查看: 52780|回復: 142
STM32開源閉環步進電機源程序+PCB原理圖全套資料分享
ID:520801 發表于 2019-10-27 14:27 | 顯示全部樓層 |閱讀模式
這個閉環電機是我轉過來的,自己打板驗證過穩定 電機版權歸開發者,侵刪, 上傳的源碼為開源版本
  1. /* Define to prevent recursive inclusion -------------------------------------*/
  2. #ifndef __STM32F0xx_HAL_CONF_H
  3. #define __STM32F0xx_HAL_CONF_H
  4. #ifdef __cplusplus
  5. extern "C" {
  6. #endif
  7. #include "main.h"
  8. /* Exported types ------------------------------------------------------------*/
  9. /* Exported constants --------------------------------------------------------*/
  10. /* ########################## Module Selection ############################## */
  11. /**
  12.   * @brief This is the list of modules to be used in the HAL driver
  13.   */
  14. #define HAL_MODULE_ENABLED
  15. /*#define HAL_ADC_MODULE_ENABLED   */
  16. /*#define HAL_CRYP_MODULE_ENABLED   */
  17. /*#define HAL_CAN_MODULE_ENABLED   */
  18. /*#define HAL_CEC_MODULE_ENABLED   */
  19. /*#define HAL_COMP_MODULE_ENABLED   */
  20. /*#define HAL_CRC_MODULE_ENABLED   */
  21. /*#define HAL_CRYP_MODULE_ENABLED   */
  22. /*#define HAL_TSC_MODULE_ENABLED   */
  23. /*#define HAL_DAC_MODULE_ENABLED   */
  24. /*#define HAL_I2S_MODULE_ENABLED   */
  25. /*#define HAL_IWDG_MODULE_ENABLED   */
  26. /*#define HAL_LCD_MODULE_ENABLED   */
  27. /*#define HAL_LPTIM_MODULE_ENABLED   */
  28. /*#define HAL_RNG_MODULE_ENABLED   */
  29. /*#define HAL_RTC_MODULE_ENABLED   */
  30. /*#define HAL_SPI_MODULE_ENABLED   */
  31. /*#define HAL_TIM_MODULE_ENABLED   */
  32. /*#define HAL_UART_MODULE_ENABLED   */
  33. /*#define HAL_USART_MODULE_ENABLED   */
  34. /*#define HAL_IRDA_MODULE_ENABLED   */
  35. /*#define HAL_SMARTCARD_MODULE_ENABLED   */
  36. /*#define HAL_SMBUS_MODULE_ENABLED   */
  37. /*#define HAL_WWDG_MODULE_ENABLED   */
  38. /*#define HAL_PCD_MODULE_ENABLED   */
  39. #define HAL_CORTEX_MODULE_ENABLED
  40. #define HAL_DMA_MODULE_ENABLED
  41. #define HAL_FLASH_MODULE_ENABLED
  42. #define HAL_GPIO_MODULE_ENABLED
  43. #define HAL_PWR_MODULE_ENABLED
  44. #define HAL_RCC_MODULE_ENABLED
  45. #define HAL_I2C_MODULE_ENABLED
  46. /* ########################## HSE/HSI Values adaptation ##################### */
  47. /**
  48.   * @brief Adjust the value of External High Speed oscillator (HSE) used in your application.
  49.   *        This value is used by the RCC HAL module to compute the system frequency
  50.   *        (when HSE is used as system clock source, directly or through the PLL).
  51.   */
  52. #if !defined  (HSE_VALUE)
  53.   #define HSE_VALUE    ((uint32_t)8000000) /*!< Value of the External oscillator in Hz */
  54. #endif /* HSE_VALUE */
  55. /**
  56.   * @brief In the following line adjust the External High Speed oscillator (HSE) Startup
  57.   *        Timeout value
  58.   */
  59. #if !defined  (HSE_STARTUP_TIMEOUT)
  60.   #define HSE_STARTUP_TIMEOUT    ((uint32_t)100)   /*!< Time out for HSE start up, in ms */
  61. #endif /* HSE_STARTUP_TIMEOUT */
  62. /**
  63.   * @brief Internal High Speed oscillator (HSI) value.
  64.   *        This value is used by the RCC HAL module to compute the system frequency
  65.   *        (when HSI is used as system clock source, directly or through the PLL).
  66.   */
  67. #if !defined  (HSI_VALUE)
  68.   #define HSI_VALUE    ((uint32_t)8000000) /*!< Value of the Internal oscillator in Hz*/
  69. #endif /* HSI_VALUE */
  70. /**
  71.   * @brief In the following line adjust the Internal High Speed oscillator (HSI) Startup
  72.   *        Timeout value
  73.   */
  74. #if !defined  (HSI_STARTUP_TIMEOUT)
  75. #define HSI_STARTUP_TIMEOUT   ((uint32_t)5000) /*!< Time out for HSI start up */
  76. #endif /* HSI_STARTUP_TIMEOUT */
  77. /**
  78.   * @brief Internal High Speed oscillator for ADC (HSI14) value.
  79.   */
  80. #if !defined  (HSI14_VALUE)
  81. #define HSI14_VALUE ((uint32_t)14000000) /*!< Value of the Internal High Speed oscillator for ADC in Hz.
  82.                                              The real value may vary depending on the variations
  83.                                              in voltage and temperature.  */
  84. #endif /* HSI14_VALUE */
  85. /**
  86.   * @brief Internal High Speed oscillator for USB (HSI48) value.
  87.   */
  88. #if !defined  (HSI48_VALUE)
  89. #define HSI48_VALUE ((uint32_t)48000000) /*!< Value of the Internal High Speed oscillator for USB in Hz.
  90.                                              The real value may vary depending on the variations
  91.                                              in voltage and temperature.  */
  92. #endif /* HSI48_VALUE */
  93. /**
  94.   * @brief Internal Low Speed oscillator (LSI) value.
  95.   */
  96. #if !defined  (LSI_VALUE)
  97. #define LSI_VALUE  ((uint32_t)40000)
  98. #endif /* LSI_VALUE */                      /*!< Value of the Internal Low Speed oscillator in Hz
  99.                                              The real value may vary depending on the variations
  100.                                              in voltage and temperature.  */
  101. /**
  102.   * @brief External Low Speed oscillator (LSI) value.
  103.   */
  104. #if !defined  (LSE_VALUE)
  105. #define LSE_VALUE  ((uint32_t)32768)    /*!< Value of the External Low Speed oscillator in Hz */
  106. #endif /* LSE_VALUE */
  107. #if !defined  (LSE_STARTUP_TIMEOUT)
  108.   #define LSE_STARTUP_TIMEOUT    ((uint32_t)5000)   /*!< Time out for LSE start up, in ms */
  109. #endif /* LSE_STARTUP_TIMEOUT */
  110. /* Tip: To avoid modifying this file each time you need to use different HSE,
  111.    ===  you can define the HSE value in your toolchain compiler preprocessor. */
  112. /* ########################### System Configuration ######################### */
  113. /**
  114.   * @brief This is the HAL system configuration section
  115.   */
  116. #define  VDD_VALUE                    ((uint32_t)3300) /*!< Value of VDD in mv */
  117. #define  TICK_INT_PRIORITY            ((uint32_t)0)    /*!< tick interrupt priority (lowest by default)  */
  118.        /*  Warning: Must be set to higher priority for HAL_Delay()  */
  119.        /*  and HAL_GetTick() usage under interrupt context          */
  120. #define  USE_RTOS                     0
  121. #define  PREFETCH_ENABLE              1
  122. #define  INSTRUCTION_CACHE_ENABLE     0
  123. #define  DATA_CACHE_ENABLE            0
  124. /* ########################## Assert Selection ############################## */
  125. /**
  126.   * @brief Uncomment the line below to expanse the "assert_param" macro in the
  127.   *        HAL drivers code
  128.   */
  129. /* #define USE_FULL_ASSERT   1U */
  130. /* ################## SPI peripheral configuration ########################## */
  131. /* CRC FEATURE: Use to activate CRC feature inside HAL SPI Driver
  132. * Activated: CRC code is present inside driver
  133. * Deactivated: CRC code cleaned from driver
  134. */
  135. #define USE_SPI_CRC                     0U
  136. /* Includes ------------------------------------------------------------------*/
  137. /**
  138.   * @brief Include module's header file
  139.   */
  140. #ifdef HAL_RCC_MODULE_ENABLED
  141. #include "stm32f0xx_hal_rcc.h"
  142. #endif /* HAL_RCC_MODULE_ENABLED */
  143. #ifdef HAL_GPIO_MODULE_ENABLED
  144. #include "stm32f0xx_hal_gpio.h"
  145. #endif /* HAL_GPIO_MODULE_ENABLED */
  146. #ifdef HAL_DMA_MODULE_ENABLED
  147.   #include "stm32f0xx_hal_dma.h"
  148. #endif /* HAL_DMA_MODULE_ENABLED */
  149. #ifdef HAL_CORTEX_MODULE_ENABLED
  150. #include "stm32f0xx_hal_cortex.h"
  151. #endif /* HAL_CORTEX_MODULE_ENABLED */
  152. #ifdef HAL_ADC_MODULE_ENABLED
  153. #include "stm32f0xx_hal_adc.h"
  154. #endif /* HAL_ADC_MODULE_ENABLED */
  155. #ifdef HAL_CAN_MODULE_ENABLED
  156. #include "stm32f0xx_hal_can.h"
  157. #endif /* HAL_CAN_MODULE_ENABLED */
  158. #ifdef HAL_CEC_MODULE_ENABLED
  159. #include "stm32f0xx_hal_cec.h"
  160. #endif /* HAL_CEC_MODULE_ENABLED */
  161. #ifdef HAL_COMP_MODULE_ENABLED
  162. #include "stm32f0xx_hal_comp.h"
  163. #endif /* HAL_COMP_MODULE_ENABLED */
  164. #ifdef HAL_CRC_MODULE_ENABLED
  165. #include "stm32f0xx_hal_crc.h"
  166. #endif /* HAL_CRC_MODULE_ENABLED */
  167. #ifdef HAL_DAC_MODULE_ENABLED
  168. #include "stm32f0xx_hal_dac.h"
  169. #endif /* HAL_DAC_MODULE_ENABLED */
  170. #ifdef HAL_FLASH_MODULE_ENABLED
  171. #include "stm32f0xx_hal_flash.h"
  172. #endif /* HAL_FLASH_MODULE_ENABLED */
  173. #ifdef HAL_I2C_MODULE_ENABLED
  174. #include "stm32f0xx_hal_i2c.h"
  175. #endif /* HAL_I2C_MODULE_ENABLED */
  176. #ifdef HAL_I2S_MODULE_ENABLED
  177. #include "stm32f0xx_hal_i2s.h"
  178. #endif /* HAL_I2S_MODULE_ENABLED */
  179. #ifdef HAL_IRDA_MODULE_ENABLED
  180. #include "stm32f0xx_hal_irda.h"
  181. #endif /* HAL_IRDA_MODULE_ENABLED */
  182. #ifdef HAL_IWDG_MODULE_ENABLED
  183. #include "stm32f0xx_hal_iwdg.h"
  184. #endif /* HAL_IWDG_MODULE_ENABLED */
  185. #ifdef HAL_PCD_MODULE_ENABLED
  186. #include "stm32f0xx_hal_pcd.h"
  187. #endif /* HAL_PCD_MODULE_ENABLED */
  188. #ifdef HAL_PWR_MODULE_ENABLED
  189. #include "stm32f0xx_hal_pwr.h"
  190. #endif /* HAL_PWR_MODULE_ENABLED */
  191. #ifdef HAL_RTC_MODULE_ENABLED
  192. #include "stm32f0xx_hal_rtc.h"
  193. #endif /* HAL_RTC_MODULE_ENABLED */
  194. #ifdef HAL_SMARTCARD_MODULE_ENABLED
  195. #include "stm32f0xx_hal_smartcard.h"
  196. #endif /* HAL_SMARTCARD_MODULE_ENABLED */
  197. #ifdef HAL_SMBUS_MODULE_ENABLED
  198. #include "stm32f0xx_hal_smbus.h"
  199. #endif /* HAL_SMBUS_MODULE_ENABLED */
  200. #ifdef HAL_SPI_MODULE_ENABLED
  201. #include "stm32f0xx_hal_spi.h"
  202. #endif /* HAL_SPI_MODULE_ENABLED */
  203. #ifdef HAL_TIM_MODULE_ENABLED
  204. #include "stm32f0xx_hal_tim.h"
  205. #endif /* HAL_TIM_MODULE_ENABLED */
  206. #ifdef HAL_TSC_MODULE_ENABLED
  207. #include "stm32f0xx_hal_tsc.h"
  208. #endif /* HAL_TSC_MODULE_ENABLED */
  209. #ifdef HAL_UART_MODULE_ENABLED
  210. #include "stm32f0xx_hal_uart.h"
  211. #endif /* HAL_UART_MODULE_ENABLED */
  212. #ifdef HAL_USART_MODULE_ENABLED
  213. #include "stm32f0xx_hal_usart.h"
  214. #endif /* HAL_USART_MODULE_ENABLED */
  215. #ifdef HAL_WWDG_MODULE_ENABLED
  216. #include "stm32f0xx_hal_wwdg.h"
  217. #endif /* HAL_WWDG_MODULE_ENABLED */
  218. /* Exported macro ------------------------------------------------------------*/
  219. #ifdef  USE_FULL_ASSERT
  220. /**
  221.   * @brief  The assert_param macro is used for function's parameters check.
  222.   * @param  expr: If expr is false, it calls assert_failed function
  223.   *         which reports the name of the source file and the source
  224.   *         line number of the call that failed.
  225.   *         If expr is true, it returns no value.
  226.   * @retval None
  227.   */
  228.   #define assert_param(expr) ((expr) ? (void)0U : assert_failed((uint8_t *)__FILE__, __LINE__))
  229. /* Exported functions ------------------------------------------------------- */
  230.   void assert_failed(uint8_t* file, uint32_t line);
  231. #else
  232.   #define assert_param(expr) ((void)0U)
  233. #endif /* USE_FULL_ASSERT */
  234.
  235. #ifdef __cplusplus
  236. }
  237. #endif
  238. #endif /* __STM32F0xx_HAL_CONF_H */
20190917電機軟硬件更新:軟件跟前版基本一樣只更改了幾個參數以提高穩定性,增加了中文注釋以方便學習理解;硬件加了防反接二極管,型號SL54,將原來的排針座子改為更美觀高度更低的XH2.54座子,另外將串口和燒錄口合二為一,方便用STLINKV2.1直接進行燒錄和串口通信。
    20190831軟硬件更新:硬件電路板將光耦輸入側覆銅挖空防止干擾,傳感器改為底層焊接,電路板設計為需要用尼龍墊圈跟電機隔開2mm左右以防止干擾;軟件方面所有浮點數變量都改為定點變量,重新改寫了程序以適應定點變量,單片機計算量大為降低,CPU仍然有3/5左右空閑時間可以用來進行其他功能的二次開發。位置環更新頻率由5KHZ提高到10KHZ,控制性能加強,42最高轉速提到1200RPM左右,57提到1000RPM左右。優化了定時器處理STEP/DIR信號的部分程序,即使是幾百K乃至上M的高速脈沖都可以輕松處理而不丟脈沖。重載了stdio.h頭文件里的fputc()和fgetc()兩個函數,程序現在可以利用printf()和scanf()等標準輸入輸出函數編寫RS232和RS485協議,另外加了一個簡單的ASCII協議作為參考。
      20190810最新更新:硬件電路板換了新的LDO型號RS3005,徹底解決了穩壓芯片過熱停機的問題。另外輸入信號CLK由原來的外部中斷腳位改為定時器TIM1的外部計數輸入腳,電路板改為同時支持STM32F103和STM32F030兩種單片機。軟件上對原來CLK信號的處理由外部中斷改為定時器計數,這樣就不需要耗費大量的處理器資源。原先用中斷來處理CLK信號導致耗費大量的處理時間,也會導致程序對電機的測速不正確,32細分的情況下電機轉速只要跑到1000RPM就可能使程序崩潰,想要使用128/256這樣的高細分幾乎不可能。
     這套一體化閉環步進電機是店主自己全新研發的,不是拿人家外國開源的項目直接山寨抄襲來騙小白的, 購買電機附帶全套軟硬件,包括源代碼程序、42步進和57步進的原理圖和PCB,可以買回去自己打板復制,也可以二次開發,店主會不定期更新軟硬件并修復BUG,可以提供代碼級技術支持。數量有限,都是平時抽空手工焊接做出來的,購買前請先咨詢店主是否有貨。
    電機軟硬件性能大幅提高,硬件成本僅國外MECHADUINO及其山寨產品的1/2不到,最大驅動電流可達3.5A,是國外版的2倍,最大轉速提高2.5倍(42電機1000RPM,57電機800RPM),振動及噪聲減小2/3。按照工業級標準設計,加入高速隔離光耦、軟件看門狗,可靠性大幅優化。自帶開環閉環模式隨意切換,細分選擇、編碼器校正全部撥碼開關一鍵完成,無需連接上位機二次編程!
更多細節和視頻可以參考帖子:
https://www.bilibili.com/video/av53223504?from=search&seid=10269700708564966156
閉環步進參數:
主控芯片:意法半導體STM32F030C8T6
驅動芯片:兩顆A4950(最大電流3.5A)
編碼器芯片:英飛凌15位汽車工業級TLE5012B
高速光耦:東芝雙通道TLP2168
工作電壓:12-30V(推薦24V)
工作電流:額定1.3A(42步進)2.5A(57步進)最大3.5A
控制精度:小于0.08度
電子齒輪:4、8、16、32(可任意設置)
清單:包含一塊電機驅動板+電機+專用徑向磁鐵
          +安裝墊片,全部組裝好測好到手能用!
電流設置
電流設置
STM32_FLASH的3種燒寫方式.pdf
606.22 KB, 下載次數: 655, 下載積分: 黑幣 -5
燒錄
PID經典教程.pdf
343.56 KB, 下載次數: 723, 下載積分: 黑幣 -5
pid調整
42步進電路圖,57步進電路PCB文件圖.7z
14.08 MB, 下載次數: 885, 下載積分: 黑幣 -5
原理圖pcb
4257通用固件.7z
2.7 MB, 下載次數: 1106, 下載積分: 黑幣 -5
源碼
參與人數 6黑幣 +108 收起 理由
lzh1762 + 6
hzd530 + 6 贊一個!
lxj199610 + 30 共享資料的黑幣獎勵!
accumulation + 10 很給力!
BigWheels + 6 贊一個!
ID:631549 發表于 2019-10-29 14:55 | 顯示全部樓層
感謝分享。
ID:605233 發表于 2019-10-29 18:08 | 顯示全部樓層
厲害厲害,學習了
ID:240034 發表于 2019-10-29 20:12 | 顯示全部樓層
謝樓主搬過來!
ID:631549 發表于 2019-11-1 14:19 | 顯示全部樓層
好像現在有更新的版本了,你有了嗎
ID:373211 發表于 2019-11-6 12:27 | 顯示全部樓層
正在學習stm32,謝謝
ID:194659 發表于 2019-11-6 15:08 | 顯示全部樓層
樓主厲害了,謝謝
ID:512926 發表于 2019-11-10 14:43 | 顯示全部樓層
樓主厲害了,謝謝
ID:154493 發表于 2019-11-10 15:52 | 顯示全部樓層
正在學習STM32,樓主威武
ID:639612 發表于 2019-11-11 12:55 | 顯示全部樓層
正在學習STM32 步進控制部分,樓主威武
ID:81072 發表于 2019-11-17 00:36 | 顯示全部樓層
已經加樓主的群了
ID:290380 發表于 2019-11-29 14:11 | 顯示全部樓層
厲害厲害,學習了
ID:652775 發表于 2019-12-4 17:42 | 顯示全部樓層
能將資料集合一起嗎?
ID:658266 發表于 2019-12-7 15:45 | 顯示全部樓層
想打板試一下效果
ID:658526 發表于 2019-12-7 22:37 | 顯示全部樓層
給力,牛逼
ID:659782 發表于 2019-12-9 16:46 | 顯示全部樓層
樓主辛苦了,感謝分享!!!
ID:273989 發表于 2019-12-10 12:05 來自觸屏版 | 顯示全部樓層
感謝分享
ID:661403 發表于 2019-12-11 11:42 | 顯示全部樓層
厲害厲害, 感謝分享。
ID:664460 發表于 2019-12-16 21:39 來自觸屏版 | 顯示全部樓層
yyyhhhsss 發表于 2019-11-1 14:19
好像現在有更新的版本了,你有了嗎
你有么?
ID:199698 發表于 2019-12-17 09:20 | 顯示全部樓層
板子好看。。。最近也在學AD
ID:216244 發表于 2019-12-20 22:14 | 顯示全部樓層
不錯,感謝分享!
ID:678860 發表于 2020-1-1 13:29 | 顯示全部樓層
給力!
ID:250696 發表于 2020-1-2 11:27 | 顯示全部樓層
有作者的那個寶店嗎
ID:525089 發表于 2020-1-2 16:13 | 顯示全部樓層
真好要開發步進電機驅動,謝謝樓主
ID:597389 發表于 2020-1-31 07:27 來自觸屏版 | 顯示全部樓層
感謝樓主,多謝分享
ID:462326 發表于 2020-2-1 19:29 | 顯示全部樓層
用什么軟件打開?keil?
ID:592475 發表于 2020-2-2 11:24 | 顯示全部樓層
好東西,收藏
ID:41619 發表于 2020-2-3 14:33 | 顯示全部樓層
到哪里去買?樓主給個地址
ID:140186 發表于 2020-2-3 22:39 | 顯示全部樓層
謝謝樓主分享~
ID:688561 發表于 2020-2-7 17:46 | 顯示全部樓層
這個非常實用!!樓主的資料很好!
ID:475367 發表于 2020-2-8 23:09 | 顯示全部樓層
樓主的資料很好!贊贊贊
ID:691330 發表于 2020-2-9 13:15 | 顯示全部樓層
很好,有用的
ID:123983 發表于 2020-2-21 14:45 | 顯示全部樓層
謝謝分享!!!
ID:490458 發表于 2020-2-21 21:43 | 顯示全部樓層
要是打包了就好了,要太多幣了,下不起
ID:697855 發表于 2020-2-25 11:11 | 顯示全部樓層
感謝分享。
ID:317074 發表于 2020-2-25 13:30 | 顯示全部樓層
有網店嗎?
ID:592475 發表于 2020-2-25 22:31 | 顯示全部樓層
沒有積分啊,下載不全啊
ID:53978 發表于 2020-2-27 21:32 | 顯示全部樓層
這個看著很好,下載來看看。
ID:417194 發表于 2020-3-1 11:05 | 顯示全部樓層
樓主厲害了,謝謝
ID:185519 發表于 2020-3-1 13:03 | 顯示全部樓層
正在學習stm32,謝謝
主站蜘蛛池模板: 鲁鲁鲁鲁鲁鲁鲁777777 | 亚洲区在线 | 国产综合视频 | 成人免费看片在线观看 | www欧美| 特级黄色片 | 国产欧美成人 | 国产精品久久久久久久久久久久午夜片 | 国产超碰在线观看 | 国产精品国产精品国产专区不卡 | 久久久黄色片 | 国产精品毛片一区视频播 | 青青草手机在线视频 | 亚洲精品伦理 | 黄色av免费 | 亚洲黄色影院 | 国产视频成人 | www.久草| 欧美综合久久 | 精品福利一区 | 亚洲精品一二 | 丰满岳乱妇一区二区 | 五月激情久久 | 欧美色综合网 | 国产激情| 欧美激情三区 | 亚洲69视频 | 欧美性生交 | 久久av一区二区三区亚洲 | 婷婷六月色 | 国产精品毛片一区视频播 | 看真人一级毛片 | 国产免费视频 | 不卡视频在线观看 | 二区在线观看 | 在线a| 91久久久精品 | 日产久久视频 | 特黄aaaaaaaaa真人毛片 | 久久免费精品 | 久久神马 |
