查看: 3406|回復: 2
步進電機(用STM32定時器中斷)12864串口模式顯示,按鍵可設置
ID:105206 發表于 2019-10-8 16:34 | 顯示全部樓層 |閱讀模式
用按鍵設置定時器重裝值及分頻值,脈沖數。經過開發板測試。圖片無法上傳
//步進電機
//用定時器中斷(S曲線7段法)。LCD12864串口模式顯示,用按鍵設置定時器(TIM5_Int_Init(999,999);)的兩個傳入參數來
//改變中斷次數與分頻系數達到單位時間內的脈沖值。
//脈沖可設置
#include "sys.h"
#include "delay.h"
#include "usart.h"
#include "motor.h"
#include "s_curve.h"
#include "key.h"
#include "12864.h"
u8 key_num=0;
u8 Table0[3]={0x00};
u8 Table1[3]={0x00};
u8 Table2[3]={0x00};
u16 arr,psc,pulse;
void display()
        lcd_pos(1,3); //自動重裝值
        write_char(':');
        Table0[0]=(arr%1000/100+0x30);
        Table0[1]=(arr%100/10+0x30);
        Table0[2]=(arr%10+0x30);
        write_char(Table0[0]);
        write_char(Table0[1]);
        write_char(Table0[2]);
        lcd_pos(2,4); //時鐘預分頻數
        write_char(':');
        Table1[0]=(psc%1000/100+0x30);
        Table1[1]=(psc%100/10+0x30);
        Table1[2]=(psc%10+0x30);
        write_char(Table1[0]);
        write_char(Table1[1]);
        write_char(Table1[2]);
        lcd_pos(3,3); //脈沖數
        write_char(':');
        Table2[0]=(pulse%1000/100+0x30);
        Table2[1]=(pulse%100/10+0x30);
        Table2[2]=(pulse%10+0x30);
        write_char(Table2[0]);
        write_char(Table2[1]);
        write_char(Table2[2]);
int main(void)
        u8        key;
        delay_init();                     //延時函數初始化
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //設置NVIC中斷分組2:2位搶占優先級,2位響應優先級
        lcd_gpio_Init();
        Motor_Init();
        TIM5_Int_Init(999,999);//
        KEY_Init();
        lcd_init();//12864初始化
        delay_ms(20);
        lcd_clear();//清屏
        delay_ms(10);
        lcd_wstr(1,0,"重裝值   ");
        lcd_wstr(2,0,"分頻系數 ");
        lcd_wstr(3,0,"脈沖數     ");
        display();
        delay_ms(2000);
        s_curve_start_Motor(1,40);//1代表順時針,400旋轉脈沖
        delay_ms(3000);
        s_curve_start_Motor(0,40);//0代表逆時針,400旋轉脈沖
        delay_ms(3000);
                key=KEY_Scan(0);
                if(key==KEY0_PRES)
                        delay_ms(50);
                        key_num++;
                        switch(key_num)
                                case 1:
                                send_cmd(0x0c);        //關光標關閃爍
                                lcd_pos(1,3); //
                                write_char(':');
                                send_cmd(0x80|0x04);
                                send_cmd(0x0f);        //開光標并閃爍
                                    break;
                                case 2:
                                        lcd_pos(2,4); //
                                        write_char(':');
                                send_cmd(0x90|0x05);
                                        break;
                                case 3:
                                        lcd_pos(3,3); //
                                        write_char(':');
                                send_cmd(0x88|0x04);
                                        break;
                                case 4:
                                        key_num=0;
                                        TIM5_Int_Init(arr,psc);//
                                break;
                if(key_num!=0)
                        if(key==KEY1_PRES)
                                delay_ms(50);
                                switch(key_num)
                                        case 1:arr+=10;if(arr==1000)arr=0;
                                                        lcd_pos(1,3); //
                                                        write_char(':');
                                        break;
                                        case 2:psc+=10;if(pulse==1000)pulse=0;
                                                        lcd_pos(2,4); //
                                                        write_char(':');
                                        break;
                                        case 3:pulse+=10;if(pulse==1000)pulse=0;
                                                        lcd_pos(3,3); //
                                                        write_char(':');
                                        break;
                if(key_num==0)
//                        if(key==KEY0_PRES)
//                                s_curve_start_Motor(1,400);//順時針旋轉1圈
//                                delay_ms(500);
                        if(key==KEY1_PRES)
                                s_curve_start_Motor(0,pulse);//順時針旋轉1圈
                                delay_ms(500);
全部程序51hei下載地址:
stm32_步進電機.7z (193.99 KB, 下載次數: 57)
ID:96552 發表于 2019-10-11 17:11 | 顯示全部樓層
能顯示,液晶反應很慢,顯示驅動有問題
ID:240600 發表于 2020-11-13 14:28 | 顯示全部樓層
時序有點小毛病,需要稍微調整一下
主站蜘蛛池模板: 国产激情网站 | 免费中文字幕日韩欧美 | 日本a v在线播放 | 国产永久视频 | 四虎影视库 | 精品免费 | 国产精品tv | 成人欧美一区二区三区黑人孕妇 | 精品免费国产一区二区三区四区 | 日韩视频在线免费观看 | 亚洲精品网站在线观看 | 欧美日皮视频 | 亚洲激情文学 | 天堂av中文在线 | 青青操国产 | 国产综合在线视频 | 99热1| 国产乱码精品一品二品 | 欧美一级黄色大片 | 精品日韩一区二区 | 手机在线播放av | 99免费视频 | 一级特黄视频 | 国产一区在线视频 | 日韩欧美在线一区二区 | 久久综合社区 | 日本中文在线 | 国产三级精品视频 | a视频| 日韩精品在线观看视频 | 成人福利网站 | 免费在线观看黄色片 | 久草网在线观看 | 五月婷婷综合网 | 国产毛片在线 | 日韩欧美在线一区 | 日日夜夜噜 | 久久精品国产77777蜜臀 | 国产精品福利在线观看 | 91亚色视频 | 五月激情综合 |
