查看: 2383|回復: 0
音樂盒猜歌名 單片機Proteus仿真程序
#include <reg51.h>
#define uchar unsigned char         //宏的定義變量類型 uchar 代替 unsigned char
#define uint  unsigned int         //宏的定義變量類型 uint  代替 unsigned int
uchar  dis_buf;            //顯示緩存
uchar  temp;
uchar  key,a,b,c,d,e,f,g,h,k,m,n,p,q,r,s,t,bb,cc;                //鍵順序碼
void delay(uchar x);      //x*0.14MS
#define LCDLCDDisp_Off   0x3e
#define LCDLCDDisp_On    0x3f
#define Page_Add     0xb8//頁地址
#define LCDCol_Add     0x40//列地址
#define Start_Line     0xC0//行地址
/*****液晶顯示器的端口定義*****/
#define data_ora P0 /*液晶數據總線*/
sbit LCDMcs=P2^1 ;    /*片選1*/
sbit LCDScs=P2^2 ;    /*片選2*/
sbit RESET=P2^3 ;  /*復位信號*/
sbit LCDDi=P2^4 ;     /*數據/指令 選擇*/
sbit LCDRW=P2^5 ;     /*讀/寫 選擇*/
sbit LCDEnable=P2^6 ;     /*讀/寫 使能*/
sbit key1=P1^0;
sbit key2=P1^1;
sbit key3=P1^2;
sbit key4=P1^3;
sbit LED_R=P1^6;
sbit LED_G=P1^7;
sbit SPK = P3^7;
uchar tone_h;                //高音
uchar tone_l;                //低音
uint note = 1;                //音符
uchar beat;                        //節拍
uchar a=0;
unsigned int Num0=0,Num1=0,Num2=0,Num3=0,Num4=0,Num5=0,Num6=0;
bit flag0,flag_up,flag_dn,flag_door,flag_keyoff,flag_bb,flag_cc,flag1,flag2,flag3,flag4,flag5,flag6,flag7,flag8,flag9;
bit flag_1_up, flag_2_up,flag_2_dn, flag_3_up,flag_3_dn,flag_4_dn;
unsigned char code Bmp0[]=
  源文件 / 文字 : 來自剪貼板! /已選樓層
  寬×高(像素): 64×16
  字模格式/大小 : 單色點陣液晶字模,縱向取模,字節倒序/256字節
  數據轉換日期  : 2018-6-22
0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0xC0,0x80,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0xC0,0x30,0x1E,0x10,0x10,0x10,0xFF,0x10,0x10,0x10,0x10,0x18,0x10,0x00,0x00,
0x00,0x00,0x00,0xFE,0x82,0x82,0x82,0x82,0x82,0x82,0x82,0xFF,0x02,0x00,0x00,0x00,
0x00,0x00,0x04,0x0C,0x18,0x38,0x38,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x41,0x40,0x42,0x42,0x42,0x42,0x42,0x7F,0x42,0x42,0x42,0x43,0x42,0x60,0x40,0x00,
0x00,0x00,0x00,0x7F,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x7F,0x00,0x00,0x00,0x00
unsigned char code Bmp1[]=
  源文件 / 文字 : 來自剪貼板!/當前樓層
  寬×高(像素): 64×16
  數據轉換日期  : 2018-6-22
0x00,0x00,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x0C,0x08,0x00,0x00,0x00,
0x10,0x10,0x10,0xFF,0x90,0x50,0xFE,0x42,0x42,0xC2,0x42,0x42,0xFF,0x02,0x00,0x00,
0x10,0x21,0x62,0x06,0x80,0xFE,0x22,0xE2,0x22,0x22,0x22,0x22,0xBF,0x02,0x00,0x00,
0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x18,0x10,0x00,
0x02,0x42,0x81,0x7F,0x40,0x20,0x1E,0x10,0x20,0x7F,0x44,0x44,0x46,0x64,0x20,0x00,
0x04,0x04,0x7E,0x81,0x60,0x1F,0x00,0x3F,0x48,0x44,0x42,0x41,0x41,0x40,0x70,0x00
unsigned char code Bmp2[]=
  源文件 / 文字 : 來自剪貼板!/升降狀態
  寬×高(像素): 64×16
  數據轉換日期  : 2018-6-22
0x00,0x04,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0xC4,0x86,0x04,0x00,0x00,
0x02,0xF2,0x12,0x12,0x12,0xFE,0x12,0x12,0x12,0xFE,0x12,0x12,0x12,0xFB,0x12,0x00,
0x00,0x00,0x00,0xFC,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0xFE,0x04,0x00,0x00,0x00,
0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x30,0x20,0x00,
0x00,0xFF,0x10,0x08,0x04,0x03,0x14,0x08,0x04,0x03,0x04,0x48,0x98,0x7F,0x00,0x00,
0x00,0x80,0x40,0x23,0x11,0x19,0x01,0x01,0x01,0x09,0x11,0x23,0x60,0xC0,0x00,0x00
unsigned char code Bmp3[]=
  源文件 / 文字 : 來自剪貼板!/開門狀態
  寬×高(像素): 64×16
  數據轉換日期  : 2018-6-22
unsigned char code Bmp4[]=
  源文件 / 文字 : 來自剪貼板!/  上升
  寬×高(像素): 64×16
  數據轉換日期  : 2018-6-22
0x80,0x70,0x00,0xFF,0x10,0x20,0x10,0x10,0xFF,0x10,0x10,0x10,0xF8,0x10,0x00,0x00,
0x00,0x80,0xC0,0xBC,0x84,0x84,0x84,0xF4,0x82,0x82,0x83,0x82,0x80,0xC0,0x80,0x00,
0x00,0x00,0x00,0xFF,0x82,0x42,0x22,0x1A,0x07,0x0A,0x12,0x22,0x43,0xC2,0x42,0x00,
0x00,0x40,0x20,0x10,0x0C,0x40,0x80,0x7F,0x00,0x00,0x04,0x08,0x30,0x60,0x00,0x00,
unsigned char code Bmp5[]=
  源文件 / 文字 : 來自剪貼板!/  下降
  寬×高(像素): 64×16
  數據轉換日期  : 2018-6-22
0x10,0xE8,0x27,0xF4,0x2C,0xE0,0x24,0xA4,0xFC,0x22,0x22,0x40,0xFF,0x40,0x30,0x00,
0x40,0xCF,0x49,0x2F,0x29,0x2F,0x04,0x03,0xFF,0x81,0x42,0x30,0x0F,0x30,0x40,0x00,
unsigned char code Bmp6[]=
  源文件 / 文字 : 來自剪貼板!/  打開
  寬×高(像素): 64×16
  數據轉換日期  : 2018-6-22
0x40,0x40,0x48,0x48,0x48,0x48,0x7F,0xC8,0x4C,0x68,0x50,0x48,0x4C,0x60,0x40,0x00,
0x00,0x00,0xF8,0x48,0x48,0x48,0xF8,0x4F,0x4A,0x2A,0x2B,0x0A,0xA8,0x18,0x00,0x00,
0x40,0x20,0x10,0x08,0x04,0x7E,0x91,0x90,0x88,0x88,0x84,0x86,0x80,0xE0,0x00,0x00,
0x80,0x40,0x3F,0x80,0x40,0x3C,0x04,0x05,0x05,0x7F,0x85,0x81,0x81,0xE0,0x00,0x00,
unsigned char code Bmp7[]=
  源文件 / 文字 : 來自剪貼板!/  關閉
  寬×高(像素): 64×16
  數據轉換日期  : 2018-6-22
uchar code chuzhi[3][16]={  //音調對應的計數初值
         0xff,0xff,//占0位
         0xf8,0x8c,//低1
         0xf9,0x5b,//  2
         0xfa,0x15,//  3
         0xfa,0x67,//  4
         0xfb,0x04,//  5
         0xfb,0x90,//  6
         0xfc,0x0c,//低7
         0xff,0xff,//占0位
         0xfc,0x44,//中1
         0xfc,0xac,//  2
         0xfd,0x09,//  3
         0xfd,0x34,//  4
         0xfd,0x82,//  5
         0xfd,0xc8,//  6
         0xfe,0x06,//中7
         0xff,0xff,//占0位
         0xfe,0x22,//高1
         0xfe,0x56,//        2
         0xfe,0x85,//        3
         0xfe,0x9a,//        4
         0xfe,0xc1,//        5
         0xfe,0xe4,//        6
         0xff,0x03 //高7
//****** 測試曲譜 ****** 個位:音調 ,十位:低中高音 對應 0 1 2,千百位:節拍 1~16
uint code test2[] = {        120, //曲速 暫時未用到
        401,402,403,404,405,406,407,
        611,612,613,614,615,616,617,
        821,822,823,824,825,826,827,
        0xffff        //0xffff表示結尾
//****** 生日快樂 ******
uint code test[] = { 120,
        205,205,406,405,411,807,
        205,205,406,405,412,811,
        205,205,415,413,411,407,406,
        314,114,413,411,413,812,
        305,105,406,405,411,807,
        305,105,406,405,412,811,
        305,105,415,413,411,
        407,406,314,114,413,411,412,811,410,
        0xffff
void delayms(uint ms)          /*ms 等于1時,延時1ms 等于2時,延時2ms,以此類推*/
        uchar a,b,c;                                   //+3
        while(ms--)
         for(c=1;c>0;c--)                        //         1+2 = 3
        for(b=142;b>0;b--)                  //        1*( 1+142*2)) = 285
            for(a=2;a>0;a--);        //         142*(1+2*2) = 710
void delay125ms(uint pai)  //延時 ?*125ms 即?個節拍
    uchar a,b,c;
        while(pai--)
        for(c=239;c>0;c--)
                for(b=104;b>0;b--)
                        for(a=1;a>0;a--);
void system_Ini()
             EA = 1;
        ET0 = 1;
        PT0 = 1;
        TMOD = 0x11;
        TH0 = 255;
        TL0 = 255;
void  delay(uchar x)
{ uchar j;
    while((x--)!=0)  //CPU執行x*12次
    { for(j=0;j<125;j++)
函數功能:LCD延時程序
入口參數:t
出口參數:
void LCDdelay(unsigned int t)
        unsigned int i,j;
        for(i=0;i<t;i++);
        for(j=0;j<10;j++);
狀態檢查,LCD是否忙
void CheckState()
   unsigned char dat,DATA;//狀態信息(判斷是否忙)
   LCDDi=0; // 數據\指令選擇,D/I(RS)="L" ,表示 DB7∽DB0 為顯示指令數據
   LCDRW=1; //R/W="H" ,E="H"數據被讀到DB7∽DB0
   do
      DATA=0x00;
      LCDEnable=1;        //EN下降源
          LCDdelay(2);//延時
          dat=DATA;
      LCDEnable=0;
      dat=0x80 & dat; //僅當第7位為0時才可操作(判別busy信號)
    while(!(dat==0x00));
函數功能:寫命令到LCD程序,RS(DI)=L,RW=L,EN=H,即來一個脈沖寫一次
入口參數:cmdcode
出口參數:
void write_com(unsigned char cmdcode)
    CheckState();//檢測LCD是否忙
        LCDDi=0;
        LCDRW=0;
        P0=cmdcode;
        LCDdelay(2);
        LCDEnable=1;
        LCDdelay(2);
        LCDEnable=0;
函數功能:LCD初始化程序
入口參數:
出口參數:
void init_lcd()
        system_Ini();
        LCDdelay(100);
        LCDMcs=1;//剛開始關閉兩屏
        LCDScs=1;
        LCDdelay(100);
        write_com(LCDLCDDisp_Off);         //寫初始化命令
        write_com(Page_Add+0);
        write_com(Start_Line+0);
        write_com(LCDCol_Add+0);
        write_com(LCDLCDDisp_On);
函數功能:寫數據到LCD程序,RS(DI)=H,RW=L,EN=H,即來一個脈沖寫一次
入口參數:LCDDispdata
出口參數:
void write_data(unsigned char LCDDispdata)
        LCDDi=1;
        LCDRW=0;
        P0=LCDDispdata;
        LCDdelay(2);
        LCDEnable=1;
        LCDdelay(2);
        LCDEnable=0;
函數功能:清除LCD內存程序
入口參數:pag,col,hzk
出口參數:
void Clr_Scr()
        unsigned char j,k;
        LCDMcs=0; //左、右屏均開顯示
        LCDScs=0;
         for(k=0;k<8;k++)//控制頁數0-7,共8頁
                write_com(Page_Add+k); //每頁每頁進行寫
                  for(j=0;j<64;j++)  //每頁最多可寫32個中文文字或64個ASCII字符
                      write_com(LCDCol_Add+j);
                        write_data(0x00);//控制列數0-63,共64列,寫點內容,列地址自動加1
函數功能:左屏位置顯示
入口參數:page,column,hzk
出口參數:
void Bmp_Left_Disp(unsigned char page,unsigned char column, unsigned char code *Bmp)
        unsigned char j=0,i=0;
        for(j=0;j<2;j++)
                write_com(Page_Add+page+j);
                write_com(LCDCol_Add+column);
                for(i=0;i<64;i++)
                        write_data(Bmp[128*j+i]);
void Bmp_Left_Disp1(unsigned char page,unsigned char column, unsigned char code *Bmp)
        for(j=0;j<2;j++)
                for(i=0;i<64;i++)
                        write_data(Bmp[64*j+i]);
函數功能:右屏位置顯示
出口參數:
void Bmp_Right_Disp(unsigned char page,unsigned char column, unsigned char code *Bmp)
        for(j=0;j<2;j++)
                for(i=64;i<128;i++)
void Bmp_Right_Disp1(unsigned char page,unsigned char column, unsigned char code *Bmp)
        for(j=0;j<2;j++)
                for(i=0;i<64;i++)
        init_lcd();
        Clr_Scr();
        LCDMcs=0; //左屏開顯示
        LCDScs=1;
        Bmp_Left_Disp1(0,0,Bmp0);
        Bmp_Left_Disp1(2,0,Bmp1);
        Bmp_Left_Disp1(4,0,Bmp2);
        Bmp_Left_Disp1(6,0,Bmp3);
    LCDMcs=1; //右屏開顯示
        LCDScs=0;
        Bmp_Right_Disp1(0,0,Bmp4);
        Bmp_Right_Disp1(2,0,Bmp5);
        Bmp_Right_Disp1(4,0,Bmp6);
        Bmp_Right_Disp1(6,0,Bmp7);
                                if(test[note] == 0xffff)
                        note = 1;
                if(test[note]%10 != 0)        //音調不為0 【音調為0時表示不發聲,但有節拍】
                        tone_h = TH0 = chuzhi[test[note]%100/10][(test[note]%10)*2 ];                //音調高位 【二維數組 第1維表示低中高音,第二維表示音調】
                        tone_l = TL0 = chuzhi[test[note]%100/10][(test[note]%10)*2 + 1];        //音調低位
                        TR0 = 1;
                delay125ms(test[note]/100);        //節拍
                TR0 = 0;
                delayms(1);
                note++;
                                while(a==1)
                                        SPK=1;
                                        if(key4==0)
                                                 LED_R=1;
                                                LED_G=1;
                                                a=0;
                                                note=0;
void timer0() interrupt 1
        TH0 = tone_h;
        TL0 = tone_l;
        SPK = ~SPK;
                if(key1==0)
                        LED_G=0;
                        a=1;
                else if(key2==0||key3==0)
                        LED_R=0;
                        a=1;
全部資料51hei下載地址:
音樂盒12864(最終).zip (143.33 KB, 下載次數: 26)
主站蜘蛛池模板: 国产成人精品一区二区三区福利 | 午夜精品久久 | 欧美在线视频一区二区 | 奇米av| 亚洲综合激情五月久久 | 久久精品国产视频 | 天堂网久久 | 国产成人+综合亚洲+天堂 | 久久久黄色片 | www.国产一区 | 草草福利影院 | 黄色一级大片在线免费看产 | 日本特黄一级片 | 欧美一区二区在线视频 | 亚洲欧美在线观看 | 国产综合久久久 | 久久免费看视频 | 中文字幕高清 | 国产一区二区欧美 | 国产伦精品一区二区三区免.费 | 亚洲在线免费观看 | 日韩不卡一区二区 | 亚洲天堂网址 | 成人免费毛片aaaaaa片 | 免费av在线 | 亚洲精品日韩精品 | aaa免费视频 | 久久黄视频 | 国产探花在线精品一区二区 | 久久成人免费视频 | 国产又色又爽又黄又免费 | av毛片在线播放 | 九九99久久 | 国产黄色免费网站 | 伊人精品 | 国产av毛片 | 婷婷四房综合激情五月 | 国产成人精品视频 | 国产精品偷拍 | 日韩在线观看中文字幕 | 亚洲资源网 |
