- #include <iom16v.h>
- #include <macros.h>
- #include "stdio.h"
- #include "delay.h"
- #define uchar unsigned char
- #define uint unsigned int
- char smg_zx[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d, 0x7d,0x07,0x7f,0x6f,0x76,0X38};//
- char smg_wx[]={0B00000001,0B00000010,0B00000100,0b00001000,0b00010000,0b00100000,0b01000000,0b10000000};
- char buff[]={1,2,3,4,5,6,7,8};
- uint cnt0=0,lc=0,dj=0,KS=11,ZJ=0;
- uchar mode=0;
- void delay_ms(unsigned int k) //8M MS級函數(shù)
- unsigned int i,j;
- for(i=0;i<k;i++)
- for(j=0;j<570;j++);
- ////多位數(shù)拆分函數(shù)///////*/
- void xs_buff()
- buff[0]=lc/10;
- buff[1]=lc%10;
- buff[2]=dj/10;
- buff[3]=dj%10;
- buff[4]=ZJ/100;
- buff[5]=ZJ/10%10;
- buff[6]=ZJ%10;
- buff[7]=KS;
- void xs_smg()
- static unsigned char posit=0;
- PORTA |= 0XFF; // turn off
- PORTA = ~ smg_wx[posit];//selecting led 7-segment
- PORTB = smg_zx[buff[posit]]; //
- delay_ms(2);
- if(posit++>=7)posit=0;
- void keyscan()
- if((PIND&0xf0)!=0xf0)
- delaynms(20);
- if((PIND&0x10)==0) //第一個按鍵
- if(dj++>=10)dj=0;
- KS=11; //L //++cnt_1; //00-FF
- if((PIND&0x20)==0) //第二個按鍵
- mode=0; //--cnt_1;//00-FF
- SEI();
- KS=10; //H
- if((PIND&0x40)==0) //第三個按鍵
- //--cnt_1;//00-FF
- CLI();
- KS=11; //L
- if((PIND&0x80)==0) //第四個按鍵
- if(mode++>=2)mode=0;//第一次按下時結(jié)束計價,第二次時清零,
- KS=11; //L //--cnt_1;//00-FF
- CLI();
- if(mode==2)
- {ZJ=0; lc=0;}
- while((PIND&0xf0)!=0xf0);
- void init_devices(void)//設(shè)備初始化函數(shù)
- PORTA = 0XFF;//內(nèi)部上拉
- DDRA = 0xFF;//輸出
- PORTB = 0XFF;//內(nèi)部上拉
- DDRB = 0xFF;//輸出
- PORTD = BIT(4)|BIT(5)|BIT(6)|BIT(7);//內(nèi)部上拉
- PORTD &= (~BIT(3));
- DDRD = ~(BIT(3)|BIT(4)|BIT(5)|BIT(6)|BIT(7));//輸入
- /****外部事件計數(shù)*******/
- MCUCR = 0x02;
- GICR = 0x80;
- SREG = 0x80;
- CLI(); //關(guān)中斷
- //SEI(); //開中斷
- void main(void)
- init_devices();//設(shè)備初始化
- delaynms(300); //延時待系統(tǒng)穩(wěn)定;
- while(1)
- keyscan();
- xs_buff();
- xs_smg();
- ZJ=lc*dj;
- #pragma interrupt_handler int1_isr:3
- void int1_isr()
- if(++cnt0>500){cnt0=0;if(lc++>=99)lc=0;}
全部資料51hei下載地址:
AVR出租車計價器.rar
(176.81 KB, 下載次數(shù): 42)
2020-4-4 17:33 上傳
點擊文件名下載附件
