查看: 2305|回復: 2
STM32 12864 ST7920源程序
ID:593994 發表于 2020-3-4 19:08 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
  1. #include "12864.h"
  2. GPIO_InitTypeDef GPIO_InitStructure;
  3. void Delay(__IO uint32_t nCount)
  4. {
  5.    for(; nCount != 0; nCount--);
  6. }
  7. void send_dat(unsigned char dat)
  8. {
  9.     unsigned char i;
  10.         //GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  11.     for(i=0;i<8;i++)
  12.     {
  13.                 if((dat&0x80)==0x80) SID_1;
  14.                 if((dat&0x80)==0x00) SID_0;
  15.         CLK_0;
  16.                 Delay(35);
  17.         CLK_1;
  18.                 dat<<=1;
  19.     }
  20. }
  21. unsigned char get_byte()
  22. {
  23.      unsigned char i,temp1=0,temp2=0;
  24.          //GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  25.      for(i=0;i<8;i++)
  26.      {
  27.            temp1=temp1<<1;
  28.            CLK_0;
  29.                    Delay(25);
  30.            CLK_1;
  31.                    Delay(20);
  32.            CLK_0;
  33.            if(GPIO_ReadOutputDataBit(GPIOE,GPIO_Pin_3)) temp1++;
  34.      }
  35.      for(i=0;i<8;i++)
  36.      {
  37.            temp2=temp2<<1;
  38.            CLK_0;
  39.                    Delay(25);
  40.            CLK_1;
  41.                    Delay(25);
  42.            CLK_0;
  43.            if(GPIO_ReadOutputDataBit(GPIOE,GPIO_Pin_3))  temp2++;
  44.      }
  45.          //GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  46.      return ((0xf0&temp1)+(0x0f&temp2));
  47. }
  48. void check_busy()
  49. {
  50.     do
  51.     {
  52.         send_dat(0xfc);
  53.     }
  54.     while((get_byte()&0x8000)==0x8000);
  55. }
  56. void send_cmd(unsigned char cmd)
  57. {
  58.     check_busy();
  59.     send_dat(0xf8);    //
  60.     send_dat(cmd&0xf0); //
  61.     send_dat((cmd&0x0f)<<4); //
  62. }
  63. void write_char(unsigned char dat)
  64. {
  65.     check_busy();
  66.     send_dat(0xfa);//rw=0;rs=1
  67.     send_dat(dat&0xf0);
  68.     send_dat((dat&0x0f)<<4);
  69. }
  70. void lcd_clear()        //清除顯示
  71. {
  72.     send_cmd(0x01);
  73. }
  74. void lcd_pos(unsigned char y_add , unsigned char x_add)
  75. {
  76.     switch(y_add)
  77.     {
  78.         case 1:
  79.         send_cmd(0X80|x_add);break;
  80.         case 2:
  81.         send_cmd(0X90|x_add);break;
  82.         case 3:
  83.         send_cmd(0X88|x_add);break;
  84.         case 4:
  85.         send_cmd(0X98|x_add);break;
  86.         default:break;
  87.     }
  88. }
  89. void lcd_wstr(unsigned char y_add , unsigned char x_add , unsigned char *str)    //
  90. {
  91.     unsigned char i;
  92.     lcd_pos(y_add , x_add);
  93.     for(i=0;str[i]!='\0';i++)
  94.     {
  95.         write_char(str[i]);
  96.     }
  97. }
  98. void write_figer(unsigned char y_add , unsigned char x_add , unsigned int figer)//在任何位置寫數字
  99. {
  100.     unsigned char d[5],i,j;
  101.     lcd_pos(y_add , x_add);
  102.     d[4]=figer%10;
  103.     d[3]=figer%100/10;
  104.     d[2]=figer%1000/100;
  105.     d[1]=figer%10000/1000;
  106.     d[0]=figer/10000;
  107.     for(i=0;i<5;i++)
  108.     {
  109.         if(d[i]!=0)break;
  110.     }
  111.     if(i==5)i--;
  112.     if(i==4)send_dat(0x30);//數據裝完,準備發送
  113.     for(j=i;j<5;j++)
  114.     {
  115.        send_dat(d[j]|0x30);//取得的數字加上0x30也即得到該數字的ASCII碼,再將該數字發送去顯示
  116.     }
  117. }
  118. void lcd_init()     //
  119. {
  120.     Delay(0xfff);
  121.     send_cmd(0x30);
  122.     send_cmd(0x0C);//0000,1100 整體顯示,游標off,游標位置off
  123.     send_cmd(0x01);//0000,0001 清DDRAM
  124.     send_cmd(0x02);//0000,0010 DDRAM地址歸位
  125.     send_cmd(0x80);//1000,0000 設定DDRAM 7位地址000,0000到地址計數器A
  126. }
  127. /******************* (C) COPYRIGHT 2011 奮斗STM32 *****END OF FILE****/
全部資料51hei下載地址:
12864.7z (401 KB, 下載次數: 45)
ID:291668 發表于 2023-4-25 14:55 | 只看該作者
謝謝分享!有原理圖最好了
ID:1033435 發表于 2023-4-24 15:45 | 只看該作者
有接線圖嘛
主站蜘蛛池模板: 中文字幕在线免费视频 | 久久精品一区二区国产 | 六月激情婷婷 | 在线视频一区二区 | 超碰com| 婷婷五月在线视频 | 少妇xxxx69 | 97超碰资源 | 亚洲欧美日韩一区二区三区四区 | 久久夜色精品国产欧美乱极品 | 男女啪啪网站 | 久久黄视频 | 在线免费观看av网站 | 久久久久国产一区二区三区 | 日本一区二区三区四区五区 | 久久人人爽人人爽人人片 | 亚洲午夜在线观看 | 欧美日韩91 | 欧美综合在线视频 | 日韩免费在线观看 | 夜夜草导航 | av资源在线 | 欧美日韩亚洲一区二区三区 | 色偷偷网站 | 一级做a爰片久久毛片潮喷 视频一二区 | 久操国产| 精品一区二区三区av | 黑人精品一区二区 | 成人免费福利 | 色站综合| 色婷婷国产 | 永久免费精品视频 | 国产欧美日韩在线观看 | 精品欧美一区二区三区久久久 | 韩日一级片 | 黄色免费毛片 | 日韩一区二区三区av | 国产中文字幕视频 | 久草福利资源 | 色天天综合 | 拍床戏真做h文黄肉1v1 |
