查看: 3542|回復(fù): 1
基于51單片機(jī)的等精度頻率計(jì)Proteus仿真程序設(shè)計(jì)
ID:704458 發(fā)表于 2020-4-3 14:16 | 顯示全部樓層 |閱讀模式
proteus仿真
proteus仿真
單片機(jī)源程序如下:
  1.    /*等精度plj*/
  2.    #include<at89x52.h>
  3.    #define uchar unsigned char
  4.    #define uint  unsigned int
  5.    #define ulong  unsigned  long
  6.    #define duan                P0    //段驅(qū)動(dòng)
  7.    #define wei      P2    //位掃描
  8.    #define shuju    P1    //外部取數(shù)據(jù)
  9.    sbit clear=P3^7;  //清除外部數(shù)據(jù)
  10.    sbit on=P3^6;  //閘門信號
  11.    uchar  code smgduan[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f}; //0,1,2,3,4,5,6,7,8,9字型碼
  12.    uchar  weixuan[8]={0x00,0x04,0x08,0x0c,0x10,0x14,0x18,0x1c};
  13.    int    output[8];      //待顯示的輸出BCD碼
  14.    uchar  shuju2;         //外部計(jì)數(shù)器接收緩存
  15.    ulong  jz;             //基準(zhǔn)
  16.    ulong  js;                          //計(jì)數(shù)
  17.    ulong  huancun;        //緩存
  18.    bit cs;                //允許數(shù)據(jù)更新標(biāo)志位
  19.    int i;
  20.    //短延時(shí)
  21. void delay(uchar time)
  22.    {
  23.       for(;time!=0;time--);
  24.    }
  25.    //長延時(shí)
  26. void  ldelay()
  27.    {
  28.       uint dd=1100;
  29.           while(dd--);
  30.    }
  31.    //八位掃描顯示子程序
  32. void  display(ulong p)
  33.    {
  34.                                 output[7]=smgduan[p%100000000/10000000];
  35.                                 output[6]=smgduan[p%10000000/1000000];
  36.                                 output[5]=smgduan[p%1000000/100000];
  37.                                 output[4]=smgduan[p%100000/10000];
  38.                                 output[3]=smgduan[p%10000/1000];
  39.                                 output[2]=smgduan[p%1000/100];
  40.                                 output[1]=smgduan[p%100/10];
  41.                                 output[0]=smgduan[p%10];
  42.                                 for(i=0;i<8;i++)
  43.                                 {
  44.                                    wei=0xff;
  45.                                    wei=weixuan[i];
  46.                                    duan=output[i];
  47.                                    delay(100);
  48.                                    wei=0xff;
  49.                                 }
  50.    }
  51. void  main()
  52.    {
  53.        on=0;                 //閘門關(guān)閉
  54.            clear=1;                 //計(jì)數(shù)器清零
  55.            clear=0;                 //清零關(guān)閉
  56.            TMOD=0x55;
  57.
  58.            EA=1;
  59.            EX1=1;
  60.            IT1=1;
  61.            ET0=1;
  62.            ET1=1;
  63.
  64.            TR1=1;
  65.            TR0=1;
  66.            on=1;                  //閘門開啟
  67.            while(1)
  68.                  {
  69.                         display(huancun);
  70.                         if(cs)                    //閘門關(guān)閉時(shí)處理數(shù)據(jù)
  71.                         {
  72.                             cs=0;
  73.                                 shuju2=shuju;
  74.                                 huancun=TH0;
  75.                                 huancun<<=8;
  76.                                 huancun+=TL0;
  77.                                 huancun<<=4;
  78.                                 huancun+=(shuju2&0x0f);
  79.                                 js+=huancun;
  80.                                 huancun=TH1;
  81.                                 huancun<<=8;
  82.                                 huancun+=TL1;
  83.                                 huancun<<=4;
  84.                                 huancun+=(shuju2>>4);
  85.                                 jz+=huancun;
  86.                                 huancun=(float)js/(float)jz*24000000;
  87.                 display(huancun);
  88.                                 jz=0;
  89.                                 js=0;
  90.                                 TH0=0;
  91.                                 TL0=0;
  92.                                 TH1=0;
  93.                                 TL1=0;
  94.                                 clear=1;
  95.                                 clear=0;
  96.                                 on=1;
  97.                         }
  98.                         else
  99.                         {
  100.                                ldelay();   //處理數(shù)據(jù)時(shí)間補(bǔ)償  防止閃爍
  101.                         }
  102.                   }
  103.    }
  104. //定時(shí)器0
  105. void   jsq0() interrupt 1 using  2
  106.           {
  107.              js+=0x000001;
  108.                  if(js>=0xc00000)
  109.                  {
  110.                     on=0;     //關(guān)閉閘門
  111.                  }
  112.           }
  113. //等精度計(jì)數(shù)結(jié)束,允許處理數(shù)據(jù)
  114. void   end()   interrupt 2 using 1        //外部中斷1
  115.          {
  116.             cs=1;
  117.          }
  118. //定時(shí)器1
  119. void         jsq1()  interrupt 3 using  3
  120.           {
  121.              jz+=0x000001;
  122.                  if(jz>=0xc00000)
  123.                  {
  124.                     on=0;     //關(guān)閉閘門
  125.                  }
  126.           }
頻率計(jì).zip (157.89 KB, 下載次數(shù): 50)
ID:780349 發(fā)表于 2020-6-16 00:57 | 顯示全部樓層
學(xué)習(xí)一下
主站蜘蛛池模板: 久久久久成人精品 | 我爱操| 欧美国产激情 | 天天草av | 久久999| 在线视频中文字幕 | 久久久久久精 | 日韩三级电影在线看 | 一区二区三区中文字幕 | www.一区二区三区 | 作爱视频免费观看 | 91久久综合亚洲鲁鲁五月天 | 黄色片视频免费 | 在线播放国产一区二区三区 | 九九久久精品视频 | 欧美精品一区三区 | 国产精品欧美日韩 | 日韩中文字幕一区 | 国产精品不卡视频 | 在线不卡视频 | 中文字幕在线国产 | 女人精96xxx免费网站p | 成人乱人乱一区二区三区软件 | 久久久久久99 | 狠狠婷婷综合久久久久久妖精 | 久久99精品国产 | 久久久久久国模大尺度人体 | 国产精品久久久久久久久免费相片 | 久久91精品国产一区二区 | 国产精品av久久久久久久久久 | aaa大片免费观看 | 最新一级毛片 | 国产男女精品 | 国产成视频在线观看 | 免费视频久久 | 日本成人免费观看 | 国产精品福利网站 | 特黄毛片 | 在线看av的网址 | 91在线一区 | 在线国产一区二区 |
