查看: 2700|回復: 1
多功能智能語音家居衣柜
ID:625887 發表于 2020-4-1 16:45 | 顯示全部樓層 |閱讀模式
之前參加ican比賽,做了一個智能語音衣柜的項目,獲得了國家二等獎,電控部分完全是一個人完成的,外型是用3D打印的,用到了飛思卡爾的plc芯片,還有openmv,還有語音模塊,視頻里人丑忽略,大家多多執教,謝謝,最后附上程序。B站有視頻:https://www.bilibili.com/video/BV1qQ4y1M739
Python源程序如下:
  1. from pid import PID
  2. from pyb import Servo
  3. import sensor, image, time,pyb
  4. from pyb import UART
  5. pan_pid = PID(p=0.075, i=0, imax=90)
  6. tilt_pid = PID(p=0.05, i=0, imax=90)
  7. s1 = Servo(1)
  8. tilt_servo=Servo(2)
  9. s3 = Servo(3)
  10. sensor.reset()
  11. led1 = pyb.LED(1)
  12. led2 = pyb.LED(2)
  13. led3 = pyb.LED(3)
  14. sensor.set_contrast(3)
  15. sensor.set_gainceiling(16)
  16. sensor.set_framesize(sensor.QVGA)
  17. sensor.set_windowing((320, 240))
  18. sensor.set_pixformat(sensor.GRAYSCALE)
  19. sensor.skip_frames(time = 2000)
  20. sensor.set_auto_gain(False, value=100)
  21. led1.on()
  22. led2.on()
  23. led3.on()
  24. def draw_keypoints(img, kpts):
  25.         if kpts:
  26.                 print(kpts)
  27.                 img.draw_keypoints(kpts)
  28.                 img = sensor.snapshot()
  29.                 time.sleep(1000)
  30. kpts1 = None
  31. K=5000
  32. clock = time.clock()
  33. i = 0
  34. while (True):
  35.         s3.angle(-60)
  36.         b = 1500 + i
  37.         s1.pulse_width(b)
  38.         i = i+40
  39.         if(i>1000):
  40.                 i = 0
  41.         clock.tick()
  42.         img = sensor.snapshot()
  43.         if (kpts1 == None):
  44.                 kpts1 = img.find_keypoints(max_keypoints=150, threshold=7, scale_factor=1.2)
  45.                 draw_keypoints(img, kpts1)
  46.         else:
  47.                 kpts2 = img.find_keypoints(max_keypoints=150, threshold=7, normalized=True)
  48.                 if (kpts2):
  49.                         img = sensor.snapshot()
  50.                         match = image.match_descriptor(kpts1, kpts2, threshold=85)
  51.                         if (match.count()>10):
  52.                          while(1):
  53.                                 kpts2 = img.find_keypoints(max_keypoints=150, threshold=7, normalized=True)
  54.                                 img = sensor.snapshot()
  55.                                 img.draw_rectangle(match.rect())
  56.                                 img.draw_cross(match.cx(), match.cy(), size=10)
  57.                                 s1.pulse_width(b)
  58.                                 time.sleep(2000)
  59.                                 s3.angle(-20)
  60.                                 time.sleep(2000)
  61.                                 s1.angle(-180)
  62.                                 time.sleep(2000)
  63.                                 s3.angle(-60)
  64.                                 time.sleep(200000)
以上資料51hei提供下載(注意資料不全  僅供參考):
比賽程序.zip (292.2 KB, 下載次數: 9)
ID:1 發表于 2020-4-1 21:36 | 顯示全部樓層
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
主站蜘蛛池模板: 久久小视频 | 国产精品日韩在线 | 日韩中文字幕在线播放 | 黄片毛片 | 成人在线视频免费 | 日韩免费成人 | 日韩免费视频 | 亚洲国产网站 | 综合色婷婷一区二区亚洲欧美国产 | h片免费看 | 依人久久 | 黄色片一级片 | 97精品国产 | 国产操操操 | 蜜桃91丨九色丨蝌蚪91桃色 | 中国黄色1级片 | 日本不卡视频 | 国产一区中文字幕 | 精品一区二区三区中文字幕 | 日韩特级毛片 | 中文字幕在线观看日本 | 亚洲激情网 | 九九在线| 欧美精品自拍 | 性大毛片视频 | 91在线小视频 | 玖玖在线播放 | 婷婷狠狠 | 青青青草视频 | 国产视频成人 | 羞羞在线 | 欧美日韩成人在线 | 在线视频成人 | 黑人黄色一级片 | 一级欧美一级日韩 | 亚洲免费大片 | 亚洲自拍网站 | 人与拘一级a毛片 | 丁香久久 | 天天看天天操 | 国产视频一区二区在线 |
