查看: 7335|回復(fù): 6
單片機(jī)8鍵電子琴源程序+PCB工程+Proteus仿真
ID:675778 發(fā)表于 2019-12-27 23:01 | 顯示全部樓層 |閱讀模式
制作出來的實(shí)物圖如下:
單片機(jī)電子琴仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
單片機(jī)源程序如下:
  1. #include <reg52.H>
  2. unsigned char temp;
  3. unsigned char key;
  4. unsigned char i,j;
  5. unsigned char STH0;
  6. unsigned char STL0;
  7. unsigned int code tab[]=  {64820,64898,64968,65030,65058,65110,65157,65178};  //音符表 do re mi fa sol la xi duo
  8. sbit K1=P1^0;  //音符按鍵
  9. sbit K2=P1^1;
  10. sbit K3=P1^2;
  11. sbit K4=P1^3;
  12. sbit K5=P1^4;
  13. sbit K6=P1^5;
  14. sbit K7=P1^6;
  15. sbit K8=P1^7;
  16. sbit Speak=P2^0; //喇叭
  17. /***********************1ms*****************************/
  18. void delay_1ms(unsigned int q)
  19. {
  20.         unsigned int i,j;
  21.         for(i=0;i<q;i++)
  22.                 for(j=0;j<120;j++);
  23. }
  24. void main(void)   //主程序
  25. {
  26.   TMOD=0x01;
  27.         ET0=1;
  28.         EA=1;
  29.         while(1)
  30.                 {
  31.
  32.       if(!K1)
  33.                     {
  34.                            delay_1ms(20);//延時(shí)去抖
  35.                                   if(!K1)
  36.                                   {
  37.            key=0;//將音樂的值賦值給定時(shí)器以便發(fā)出對(duì)應(yīng)的聲音
  38.                                          P0=0xC0;//顯示0
  39.            STH0=tab[key]/256;        //計(jì)算音符對(duì)應(yīng)的定時(shí)器計(jì)數(shù)值
  40.                                    STL0=tab[key]%256;
  41.                                    TR0=1;
  42.                                    while(!K1)
  43.                                    ;
  44.           }
  45.         }
  46.
  47.                          if(!K2)
  48.                     {
  49.                            delay_1ms(20);//延時(shí)去抖
  50.                                   if(!K2)
  51.                                   {
  52.            key=1;
  53.                                          P0=0xF9;//顯示1
  54.            STH0=tab[key]/256;        //計(jì)算音符對(duì)應(yīng)的定時(shí)器計(jì)數(shù)值
  55.                                    STL0=tab[key]%256;
  56.                                    TR0=1;
  57.                                    while(!K2)
  58.                                    ;
  59.           }
  60.         }
  61.
  62.                         if(!K3)
  63.                     {
  64.                            delay_1ms(20);//延時(shí)去抖
  65.                                   if(!K3)
  66.                                   {
  67.            key=2;
  68.                                          P0=0xA4;//顯示2
  69.            STH0=tab[key]/256;        //計(jì)算音符對(duì)應(yīng)的定時(shí)器計(jì)數(shù)值
  70.                                    STL0=tab[key]%256;
  71.                                    TR0=1;
  72.                                    while(!K3)
  73.                                    ;
  74.           }
  75.         }
  76.
  77.                         if(!K4)
  78.                     {
  79.                            delay_1ms(20);//延時(shí)去抖
  80.                                   if(!K4)
  81.                                   {
  82.            key=3;
  83.                                          P0=0xB0;//顯示3
  84.            STH0=tab[key]/256;        //計(jì)算音符對(duì)應(yīng)的定時(shí)器計(jì)數(shù)值
  85.                                    STL0=tab[key]%256;
  86.                                    TR0=1;
  87.                                    while(!K4)
  88.                                    ;
  89.           }
  90.         }
  91.
  92.                         if(!K5)
  93.                     {
  94.                            delay_1ms(20);//延時(shí)去抖
  95.                                   if(!K5)
  96.                                   {
  97.            key=4;
  98.                                          P0=0x99;//顯示4
  99.            STH0=tab[key]/256;        //計(jì)算音符對(duì)應(yīng)的定時(shí)器計(jì)數(shù)值
  100.                                    STL0=tab[key]%256;
  101.                                    TR0=1;
  102.                                    while(!K5)
  103.                                    ;
  104.           }
  105.         }
  106.
  107.                         if(!K6)
  108.                     {
  109.                            delay_1ms(20);//延時(shí)去抖
  110.                                   if(!K6)
  111.                                   {
  112.            key=5;
  113.                                          P0=0x92;//顯示5
  114.            STH0=tab[key]/256;        //計(jì)算音符對(duì)應(yīng)的定時(shí)器計(jì)數(shù)值
  115.                                    STL0=tab[key]%256;
  116.                                    TR0=1;
  117.                                    while(!K6)
  118.                                    ;
  119.           }
  120.         }
  121.
  122.                         if(!K7)
  123.                     {
  124.                            delay_1ms(20);//延時(shí)去抖
  125.                                   if(!K7)
  126.                                   {
  127.            key=6;
  128.                                          P0=0x82;//顯示6
  129.            STH0=tab[key]/256;        //計(jì)算音符對(duì)應(yīng)的定時(shí)器計(jì)數(shù)值
  130.                                    STL0=tab[key]%256;
  131.                                    TR0=1;
  132.                                    while(!K7)
  133.                                    ;
  134.           }
  135.         }
  136.
  137.                 if(!K8)
  138.                     {
  139.                            delay_1ms(20);//延時(shí)去抖
  140.                                   if(!K8)
  141.                                   {
  142.            key=7;
  143.                                          P0=0xF8;//顯示7
  144.            STH0=tab[key]/256;        //計(jì)算音符對(duì)應(yīng)的定時(shí)器計(jì)數(shù)值
  145.                                    STL0=tab[key]%256;
  146.                                    TR0=1;
  147.                                    while(!K8)
  148.                                    ;
  149.           }
  150.         }
  151.
  152.
  153.                           delay_1ms(20);
  154.                                 TR0=0;
  155.                           Speak=1;//當(dāng)按鍵彈起的時(shí)候,蜂鳴器停止發(fā)音
  156.
  157. }
  158. }
  159. void t0(void) interrupt 1 using 0 {     //定時(shí)器T0中斷服務(wù)函數(shù)
  160.         TH0=STH0;
  161.         TL0=STL0;
  162.         Speak=~Speak;                                  //產(chǎn)生方波
  163. }
電子琴(8鍵).7z (414.72 KB, 下載次數(shù): 259)
評(píng)分
參與人數(shù) 2黑幣 +62 收起 理由
3333大賽的 + 12 贊一個(gè)!
查看全部評(píng)分
ID:732282 發(fā)表于 2020-4-19 15:20 | 顯示全部樓層
真的能夠發(fā)聲?
ID:599032 發(fā)表于 2020-5-20 08:33 | 顯示全部樓層
樓主借下您的貼我做個(gè)eagle軟件的使用教學(xué)
ID:775452 發(fā)表于 2020-6-10 20:48 | 顯示全部樓層
請(qǐng)問樓主實(shí)物是自己焊接的嗎????有沒有什么地方可以焊接???
ID:790142 發(fā)表于 2020-6-29 19:39 | 顯示全部樓層
能解釋一下 原理圖 那個(gè)電源部分是什么嗎
ID:793527 發(fā)表于 2020-6-30 10:03 | 顯示全部樓層
這個(gè)電子琴的21種音調(diào)嘛?
ID:1039225 發(fā)表于 2022-7-12 10:13 | 顯示全部樓層
我需要這個(gè)文檔,有沒有性價(jià)比更高的?》
主站蜘蛛池模板: 午夜av免费 | 波多野结衣一区二区三区在线观看 | 亚洲男人的天堂在线观看 | 黄色片播放 | 亚洲欧洲视频 | 久久精品日韩 | 午夜精品久久久久久久 | www.午夜 | 亚洲欧美精品一区二区 | 在线亚洲一区 | 国产综合一区二区 | 欧美 日韩 国产 成人 在线 | 特黄aaaaaaaaa真人毛片 | 亚洲一区成人 | 天天看天天操 | 一区二区视频在线 | 视频爱爱免费视频爱爱太爽 | 日韩福利视频 | 黄色av观看 | 久久av免费观看 | 欧美视频在线观看 | 四虎在线观看视频 | 五月婷婷丁香综合 | 欧美日韩大片 | 五月婷婷激情综合 | 亚洲黄色成人 | 51成人网| 18成人免费观看网站 | 操久 | 久久免费精品 | 日韩少妇视频 | 五月天综合网 | 青青草国产成人av片免费 | 亚洲精品字幕在线观看 | 国语对白做受欧美 | 黄色大片网站 | 亚洲欧洲在线观看 | 欧美激情成人 | 国产成人在线视频 | 手机看片欧美 | 免费国产视频 |
