查看: 4003|回復: 3
51單片機四位抽獎機制作 帶時鐘功能 附源程序
之前的帖子已經有在開發板上測試了一下,現在補充一個完整版,自己做了一個板,擴展了交流穩壓輸入模塊,可實現的功能有上電初始化顯示,四位同時抽獎,逐位抽獎,以及實時時鐘,程序,原理圖,制作出來的實物圖如下:
電路原理圖如下:
如有不足的地方可以再交流一下哈,相互學習學習
  1. #include <reg52.h>
  2. #include <stdio.h>
  3. #include <stdlib.h>
  4. #include <main.h>
  5. #define uchar unsigned char
  6. #define uint  unsigned int
  7. unsigned char code table_disp[]={0x05,0xaf,0x46,0x86,0xac,0x94,0x14,0xa7,0x04,0x84};//段碼表
  8.                                /*  0    1    2    3    4    5    6    7    8    9  */
  9. unsigned char code table_clock[]={0x01,0xab,0x42,0x82,0xa8,0x90,0x10,0xa3,0x00,0x80};//時鐘段碼表
  10. uchar t2; //1s計數
  11. uchar p;
  12. uchar msta; //散轉變量
  13. uchar hour,minute,second;
  14. uchar q,w,e,r,y,u;
  15. /**************函數聲明******************/
  16. void init();
  17. void keyscan();
  18. void disp(uchar x3,uchar x2,uchar x1,uchar x0,bit  s,uchar x);
  19. //程序開始部分
  20. void main(){
  21. init();
  22.         while(1)
  23.         {
  24.
  25.                   while(!TF0);
  26.                                 TH0=0xEC;
  27.               TL0=0x78;
  28.                           TF0=0;
  29.                             t2++;
  30.                           keyscan();
  31.                           disp(q,w,e,r,y,u);
  32.
  33.
  34.                 if(t2==200)
  35.                 {
  36.                         t2=0;
  37.                         second++;
  38.                         if(second==60)
  39.                         {
  40.                                 second=0;
  41.                                 minute++;
  42.                                 if(minute==60)
  43.                                 {
  44.                                         minute=0;
  45.                                         hour++;
  46.                                         if(hour==24)
  47.                                                 hour=0;
  48.                                 }
  49.                         }
  50.                 }
  51.
  52.                                 switch(msta)
  53.                                 {
  54.                                         case 0:
  55.                                         {
  56.                                                 q=0;
  57.                                                 w=2;
  58.                                                 e=3;
  59.                                                 r=4;
  60.                                                 if(key1==1)
  61.                                                 { msta=1;
  62.                                                         led1=0;
  63.                                                   p=0;}
  64.                                                 break;}
  65.                                         case 1:
  66.                                         {
  67.                                                 if(p==0)
  68.                                                 {q=rand()%10;
  69.                                                  w=rand()%10;
  70.                                                  e=rand()%10;
  71.                                                  r=rand()%10;}
  72.                                                 if(key1==1)
  73.                                                 { key1=0;
  74.                                                         msta=2;
  75.                                                   led1=1;
  76.                                                   led2=0;
  77.                                                   p=0;}
  78.                                                 if(key2==1)
  79.                                                         p=1;
  80.                                                 if(key3==1)
  81.                                              p=0;
  82.
  83.                                 break;}
  84.                                 case 2:
  85.                                 {
  86.                                         switch(p)
  87.                                         {
  88.                                                 case 0:
  89.                                                         r=rand()%10;
  90.                                                 case 1:
  91.                                                         e=rand()%10;
  92.                                                 case 2:
  93.                                                         w=rand()%10;
  94.                                                 case 3:
  95.                                                         q=rand()%10;
  96.                                                 break;
  97.                                                 }
  98.                                         if(key2==1)
  99.                                             p++;
  100.                                         if(key3==1)
  101.                                                 p=0;
  102.                                         if(key1==1)
  103.                                         { msta=3;
  104.                                                 led2=1;
  105.                                                 led3=0; }
  106.                                         break;
  107.                                 }
  108.                                 case 3:
  109.                                 {
  110.                                         y=1;
  111.                                         u=1;
  112.                                         q=hour/10;
  113.                                         w=hour%10;
  114.                                         e=minute/10;
  115.                                         r=minute%10;
  116.                                                 if(key2==1)
  117.                                                 {        hour++;
  118.                                                         if(hour==24)
  119.        hour=0;}
  120.                                                 if(key3==1)
  121.                                                 {  minute++;
  122.                                                         if(minute==60)
  123.        minute=0;}
  124.                                                 if(key1==1)
  125.                                                 { msta=0;
  126.                                                         y=u=0;
  127.                                                         led3=1;        }
  128.                                                 break;
  129.                                          }
  130.                                                 }
  131.                         }}
  132. /**************************
  133.        初始化函數定義
  134. **************************/
  135. void init(){
  136.         led0=0;
  137.           msta=0;
  138.           hour=12;
  139.           minute=30;
  140.           TMOD=0x01;  //選擇定時器0,工作方式1
  141.                 TH0=0xEC;   //5ms計數初值
  142.           TL0=0x78;
  143.           TR0=1;
  144. }
  145. /**************************
  146.        顯示函數定義
  147. **************************/
  148. void disp(uchar x0,uchar x1,uchar x2,uchar x3,bit s,uchar x)
  149.         {static uchar dsbit,cut300;bit s300;
  150.                 cs0=1;cs1=1;cs2=1;cs3=1;   //關顯示
  151.
  152.                 switch(dsbit)
  153.                 {
  154.                         case 0:
  155.                         {
  156.                                 if(x==1)
  157.                    P0=table_clock[x0];
  158.                                 else
  159.                    P0=table_disp[x0];
  160.                                 cs0=0;
  161.                                 dsbit=1;
  162.                                 break;
  163.                 }
  164.                         case 1:
  165.                         {
  166.                                 if(x==1)
  167.                            P0=table_clock[x1];
  168.                                 else
  169.                           P0=table_disp[x1];
  170.                                 cs1=0;
  171.                                 dsbit=2;
  172.                                 break;
  173.                 }
  174.                         case 2:
  175.                         {
  176.                                 P0=table_disp[x2];
  177.                                 cs2=0;
  178.                                 dsbit=3;
  179.                                 break;
  180.                 }
  181.                         case 3:
  182.                         {
  183.                                 P0=table_disp[x3];
  184.                                 cs3=0;
  185.                                 dsbit=0;
  186.                                 break;
  187.                 }
  188.         }
  189.                 cut300++;
  190.            if(cut300==100)
  191.                  { s300^=1;
  192.                          cut300=0;}
  193.                  if(s&&s300)
  194.                  { dot=1;
  195.                          }
  196.
  197.       return;
  198.         }
  199.
以上程序51hei下載地址:
源程序.docx (15.62 KB, 下載次數: 35)
收藏收藏2 分享淘帖 頂1 踩
ID:731515 發表于 2020-4-17 17:40 | 只看該作者
樓主好,我也想做一個這個東西,可以詳細介紹一下需要什么零件嗎?AT89S52,還有其他配件是什么型號呢?
ID:731515 發表于 2020-4-17 19:30 | 只看該作者
你好,我是剛學單片機的萌新,想學做你的這個東西,可以留個聯系方式嗎?
ID:294799 發表于 2021-3-31 22:30 | 只看該作者
有段時間沒來論壇了,有問題的可以私信我
主站蜘蛛池模板: 日韩视频一区二区三区 | 国产高清毛片 | 国产乱码一区二区三区 | 欧美精品一级片 | 日韩资源在线 | 九九视频这里只有精品 | 日本在线天堂 | 97国产精品| 国产精品毛片va一区二区三区 | 四虎在线播放 | 亚洲精品福利 | 日韩在线综合 | 精品在线看| 激情网站在线观看 | 亚洲欧美第一页 | 日韩在线精品 | 日韩三级视频 | 中文字幕国产 | 日韩在线一区二区 | 天天做夜夜爽 | 狠狠干狠狠干 | 一级做a爱片性色毛片 | 四虎黄色网址 | 中文字幕在线观 | 国产中文在线 | www.av在线 | 国产一区二区日韩 | 色综合视频在线观看 | 国产自产21区 | 久久少妇 | 国产福利91精品一区二区三区 | 成人在线国产 | 综合网av | 天天干天天操天天射 | 国产一级片免费观看 | 黄色片视频| 三级在线观看视频 | av在线播放网址 | 日本理伦片午夜理伦片 | 亚洲国产欧美日韩在线 | 精品久久久久久久久久久久久久久久 |
