查看: 3433|回復: 1
C8051F410單片機利用pca捕獲外部脈沖
ID:511588 發表于 2019-7-31 14:16 | 顯示全部樓層 |閱讀模式
// 聲明:外部引腳的脈沖輸入CEX0為P0^0,
#include <c8051f410.h>                 // SFR declarations
#include"UART.h"
#include <stdio.h>
#define SYSCLK      24500000           // SYSCLK frequency in Hz
#define BAUDRATE        9600           // Baud rate of UART in bps
sfr16 PCA0CP0 = 0xFB;                  // PCA0 Compare Register Definition
unsigned int CLKNUM = 0;
float period;
void OSCILLATOR_Init (void);
void PORT_Init (void);
void PCA0_Init (void);
static unsigned int capture_period;
unsigned int counter;
void main (void)
   PCA0MD = 0x00;                      // Disable watchdog timer
   PORT_Init ();                       // Initialize crossbar and GPIO
   OSCILLATOR_Init ();                 // Initialize oscillator
   PCA0_Init ();                       // Initialize PCA0
   UART0_Init ();
   EA = 1;
   while (1)
      printf("CLKNUM= %d us\n",CLKNUM);
         printf("period= %f us\n",period);
   OSCICN = 0x87;                      // Set internal oscillator to run
                                       // at its maximum frequency
   CLKSEL = 0x00;                      // Select the internal osc. as
                                       // the SYSCLK source
     RSTSRC = 0x04;                      // enable missing clock detector(串口需要)
   XBR0    = 0x01;                     //串口通信使能
   XBR1    = 0x41;                     // Route CEX0 to P0.0,
                                       // Enable crossbar and weak pull-ups
   PCA0CN = 0x00;                      // Stop counter; clear all flags
   PCA0MD = 0x08;                      // Use 系統時鐘 as time base
   PCA0CPM0 = 0x21;                    // Module 0 = Rising Edge Capture Mode
                                       // enable CCF flag.
   EIE1 = 0x10;                       // Enable PCA interrupts
   CR = 1;                             // Start PCA counter
void PCA0_ISR (void) interrupt 11
   static unsigned int current_capture_value, previous_capture_value;
   if (CCF0)        // If Module 0 caused the interrupt
//          CLKNUM++;
      CCF0 = 0;        // Clear module 0 interrupt flag.
      current_capture_value = PCA0CP0;                                               // Store most recent capture value
      capture_period = current_capture_value - previous_capture_value;               // Calculate capture period from last two values.
      previous_capture_value = current_capture_value;                                // Update previous capture value with most recent info.
            period = capture_period *4.0816326530612244897959183673469e-8;
   else                                // Interrupt was caused by other bits.
      PCA0CN &= ~0x86;                 // Clear other interrupt flags for PCA
ID:64765 發表于 2019-11-16 17:01 | 顯示全部樓層
好資料,學習了,謝謝分享。
主站蜘蛛池模板: 一区二区三区不卡视频 | 国内外成人免费视频 | 一级片aa| 日韩精品一区二区三区四区 | 欧美区在线 | 精品国产欧美一区二区三区成人 | 天天射天天舔 | 国产午夜视频在线观看 | 天堂在线中文资源 | av免费网站 | 日本少妇做爰全过程毛片 | 欧美精产国品一二三区 | 国产精品国产三级国产专区52 | www.国产.com| 黄色免费片 | 欧美日韩一区在线观看 | 成人黄色一级片 | 国产精品二区一区二区aⅴ污介绍 | 黄色小视频在线观看 | 在线观看不卡av | 免费国产一区二区 | 中文字幕在线视频播放 | 中文字幕在线免费视频 | 一级免费黄色片 | 国产精品视频一区二区三区 | 亚洲第一区视频 | 国产在线不卡视频 | 欧美日韩综合网 | 国产成人三级一区二区在线观看一 | 黄网站免费看 | 亚洲性生活片 | 亚洲精品成人网 | av在线免费网站 | 亚洲综合区 | 久热综合 | 他揉捏她两乳不停呻吟动态图 | www色| 91精品国产乱码久久久 | 免费午夜视频 | 日本aaaa| 性网址|
