查看: 4543|回復: 2
[求助] 用串口控制繼電器工作狀態
ID:44179 發表于 2013-1-23 18:48 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
如下程序我想實現串口發不同的字符后,單片機P0口高電平驅動三極管工作。但是發現沒有辦法動作!求助!!!
#include <reg51.h>
#include <string.h>
#define INBUF_LEN 4 //數據長度
unsigned char inbuf1[INBUF_LEN];
unsigned char checksum,count3;
bit read_flag= 0;
sbit keypad1=P0^0;
sbit keypad2=P0^1;
sbit keypad3=P0^2;
sbit keypad4=P0^3;
sbit keypad5=P0^4;
sbit keypad6=P0^5;
void delay_ms(unsigned int ms)
unsigned int i;
unsigned char j;
    for(i=0;i<ms;i++)
        for(j=0;j<200;j++);
        for(j=0;j<102;j++);
void init_serialcomm( void )
 SCON = 0x50 ; //SCON: serail mode 1, 8-bit UART, enable ucvr
 TMOD |= 0x20 ; //TMOD: timer 1, mode 2, 8-bit reload
 PCON |= 0x80 ; //SMOD=1;
 TH1 = 0xF4 ; //Baud:4800 fosc=11.0592MHz
 IE |= 0x90 ; //Enable Serial Interrupt
 TR1 = 1 ; // timer 1 run
 //TI=1;
//向串口發送一個字符
void send_char_com(unsigned char ch)
 SBUF=ch;
 while (TI== 0 );
 TI= 0 ;
//向串口發送一個字符串,strlen為該字符串長度
void send_string_com( unsigned char *str, unsigned int strlen)
 unsigned int k= 0 ;
 do
  send_char_com(*(str + k));
  k++;
 while (k < strlen);
//串口接收中斷函數
void serial () interrupt 4 using 3
 if (RI)
  unsigned char ch;
  RI = 0 ;
  ch=SBUF;
  if (ch> 127 )
   count3= 0 ;
   inbuf1[count3]=ch;
   checksum= ch- 128 ;
   count3++;
   inbuf1[count3]=ch;
   checksum ^= ch;
   if ( (count3==(INBUF_LEN- 1 )) && (!checksum) )
    read_flag= 1 ; //如果串口接收的數據達到INBUF_LEN個,且校驗沒錯,就置位取數標志
void main(void)
    unsigned char relay;
 relay='A';
 P0=0x00;
 init_serialcomm(); //初始化串口
 while ( 1 )
  if (read_flag) //如果取數標志已置位,就將讀到的數從串口發出
      read_flag= 0 ; //取數標志清0
            //send_string_com(inbuf1,INBUF_LEN);
         send_char_com(relay);
   switch(relay)
       case 'B':
    delay_ms(500);
          keypad1=1;//氣缸1 Close
          delay_ms(2500);
             keypad2=1;//氣缸2 Close
    break;
    case 'C':
    delay_ms(500);
    keypad3=1;//氣缸3 Close
    delay_ms(1000);
    keypad3=0;//氣缸3 Open
    break;
    case 'D':
    delay_ms(500);
          keypad1=0;//氣缸1 Open
             keypad2=0;//氣缸1 Open
    break;
    case 'E':
             delay_ms(500);
          keypad4=1;//氣缸4 Close
          delay_ms(2500);
             keypad5=1;//氣缸5 Close
    break;
    case 'F':
               delay_ms(500);
     keypad6=1;//氣缸6 Close
    delay_ms(1000);
    keypad6=0;//氣缸6 Open
    break;
       case 'G':
                delay_ms(500);
             keypad4=0;//氣缸4 Open
             keypad5=0;//氣缸5 Open
    break;
    default:
    P0=0x00;
    break;
ID:7485 發表于 2013-1-24 19:21 | 只看該作者
p0口高電平驅動繼電器?你用的是什么型號的單片機?
普通的P0口需要加上拉電阻才有可能輸出高電平。
ID:44179 發表于 2013-1-29 10:39 | 只看該作者
P0 口是高電平驅動繼電器,用的是AT89S51單片機!驅動是沒有問題!
問題是串口控制的部分,無法實現!
主站蜘蛛池模板: 麻豆av在线免费观看 | 日韩高清一区 | 精品国产区一区二 | 亚洲精品1 | 欧美在线播放视频 | 亚洲第一视频网站 | 一区二区免费 | 男男成人高潮片免费网站 | av影片在线观看 | 久久只有精品 | 免费毛片在线播放免费 | 日日夜夜精品免费 | 国产aaaaaa| 国产超级av| 国产这里只有精品 | 男女啪啪免费 | 国产欧美视频在线观看 | 第一福利视频 | 久久精品视 | 欧美综合在线视频 | 国产美女自拍视频 | 一区二区三区在线免费 | 色八区 | 在线精品一区 | 久久久免费看 | 日韩中文字幕一区 | 在线一级片| 日韩中文字幕第一页 | 欧美日韩国产在线 | 91av免费在线观看 | 青青草免费观看 | 日本青青草 | 国产黄色av网站 | www.狠狠操 | 国产在线小视频 | 黄色一级毛片 | 玖玖伊人| 91精品国产综合久久久蜜臀九色 | 午夜88| 色黄大色黄女片免费中国 | 亚洲一级二级三级 |
