查看: 3409|回復(fù): 0
HT1621燃?xì)獬沓绦?/span>
ID:399111 發(fā)表于 2020-1-18 22:30 | 顯示全部樓層 |閱讀模式
本人自寫(xiě)的燃?xì)獬幢沓绦颍玫紿T1621驅(qū)動(dòng)顯示屏,希望能幫到大家
單片機(jī)源程序如下:
  1. //ICC-AVR application builder : 2005-3-3 17:58:11
  2. // Target : M8
  3. // Crystal: 4.0000Mhz
  4. //1621引線:CS:PB4  WR:PB5  Data:PB3
  5. #include <iom8v.h>
  6. #include <macros.h>
  7. #include <eeprom.h>
  8. #define WR      0B00100000//時(shí)鐘線
  9. #define DATA    0B00001000//數(shù)據(jù)線
  10. #define CS      0b00010000//片選線
  11. #define P       0x80
  12. #define data_length 8
  13. const char   seg_tab[]={0x5f,0x06,0x6b,0x2f,0x36,0x3d,0x7d,0x07,0x7f,0x3f,
  14.                         0x77,0x7c,0x59,0x6e,0x79,0x71,0x58,0x76,0x00};
  15. unsigned char disbuff[6] ={0,0,0,0,0,0};//對(duì)應(yīng)LCD的6位
  16. unsigned char p1 =0;
  17. unsigned char p2 =0;
  18. unsigned long int time =0;//每一毫秒加1
  19. //1621的顯存是4位*32的,故用16*8位的寄存器就能滿(mǎn)足要求奇數(shù)顯存放高4位,偶數(shù)放低4位
  20. /*****************************************************************/
  21.    //1621初始化命令
  22. const char init_tab[]={
  23.                                                 0b00000001,//打開(kāi)系統(tǒng)振蕩器命令
  24.                              0b00000011,//打開(kāi)LCD偏壓發(fā)生器命令
  25.                                         0b00000101,//WDT 溢出標(biāo)志輸出失效命令
  26.                                        0b00000110,//時(shí)基輸出使能命令
  27.                                        0b00011000,//系統(tǒng)時(shí)鐘源片內(nèi)RC振蕩器命令
  28.                                        0b00101001,//LCD1/3偏壓選項(xiàng)4個(gè)公共口命令
  29.                                        //0b01000000,//聲音頻率4KHz命令
  30.                                        //0b00001001,//打開(kāi)聲音輸出命令
  31.                                        0b10100000,//時(shí)基/WDT 時(shí)鐘輸出1Hz命令
  32.                                        0b10001000 //使/IRQ 輸出有效命令
  33.                                           };
  34.
  35.
  36. void send_data(unsigned char data_bus,unsigned char loop);
  37. void delayns(void);
  38. void display(void);
  39. void display_init(void);
  40. void votlageget(void);
  41. void delay(int temp);
  42. void port_init(void)
  43. {
  44. PORTB = 0xFF;
  45. DDRB  = 0B11111000;
  46. PORTC = 0x00; //m103 output only
  47. DDRC  = 0x00;
  48. PORTD = 0xFF;
  49. DDRD  = 0XFF;
  50. }
  51. void timer1_init(void)
  52. {
  53. TCCR1B = 0x00; //stop
  54. TCNT1H = 0xFE; //setup
  55. TCNT1L = 0x0C;
  56. OCR1AH = 0x01;
  57. OCR1AL = 0xF4;
  58. OCR1BH = 0x01;
  59. OCR1BL = 0xF4;
  60. ICR1H  = 0x01;
  61. ICR1L  = 0xF4;
  62. TCCR1A = 0x00;
  63. TCCR1B = 0x02; //start Timer
  64. }
  65. #pragma interrupt_handler timer1_ovf_isr:9
  66. void timer1_ovf_isr(void)     //每毫秒中斷一次
  67. {
  68. //TIMER1 has overflowed
  69. TCNT1H = 0xFE; //reload counter high value
  70. TCNT1L = 0x0C; //reload counter low value
  71. time ++;
  72. disbuff[5] =time&0x0f;
  73. disbuff[4] =(time>>4)&0x0f;
  74. disbuff[3] =(time>>8)&0x0f;
  75. disbuff[2] =(time>>12)&0x0f;
  76. disbuff[1] =(time>>16)&0x0f;
  77. disbuff[0] =(time>>20)&0x0f;
  78. display();  //刷新1621的緩存
  79. }
  80. //***********************************************************************/
  81. void display_init(void)
  82. {
  83.   unsigned char t;
  84.   PORTB &=~CS;
  85.   send_data(0b10000000,3);//送3位命令模式代碼100
  86.   for(t=0;t<=7;t++)
  87.   {
  88.    send_data(init_tab[t],9);//送9位命令代碼
  89.   }
  90.   PORTB |=CS;
  91.   PORTB |=WR;
  92. }
  93. //***********************************************************************/
  94. void display(void)
  95. {
  96.   unsigned char t;
  97.   unsigned char seg_temp;
  98.
  99.   PORTB &=~CS;
  100.   PORTB &=~WR;
  101.   send_data(0b10100000,3);//送3位“寫(xiě) ”模式命令代碼101
  102.   send_data(0,6);//送6位首地址00h
  103.   for(t=0;t<=5;t++)
  104.   {
  105.     seg_temp =seg_tab[disbuff[t]];
  106.
  107.     send_data(seg_temp,data_length);//向顯存送數(shù)據(jù)
  108.   }
  109.   PORTB |=CS;
  110.   PORTB |=WR;
  111. }
  112. //***********************************************************************/
  113. void send_data(unsigned char data_temp,unsigned char loop)
  114. {
  115.   for(;loop!=0;loop--)
  116.   {
  117.     delayns();
  118.     PORTB &=~WR;
  119.     delayns();
  120.   if((data_temp&0b10000000)==0)
  121.   {
  122.     PORTB &=~DATA;
  123.   }
  124.   else
  125.   {
  126.     PORTB |=DATA;
  127.   }
  128.     data_temp=(data_temp<<1);
  129.     PORTB |=WR;
  130.   }
  131. }
  132. //~~~~~~~~~~~~~~~~~~~~~`
  133. void delayns(void)
  134. {
  135.   asm("nop");
  136.   asm("nop");
  137.   asm("nop");
  138.   asm("nop");
  139.   asm("nop");
  140.   asm("nop");
  141. }
  142. //call this routine to initialize all peripherals
  143. void init_devices(void)
  144. {
  145. //stop errant interrupts until set up
  146. CLI(); //disable all interrupts
  147. port_init();
  148. timer1_init();
  149. TIMSK = 0x04; //timer interrupt sources
  150. SEI(); //re-enable interrupts
  151. }
  152. void main(void)
  153. {
  154.   init_devices();  //單片機(jī)初始化
  155.   display_init();  //1621初始化
  156.   while(1)
  157.   {
  158.     ;
  159.   }
  160. }
ht1621.rar (768.63 KB, 下載次數(shù): 24)
評(píng)分
查看全部評(píng)分
主站蜘蛛池模板: 天天草天天草 | 中文字幕视频在线 | 国产一级视频在线观看 | 欧美成人精品一区二区三区在线看 | 五月婷综合 | 国产成人免费 | 久久在线免费观看 | 亚洲视频在线观看一区 | 日韩欧美视频在线 | 色综合久久88色综合天天 | 日本黄a三级三级三级 | 国产午夜精品视频 | 国产精品自拍第一页 | 在线看91| 日韩av一级 | 97视频免费观看 | www.午夜| 精品国产99久久久久久宅男i | 激情视频网 | 欧美亚洲一区二区三区 | 男人天堂av网 | 日韩不卡在线 | 国产黄色片网站 | 欧美综合一区 | 欧美a级黄色片 | 91小视频在线观看 | 夜色在线影院 | 国产又粗又猛又黄又爽无遮挡 | 日日操夜夜爽 | 五月天毛片| 激情做爰呻吟视频舌吻 | 成人国产在线观看 | 国产中文字幕在线播放 | 亚欧洲精品在线视频免费观看 | 日韩欧美视频在线 | 婷婷午夜天 | 久久香蕉国产 | 91色网站 | 97色在线| 亚洲高清视频在线观看 | 91福利网站 |
