查看: 6223|回復: 7
對講機BK4811驅動程序 STM32
ID:60158 發表于 2019-12-4 09:07 | 顯示全部樓層 |閱讀模式
對講機芯片BK4811驅動程序,親測可用
  1. #include "BK4811.h"
  2. #include "delay.h"
  3. u8 chan_num;
  4. u16 freq_h,freq_l;
  5. UINT16 g_reg0_15_buff[16];
  6. CODE UINT16 reg0_18[]=
  7. {
  8. 0x9100,
  9. 0x0000,
  10. 0xB525,//2,updated
  11. 0x08CC,//3,updated
  12. 0x021D,//4,updated
  13. 0xB888,//5,updated
  14. 0x07E7,//6,updated
  15. 0xD051,//7,NOT read
  16. 0xFF40,//8,NOT read
  17. 0xA1FF,//9,updated
  18. 0x1C40,//10,updated
  19. 0x8130,//11,updated
  20. 0x0000,//12,NOT read
  21. 0x8030,//13,NOT read
  22. 0x08C0,//14,NOT read
  23. 0x0000,//15,NOT read
  24. 0x0000,
  25. 0x8800,
  26. 0x4068
  27. };
  28. CODE UINT16 ramp_table[]=
  29. {
  30. 0x0000,
  31. 0x0420,
  32. 0x083F,
  33. 0x0C5E,
  34. 0x107C,
  35. 0x149A,
  36. 0x18B7,
  37. 0x1CD4,
  38. 0x20F0,
  39. 0x250B,
  40. 0x2927,
  41. 0x2D41,
  42. 0x315C,
  43. 0x3575,
  44. 0x398F,
  45. 0x3DA7,
  46. 0x41C0,
  47. 0x45D7,
  48. 0x49EF,
  49. 0x4E05,
  50. 0x521B,
  51. 0x5631,
  52. 0x5A46,
  53. 0x5E5B,
  54. 0x626F,
  55. 0x6683,
  56. 0x6A96,
  57. 0x6EA9,
  58. 0x72BB,
  59. 0x76CD,
  60. 0x7ADE,
  61. 0x7EEF,
  62. 0x82FF,
  63. 0x870F,
  64. 0x8B1E,
  65. 0x8F2D,
  66. 0x933B,
  67. 0x9749,
  68. 0x9B56,
  69. 0x9F63,
  70. 0xA36F,
  71. 0xA77B,
  72. 0xAB86,
  73. 0xAF91,
  74. 0xB39B,
  75. 0xB7A5,
  76. 0xBBAE,
  77. 0xBFB7,
  78. 0xC3BF,
  79. 0xC7C7,
  80. 0xCBCE,
  81. 0xCFD5,
  82. 0xD3DB,
  83. 0xD7E1,
  84. 0xDBE6,
  85. 0xDFEB,
  86. 0xE3EF,
  87. 0xE7F3,
  88. 0xEBF6,
  89. 0xEFF9,
  90. 0xF3FB,
  91. 0xF7FD,
  92. 0xFBFE,
  93. 0xFFFF
  94. };
  95. /***************************
  96. return:
  97. default: 145
  98. ***************************/
  99. u16 Read_BK4811_DeviceID(void)
  100. {
  101.         u16 read_Value;
  102.         read_Value=BK_Read_Reg(0x00);
  103.         return ((read_Value&0xff00)>>8);
  104. }
  105. /***************************
  106. return:
  107. default: 66
  108. ***************************/
  109. u16 Read_BK4811_ChipID(void)
  110. {
  111.         u16 read_Value;
  112.         read_Value=BK_Read_Reg(0x01);
  113.         return (read_Value&0x00ff);
  114. }
  115. /***************************
  116. return:
  117. 1:25khz
  118. 0:12.5khz
  119. ***************************/
  120. u8 Read_BK4811_Channel(void)
  121. {
  122.         u16 read_Value;
  123.         read_Value=BK_Read_Reg(0x01);
  124.         if(read_Value&0x8000)
  125.                 return 1;
  126.         else
  127.                 return 0;
  128. }
  129. /***************************
  130. channel:
  131. 1:25khz
  132. 0:12.5khz
  133. ***************************/
  134. void Set_BK4811_Channel(u8 channel)
  135. {
  136.         u16 read_Value;
  137.
  138.         if(0==channel)
  139.         {
  140.                 read_Value=BK_Read_Reg(0x01);
  141.                 read_Value&=0x7fff;
  142.                 BK_Write_Reg(0x01,read_Value);
  143.         }
  144.         else if(1==channel)
  145.         {
  146.                 read_Value=BK_Read_Reg(0x01);
  147.                 read_Value|=0x8000;
  148.                 BK_Write_Reg(0x01,read_Value);
  149.         }
  150. }
  151. /***************************
  152. return:
  153. 1:2.4kbps
  154. 0:1.2kbps
  155. ***************************/
  156. u8 Read_BK4811_FSK_AIR_DataRate(void)
  157. {
  158.         u16 read_Value;
  159.         read_Value=BK_Read_Reg(0x01);
  160.         if(read_Value&0x4000)
  161.                 return 1;
  162.         else
  163.                 return 0;
  164. }
  165. /***************************
  166. return:
  167. 1:2.4kbps
  168. 0:1.2kbps
  169. ***************************/
  170. void Set_BK4811_FSK_AIR_DataRate(u8 data_rate)
  171. {
  172.         u16 read_Value;
  173.
  174.         if(0==data_rate)
  175.         {
  176.                 read_Value=BK_Read_Reg(0x01);
  177.                 read_Value&=0xBFFF;
  178.                 BK_Write_Reg(0x01,read_Value);
  179.         }
  180.         else if(1==data_rate)
  181.         {
  182.                 read_Value=BK_Read_Reg(0x01);
  183.                 read_Value|=0x4000;
  184.                 BK_Write_Reg(0x01,read_Value);
  185.         }
  186. }
  187. /*************************************************
  188.   Description:    ramp table initilaize
  189. *************************************************/
  190. void BK4811_Ramp_Table_Init(void)
  191. {
  192.         UINT8 i;
  193.         for(i=0;i<64;i++)
  194.                 BK_Write_Reg(42,ramp_table[i]);
  195. }
  196. /*************************************************
  197.   Description:    analog register initilaize
  198. *************************************************/
  199. void BK4811_Analog_Init(void)
  200. {
  201.         UINT8 i;
  202.         for(i=1;i<=15;i++)
  203.         {
  204.                 g_reg0_15_buff[i]=reg0_18[i];
  205.                 BK_Write_Reg(i, g_reg0_15_buff[i]);
  206.         }
  207.         BK4811_Ramp_Table_Init();
  208.         BK_Write_Reg(16, 0x3684);//0x3684:IF=88K,0x4B80: IF=121.875kHz, 0x05CF: IF=9.375kHz
  209.         BK_Write_Reg(17, 0x8800);//updated 4812
  210.         BK_Write_Reg(18, 0x406c);//updated 4812
  211.         BK_Write_Reg(19, 0x8000);//updated 4812
  212.         BK_Write_Reg(20, 0x0000);//updated
  213.         BK_Write_Reg(21, 0x0000);
  214.         BK_Write_Reg(22, 0x3200);//updated
  215.         BK_Write_Reg(23, 0x2000);//updated
  216.         BK_Write_Reg(24, 0x086c);
  217.         BK_Write_Reg(25, 0x13ba);
  218.         BK_Write_Reg(26, 0x0000);
  219.         BK_Write_Reg(27, 0x0000);
  220.         BK_Write_Reg(28, 0x0000);
  221.         BK_Write_Reg(29, 0x0000);
  222.         BK_Write_Reg(30, 0x0000);
  223. ……………………
  224. …………限于本文篇幅 余下代碼請從51黑下載附件…………
BK4811_FM.7z (220.31 KB, 下載次數: 73)
ID:1 發表于 2019-12-4 15:57 | 顯示全部樓層
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
ID:429522 發表于 2020-6-17 01:05 | 顯示全部樓層
非常感謝,對我很有用!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ID:72990 發表于 2020-11-23 12:18 | 顯示全部樓層
void BK_Set_Freq(UINT8 dir,  double frequency)  //frequencyP 這個參數為什么沒有使用
        UINT16         val = 0;
        if(DIR_TX==dir)
                BK_RampDown_Enable();
        if((chan_num == 1)||(chan_num == 2))  //chan_num 這個變量沒看到賦值,怎么做判斷
                val = BK_Read_Reg(126);
                val |= 0x0010;
                BK_Write_Reg(126, val);
                if(chan_num == 1)
                        BK_Write_Reg(127, 0x4719);
                        BK_Write_Reg(127, 0x1095);
        if((chan_num == 3)||(chan_num == 4)||(chan_num == 5))
                val &= 0xffef;
                if(chan_num == 3)
                        BK_Write_Reg(127, 0xDA11);
                else if(chan_num == 4)
                        BK_Write_Reg(127, 0xA38D);
                        BK_Write_Reg(127, 0x6D08);
        BK_Write_Reg(113, freq_h);//freq_h這個也沒見給賦值
        BK_Write_Reg(114, freq_l);//freq_l這個也沒見給賦值
        BK_SPI_Trigger();
        g_reg0_15_buff[3]&=0x1FFF;
        if(chan_num == 1)
                g_reg0_15_buff[3]|=0x8000;
        else if(chan_num == 2)
                g_reg0_15_buff[3]|=0x6000;
        else if(chan_num == 3)
                g_reg0_15_buff[3]|=0x4000;
                g_reg0_15_buff[3]|=0x2000;
        else if(chan_num == 5)
                g_reg0_15_buff[3]|=0x0000;
        BK_Write_Reg(3, g_reg0_15_buff[3]);
        delay_ms(15);
        if(DIR_TX==dir)
                BK_RampUp_Enable();
求解 謝謝
ID:758755 發表于 2021-3-2 12:10 來自觸屏版 | 顯示全部樓層
157442843 發表于 2020-11-23 12:18
        UINT16         val ...
請問怎樣取消發射時限??我們需要開機就一直發射!
ID:622059 發表于 2021-3-11 21:48 | 顯示全部樓層
小白一枚,想問問附件下載后那個文件是源碼啊
ID:901572 發表于 2024-9-11 15:08 | 顯示全部樓層
有用,感謝大佬分享
ID:606120 發表于 2025-3-5 20:55 | 顯示全部樓層
小白一枚
主站蜘蛛池模板: 亚洲黄色av | 亚洲精品观看 | 亚洲人成免费 | 中文字幕日韩高清 | 亚洲第一伊人 | 欧美一区不卡 | 婷婷视频网 | 欧美超碰在线 | 国产精品亚洲综合 | 精产国产伦理一二三区 | av影院在线 | 国产精品一区二区不卡 | www.黄视频| av青青草 | 国产美女毛片 | 国产精品毛片va一区二区三区 | 国产精品国产三级国产 | 久久成人综合 | 欧美一级全黄 | 亚洲精品三级 | 少妇网址 | 国产激情视频 | 欧美一区二区在线视频 | 日本天堂在线 | 玖草在线 | 国产主播99 | 一二三四区在线观看 | 黄色三级在线 | 久久靖品 | 在线视频黄 | 日韩欧美在线观看视频 | 日韩欧美在线一区 | 91亚色视频 | 色婷婷视频在线观看 | 久草福利在线视频 | 狠狠干夜夜操 | 国产福利在线视频 | 国产精品国产三级国产aⅴ浪潮 | 黄色大片av| 影音先锋在线观看视频 | 理论片中文字幕 |
