查看: 2273|回復: 0
單片機萬年歷設計簡單1602顯示ds1302采集系統 Proteus仿真程序
ID:508977 發表于 2019-12-18 16:49 | 顯示全部樓層 |閱讀模式
根據電路圖,編寫程序使得LCD1602顯示器顯示DS1302時鐘芯片當前年、月、日、十、分和秒信息。
附件包含對應仿真和C程序
  1. #include <reg52.h>
  2. #include <intrins.h>
  3. #include <string.h>
  4. #define uint unsigned int
  5. #define uchar unsigned char
  6. sbit IO=P1^1;
  7. sbit SCLK=P1^0;
  8. sbit RST=P1^2;
  9. sbit RS=P2^0;
  10. sbit RW=P2^1;
  11. sbit EN=P2^2;
  12. uchar *WEEK[]=
  13. {
  14.         "SUN","***","MON","TUS","WEN","THU","FRI","SAT"
  15. };
  16. uchar LCD_DSY_BUFFER1[]={"DATE 00-00-00   "};
  17. uchar LCD_DSY_BUFFER2[]={"TIME 00:00:00   "};
  18. uchar DateTime[7];
  19. void DelayMS(uint ms)
  20. {
  21.   uchar i;
  22.   while(ms--)
  23.      { for(i=0;i<120;i++); }
  24. }
  25. void Write_A_Byte_TO_DS1302(uchar x)
  26. {
  27.   uchar i;
  28.   for(i=0;i<8;i++)
  29.     { IO=x&0x01;SCLK=1;SCLK=0;x>>=1; }
  30. }
  31. uchar Get_A_Byte_FROM_DS1302()
  32. {
  33.    uchar i,b=0x00;
  34.    for(i=0;i<8;i++)
  35.    {
  36.          b |= _crol_((uchar)IO,i);
  37.          SCLK=1;SCLK=0;
  38.    }
  39.    return b/16*10+b%16;
  40. }
  41. uchar Read_Data(uchar addr)
  42. {
  43.   uchar dat;
  44.   RST=0;SCLK=0;RST=1;
  45.   Write_A_Byte_TO_DS1302(addr);
  46.   dat=Get_A_Byte_FROM_DS1302();
  47.   SCLK=1;RST=0;
  48.   return dat;
  49. }
  50. void GetTime()
  51. {
  52.    uchar i,addr=0x81;
  53.    for(i=0;i<7;i++)
  54.    { DateTime[i]=Read_Data(addr);addr+=2; }
  55. }
  56. uchar read_lcd_state()
  57. {
  58.   uchar state;
  59.   RS=0;RW=1;EN=1;DelayMS(1);
  60.   state=P0;
  61.   EN=0;DelayMS(1);
  62.   return state;
  63. }
  64. void lcd_busy_wait()
  65. {
  66.   while((read_lcd_state()&0x80)==0x80);
  67.   DelayMS(5);
  68. }
  69. void write_lcd_data(uchar dat)
  70. {
  71.          lcd_busy_wait();
  72.          RS=1;RW=0;EN=0;P0=dat;EN=1;DelayMS(1);
  73.          EN=0;
  74. }
  75. void write_lcd_command(uchar dat)
  76. {
  77.          lcd_busy_wait();
  78.          RS=0;RW=0;EN=0;P0=dat;EN=1;DelayMS(1);
  79.          EN=0;
  80. }
  81. void init_lcd()
  82. {
  83.          write_lcd_command(0x38);
  84.          DelayMS(1);
  85.          write_lcd_command(0x01);
  86.          DelayMS(1);
  87.          write_lcd_command(0x06);
  88.          DelayMS(1);
  89.          write_lcd_command(0x0c);
  90.          DelayMS(1);
  91. }
  92. void set_lcd_pos(uchar p)
  93. {
  94.         write_lcd_command(p|0x80);
  95. }
  96. void Display_LCD_String(uchar p,uchar *s)
  97. {
  98.         uchar i;
  99.         set_lcd_pos(p);
  100.         for(i=0;i<16;i++)
  101.         {
  102.           write_lcd_data(s[i]);
  103.           DelayMS(1);
  104.         }
  105. }
  106. void Format_DateTime(uchar d,uchar *a)
  107. {
  108.    a[0]=d/10+'0';
  109.    a[1]=d%10+'0';
  110. }
  111. void main()
  112. {
  113.   init_lcd();
  114.   while(1)
  115.   {
  116.         GetTime();
  117.         Format_DateTime(DateTime[6],LCD_DSY_BUFFER1+5);
  118.           Format_DateTime(DateTime[4],LCD_DSY_BUFFER1+8);
  119.         Format_DateTime(DateTime[3],LCD_DSY_BUFFER1+11);
  120.         strcpy(LCD_DSY_BUFFER1+13,WEEK[DateTime[5]]);
  121.         Format_DateTime(DateTime[2],LCD_DSY_BUFFER2+5);
  122.         Format_DateTime(DateTime[1],LCD_DSY_BUFFER2+8);
  123.         Format_DateTime(DateTime[0],LCD_DSY_BUFFER2+11);
  124.         Display_LCD_String(0x00,LCD_DSY_BUFFER1);
  125.         Display_LCD_String(0x40,LCD_DSY_BUFFER2);
  126.   }
  127. }
萬年歷設計.zip (150.13 KB, 下載次數: 25)
主站蜘蛛池模板: 二区在线观看 | 国产伦精品一区二区三区在线 | 欧美一区二区三区在线视频 | 黄网站免费看 | 自拍偷拍亚洲 | 国精产品一区二区 | 国产精品久久久一区二区三区 | 五月天.com| 午夜免费av| 亚洲免费黄色 | 人人看人人草 | 毛片av在线 | 日韩精品一区二区视频 | 日韩三级久久 | 在线免费国产 | 一本到av | 国产精品一区在线播放 | 国产免费一区二区 | 欧美综合一区二区 | 91成人亚洲| 九九精品在线观看 | 日本高清www| 亚洲精品中文字幕乱码三区91 | 欧美激情一二三区 | 韩国三级av | www.亚洲天堂| 日日干日日射 | 国产精品视频免费看 | av在线免费播放 | 亚洲天堂免费视频 | 免费在线观看黄 | 青青草免费在线观看视频 | 精品一区二区三区三区 | 免费一级黄色录像 | 福利视频1000 | av黄色网址 | 婷婷色综合 | 亚洲精品网站在线观看 | 欧美日韩一区二区三区视频 | 婷婷激情综合网 | 日韩免费一区二区 |
