查看: 3136|回復(fù): 0
實(shí)操Arduino+3d打印制造視覺(jué)暫留顯示器 附源程序
ID:613370 發(fā)表于 2019-9-19 04:58 來(lái)自觸屏版 | 顯示全部樓層 |閱讀模式
制作出來(lái)的實(shí)物圖如下:
09E3B3FB-6372-465D-976A-917A15A30222.jpeg F34769C0-12FA-4FC4-8B4F-F9A33D9E49AE.jpeg 2A841A87-FCA1-4D6C-A81E-B53CD547BE24.jpeg
配件清單
Arduino Nano×1
紅外線傳感器×1
洞洞板×1
LED 燈×若干
電阻×若干
直流電機(jī)×1
電池×1
電線×若干
熱熔膠×1
烙鐵×1
白紙×1
Arduino IDE(軟件)
LED接口方式如下:
LED0:Nano 的 D2 。
LED1: Nano 的 D3 。
LED2: Nano 的 D4 。
LED3: Nano 的 D5 。
LED4: Nano 的 D6 。
LED5: Nano 的 D7 。
LED6: Nano 的 D8 。
LED7: Nano 的 D9 。
負(fù)極為:Nano 的 Ground 。
紅外線傳感器與 Nano 連接方式如下 :
GND:Nano 的 GND。
Vin: Nano 的 5V。
Out:Nano 的 D10。
代碼
* This Code demonstrates
* LED POV DISPLAY
* Components used
* 1) Arduino Nano
* 2) DC motor
* 3) LEDs
* 4) IR sensor
* 5) Battery
* 6) Wire
* Connect leds to 2 to 9 digital pin of Nano
* Connect IR sensor out pin to 10 digital pin of Nano
* code written by Palak Mehta on March 29,2019
////////////////////////design a pattern of display the number and alphabates////////////////////////////////
int NUMBER9[]={1,1,1,1,0,0,0,1, 1,0,0,1,0,0,0,1, 1,0,0,1,0,0,0,1, 1,0,0,1,0,0,0,1, 1,1,1,1,1,1,1,1};
int NUMBER8[]={0,1,1,0,1,1,1,0, 1,0,0,1,0,0,0,1, 1,0,0,1,0,0,0,1, 1,0,0,1,0,0,0,1, 0,1,1,0,1,1,1,0};
int NUMBER7[]={1,0,0,0,0,0,0,0, 1,0,0,0,1,0,0,0, 1,0,0,0,1,0,0,0, 1,0,0,1,1,1,1,1, 1,1,1,0,1,0,0,0};
int NUMBER6[]={1,1,1,1,1,1,1,1, 1,0,0,0,1,0,0,1, 1,0,0,0,1,0,0,1, 1,0,0,0,1,0,0,1, 1,0,0,0,1,1,1,1};
int NUMBER5[]={1,1,1,1,1,0,0,1, 1,0,0,0,1,0,0,1, 1,0,0,0,1,0,0,1, 1,0,0,0,1,0,0,1, 1,0,0,0,1,1,1,1};
int NUMBER2[]= {1,0,0,0,0,0,1,1, 1,0,0,0,0,1,0,1, 1,0,0,0,1,0,0,1, 1,0,0,1,0,0,0,1, 0,1,1,0,0,0,0,1};
int NUMBER1[]= {0,0,1,0,0,0,0,0, 0,1,0,0,0,0,0,0, 1,1,1,1,1,1,1,1, 0,0,0,0,0,0,0,0, 0,0,0,0,0,0,0,0};
int NUMBER0[]= {1,1,1,1,1,1,1,1, 1,0,0,0,0,0,0,1, 1,0,0,0,0,0,0,1, 1,0,0,0,0,0,0,1, 1,1,1,1,1,1,1,1};
int _[] = {0,0,0,0,0,0,0,0, 0,0,0,0,0,0,0,0, 0,0,0,0,0,0,0,0, 0,0,0,0,0,0,0,0, 0,0,0,0,0,0,0,0};
int A[] = {1,1,1,1,1,1,1,1, 1,0,0,1,0,0,0,0, 1,0,0,1,0,0,0,0, 1,0,0,1,0,0,0,0, 1,1,1,1,1,1,1,1};
int B[] = {1,1,1,1,1,1,1,1, 1,0,0,1,0,0,0,1, 1,0,0,1,0,0,0,1, 1,0,0,1,0,0,0,1, 0,1,1,0,1,1,1,0};
int C[] = {0,0,1,1,1,1,0,0, 0,1,0,0,0,0,1,0, 1,0,0,0,0,0,0,1, 1,0,0,0,0,0,0,1, 1,0,0,0,0,0,0,1};
int D[] = {1,1,1,1,1,1,1,1, 1,0,0,0,0,0,0,1, 1,0,0,0,0,0,0,1, 0,1,0,0,0,0,1,0, 0,0,1,1,1,1,0,0};
int E[] = {1,1,1,1,1,1,1,1, 1,0,0,1,0,0,0,1, 1,0,0,1,0,0,0,1, 1,0,0,1,0,0,0,1, 1,0,0,1,0,0,0,1};
int F[] = {1,1,1,1,1,1,1,1, 1,0,0,1,0,0,0,0, 1,0,0,1,0,0,0,0, 1,0,0,1,0,0,0,0, 1,0,0,1,0,0,0,0};
int G[] = {0,1,1,1,1,1,1,1, 1,0,0,0,0,0,0,1, 1,0,0,0,1,0,0,1, 1,0,0,0,1,0,0,1, 1,0,0,0,1,1,1,0};
int H[] = {1,1,1,1,1,1,1,1, 0,0,0,0,1,0,0,0, 0,0,0,0,1,0,0,0, 0,0,0,0,1,0,0,0, 1,1,1,1,1,1,1,1};
int I[] = {1,0,0,0,0,0,0,1, 1,0,0,0,0,0,0,1, 1,1,1,1,1,1,1,1, 1,0,0,0,0,0,0,1, 1,0,0,0,0,0,0,1};
int J[] = {0,0,0,0,0,1,1,0, 0,0,0,0,1,0,0,1, 0,0,0,0,0,0,0,1, 0,0,0,0,0,0,0,1, 1,1,1,1,1,1,1,0};
int K[] = {1,1,1,1,1,1,1,1, 0,0,0,1,1,0,0,0, 0,0,1,0,0,1,0,0, 0,1,0,0,0,0,1,0, 1,0,0,0,0,0,0,1};
int L[] = {1,1,1,1,1,1,1,1, 0,0,0,0,0,0,0,1, 0,0,0,0,0,0,0,1, 0,0,0,0,0,0,0,1, 0,0,0,0,0,0,0,1};
int M[] = {1,1,1,1,1,1,1,1, 0,1,0,0,0,0,0,0, 0,0,1,0,0,0,0,0, 0,1,0,0,0,0,0,0, 1,1,1,1,1,1,1,1};
int N[] = {1,1,1,1,1,1,1,1, 0,0,1,0,0,0,0,0, 0,0,0,1,1,0,0,0, 0,0,0,0,0,1,0,0, 1,1,1,1,1,1,1,1};
int O[] = {0,1,1,1,1,1,1,0, 1,0,0,0,0,0,0,1, 1,0,0,0,0,0,0,1, 1,0,0,0,0,0,0,1, 0,1,1,1,1,1,1,0};
int P[] = {1,1,1,1,1,1,1,1, 1,0,0,1,0,0,0,0, 1,0,0,1,0,0,0,0, 1,0,0,1,0,0,0,0, 0,1,1,0,0,0,0,0};
int Q[] = {0,1,1,1,1,1,1,0, 1,0,0,0,0,0,0,1, 1,0,0,0,0,1,0,1, 0,1,1,1,1,1,1,0, 0,0,0,0,0,0,0,1};
int R[] = {1,1,1,1,1,1,1,1, 1,0,0,1,1,0,0,0, 1,0,0,1,0,1,0,0, 1,0,0,1,0,0,1,0, 0,1,1,0,0,0,0,1};
int S[] = {0,1,1,1,0,0,0,1, 1,0,0,0,1,0,0,1, 1,0,0,0,1,0,0,1, 1,0,0,0,1,0,0,1, 1,0,0,0,1,1,1,0};
int T[] = {1,0,0,0,0,0,0,0, 1,0,0,0,0,0,0,0, 1,1,1,1,1,1,1,1, 1,0,0,0,0,0,0,0, 1,0,0,0,0,0,0,0};
int U[] = {1,1,1,1,1,1,1,0, 0,0,0,0,0,0,0,1, 0,0,0,0,0,0,0,1, 0,0,0,0,0,0,0,1, 1,1,1,1,1,1,1,0};
int V[] = {1,1,1,1,1,1,0,0, 0,0,0,0,0,0,1,0, 0,0,0,0,0,0,0,1, 0,0,0,0,0,0,1,0, 1,1,1,1,1,1,0,0};
int W[] = {1,1,1,1,1,1,1,1, 0,0,0,0,0,0,1,0, 0,0,0,0,0,1,0,0, 0,0,0,0,0,0,1,0, 1,1,1,1,1,1,1,1};
int X[] = {1,1,0,0,0,0,1,1, 0,0,1,0,0,1,0,0, 0,0,0,1,1,0,0,0, 0,0,1,0,0,1,0,0, 1,1,0,0,0,0,1,1};
int Y[] = {1,1,0,0,0,0,0,0, 0,0,1,0,0,0,0,0, 0,0,0,1,1,1,1,1, 0,0,1,0,0,0,0,0, 1,1,0,0,0,0,0,0};
int Z[] = {1,0,0,0,0,1,1,1, 1,0,0,0,1,0,0,1, 1,0,0,1,0,0,0,1, 1,0,1,0,0,0,0,1, 1,1,0,0,0,0,0,1};
int* alpha[]= {A,B,C,D,E,F,G,H,I,J,K,L,M,N};//,T,U,V,W,X,Y,Z};
int letterSpace;
int delayTime;
#define IR_pin 10
void setup()
Serial.begin(9600);
pinMode(IR_pin,INPUT);
for( int i = 2; i<10 ;i++ ) // setting the ports of the leds to OUTPUT
pinMode(i, OUTPUT);
letterSpace =4;// defining the space between the letters (ms)
delayTime =1;// defining the time dots appear (ms)
void printLetter(int letter[])
int y;
// printing the first y row of the letter
for (y=0; y<8; y++)
digitalWrite(y+2, letter[y]);
delay(delayTime);
// printing the second y row of the letter
for (y=0; y<8; y++)
digitalWrite(y+2, letter[y+8]);
delay(delayTime);
// printing the third y row of the letter
for (y=0; y<8; y++)
digitalWrite(y+2, letter[y+16]);
delay(delayTime);
for(y = 0; y<8; y++) {
digitalWrite(y+2, letter[y+24]);
delay(delayTime);
digitalWrite(y+2, letter[y+32]);
delay(delayTime);
// printing the space between the letters
for (y=0; y<8; y++)
digitalWrite(y+2, 0);
delay(letterSpace);
void loop()
if(digitalRead(IR_pin)==LOW)
printLetter (P);
printLetter (O);
printLetter (V);
printLetter (_);
printLetter (_);
printLetter (D);
printLetter (I);
printLetter (S);
printLetter (P);
printLetter (L);
printLetter (A);
printLetter (Y);
printLetter (_);
評(píng)分
查看全部評(píng)分
主站蜘蛛池模板: 欧美在线免费观看视频 | 午夜性视频| 在线一级片 | 亚洲精品成人网 | 国产精品久久久久久久久久久久久久 | 日韩 欧美 亚洲 | 亚洲黄色大片 | 超碰在线免费 | аⅴ资源新版在线天堂 | 亚洲爱爱网 | 欧美激情视频一区二区三区 | 国产999久久久 | 黄色片91| 午夜天堂在线 | 久久精品欧美一区二区三区不卡 | 久草福利在线 | 韩日精品视频 | 国产精品免费一区二区 | 亚洲一区欧美一区 | 永久免费看mv网站入口亚洲 | 在线免费观看黄色片 | 97在线观看免费视频 | 欧美成人精品欧美一级私黄 | 天堂一区二区三区 | 亚洲久久久 | 国产在线视频一区二区 | 91丨九色丨蝌蚪丨丝袜 | 国产一区精品在线观看 | 成人在线小视频 | 日韩精品一区二区在线 | 午夜激情福利视频 | 午夜在线观看视频网站 | 国产h视频在线观看 | 亚洲欧美另类在线观看 | 一级免费黄色片 | 亚洲精品乱码久久久久久蜜桃91 | 欧美日韩免费视频 | 色哥网| 成人免费看片98欧美 | 大尺度做爰床戏呻吟舒畅 | 国产区视频在线 |
