查看: 4817|回復: 7
單片機+ADS8685驅動程序
ID:659046 發表于 2019-12-8 19:48 | 顯示全部樓層 |閱讀模式
ADS8685驅動,添加到工程即可使用,親測無誤!
  1. #include "ads8685.h"
  2. #include "delay.h"
  3. void Ads8685_RESET(void)
  4. {
  5.         ADS8685_RST=0;
  6.         delay_ms(30);
  7.         ADS8685_RST=1;
  8.         delay_ms(30);
  9. }
  10. void Ads8685_WriteData(u8 data)
  11. {
  12.         u8 index=0;
  13.         ADS8685_SCLK =0;
  14.         delay_us(2);
  15.         for(index=0;index<8;index++)
  16.         {
  17.                 if(data&0x80)
  18.                 {
  19.                         ADS8685_SDI=1;
  20.                 }
  21.                 else
  22.                 {
  23.                         ADS8685_SDI=0;
  24.                 }
  25.                 ADS8685_SCLK =1;
  26.                 delay_us(2);
  27.                 ADS8685_SCLK =0;
  28.                 delay_us(2);
  29.                 data=data<<1;
  30.         }
  31.         ADS8685_SCLK =0;
  32.         delay_us(2);
  33. }
  34. void Ads8685_WriteReg(u8 reg,u16 data)
  35. {
  36.         u16 retry=0;
  37.         ADS8685_CS=0;
  38.         while(ADS8685_RVS)//此引腳為低電平才可以操作ADS8685
  39.         {
  40.                 retry++;
  41.                 if(retry>=0xfffe)
  42.                 {
  43.                         break;
  44.                 }
  45.         }
  46.         Ads8685_WriteData(0xd0);//input command ,datesheet P43
  47.         Ads8685_WriteData(reg);
  48.         Ads8685_WriteData(data>>8);//寫高8位
  49.         Ads8685_WriteData((u8)(data&0xff));//寫低8位
  50.         ADS8685_CS=1;
  51. }
  52. void Ads8685_Init(void)
  53. {
  54.         GPIO_InitTypeDef  GPIO_InitStructure;
  55.
  56.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);         //使能PB,PE端口時鐘
  57.
  58.         GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);
  59.
  60.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
  61.
  62.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9;                                 //LED0-->PB.5 端口配置
  63.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                  //推挽輸出
  64.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;                 //IO口速度為50MHz
  65.         GPIO_Init(GPIOB, &GPIO_InitStructure);                                         //根據設定參數初始化GPIOB.5
  66.
  67.
  68.
  69.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5;                                 //LED0-->PB.5 端口配置
  70.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;                  //上拉輸入
  71.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  72.
  73.         ADS8685_SCLK=0;
  74.         ADS8685_RST=0;
  75.         Ads8685_RESET();
  76.         Ads8685_WriteReg(0x14,0x000b);//使用內部參考電壓源并且設置輸入電壓范圍為0~5.12V    1.5*Vref  內部參考電壓4.096V
  77. }
  78. u16 Ads8685_Readdata(void)
  79. {
  80.         u16 retry=0;
  81.         u8 index=0;
  82.         u32 read_data=0;
  83.         delay_us(10);
  84.
  85.         ADS8685_CS=1;
  86.         retry=0;
  87.         while(!ADS8685_RVS)
  88.         {
  89.                 retry++;
  90.                 if(retry>=0xfffe)
  91.                 {
  92.                         break;
  93.                 }
  94.         }
  95.
  96.         ADS8685_CS=0;
  97.         retry=0;
  98.         while(ADS8685_RVS)
  99.         {
  100.                 retry++;
  101.                 if(retry>=0xfffe)
  102.                 {
  103.                         break;
  104.                 }
  105.         }
  106.
  107.         for(index=0;index<32;index++)
  108.         {
  109.                 delay_us(2);
  110.                 ADS8685_SCLK=1;
  111.                 delay_us(2);   //時間大于15ns即可
  112.
  113.                 read_data = read_data << 1;
  114.                 if(ADS8685_SDO_0)  //串行通信  數據輸出0 讀SD0_0,如果有數據1,則加到read_data末尾
  115.                 {
  116.                         read_data=read_data+1;
  117.                 }
  118.                 ADS8685_SCLK=0;
  119.                 delay_us(1);
  120.         }
  121.         delay_us(2);
  122.         ADS8685_CS=1;
  123.
  124.         return (read_data>>16);
  125. }
ads8685驅動.zip (1.64 KB, 下載次數: 78)
ID:297557 發表于 2020-4-21 17:18 | 顯示全部樓層
非常好,謝謝分享
ID:87499 發表于 2021-7-20 13:54 | 顯示全部樓層
正在研究,希望有用
ID:955625 發表于 2021-7-25 10:38 | 顯示全部樓層
親測可用,只是模擬的spi不能完全利用芯片的采樣速率
ID:1033476 發表于 2022-8-18 15:19 | 顯示全部樓層
親測可用,好鐵
ID:1075271 發表于 2024-6-21 10:29 | 顯示全部樓層
請問有這個回讀的波形么
ID:239784 發表于 2025-5-9 19:33 | 顯示全部樓層
不錯,剛好要用這個
ID:239784 發表于 2025-5-9 19:34 | 顯示全部樓層
下載來看看如何
主站蜘蛛池模板: 成人动漫在线观看 | 九九视频在线 | 国产亚洲视频在线观看 | 欧美色综合天天久久综合精品 | 欧美性一区二区 | 中文字幕第一区综合 | 精品在线一区 | 免费av大片| 色伊伊| 一区二区视频在线 | 成人激情在线观看 | 亚洲精品第一 | 日韩二三区 | 亚洲二级片 | 欧美日韩一二三区 | 天天干天天看 | 久久狠狠干 | 久久久www成人免费精品 | 色偷偷噜噜噜亚洲男人 | 亚洲成人av在线播放 | 中文字幕麻豆 | av黄色在线观看 | 久久久久久久97 | 亚洲天堂av网 | 久久av片| 日韩二区三区 | 成人三级视频 | 亚洲在线中文字幕 | 国产精品一区二区不卡 | 亚洲精品网站在线观看 | 999久久久精品 | 黄色1级视频| 亚洲欧美日韩一区二区三区四区 | 久草资源在线 | 久久riav | 热久久免费视频 | 在线一区二区三区 | 福利小视频在线观看 | 欧美在线综合 | 日韩国产精品一区二区 | 国产肉体xxxx裸体784大胆 |
