查看: 4493|回復: 5
LCD數碼電子鐘
ID:46855 發表于 2012-11-29 14:50 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
請教高人,我這程序有何問題
QQ:619493038,用89C2051,P1口輸出外接反相器,作為SEG驅動口,P3口為掃描信號,其它,按鍵
#include <reg51.h>
unsigned char code seg_code[10]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,};
//unsigned char code seg_code[10]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x7,0x7F,0x6F,};
unsigned char set=0;
unsigned char hour=0,min=0,sec=0;
unsigned char base5ms=0;
unsigned char alarm_h=0,alarm_m=0;
bit flash05s=0;
bit Alarm=0;
sbit P1_0=P1^0;
sbit P1_1=P1^1;
sbit P1_2=P1^2;
sbit P1_3=P1^3;
sbit P1_4=P1^4;
sbit P1_5=P1^5;
sbit P1_6=P1^6;
sbit P1_7=P1^7;
sbit P3_0=P3^0;
sbit P3_1=P3^1;
sbit P3_2=P3^2;
sbit P3_3=P3^3;
sbit P3_4=P3^4;
sbit P3_5=P3^5;
sbit P3_7=P3^7;
void init_t0();
void scan_key();
void count_time();
void disp_time();
void check_alarm();
void clock();
void delay(unsigned int k);
void alarm_on_off();
void adj_time();
void adj_alarm();
void disp_alarm();
void timer0 (void) interrupt 1
 TH0=60736/256;  // 重新裝初值
 TL0=60736%256;
 base5ms++;     //全局變量+1,代表一個5ms
 init_t0();
    if(P3_4==0)
   scan_key();
  switch(set)
   case 0: clock(); break;
   case 1: adj_time();break;
   case 2: adj_alarm();break;
   case 3: alarm_on_off(); break;
   default:break;
void init_t0()
 TMOD=0x01;   // 定時器T0,方式一,16位定時器
 TH0=60736/256;  //裝初值  12M晶振 4.8ms溢出一次,加上裝初值的時間,中斷保存現場的時間,
 TL0=60736%256;     //應該大約是5ms
 IE=0x82;     //開總中斷,開定時器T0中斷
 TR0=1;     //啟動定時器
void scan_key()
 delay(1);      //延時1ms,軟件去除按鍵抖動 (注:1ms是不是有點短啊,實際測試為準吧)
 if(P3_4==0)
 set++;
 if(set>=4)
 set=0;
 while(P3_4==0){;}
void clock()
 count_time();
 disp_time();
 check_alarm();
void count_time()
 if(base5ms<=100)
  flash05s=0;
  flash05s=1;
 if(base5ms>=200)
  sec++;
     base5ms=0;
 if(sec==60)
  min++;
  sec=0;
 if(min==60)
  hour++;
  min=0;
 if(hour==24)
  hour=0;
void disp_time()
 P1=seg_code[hour/10];
 P3&=0xf7;    //P3.3=0;
 delay(1);
 P1=seg_code[hour%10];
 P3&=0xfb;      //p3.2=0;
 delay(1);
 if(flash05s==1)     //沒間隔0.5S,小數點閃爍一次
    if(P3_2==0)
   P1_7=0;
   P1_7=1;
 delay(1);
 P1=seg_code[min/10];
 P3&=0xfd;          //p3.1=0;
 delay(1);
 if(Alarm==1)
  if(P3_1==0)
   P1_7=0;
   P1_7=1;
  delay(1);
 P1=seg_code[min%10];
 P3&=0xfe;    //p3.0=0;
 delay(1);
void check_alarm()
 if(Alarm==1)
     if(hour==alarm_h)
       if(min==alarm_m)
        if(P3_0==0)
      P1_7=0;
     delay(1);
     P1_7=1;
  if(P3_5==0||P3_7==0)
   delay(1);
   Alarm=0;
void alarm_on_off()
 unsigned char i;
    if(P3_5==0)
 Alarm=1;
    for(i=0; i<30; i++)
     disp_alarm();
  P1=seg_code[alarm_m/10];
  P3=0xfd;
  delay(1);
  if(P3_1==0)
   if(Alarm==1)
   P1_7=0;
   P1_7=1;
   delay(1);
 if(P3_7==0){
  delay(1);
 if(P3-7==0)
  Alarm=0;
 for(i=0;i<30;i++)
  disp_alarm();
  P3=0xfd;
  delay(1);
  if(P3_1==0)
   if(Alarm==1)
    P1_7=0;
   else P1_7=1;
  delay(1);
void delay(unsigned int k)   //延時k ms
 unsigned int i,j;
 for(i=0; i<k; i++)
  for(j=0; j<300; j++);
 void adj_time()
  unsigned char i;
    if(P3_5==0)
     delay(1);
     if(P3_5==0)
  hour++;
     if(hour==24)
  hour=0;
     for(i=0; i<30; i++)
      disp_time();
      if(P3_2==0)
    P1_7=0;
    P1_7=1;
      delay(1);
 if(P3_7==0)
       delay(1);
    if(P3_7==0)
    min++;
    if(min==60)
    min=0;
    for(i=0; i<30; i++)
      disp_time();
      if(P3_2==0)
    P1_7=0;
    P1_7=1;
      delay(1);
void adj_alarm()
 unsigned char i;
 if(P3_5==0)
  delay(1);
  if(P3_5==0)
  alarm_h++;
  if(alarm_h==24)
  alarm_h=0;
  for(i=0;i<30;i++)
   disp_alarm();
 if(P3_7==0)
  delay(1);
  if(P3_7==0)
  alarm_m++;
  if(alarm_m==60)
  alarm_m=0;
  for(i=0;i<30;i++)
   disp_alarm();
void disp_alarm()
 P1=seg_code[alarm_h/10];
 P3=0xf7;
 delay(1);
 if(P3_3==0)
 P1_7=0;
 P1_7=1;
 delay(1);
 P1=seg_code[alarm_h%10];
 P3=0xfd;
 delay(1);
    P3=0xfd;
 delay(1);
[此貼子已經被作者于2012-11-30 12:05:14編輯過]
ID:46855 發表于 2012-11-29 20:25 | 只看該作者
看來高人都挺忙的!
ID:7485 發表于 2012-11-29 23:29 | 只看該作者
你遇到了什么問題?
ID:46855 發表于 2012-11-30 11:24 | 只看該作者
程序不能正常運行
ID:46855 發表于 2012-11-30 12:07 | 只看該作者
敬請高人指點!不勝感激!
QQ:619493038
ID:7485 發表于 2012-12-1 19:07 | 只看該作者
硬件中沒看到你說的“LCD”。
沒有仔細看你的程序,但是,不知道你的程序是哪來的?自己寫的?
“ TH0=60736/256;  // 重新裝初值
 TL0=60736%256;”
 這樣的寫法沒見過。如果是51,應該是“TH0=65536/256;  // 高位  TL0=65536%256;//低位
從這里可以感覺到。。。。。。。。。。。。。。。。。。。。。。。。。。。。
主站蜘蛛池模板: 久久免费视频观看 | 一区二区三区四区精品 | 免费视频一区 | 欧美 日韩 国产 成人 在线 | 亚洲va视频| 99热免费| 亚洲欧美国产毛片在线 | 国产一级在线播放 | 免费精品 | 91精品国产色综合久久不卡98 | 国产美女视频 | 涩五月婷婷| 亚洲69| 久久久亚洲精品视频 | 久久黄视频 | 亚洲精品乱码 | 四虎四虎| 国产人成一区二区三区影院 | 免费毛片视频 | 黄色一及片 | 国产一区二区不卡视频 | 国产精品久久久999 成人在线国产 | 国产成人免费在线视频 | 欧美91| 亚洲成人av在线播放 | 精品福利在线观看 | 成人a毛片 | 成人在线免费 | 国产精品原创 | 99九九久久| 国产福利视频 | 三级理论片 | 97视频免费观看 | 午夜在线国语中文字幕视频 | 日韩精品二区 | 99只有精品 | 国产免费一区二区三区 | 成人网战 | 国产成人网 | 亚洲欧美日韩精品 | 国产免费一区二区三区 |
