查看: 2169|回復: 1
求助一個搶答器程序怎么修改,輸入程序后,數碼管一直顯示88,無法控制
ID:652016 發表于 2019-11-28 22:52 來自觸屏版 | 顯示全部樓層 |閱讀模式
程序:#include<reg51.h>
sbit DIN=P3^0;
sbit LOAD=P3^1;
sbit CLK=P3^2;
sbit key0=P1^0;
sbit key1=P1^1;
sbit key2=P1^2;
sbit key3=P1^3;
sbit key4=P1^4;
sbit key5=P1^5;
sbit key6=P1^6;
sbit key7=P1^7;
sbit key_clear=P2^0;
sbit begin=P2^1;
sbit sounder=P3^7;
unsigned char second=30;
unsigned char counter=0;
unsigned char people=0;
unsigned char num_add[]={0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08};
unsigned char num_dat[]={0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87,0x88,0x89};
unsigned char keyscan()
        unsigned char keyvalue,temp;
        keyvalue=0;
        P1=0xff;
        temp=P1;
        if(~(P1&temp))
    switch(temp)
          case 0xfe:
           keyvalue=1;
           break;
          case 0xfd:
           keyvalue=2;
           break;
          case 0xfb:
           keyvalue=3;
           break;
          case 0xf7:
           keyvalue=4;
           break;
          case 0xef:
           keyvalue=5;
           break;
          case 0xdf:
           keyvalue=6;
           break;
          case 0xbf:
           keyvalue=7;
           break;
          case 0x7f:
           keyvalue=8;
           break;
          default:
             keyvalue=0;
                 break;
  return keyvalue;
void max7219_send(unsigned char add,unsigned char dat)
       unsigned char ADS,i,j;
           LOAD=0;
           i=0;
           while(i<16)
             if(i<8)
                    ADS=add;
                    ADS=dat;
                 for(j=8;j>=1;j--)
                   DIN=ADS&0x80;
                   ADS=ADS<<1;
                   CLK=1;
                   CLK=0;
                 i=i+8;
           LOAD=1;
void max7219_init()
   max7219_send(0x0c,0x01);
   max7219_send(0x0b,0x07);
   max7219_send(0x0a,0xf5);
   max7219_send(0x09,0xff);
void time_display(unsigned char x)
   unsigned char i,j;
   i=x/10;
   j=x%10;
   max7219_send(num_add[1],num_dat[j]);
   max7219_send(num_add[0],num_dat[i]);
void scare_display(unsigned char x)
   unsigned char i,j;
   i=x/10;
   j=x%10;
   max7219_send(num_add[3],num_dat[j]);
   max7219_send(num_add[2],num_dat[i]);
   void holderscan()
    time_display(second);
        scare_display(people);
        if(~key_clear)
           while(~key_clear);
           if(people)
             second=30;
                 people=0;
         if(second<60)
           second++;
         second=0;
void timer_init()
  EA=1;
  ET0=1;
  TMOD=0x01;
  TH0=0xd8;
  TL0=0xef;
    while(1);
            do
                         holderscan();
                while(begin);
                while(~begin);
                max7219_init();
                timer_init();
                TR0=1;
                do
                  people=keyscan();
                 while((!people)&&(second));
                 TR0=0;
   void timer0()interrupt 1
     if(counter<100)
            counter++;
                if(counter==50)
                  sounder=0;
              sounder=1;
                  counter=0;
                  second=second-1;
        TH0=0xd8;
        TL0=0xef;
        TR0=1;
ID:985382 發表于 2021-11-27 19:50 | 顯示全部樓層
數碼管的問題,共陰和共陽
主站蜘蛛池模板: 天天操天天干天天操 | 免费一看一级毛片 | 国产视频一区二区在线 | 蜜桃综合网 | 一区二区三区国产视频 | 亚洲国产精品久久久 | 亚洲精品www | 精品理论片 | av免费网站| 欧美精品二区三区四区免费看视频 | 五月婷婷中文字幕 | 蜜桃综合网 | 99热 | 夜间福利视频 | 在线黄色av | 亚洲天堂视频在线 | 在线中文字幕视频 | 久久精品播放 | 亚洲精品成a人在线观看 | 99久久久精品 | 亚洲欧美日韩在线 | av中文网| 日本香蕉视频 | 国产成人在线免费观看 | 国产一区二区自拍 | 国产主播99| 欧美激情综合五月色丁香 | 成人免费毛片嘿嘿连载视频 | 精品少妇一区二区三区免费观 | 亚洲免费专区 | 国产精品无遮挡 | 亚洲91精品 | 日韩欧美一区二区在线观看 | 国产毛片在线 | 99久久九九 | 18视频在线观看男男 | 成人在线视频免费 | 亚洲黄色大片 | 亚洲激情欧美 | 国产一区2区 | 欧美www.|
