使能外部晶振
  227.   RCC_HSEConfig(RCC_HSE_ON);
  228.
  229.   // 等待外部晶振穩定
  230.   HSEStartUpStatus = RCC_WaitForHSEStartUp();
  231.   if(HSEStartUpStatus == SUCCESS)
  232.   {
  233.     // 設置鎖相環頻率PLLCLK = 8MHz * 9 = 72 MHz
  234.     RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
  235.   }
  236.   else {
  237.     // 使能內部晶振
  238.     RCC_HSICmd(ENABLE);
  239.     // 等待內置振蕩器穩定
  240.     while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
  241.     // 設置鎖相環頻率PLLCLK = 8MHz/2 * 16 = 64 MHz
  242.     RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_16);
  243.   }
  244.     // 使能FLASH的預取緩沖
  245.   FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
  246.   //設置代碼延時值,FLASH_Latency_2為兩個延時周期
  247.   FLASH_SetLatency(FLASH_Latency_2);
  248.
  249.   //設置系統總線時鐘
  250.   RCC_HCLKConfig(RCC_SYSCLK_Div1);
  251.   //設置高速設備總線時鐘,RCC_HCLK_Div1為系統時鐘除以1
  252.   RCC_PCLK2Config(RCC_HCLK_Div1);
  253.   //設置低速設備總線時鐘,RCC_HCLK_Div2為系統時鐘除以2
  254.   RCC_PCLK1Config(RCC_HCLK_Div2);
  255.
  256.   //使能鎖相環倍頻
  257.   RCC_PLLCmd(ENABLE);
  258.
  259.   // 等待鎖相環倍頻后的頻率穩定
  260.   while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  261.
  262.   // 選擇鎖相環時鐘為系統時鐘源
  263.   RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  264.
  265.   // 等待設置完成
  266.   while(RCC_GetSYSCLKSource() != 0x08);
  267.
  268.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA |
  269.             RCC_APB2Periph_USART1|RCC_APB2Periph_AFIO,
  270.             ENABLE);
  271. }
  272. /*******************************************************************************
  273. * 函數名   : GPIO_Configuration
  274. * 描述         : 設置設置串口所用GPIO引腳的參數
  275. * 輸入         : None
  276. * 輸出         : None
  277. * 返回         : None
  278. *******************************************************************************/
  279. void GPIO_Configuration(void)
  280. {
  281.   GPIO_InitTypeDef GPIO_InitStructure;
  282.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
  283.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_2 |GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5;    //abcd OE ST LT0輸出
  284.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
  285.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  286.   GPIO_Init(GPIOA, &GPIO_InitStructure);
  287. }
  288. /*******************************************************************************
  289. * Function Name  : NVIC_Configuration
  290. * Description    : Configures Vector Table base location.
  291. * Input          : None
  292. * Output         : None
  293. * Return         : None
  294. *******************************************************************************/
  295. void NVIC_Configuration(void)
  296. {
  297.   //NVIC_InitTypeDef NVIC_InitStructure;
  298.   ;
  299. }
  300. #ifdef  DEBUG
  301. /*******************************************************************************
  302. * Function Name  : assert_failed
  303. * Description    : Reports the name of the source file and the source line number
  304. *                  where the assert_param error has occurred.
  305. * Input          : - file: pointer to the source file name
  306. *                  - line: assert_param error line source number
  307. * Output         : None
  308. * Return         : None
  309. *******************************************************************************/
  310. void assert_failed(u8* file, u32 line)
  311. {
  312.   /* User can add his own implementation to report the file name and line number,
  313.      ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  314.   /* Infinite loop */
  315.   while (1)
  316.   {
  317.   }
  318. }
  319. #endif
收藏收藏4 分享淘帖 頂1 踩
主站蜘蛛池模板: 亚洲一区欧美 | 国产一区视频在线播放 | 我要操网站 | 亚洲成人av | 韩国精品一区二区 | 亚洲精品视频免费 | 国产精品免费在线 | 国产精品网站在线观看 | 日韩精品免费观看 | 黄色小视频免费看 | 操操操操操操 | 精品一区二区三区三区 | 国产在线日韩 | 99热综合| 亚洲国产精品视频 | 天天操天天操 | av片在线免费观看 | av久久久 | 狠狠干天天 | 成人毛片在线 | 一级黄色网 | 一级做a爰片久久毛片潮喷 视频一二区 | 日韩精品中文字幕在线观看 | 国产成人三级一区二区在线观看一 | 日韩av成人在线 | 国产一区中文字幕 | 日本黄色中文字幕 | 182tv午夜| www.黄色| 精品久久精品 | 国产自产21区| 欧美日韩精品久久久免费观看 | 亚洲av毛片成人精品 | 亚洲免费福利视频 | 免费观看全黄做爰的视频 | www.桃色| 岛国av在线播放 | 免费一区二区视频 | 密乳av| 免费av片 | 久久久久女人精品毛片九一 |
