查看: 6250|回復: 4
基于51單片機直流電機轉速測速系統(PG160128液晶顯示+程序)
ID:656668 發表于 2020-3-29 11:45 | 顯示全部樓層 |閱讀模式
51單片機直流電機轉速測速系統PG160128液晶顯示+程序
可實現轉速的控制,測量,轉速的顯示
PROTEUS仿真如下:
#include <showfun.h>
#include <stdio.h>
extern char fnLCMInit(); // LCM 初始化
extern void at(unsigned char x,unsigned char y);/*設定文本x,y值*/
extern void cls();         // 清屏
extern void charout(unsigned char *str); //ASCII(8*8) 顯示函數
extern void fnSetPos(unsigned char urow, unsigned char  ucol);        // 設置當前地址
extern uchar dprintf(uchar x,uchar y,char *fmt);// ASCII(8*16) 及 漢字(16*16) 顯示函數
extern uchar fnPR12(uchar uCmd); // 寫無參數的指令
extern uchar fnPR13(uchar uData); // 寫數據
extern unsigned int Adc0832(unsigned char channel);
extern void Line( unsigned char x1, unsigned char y1, unsigned char x2, unsigned char y2, bit Mode);
extern void Pixel(unsigned char PointX,unsigned char PointY, bit Mode);
uchar dsp[10]={0,0,0,0,0,0,0,0,0,0,};
char abc[3]={0,0,0,};
uchar key=0;
uint a=100;
uchar n=5;
uchar count=1;
uint k1=0;
uchar GeyKey();
void delay(uchar i);
void control();
main()
        fnLCMInit();
        fnSetPos(0,0);
        dprintf(0,0,"直流電機加-減速及測速系統");
        dprintf(0,12,"鍵盤+:步長加速");
        dprintf(0,24,"鍵盤-:步長減速");
        dprintf(0,36,"鍵盤=:順時針轉");
        dprintf(0,48,"鍵盤on/c:逆時針轉");
     dprintf(0,72,"方向:");
           dprintf(0,84,"轉速:");
         P1_1=0;
     TMOD=0x15;
         TH1=0x3c;
         TL1=0xb0;
     TH0=0x00;
         TL0=0x00;
         ET0=1;
         ET1=1;
         TR0=1;
         TR1=1;
        {  key=GeyKey();
      switch(key)
       {   case '1': {          a=10;
                                    //sprintf(abc,"%3.2f",a/255.0);
                                        dprintf(0,96,"  5    r/min");
                                //dprintf(0,96,abc);
                                dprintf(60,96,"r/min");
                                    break;      }
               case '2': {          a=25;dprintf(0,96,"  25    r/min");    break;      }
                   case '3': {          a=40; dprintf(0,96," 40    r/min");   break;      }
                   case '4': {          a=55; dprintf(0,96," 60    r/min");   break;      }
                   case '5': {          a=70; dprintf(0,96," 80    r/min");   break;      }
                   case '6': {          a=90; dprintf(0,96,"100    r/min");   break;      }
                   case '7': {          a=110; dprintf(0,96,"120    r/min");   break;      }
                   case '8': {          a=130; dprintf(0,96,"135    r/min");   break;      }
                   case '9': {          a=150; dprintf(0,96,"150    r/min");   break;      }
               case '+': {          dprintf(0,72,"方向: 順時針");
                                    control();
        break;
           case '-': {         P1_0=0;
                                        dprintf(0,72,"方向: 逆時針");
                                         control();
                                        break;
           case '=': {P1_0=1;dprintf(0,72,"方向: 順時針");break;}
           case 'c': {P1_0=0;dprintf(0,72,"方向: 逆時針");break;}
           case '/': {dprintf(0,72,"方向: 順時針");
                                    control();}
                   default:  break;
uchar GeyKey()
        P1_4=0;
        P1_5=1;
        P1_6=1;
        P1_7=1;
        P3_0=1;
        P3_1=1;
        P3_2=1;
    P3_3=1;
        _nop_();_nop_();
        if(!P3_0)return '7';
        if(!P3_1)return '8';
        if(!P3_2)return '9';
    if(!P3_3)return '/';
        P1_4=1;
        P1_5=0;
        P1_6=1;
        P1_7=1;
        _nop_();_nop_();
        if(!P3_0)return '4';
        if(!P3_1)return '5';
        if(!P3_2)return '6';
    if(!P3_3)return '*';
        P1_4=1;
        P1_5=1;
        P1_6=0;
        P1_7=1;
        _nop_();_nop_();
        if(!P3_0)return '1';
        if(!P3_1)return '2';
        if(!P3_2)return '3';
    if(!P3_3)return '-';
        P1_4=1;
        P1_5=1;
        P1_6=1;
        P1_7=0;
        _nop_();_nop_();
        if(!P3_0)return 'c';
        if(!P3_1)return '0';
        if(!P3_2)return '=';
    if(!P3_3)return '+';
        return 0;
void delay(uchar i)
{  uchar j,k;
    for(;i>0;i--)
    for(j=15;j>0;j--)
    for(k=11;k>0;k--);
void time()interrupt 3
     TR1=0;
     count++;
     k1+=TL0;
         if(count==51)
              sprintf(dsp,"%3d",k1);
                  dprintf(0,108,dsp);
          dprintf(60,108,"r/min");
                  count=1;
          k1=0;
          TH1=0x3c;
          TL1=0xb0;
          TH0=0x00;
          TL0=0x00;
          TR1=1;
void control()
       EA=1;
           {    if(a>=150)
               a=150;
                        if(a<=10)
                            a=10;
                         P1_1=0;
                         delay(160-a);
                         P1_1=1;
                         delay(a);
                         key=GeyKey();
                         if(key=='-') a-=n;
                           if(key=='+') a+=n;
                           if(key=='=')
                           {  P1_0=1;
                         if(key=='c')
                         {  P1_0=0;
                          if(key=='*')
                          {   P1_1=0;
                              break;
                         if(key!=0)
                           break;
                 EA=0;
直流電機測速+中文液晶顯示.zip (104.74 KB, 下載次數: 125)
ID:601639 發表于 2020-9-10 10:23 | 顯示全部樓層
很好,下下來直接就能用,做的不錯。
沒有缺頭文件的可以在51hei下載:http://m.zg4o1577.cn/bbs/dpj-55046-1.html
ID:316613 發表于 2020-9-16 17:22 | 顯示全部樓層
程序不行,只有自帶的HEZ能用,
ID:1083585 發表于 2023-7-1 15:20 | 顯示全部樓層
very good謝謝大佬
ID:1111120 發表于 2024-4-15 16:57 | 顯示全部樓層
程序不行,只有自帶的HEx能用,.h文件沒有
主站蜘蛛池模板: 亚洲国产精品av | 成人国产网站 | 曰本一级片 | 精品欧美在线 | 国产美女自拍视频 | 亚洲最新视频 | 三级在线观看 | 又黄又爽网站 | 欧美成人三级 | 黄大色黄大片女爽一次 | 久久精品视频99 | 免费的黄网站 | 日本不卡一区二区 | 欧美日韩免费 | 欧美日韩国产一区二区 | 精品国产一区二区三区四区 | 亚洲视频精品 | 黄网免费看 | 成年人黄色大片 | 日韩久久av | 不卡av在线 | 91网站免费 | 91欧美大片| 超碰在线小说 | 中国免费毛片 | 在线观看免费毛片 | 国产免费一区二区三区免费视频 | 一级片日韩 | 国产一区二区视频在线 | av噜噜噜| 一级看片免费视频 | 亚洲午夜一区 | 97成人免费视频 | 亚洲在线播放 | 人人爱人人插 | 日皮视频在线观看 | 91看片在线 | 免费黄色一级视频 | 欧美精品成人 | www.国产精品.com | 中文字幕在线观看免费视频 |
