分享學(xué)習(xí)一下
單片機(jī)源程序如下:
- using System;
- using System.Collections.Generic;
- using System.ComponentModel;
- using System.Data;
- using System.Drawing;
- using System.Linq;
- using System.Text;
- using System.Windows.Forms;
- using System.IO.Ports;
- namespace SerialCommunicate
- public partial class Form1 : Form
- public Form1()
- InitializeComponent();
- System.Windows.Forms.Control.CheckForIllegalCrossThreadCalls = false;
- private void button1_Click(object sender, EventArgs e)
- try
- serialPort1.PortName = comboBox1.Text;
- serialPort1.BaudRate = Convert.ToInt32(comboBox2.Text,10);//十進(jìn)制數(shù)據(jù)轉(zhuǎn)換
- serialPort1.Open();
- button1.Enabled = false;//打開串口按鈕不可用
- button2.Enabled = true;//關(guān)閉串口
- catch {
- MessageBox.Show("端口錯誤,請檢查串口", "錯誤");
- private void Form1_Load(object sender, EventArgs e)
- for (int i = 1; i < 20; i++)
- comboBox1.Items.Add("COM" + i.ToString());
- comboBox1.Text = "COM1";//串口號多額默認(rèn)值
- comboBox2.Text = "9600";//波特率默認(rèn)值
- /*****************非常重要************************/
- serialPort1.DataReceived += new SerialDataReceivedEventHandler(port_DataReceived);//必須手動添加事件處理程序
- private void port_DataReceived(object sender, SerialDataReceivedEventArgs e)//串口數(shù)據(jù)接收事件
- if (!radioButton3.Checked)//如果接收模式為字符模式
- string str = serialPort1.ReadExisting();//字符串方式讀
- textBox1.AppendText(str);//添加內(nèi)容
- else { //如果接收模式為數(shù)值接收
- byte data;
- data = (byte)serialPort1.ReadByte();//此處需要強(qiáng)制類型轉(zhuǎn)換,將(int)類型數(shù)據(jù)轉(zhuǎn)換為(byte類型數(shù)據(jù),不必考慮是否會丟失數(shù)據(jù)
- string str = Convert.ToString(data, 16).ToUpper();//轉(zhuǎn)換為大寫十六進(jìn)制字符串
- textBox1.AppendText("0x" + (str.Length == 1 ? "0" + str : str) + " ");//空位補(bǔ)“0”
- //上一句等同為:if(str.Length == 1)
- // str = "0" + str;
- // else
- // str = str;
- // textBox1.AppendText("0x" + str);
- private void radioButton2_CheckedChanged(object sender, EventArgs e)
- private void button2_Click(object sender, EventArgs e)
- try
- serialPort1.Close();//關(guān)閉串口
- button1.Enabled = true;//打開串口按鈕可用
- button2.Enabled = false;//關(guān)閉串口按鈕不可用
- catch (Exception err)//一般情況下關(guān)閉串口不會出錯,所以不需要加處理程序
- private void button3_Click(object sender, EventArgs e)
- byte[] Data = new byte[1];//作用同上集
- if (serialPort1.IsOpen)//判斷串口是否打開,如果打開執(zhí)行下一步操作
- if (textBox2.Text != "")
- if (!radioButton1.Checked)//如果發(fā)送模式是字符模式
- try
- serialPort1.WriteLine(textBox2.Text);//寫數(shù)據(jù)
- MessageBox.Show("串口數(shù)據(jù)寫入錯誤", "錯誤");//出錯提示
- else
- for (int i = 0; i < (textBox2.Text.Length - textBox2.Text.Length % 2) / 2; i++)//取余3運算作用是防止用戶輸入的字符為奇數(shù)個
- Data[0] = Convert.ToByte(textBox2.Text.Substring(i * 2, 2), 16);
- serialPort1.Write(Data, 0, 1);//循環(huán)發(fā)送(如果輸入字符為0A0BB,則只發(fā)送0A,0B)
- if (textBox2.Text.Length % 2 != 0)//剩下一位單獨處理
- Data[0] = Convert.ToByte(textBox2.Text.Substring(textBox2.Text.Length-1, 1), 16);//單獨發(fā)送B(0B)
- serialPort1.Write(Data, 0, 1);//發(fā)送
SerialCommunicate.zip
(238.24 KB, 下載次數(shù): 49)
2019-11-3 16:28 上傳
點擊文件名下載附件
