查看: 6310|回復: 6
剛學PIC單片機,分享第一個電子時鐘,定時器計時
    #define _XTAL_FREQ 4000000 //晶振定義
    #include<pic.h> //頭文件包含
//__CONFIG(0x3b31);//芯片配置字定義
// CONFIG1
#pragma config FOSC = XT        // Oscillator Selection bits (XT oscillator: Crystal/resonator on RA6/OSC2/CLKOUT and RA7/OSC1/CLKIN)
#pragma config WDTE = OFF       // Watchdog Timer Enable bit (WDT disabled and can be enabled by SWDTEN bit of the WDTCON register)
#pragma config PWRTE = OFF      // Power-up Timer Enable bit (PWRT disabled)
#pragma config MCLRE = ON       // RE3/MCLR pin function select bit (RE3/MCLR pin function is MCLR)
#pragma config CP = OFF         // Code Protection bit (Program memory code protection is disabled)
#pragma config CPD = OFF        // Data Code Protection bit (Data memory code protection is disabled)
#pragma config BOREN = ON       // Brown Out Reset Selection bits (BOR enabled)
#pragma config IESO = ON        // Internal External Switchover bit (Internal/External Switchover mode is enabled)
#pragma config FCMEN = ON       // Fail-Safe Clock Monitor Enabled bit (Fail-Safe Clock Monitor is enabled)
#pragma config LVP = ON         // Low Voltage Programming Enable bit (RB3/PGM pin has PGM function, low voltage programming enabled)
// CONFIG2
#pragma config BOR4V = BOR40V   // Brown-out Reset Selection bit (Brown-out Reset set to 4.0V)
#pragma config WRT = OFF        // Flash Program Memory Self Write Enable bits (Write protection off)
    //宏定義
    #define uchar unsigned char
    #define uint unsigned int
    #define RS RC0 //命令數據選擇
    #define RW RC1 //讀寫選擇
    #define EN RC2 //使能
    uint count=0;
    uchar miao,fen,shi;
    /*******************延時函數部分******************
    大約延時1ms
    void delayms(uint ms)
        uchar i,j;
        for(j=ms;j>0;j--)
        for(i=110;i>0;i--);
    /*******************1602發送主函數******************
    void LCD_WRITE(uchar data,uchar com)
        RS=com;//1表示數據;0表示命令
        PORTD=data;//將數據寫入
        delayms(5);//延時
        EN=1;//使能
        delayms(5);//延時
        EN=0;//關閉
    /*******************1602顯示主函數******************
    //指定位置顯示字符
    //輸入:列地址X(0~15),行地址y(0~1)
    // 字符串指針*p,要顯示的字符個數num
    void disp_1602(uchar x,uchar y,uchar *p,uchar num)
        uchar i;
        for(i=0;i<num;i++)
        if(0==y)
        x|=0x80;//第一行地址為0x80
        x|=0xc0;//第二行地址為0xC0
        LCD_WRITE(x,0); //寫地址命令
        LCD_WRITE(*p,1);//寫數據
        x++;//地址加
        p++;//顯示字符地址加
    /*******************初始化函數部分******************
    void LCD_init(void)
        // ADCON1=0x07;//定義RE為數據口
         TRISC0=0;
         TRISC1=0;
         TRISC2=0;//RE口為輸出
         RC0=0;
         RC1=0;
         RC2=0;//初始化輸出低電平
         TRISD=0;//D口為輸出
         PORTD=0;//輸出0
         LCD_WRITE(0x38,0);//設置8位總線,雙行顯示
         LCD_WRITE(0x01,0);//清屏
         LCD_WRITE(0x0c,0);//開顯示,關光標
         LCD_WRITE(0x06,0);//光標右移
         LCD_WRITE(0x80,0);//第一行顯示位置
    /*******************主程序函數******************
void main(void)
LCD_init();//端口初始化
    T1CKPS0=1;
    T1CKPS1=1;                //前置分頻器8分頻
    TMR1CS=0;                 //TMR1工作于定時器方式
    TMR1L=(65536-12500)%256;  //定時12500個時鐘
    TMR1H=(65536-12500)/256;
    GIE=1;     //總中斷允許
    PEIE=1;    //外圍功能模塊中斷允許
    TMR1IE=1;  //TMR1中斷允許
    TMR1ON=1;  //啟動TMR1
            disp_1602(0,0,"Time:",5);//第一行顯示temp:
            delayms(20);
            LCD_WRITE(0x80+5,0); //寫地址命令
            LCD_WRITE(shi/10+0x30,1);//寫數據
            LCD_WRITE(shi%10+0x30,1);//寫數據
            LCD_WRITE(':',1);//寫數據
            LCD_WRITE(fen/10+0x30,1);//寫數據
            LCD_WRITE(fen%10+0x30,1);//寫數據
            LCD_WRITE(miao/10+0x30,1);//寫數據
            LCD_WRITE(miao%10+0x30,1);//寫數據
//*********************中斷服務程序******************
void interrupt isr(void)
  if(TMR1IE&&TMR1IF)      //判斷是否為TMR1中斷
    TMR1IF=0;             //清TMR1中斷標志位(必須用軟件清零)
    count++;
    if(count==10)
        count=0;
        miao++;
        if(miao==60)
            miao=0;
            fen++;
            if(fen==60)
                fen=0;
                shi++;
                if(shi==24)
                    shi=0;
ID:190577 發表于 2020-2-7 10:15 | 只看該作者
希望幫助需要的人
ID:106272 發表于 2020-2-7 11:33 | 只看該作者
謝謝了,初學者,學習一下
ID:869854 發表于 2020-12-28 22:27 | 只看該作者
謝謝樓主,小萌新慢慢看
ID:870114 發表于 2020-12-29 11:49 | 只看該作者
謝謝樓主無私的分享,小萌新好好看好好學
ID:190577 發表于 2021-8-22 20:06 | 只看該作者
小菜雞..... 發表于 2020-12-28 22:27
謝謝樓主,小萌新慢慢看
客氣了,技術在于交流
ID:190577 發表于 2021-8-22 20:07 | 只看該作者
3310mad2 發表于 2020-2-7 11:33
謝謝了,初學者,學習一下
希望幫助需要的人
主站蜘蛛池模板: 成人久久av | 国产精品免费人成网站酒店 | 国产草草影院 | 午夜在线免费视频 | 触手繁殖の地狱3d啪啪 | 免费在线观看黄色片 | 国产色站 | 久久午夜影院 | 一级片在线播放 | 国产第一福利 | 中文字幕在线观看第一页 | 国产精品久久久久久久午夜 | 成人免费视频国产免费麻豆 | 欧美精品区 | 中文字幕少妇 | 日本中文字幕视频 | 午夜无遮挡| 91白浆| 亚洲精品色 | 亚洲黄色在线 | 免费一级片 | 日韩在线视频播放 | 自拍偷拍福利视频 | 黄色成人毛片 | 国产三级在线免费观看 | 黑人精品一区二区 | 一区二区自拍 | 国产一级黄色 | 欧美精品二区 | 国产精品99久久久久久久久久久久 | 久久精品在线观看 | 日韩视频精品 | 国产a视频| 在线观看日韩视频 | 韩日av在线 | 久草网在线观看 | 四虎成人网 | 3p在线观看 | 国产高清免费 | 黄色成人免费视频 | 四虎影视av|
