查看: 7296|回復: 1
[求助]按矩陣鍵盤顯示1-16的平方,無顯示是哪里錯了
ID:13193 發(fā)表于 2009-5-21 07:00 | 顯示全部樓層 |閱讀模式
以下為本人寫的代碼  是矩陣鍵盤的
要求按下16個矩陣鍵盤依次在數(shù)碼管上顯示1-16的平方。如按下第一個顯示1,第二個顯示4...
請高手指教哪里錯了  為什么按下鍵盤后沒有反應
#include<reg52.h>
#define uint unsigned int
#define uchar unsigned char
sbit dula=P2^6;
sbit wela=P2^7;
uchar code table[]={0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
char temp,bai,shi,ge,key;
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void display(uchar bai,uchar shi,uchar ge)
        dula=1;
        P0=table[bai];
        dula=0;
        P0=0xff;
        wela=1;
        P0=0xfe;
        wela=0;
        delay(5);
        dula=1;
        P0=table[shi];
        dula=0;
        P0=0xff;
        wela=1;
        P0=0xfd;
        wela=0;
        delay(5);
        dula=1;
        P0=table[ge];
        dula=0;
        P0=0xff;
        wela=1;
        P0=0xfb;
        wela=0;
        delay(5);
void keyscan()
        P3=0xfe;
        temp=P3;
        temp=P3&0xf0;
        if(temp!=0xf0)
                delay(5);
                temp=P3;
                temp=P3&0xf0;
                if(temp!=0xf0)
                        temp=P3;
                        switch(temp)
                                case 0xee: key=1;
                                        break;
                                case 0xde: key=2;
                                        break;
                                case 0xbe: key=3;
                                        break;
                                case 0x7e: key=4;
                                        break;
                        while(temp!=0xf0)
                                temp=P3;
                                temp=temp&0xf0;
                        temp=key*key;
                        bai=temp/100;
                        shi=temp%100/10;
                        ge=temp%10;
                        display(bai,shi,ge);
        P3=0xfd;
        temp=P3;
        temp=P3&0xf0;
        if(temp!=0xf0)
                delay(5);
                temp=P3;
                temp=P3&0xf0;
                if(temp!=0xf0)
                        temp=P3;
                        switch(temp)
                                case 0xed: key=5;
                                        break;
                                case 0xdd: key=6;
                                        break;
                                case 0xbd: key=7;
                                        break;
                                case 0x7d: key=8;
                                        break;
                        while(temp!=0xf0)
                                temp=P3;
                                temp=temp&0xf0;
                        temp=key*key;
                        bai=temp/100;
                        shi=temp%100/10;
                        ge=temp%10;
        P3=0xfb;
        temp=P3;
        temp=P3&0xf0;
        if(temp!=0xf0)
                delay(5);
                temp=P3;
                temp=P3&0xf0;
                if(temp!=0xf0)
                        temp=P3;
                        switch(temp)
                                case 0xeb: key=9;
                                        break;
                                case 0xdb: key=10;
                                        break;
                                case 0xbb: key=11;
                                        break;
                                case 0x7b: key=12;
                                        break;
                        while(temp!=0xf0)
                                temp=P3;
                                temp=temp&0xf0;
                        temp=key*key;
                        bai=temp/100;
                        shi=temp%100/10;
                        ge=temp%10;
        P3=0xf7;
        temp=P3;
        temp=P3&0xf0;
        if(temp!=0xf0)
                delay(5);
                temp=P3;
                temp=P3&0xf0;
                if(temp!=0xf0)
                        temp=P3;
                        switch(temp)
                                case 0xe7: key=13;
                                        break;
                                case 0xd7: key=14;
                                        break;
                                case 0xb7: key=15;
                                        break;
                                case 0x77: key=16;
                                        break;
                        while(temp!=0xf0)
                                temp=P3;
                                temp=temp&0xf0;
                        temp=key*key;
                        bai=temp/100;
                        shi=temp%100/10;
                        ge=temp%10;
                keyscan();
ID:7193 發(fā)表于 2009-5-22 23:29 | 顯示全部樓層
程序太長看得眼花,雖然沒能幫你找出錯誤,但是我在論壇找到一個和你實現(xiàn)一模一樣功能的程序,我看了基本差不多,而且在我的板子上已經(jīng)測試成功了 你自己對比一下應該能找到錯誤所在 希望能幫到你.
下載地址:http://m.zg4o1577.cn/ziliao/51hei-5/矩陣鍵盤_c_按鍵顯示1-16平方.rar
主站蜘蛛池模板: 又色又爽又黄gif动态图 | 精品理论片 | av观看网站 | av少妇| 97精品国产97久久久久久免费 | 久久都是精品 | 日韩av免费在线播放 | 国产高清一区 | 亚洲国产精品一区二区三区 | 蜜臀久久99精品久久久久宅男 | 蜜臀99久久精品久久久久小说 | 中文字幕免费在线看线人动作大片 | 国产福利91精品一区二区三区 | 毛片毛片毛片 | 日本一区二区三区四区五区 | 丁香婷婷网 | 国产成人av一区二区三区在线观看 | 欧美日韩成人在线观看 | 亚洲黄视频| 欧美一区二区三区四区五区 | 91超碰在线观看 | 中文字幕丰满人伦在线 | 欧美在线观看一区 | 欧美成年人视频 | 国产精品视频一区二区三区 | av黄| 欧美亚洲国产日韩 | 婷婷天堂 | 超碰在线免费播放 | 国产在线一 | 黄色片在线 | 长河落日连续剧48集免费观看 | 国产小视频在线观看 | 欧美国产精品 | 欧美激情综合 | 在线免费观看日韩av | 青青草视频免费在线观看 | 黄色激情视频网站 | 夜夜欢视频 | 亚洲午夜av | 成年人免费看视频 |
