感覺寫的很好,有參考價值,畢竟寫主發(fā)從列程很多。從發(fā)主列程是真的少
- /************* 用戶系統(tǒng)配置 **************/
- #define MAIN_Fosc 12000000L //定義主時鐘, 模擬串口和紅外接收會自動適應(yīng)。5~36MHZ
- #define D_TIMER0 125 //選擇定時器時間, us, 紅外接收要求在60us~250us之間
- #define User_code 0xFD02 //定義紅外接收用戶碼
- #define DECVICE_ADD 0x55<<1
- /************* 以下宏定義用戶請勿修改 **************/
- #include "reg51.H"
- #include "string.H"
- #define uchar unsigned char
- #define uint unsigned int
- //#define freq_base (MAIN_Fosc / 1200)
- //#define Timer0_Reload (65536 - (D_TIMER0 * freq_base / 10000))
- /************* 本地常量聲明 **************/
- /************* 本地變量聲明 **************/
- sbit SDA = P3^0; //SDA
- sbit SCL = P3^1; //SCL
- bit PreState;
- bit NowState;
- bit START_flag;
- bit STOP_flag;
- //uchar IR_SampleCnt; //采樣計數(shù)
- uchar NN;
- uchar DEVICE_ADR; //器件地址
- uchar WORD_ADR; //內(nèi)存地址
- uchar REC_DATA; //接收到的內(nèi)容
- unsigned int *send_ptr;//
- code unsigned AA0[9] = {0x70,0x2c,0x6e,0x2a,0x00,0x00,0x00,0xc0}; //
- code unsigned AA8[2] = {0xff,0x2c}; //
- //code unsigned AA0[9] = {0x70,0x2c,0x6e,0x2a,0x00,0x00,0x00,0xc0}; //
- code unsigned A00[33] = {0xed,0xcf,0x48,0xe6,0x89,0xe8,0x0c,0xe8,
- 0x97,0xaf,0xd2,0x40,0x6d,0xc2,0xc4,0x04,
- 0xca,0xd5,0xea,0xa7,0xae,0x43,0x37,0xe2,
- 0x12,0x05,0x3b,0x59,0xb7,0xfb,0x3d,0xa5
- code unsigned A20[33] = {0xCB,0x85,0x8b,0x54,0x6d,0x97,0x3c,0x05,
- 0x46,0x0f,0x45,0xb4,0xd1,0x0a,0xb8,0x9b,
- 0xdf,0xa2,0x43,0x8d,0xe6,0x7a,0x6f,0xf8,
- 0x7f,0xaa,0x52,0x37,0xa6,0x8f,0xdc,0x71
- code unsigned A40[33] = {
- 0x15,0x67,0xc5,0x82,0xfe,0x01,0x87,0x44,
- 0x10,0xcd,0xf8,0xe2,0xd7,0xb1,0x7d,0xb6,
- 0x53,0xc0,0x43,0x39,0x3a,0xb3,0x32,0xba,
- 0x5d,0x84,0xf1,0x03,0x13,0xcd,0x74,0x28
- code unsigned A60[33] = {
- 0x34,0x39,0xab,0x32,0x3b,0x32,0x76,0x4b,
- 0xff,0x6f,0x2d,0xd6,0x20,0xab,0x8c,0x73,
- 0x6b,0xd0,0xad,0xa6,0x83,0xdf,0x60,0xe0,
- 0x63,0x51,0xe4,0x76,0x1e,0x58,0x9f,0x52
- uchar temp;
- /************* 外部函數(shù)和變量聲明 *****************/
- void init(void);//初如化函數(shù)
- void delay_24C02(void); // 延時 5us
- void ACK(void);//應(yīng)答
- void WaitACK(void);//等待主機回復(fù)
- /********************* 主函數(shù) *************************/
- void main(void)
- uchar gg,MM,i,count;
- init();//初如化
- while(1)
- NN=50;
- PreState = SDA;
- while(SCL && NN--)
- NowState = SDA;
- if(PreState && !NowState) //啟動
- START_flag = 1;
- //_DINT();
- if(!PreState && NowState) //結(jié)束
- STOP_flag = 1;
- //_EINT();
- PreState = NowState;
- if(START_flag) //如果是啟動的話
- START_flag=0;
- while(SCL); //START時的SCL高電平狀態(tài)就等待
- for(gg=8;gg>0;gg--) //接收器件地址
- while(!SCL); //SCL低電平狀態(tài)就等待
- DEVICE_ADR<<=1;
- if(SDA) //數(shù)據(jù)的第一個CLK高電平來臨
- DEVICE_ADR |= 0x01;
- while(SCL); //SCL高電平狀態(tài)就等待
- ACK(); //對設(shè)備地址ACK應(yīng)答信
- //-----------以上收到了設(shè)備地址,并知曉主機要對從機進(jìn)行讀還是寫操作---
- for(gg=8;gg>0;gg--) //接收內(nèi)存單元地址
- while(!SCL);
- WORD_ADR<<=1;
- if(SDA)
- WORD_ADR |= 0x01;
- while(SCL);
- //-----------以上就已經(jīng)接收到內(nèi)存單元地址------------
- ACK(); //對內(nèi)存單元ACK應(yīng)答信號
- //--------------------- 以上就已經(jīng)接收到內(nèi)存單元地址 -------------------------
- delay_24C02();//5us
- delay_24C02();
- delay_24C02();
- MM=50;
- PreState = SDA;
- while(SCL && MM--)
- NowState = SDA;
- if(PreState && !NowState) // 如果 SDA 下降沿且 SCL 為高 , 則示開始信號
- START_flag = 1;
- //--------------------START_Flag=1: 表示隨即讀數(shù)據(jù) -------------------------
- if(START_flag==1)
- //--------------------------- 讀取器件地址 ---------------------------------
- //while(!SCL);
- START_flag=0; // 清除標(biāo)志位
- while(SCL); //START 時的 SCL 高電平狀態(tài)就等待
- for(gg=8;gg>0;gg--) // 接收器件地址
- while(!SCL); //SCL 低電平狀態(tài)就等待
- DEVICE_ADR<<=1; // 高位在前
- if(SDA) // 數(shù)據(jù)的第一個 CLK 高電平來臨
- DEVICE_ADR |= 0x01; // 上升沿讀取數(shù)據(jù)位
- while(SCL); //SCL 高電平狀態(tài)就等待
- ACK(); // 對設(shè)備地址 ACK 應(yīng)答信
- //------------------ 判斷地址是否為 0xa1 ,表示讀數(shù)據(jù)指令 -------------------
- if(DEVICE_ADR == 0xab) //( DECVICE_ADD+1)
- switch(WORD_ADR)
- case 0xa0: count=8; send_ptr =AA0; // memcpy(temp,AA0,count);
- break;
- case 0xa8: count=1; send_ptr =AA8; // memcpy(temp,AA8,count);
- break;
- case 0x00: count=32; send_ptr =A00; // memcpy(temp,A00,count);
- break;
- case 0x20: count=32; send_ptr =A20;// memcpy(temp,A20,count);
- break;
- case 0x40: count=32; send_ptr =A40; // memcpy(temp,A40,count);
- break;
- case 0x60: count=32; send_ptr =A60;// / memcpy(temp,A60,count);
- break;
- for(i=0;i<count;i++) // 要 讀 多 少 字 節(jié) , 由
- //*send_ptr =WORD_ADR;
- temp = send_ptr[i];
- for(gg=8;gg>0;gg--) // 輸出數(shù)據(jù)給主機
- while(SCL);//如果為高,保持
- if( temp & 0x80)
- SDA=1; // 輸出 1
- else
- SDA=0; // 輸出 0
- while(!SCL);
- //while(SCL); //SCL 為 1 ,就保持 SDA 輸出不變
- // SDA=1;
- //*send_ptr <<=1;
- temp <<=1;
- WaitACK();//主機回復(fù)ACK
- //send_ptr++;
- }//if(DEVICE_ADR==0xa1)
- else //如果不是,退出
- }//if(START_flag==1)
- else // 如果 START_flag!=1 則表示主機對從機進(jìn)行寫操作
- if(WORD_ADR == 0xa9)
- for(i=0;i<8;i++)
- for(gg=8;gg>0;gg--) // 讀取主機發(fā)來的數(shù)據(jù)
- // while(!SCL);
- // //READ_BUF[i] <<=1;
- // //SDA=0;
- // if(SDA)
- // //READ_BUF[i] |= 0x01;
- // //SDA=0;
- // while(SCL);
- while(!SCL);
- while(SCL);
- }// if(START_flag)
- }//end while(SCL && NN--)
- }//end while(1)
- 函數(shù)功能:初始化函數(shù)
- 入口參數(shù):無
- 返 回:無。
- 備 注:無。
- void init(void)
- SDA=1; // 初始數(shù)據(jù)引腳
- SCL=1; // 初始時鐘引腳
- // EA=1; // 開總中斷
- // IP=0x90; // 中斷優(yōu)先級設(shè)定,設(shè)為串口 >INTO>T0>INT1>T1
- // EX0=1; // 開外部中斷 0
- 函數(shù)功能:從機應(yīng)答函數(shù)
- 入口參數(shù):無
- 返 回:無。
- 備 注:應(yīng)答函數(shù),保證在兩個時鐘跳變沿 SDA 為低,則主機認(rèn)為是從機應(yīng)答
- void ACK(void)
- // while(!SCL);
- // SDA=0; // 第 9 個 CLK 變高的情況下, SDA 輸出 0
- // while(SCL);
- // SDA=1; // 第 9 個 CLK 變低的情況下, SDA 輸出 1
- while(SCL); //低就阻塞
- delay_24C02();
- SDA=0; // 第 9 個 CLK 變高的情況下, SDA 輸出 0
- while(!SCL); //低就阻塞
- while(SCL); //高就阻塞
- delay_24C02();
- SDA=1; // 第 9 個 CLK 變低的情況下, SDA 輸出 1
- 函數(shù)功能:主機應(yīng)答函數(shù)
- 入口參數(shù):無
- 返 回:無。
- // while(!SCL);
- // while(SCL);
- delay_24C02();
- SDA=1; // 第 9 個 CLK 變高的情況下, SDA 輸出 0
- delay_24C02();
- //SDA=1; // 第 9 個 CLK 變低的情況下, SDA 輸出 1
- 函數(shù)功能:延時 us
- 入口參數(shù):無
- 返 回:無。
- 備 注:函數(shù)是用來實現(xiàn)短暫延時,用于對接上主機時鐘
- void delay_24C02(void) // 延時 5us
- uchar i;
- i=3;
- while(i--);
IICSTC2.rar
(40.35 KB, 下載次數(shù): 178)
2019-12-23 11:41 上傳
點擊文件名下載附件
