利用STM32+DMA+TIM產生正弦信號
- #include "sign.h"
- u16 SineWave_Value[256];
- /********正弦波輸出表***********/
- //cycle :波形表的位數 (0~256) 8位
- //Um :輸出電壓的峰值(0~1.5)
- void SineWave_Data( u16 cycle ,u16 *D,float Um)
- u16 i;
- for( i=0;i<cycle;i++)
- D[i]=(u16)((Um*sin(( 1.0*i/(cycle-1))*2*PI)+Um)*4095/3.3);//+Um向上平移至0~2Um; 2^12=4096; 2^8=256; 單片機電壓3.3V
- /****************初始化引腳******************/
- //----------------PA4輸出
- void SineWave_GPIO_Config(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); //開時鐘
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; //模擬輸出模式
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //輸出速率
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 ; //選擇引腳 PA4
- GPIO_SetBits(GPIOA,GPIO_Pin_4) ; //拉高輸出
- GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化
- /******************DAC初始化ˉ*************************/
- void SineWave_DAC_Config( void)
- DAC_InitTypeDef DAC_InitStructure;
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);//開DAC時鐘
- /**************DAC結構初始化*******************/
- //使能DAC通道1和通道1的DMA
- DAC_StructInit(&DAC_InitStructure);
- DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None;//不產生波形
- DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Disable; //不使能輸出緩存
- DAC_InitStructure.DAC_Trigger = DAC_Trigger_T2_TRGO; //DAC觸發為定時器2觸發
- DAC_Init(DAC_Channel_1, &DAC_InitStructure); //初始化
- DAC_Cmd(DAC_Channel_1, ENABLE); //使能DAC的通道1
- DAC_DMACmd(DAC_Channel_1, ENABLE); //使能DAC通道1的DMA
- /*********定時器初始化************/
- //定時器2初始化
- void SineWave_TIM_Config(u32 Wave1_Fre)
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); //開TIM2時鐘
- TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
- TIM_TimeBaseStructure.TIM_Prescaler = 0x0; //不預分頻
- TIM_TimeBaseStructure.TIM_ClockDivision = 0x0; //不分頻<br>
- TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //向上計數
- TIM_TimeBaseStructure.TIM_Period = Wave1_Fre; //設置輸出頻率
- TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
- TIM_SelectOutputTrigger(TIM2, TIM_TRGOSource_Update); //設置TIME輸出觸發為更新模式
- /****************DMA配置******************/
- //DMA2配置
- void SineWave_DMA_Config(void)
- DMA_InitTypeDef DMA_InitStructure;
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA2, ENABLE); //開啟DMA2時鐘
- DMA_StructInit( &DMA_InitStructure); //DMA結構體初始化
- DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST; //從寄存器讀數據
- DMA_InitStructure.DMA_BufferSize = 256; //寄存器大小
- DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//外設地址不遞增
- DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //內存地址遞增
- DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;//寬度為半字
- DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;//寬度為半字
- DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh; //優先級非常高
- DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; //關閉內存到內存模式
- DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //循環發送模式
- DMA_InitStructure.DMA_PeripheralBaseAddr = DAC_DHR12R1; //外設地址為DAC通道1的地址
- DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)SineWave_Value; //波形數據表內存地址
- DMA_Init(DMA2_Channel3, &DMA_InitStructure); //初始化
- DMA_Cmd(DMA2_Channel3, ENABLE); //使能DMA2的通道3
- /**********正弦波初始化**********************/
- //Wave1_Fre: 頻率值(0~60 000)Hz
- //Um : 電壓峰值(0.0~1.5)V
- void SineWave_Init(u16 Wave1_Fre,float Um)
- u32 f1;
- f1=(u32)(72000000/sizeof(SineWave_Value)*2/Wave1_Fre);//計算頻率 72MHz
- SineWave_Data(256,SineWave_Value,Um); //生成輸出正弦波的波形表
- SineWave_GPIO_Config(); //初始化io
- SineWave_TIM_Config(f1); //初始化定時器
- SineWave_DAC_Config(); //配置DAC
- SineWave_DMA_Config(); //配置DMA
- TIM_Cmd(TIM2, ENABLE); //開啟定時器
利用DMA產生正弦信號.7z
(185.76 KB, 下載次數: 35)
2019-12-11 15:08 上傳
點擊文件名下載附件
