查看: 6344|回復: 4
快速入門msp430fr6989之lcd功能篇
【注】德州儀器的官網上的msp430fr6989單片機上有一塊lcd,其有40個引腳,分別兩邊各有20個引腳排布。學過stm32的能很快掌握lcd的寄存器模式下寫成的代碼,但是新手最好入門庫函數一類,如果時間很緊迫的情況下。板上是0-7的行,分為上半屏和下半屏。列有LCDM1-LCDM20,總共有8*20=160個segment。在前面的帖子中,對引腳的定義是通過寄存器進行定義的,而如果我要讓流水燈亮起來就可以把寄存器及地址寫在一個函數內,包裝起來,直接在官網上找的代碼,很豐富,學這個很快。比如以下:
  1. <p>//定義輸出引腳
  2. void GPIO_setAsOutputPin(uint8_t selectedPort,
  3.                          uint16_t selectedPins) {
  4.     uint16_t baseAddress = GPIO_PORT_TO_BASE[selectedPort];</p><p>    #ifndef NDEBUG
  5.     if(baseAddress == 0xFFFF)
  6.     {
  7.         return;
  8.     }
  9.     #endif</p><p>    // Shift by 8 if port is even (upper 8-bits)
  10.     if((selectedPort & 1) ^ 1)
  11.     {
  12.         selectedPins <<= 8;
  13.     }</p><p>    HWREG16(baseAddress + OFS_PASEL0) &= ~selectedPins;
  14.     HWREG16(baseAddress + OFS_PASEL1) &= ~selectedPins;
  15.     HWREG16(baseAddress + OFS_PADIR) |= selectedPins;</p><p>    return;
  16. }</p><p>
  17. </p><p>
  18. </p><p>Init_GPIO();
  19.
  20. GPIO_clearInterrupt(GPIO_PORT_P1, GPIO_PIN1);
  21. GPIO_clearInterrupt(GPIO_PORT_P1, GPIO_PIN2);</p><font size="5"><p>void Init_GPIO(void)
  22. {
  23.   // Set all GPIO pins to output low to prevent floating input and reduce power consumption
  24.   GPIO_setOutputLowOnPin(GPIO_PORT_P1, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  25.   GPIO_setOutputLowOnPin(GPIO_PORT_P2, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  26.   GPIO_setOutputLowOnPin(GPIO_PORT_P3, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  27.   GPIO_setOutputLowOnPin(GPIO_PORT_P4, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  28.   GPIO_setOutputLowOnPin(GPIO_PORT_P5, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  29.   GPIO_setOutputLowOnPin(GPIO_PORT_P6, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  30.   GPIO_setOutputLowOnPin(GPIO_PORT_P7, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  31.   GPIO_setOutputLowOnPin(GPIO_PORT_P8, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  32.   GPIO_setOutputLowOnPin(GPIO_PORT_P9, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  33.
  34.   GPIO_setAsOutputPin(GPIO_PORT_P1, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  35.   GPIO_setAsOutputPin(GPIO_PORT_P2, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  36.   GPIO_setAsOutputPin(GPIO_PORT_P3, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  37.   GPIO_setAsOutputPin(GPIO_PORT_P4, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  38.   GPIO_setAsOutputPin(GPIO_PORT_P5, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  39.   GPIO_setAsOutputPin(GPIO_PORT_P6, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  40.   GPIO_setAsOutputPin(GPIO_PORT_P7, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  41.   GPIO_setAsOutputPin(GPIO_PORT_P8, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  42.   GPIO_setAsOutputPin(GPIO_PORT_P9, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
  43.
  44.   GPIO_setAsInputPin(GPIO_PORT_P3, GPIO_PIN5);
  45.
  46.   // Configure button S1 (P1.1) interrupt
  47.   GPIO_selectInterruptEdge(GPIO_PORT_P1, GPIO_PIN1, GPIO_HIGH_TO_LOW_TRANSITION);
  48.   GPIO_setAsInputPinWithPullUpResistor(GPIO_PORT_P1, GPIO_PIN1);
  49.   GPIO_clearInterrupt(GPIO_PORT_P1, GPIO_PIN1);
  50.   GPIO_enableInterrupt(GPIO_PORT_P1, GPIO_PIN1);
  51.
  52.   // Configure button S2 (P1.2) interrupt
  53.   GPIO_selectInterruptEdge(GPIO_PORT_P1, GPIO_PIN2, GPIO_HIGH_TO_LOW_TRANSITION);
  54.   GPIO_setAsInputPinWithPullUpResistor(GPIO_PORT_P1, GPIO_PIN2);
  55.   GPIO_clearInterrupt(GPIO_PORT_P1, GPIO_PIN2);
  56.   GPIO_enableInterrupt(GPIO_PORT_P1, GPIO_PIN2);
  57.
  58.   // Set P4.1 and P4.2 as Secondary Module Function Input, LFXT.
  59.   GPIO_setAsPeripheralModuleFunctionInputPin(
  60.                                              GPIO_PORT_PJ,
  61.                                              GPIO_PIN4 + GPIO_PIN5,
  62.                                              GPIO_PRIMARY_MODULE_FUNCTION
  63.                                                );
  64.
  65.   // Disable the GPIO power-on default high-impedance mode
  66.   // to activate previously configured port settings
  67.   PMM_unlockLPM5();</p><p>}</p></font><p>
  68. </p>
下面有開箱的源代碼。【禁止商業用途】
OutOfBox_MSP430FR6989.7z
1.49 MB, 下載次數: 38, 下載積分: 黑幣 -5
ID:628019 發表于 2019-10-23 12:44 | 只看該作者
不行,你這下載的東西是官方的樣例,,初學者,你貼的圖也不過。。
ID:64765 發表于 2020-6-25 16:15 | 只看該作者
好資料,學習了,謝謝分享。
ID:64765 發表于 2020-6-29 14:32 | 只看該作者
給力,太好了,謝謝樓主分享。
ID:497627 發表于 2020-7-29 11:01 | 只看該作者
可以提一個題外話的問題嗎?FR6989的中斷需要開全局嗎,我寫了個定時器中斷的實驗,但是中斷跳不進去
主站蜘蛛池模板: 91精品国产91久久久久久吃药 | 日本一区二区三区在线观看 | 欧美成人精品一区二区男人看 | 成人精品国产 | 91国内精品久久 | 亚洲 欧美 精品 | 美国一级黄色片 | 久久精品国产亚洲 | 国产清纯白嫩初高生在线播放视频 | 涩涩导航 | 国产成人精品免高潮在线观看 | 欧美专区在线 | 欧美日韩亚洲国产综合 | 日韩一区二区三区在线观看视频 | 中文字幕亚洲精品在线观看 | 成人免费在线小视频 | 国产成人网 | 国产在线精品一区 | 盗摄精品av一区二区三区 | 国产一区二区免费 | 国产成人麻豆免费观看 | 国产成人久久av免费高清密臂 | 毛片一级黄色 | 欧美一区二区 | 中文字幕不卡在线观看 | 五月天婷婷激情 | 91高清视频在线观看 | a在线视频| 欧美精品a∨在线观看不卡 欧美日韩中文字幕在线播放 | 亚洲伊人a | 人人艹人人 | 久久精品亚洲一区 | 日韩成人免费视频 | 日韩精品一区二区三区在线观看 | 欧洲一级黄 | 久久久精品一区二区三区四季av | 日日爱av | 一级毛片在线播放 | 嫩草视频免费 | 精品日韩一区二区 | 91精品久久久久久久99 |
