查看: 4855|回復: 9
基于STC89C52RC單片機制作的頻率及占空比均可調程序
ID:280979 發表于 2019-11-5 22:37 | 顯示全部樓層 |閱讀模式
注意  單片機必須是52rc不能用60s2
#include"main.h"
#include"peizhi.h"
#include"smg.h"
#include"eeprom.h"
sfr WDT_CONTR=0XE1;
unsigned char HighRH = 0;  //高電平重載值的高字節
unsigned char HighRL = 0;  //高電平重載值的低字節
unsigned char LowRH  = 0;  //低電平重載值的高字節
unsigned char LowRL  = 0;  //低電平重載值的低字節
/***********************按鍵定義**********************************/
bit d1 = 1;
bit d2 = 1;
bit d3 = 1;
uint8 ci;
uint8 ca = 0;
uint8 ca1 = 0;
uint16 cb = 0;
void key();                 //按鍵函數聲明
void ConfigPWM(unsigned int fr, unsigned char dc);  //頻率和占空比調節函數
   bit q1 = 1;
   bit q2 = 1;
   bit q3 = 1;
   ca = EEPROMReadByte(0);
   cb = EEPROMReadByte(1)*255+EEPROMReadByte(2);
   EA = 1;       //開總中斷
   peizhit1(1);  //配置T0定時2ms
                  ConfigPWM(cb, ca);    //頻率100Hz,占空比10%
                  if(d1 != q1)
                          q1 = d1;
                        if(d1 == 0)
                                ca1++;
                                if(ca1 >= 2)
                                          ca1 = 0;
           if(ca1 == 1)
                  if(d2 != q2)
                                  q2 = d2;
                                if(d2 == 0)
                                        ca++;
                                        EEPROMSectorErase(0);
                                        EEPROMWriteByte(0,ca);
                                        EEPROMWriteByte(2,cb);
                                        EEPROMWriteByte(1,cb>>8);
                                        if(ca >= 99)
                                                ca = 99;
                          if(d3 != q3)
                                  q3 = d3;
                                if(d3 == 0)
                                        if(ca>0)
                                                ca--;
                if(ca1 == 0)
                          if(d2 == 0)
                                  cb++;
                                  if(cb >= 200)
                                                cb = 200;
                          if(d3 == 0)
                                        if(cb>0)
                                                cb--;
                xianshi1(cb);
                xianshi2(ca);
void key()
        static uint8 saomiaozhi[] = {1,1,1,1};
        saomiaozhi[0] = (saomiaozhi[0]<<1) | in1;
        saomiaozhi[1] = (saomiaozhi[1]<<1) | in2;
        saomiaozhi[2] = (saomiaozhi[2]<<1) | in3;
        if(saomiaozhi[0] == 0x00)
                d1 = 0;
        if(saomiaozhi[0] == 0xff)
                d1 = 1;
        if(saomiaozhi[1] == 0x00)
                d2 = 0;
        if(saomiaozhi[1] == 0xff)
                d2 = 1;
        if(saomiaozhi[2] == 0x00)
                d3 = 0;
        if(saomiaozhi[2] == 0xff)
                d3 = 1;
/* 配置并啟動PWM,fr-頻率,dc-占空比 */
    unsigned int  high, low;
    unsigned long tmp;
    tmp  = (11059200/12) / fr;  //計算一個周期所需的計數值
    high = (tmp*dc) / 100;      //計算高電平所需的計數值
    low  = tmp - high;          //計算低電平所需的計數值
    high = 65536 - high + 12;   //計算高電平的重載值并補償中斷延時
    low  = 65536 - low  + 12;   //計算低電平的重載值并補償中斷延時
    HighRH = (unsigned char)(high>>8); //高電平重載值拆分為高低字節
    HighRL = (unsigned char)high;
    LowRH  = (unsigned char)(low>>8);  //低電平重載值拆分為高低字節
    LowRL  = (unsigned char)low;
    TMOD &= 0xF0;   //清零T0的控制位
    TMOD |= 0x01;   //配置T0為模式1
    TH0 = HighRH;   //加載T0重載值
    TL0 = HighRL;
    ET0 = 1;        //使能T0中斷
    TR0 = 1;        //啟動T0
    PWMOUT = 1;     //輸出高電平
/* T0中斷服務函數,產生PWM輸出 */
void InterruptTimer0() interrupt 1
    if (PWMOUT == 1)  //當前輸出為高電平時,裝載低電平值并輸出低電平
        TH0 = LowRH;
        TL0 = LowRL;
        PWMOUT = 0;
    else              //當前輸出為低電平時,裝載高電平值并輸出高電平
        TH0 = HighRH;
        TL0 = HighRL;
        PWMOUT = 1;
/* T0中斷服務函數,完成數碼管、按鍵掃描與秒表計數 */
void t1() interrupt 3
    TH1 = T1RH;  //重新加載重載值
    TL1 = T1RL;
        ci++;
        ssmg();                 //數碼管掃描
        if(ci>=2)
                ci = 0;
                key();
頻率及占空比均可調帶數碼管模塊完整程序.rar
198.16 KB, 下載次數: 108, 下載積分: 黑幣 -5
頻率及占空比均可調帶數碼管模塊DXP資料.rar
931.35 KB, 下載次數: 79, 下載積分: 黑幣 -5
ID:385637 發表于 2019-11-6 11:45 | 顯示全部樓層
這個占空比與頻率都可調,真是好資料,謝謝分享,
ID:225481 發表于 2019-11-6 13:12 | 顯示全部樓層
可以用來做LED燈光調節,不錯的資料。
ID:403593 發表于 2019-11-6 16:01 | 顯示全部樓層
非常好的資料,感謝樓主分享!
ID:73030 發表于 2022-2-8 20:17 | 顯示全部樓層
這個程序值得學習,謝謝作者分享。
ID:970519 發表于 2022-2-9 10:18 | 顯示全部樓層
程序值得學習,謝謝作者分享
ID:138707 發表于 2022-2-28 16:41 | 顯示全部樓層
ID:345506 發表于 2023-7-15 09:59 | 顯示全部樓層
不錯,不錯, 很好學習,參考的資料
ID:298215 發表于 2025-6-4 22:23 | 顯示全部樓層
謝謝分享,太好了
ID:145862 發表于 2025-6-6 09:27 | 顯示全部樓層
vss是多少
主站蜘蛛池模板: 91在线观 | 一级片黄色 | 国产美女免费 | 黄网站免费观看 | 久久午夜视频 | 中文字幕国产在线 | 国产一级在线观看 | 精品日韩一区二区三区 | 日韩专区在线 | 午夜激情福利视频 | 国产欧美在线观看 | 天堂成人在线 | 亚洲精品成人 | 少妇bbw搡bbbb搡bbbb | 亚洲黄色片 | 久久av网 | 欧美在线观看一区 | 日韩成人精品一区二区 | 日韩精品视频免费 | 亚洲精品一二区 | 久久久久性 | av网址在线 | 欧美裸体视频 | 日韩免费视频一区二区 | 国产乱淫av | 在线视频福利 | 亚洲精品成a人在线观看 | 香蕉视频在线播放 | 中文字幕一区二 | 中文在线资源 | 一级片在线播放 | av免费在线观看网站 | 国产白丝精品91爽爽久久 | 久久久久黄色 | 一区二区在线视频 | 中文字幕免费观看视频 | 欧美性色网 | 午夜视频在线看 | 乱色av | 91一区二区三区 | 亚洲免费黄色 |
